No "Extra SSE Boost"?
kelliegang
- Hardware configuration: L1:Dual Core 1.6ghz, 1GB Ram
L2:
PC1&2:P2 3.2ghz, 1GB Ram, Gforce 6800 :(
PS3 - Location: Australia
I'm not getting the "Extra SSE Boost" message, someone mentioned that if this is the case one should reboot but this apparantly isn't working for my little comp
Re: No "Extra SSE Boost"?
Some cores doesn't print it (because they don't support SSE).
Please post the relevant part of the FAHLog.txt file.
kelliegang
L2:
Ah.. Thats probably the answer then... I just noted that whilst I usually get about 300 points per day per core on my desktop and laptop I've recently only been getting 100-150, thought it had something to do with the sse thing but, seeing as how it doesnt "fix" when I reboot sounds like I'm running work units that dont support it, likely something else going on with my comp then
Thanks toTOW sorry for the ignorance
If you post which project you're folding, I'll be able to tell if it can use SSE or not.
kelliegang
L2:
[09:24:37] Project: 4615 (Run 8, Clone 4, Gen 35)
[09:24:37] Assembly optimizations on if available.
[09:24:37] Entering M.D.
[09:25:49] Protein: p4615_T0_BBL-16_minout
[09:25:49] -
John_Weatherman
4615 is an Amber project and that does n't use SSE - but AMD CPUs like them, and tend to work faster then Intells on those WUs.
