"Irreducible ControlFlow detected" (fixed by reinstall)
midhart90
Post by midhart90 »
I just received three WUs, all from the same project (13428), that failed within a minute or two of launch:
project:13428 run:2629 clone:41 gen:0
project:13428 run:5913 clone:40 gen:0
project:13428 run:5284 clone:49 gen:2
Each of these WUs threw a "Irreducible ControlFlow Detected" error and were returned as FAULTY (below is an example from the first one, the other two were substantially the same apart from the WUs and timestamps).
18:53:02:WU02:FS01:0x22:Attempting to create OpenCL context:
18:53:02:WU02:FS01:0x22:  Configuring platform OpenCL
18:53:10:WU02:FS01:0x22:Failed to create OpenCL context:
18:53:10:WU02:FS01:0x22:Error compiling kernel: "C:\Users\Owner\AppData\Local\Temp\OCL9104T24.cl", line 21: warning: OpenCL
18:53:10:WU02:FS01:0x22:          extension is now part of core
18:53:10:WU02:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
18:53:10:WU02:FS01:0x22:                           ^
18:53:10:WU02:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
18:53:10:WU02:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
18:53:10:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
18:53:10:WU02:FS01:0x22:Saving result file science.log
18:53:10:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:53:11:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:53:11:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13428 run:2629 clone:41 gen:0 core:0x22 unit:0x0000000112bc7d9a000000000a450029
18:53:11:WU02:FS01:Uploading 2.76KiB to 18.188.125.154
18:53:11:WU02:FS01:Connecting to 18.188.125.154:8080
18:53:11:WU02:FS01:Upload complete
18:53:11:WU02:FS01:Server responded WORK_ACK (400)
18:53:11:WU02:FS01:Cleaning up
After the third problematic WU, I was dealt a WU from a different project and it appears to be proceeding without issue. I'm curious to find out if anyone else has experienced this issue/what may have caused it/how to fix it.
Re: Project 13428 "Irreducible ControlFlow detected"
I have not seen this error before. I'll pass it on to the team that supports OpenMM and see what they say.
_r2w_ben
Post by _r2w_ben »
What GPU and Windows version was this? Have other GPU work units run successfully?
_r2w_ben wrote:What GPU and Windows version was this? Have other GPU work units run successfully?
...And which OpenCL are you using for that GPU?
midhart90
Post by midhart90 »
Sorry it took so long to get back to you guys... I ended up uninstalling and reinstalling the F@h client and that appears to have done the trick. I'll let you know if I see this issue in the future.
Re: "Irreducible ControlFlow detected" (fixed by reinstall)
Would it be possible for you to post the first 100 lines of your log file so we can see what hardware you were trying to fold on? While it's nice that your issue has been resolved, we would still like to know a bit more in case there's an edge case or something else that we can fix :)
midhart90
Post by midhart90 »
Is this what you're looking for?
*********************** Log Started 2020-12-26T05:11:04Z ***********************
05:11:04:******************************* libFAH ********************************
05:11:04:           Date: Oct 20 2020
05:11:04:           Time: 13:36:55
05:11:04:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
05:11:04:         Branch: master
05:11:04:       Compiler: Visual C++ 2015
05:11:04:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
05:11:04:       Platform: win32 10
05:11:04:           Bits: 32
05:11:04:           Mode: Release
05:11:04:****************************** FAHClient ******************************
05:11:04:        Version: 7.6.21
05:11:04:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:11:04:      Copyright: 2020 foldingathome.org
05:11:04:       Homepage: https://foldingathome.org/
05:11:04:           Time: 13:41:04
05:11:04:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
05:11:04:           Bits: 32
05:11:04:           Args: --open-web-control
05:11:04:         Config: C:\ProgramData\FAHClient\config.xml
05:11:04:******************************** CBang ********************************
05:11:04:           Time: 11:36:18
05:11:04:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
05:11:04:           Bits: 32
05:11:04:******************************* System ********************************
05:11:04:            CPU: Intel(R) Pentium(R) CPU G840 @ 2.80GHz
05:11:04:         CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
05:11:04:           CPUs: 2
05:11:04:         Memory: 15.98GiB
05:11:04:    Free Memory: 11.90GiB
05:11:04:        Threads: WINDOWS_THREADS
05:11:04:     OS Version: 6.2
05:11:04:    Has Battery: false
05:11:04:     On Battery: false
05:11:04:     UTC Offset: -5
05:11:04:            PID: 4024
05:11:04:            CWD: C:\ProgramData\FAHClient
05:11:04:  Win32 Service: false
05:11:04:             OS: Windows 10 Home
05:11:04:        OS Arch: AMD64
05:11:04:           GPUs: 1
05:11:04:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 R575A [Radeon R7 250/HD 7700]
05:11:04:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
05:11:04:                 specified module could not be found.
05:11:04:
05:11:04:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3188.4
05:11:04:***********************************************************************
05:11:04:<config>
05:11:04:  <!-- Network -->
05:11:04:  <proxy v=':8080'/>
05:11:04:
05:11:04:  <!-- Slot Control -->
05:11:04:  <power v='full'/>
05:11:04:
05:11:04:  <!-- User Information -->
05:11:04:  <passkey v='*****'/>
05:11:04:  <user v='midhart90'/>
05:11:04:
05:11:04:  <!-- Folding Slots -->
05:11:04:  <slot id='0' type='CPU'/>
05:11:04:  <slot id='1' type='GPU'>
05:11:04:    <pci-bus v='1'/>
05:11:04:    <pci-slot v='0'/>
05:11:04:  </slot>
05:11:04:</config>
05:11:04:Trying to access database...
05:11:04:Successfully acquired database lock
05:11:04:FS00:Initialized folding slot 00: cpu:1
05:11:04:FS01:Initialized folding slot 01: gpu:1:0 R575A [Radeon R7 250/HD 7700]
05:11:04:WU02:FS01:Starting
Yep, that would do. Thanks for that :)
BTW, what AMD Driver version do you have installed and did you download it from AMD's site or use Windows Update?
midhart90
Post by midhart90 »
It's running driver version 20.11.2 and I downloaded it directly from AMD's site. It's interesting to note that before I reinstalled F@h, I tried updating the driver (it was previously running an earlier version, I forget which one) to see if that would fix the problem (it didn't).
Post by Neil-B »
... did you restart the client or reboot after the driver update?
midhart90
Post by midhart90 »
The machine saw numerous reboots (with no apparent change) between when I updated the drivers and when I reinstalled the client.
midhart90
Post by midhart90 »
It looks like the same error popped up again earlier today. The big difference is that this time, after rejecting one WU, it downloaded another one, and this second WU seems to be processing normally (~3.5% as of this writing).
Here are logs from both successful and unsuccessful starts in the hopes it may help in sniffing out the problem:
/* Begin unsuccessful start attempt */
17:11:56:WU00:FS01:0x22:*********************** Log Started 2021-01-16T17:11:56Z ***********************
17:11:56:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:11:56:WU00:FS01:0x22:       Core: Core22
17:11:56:WU00:FS01:0x22:       Type: 0x22
17:11:56:WU00:FS01:0x22:    Version: 0.0.13
17:11:56:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:11:56:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
17:11:56:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
17:11:56:WU00:FS01:0x22:       Date: Sep 19 2020
17:11:56:WU00:FS01:0x22:       Time: 02:35:58
17:11:56:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
17:11:56:WU00:FS01:0x22:     Branch: core22-0.0.13
17:11:56:WU00:FS01:0x22:   Compiler: Visual C++ 2015
17:11:56:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
17:11:56:WU00:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
17:11:56:WU00:FS01:0x22:   Platform: win32 10
17:11:56:WU00:FS01:0x22:       Bits: 64
17:11:56:WU00:FS01:0x22:       Mode: Release
17:11:56:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:11:56:WU00:FS01:0x22:             <peastman@stanford.edu>
17:11:56:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 10904 -checkpoint 15
17:11:56:WU00:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
17:11:56:WU00:FS01:0x22:             -gpu-usage 100
17:11:56:WU00:FS01:0x22:************************************ libFAH ************************************
17:11:56:WU00:FS01:0x22:       Date: Sep 7 2020
17:11:56:WU00:FS01:0x22:       Time: 19:09:56
17:11:56:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
17:11:56:WU00:FS01:0x22:     Branch: HEAD
17:11:56:WU00:FS01:0x22:************************************ CBang *************************************
17:11:56:WU00:FS01:0x22:       Time: 19:08:30
17:11:56:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
17:11:56:WU00:FS01:0x22:************************************ System ************************************
17:11:56:WU00:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G840 @ 2.80GHz
17:11:56:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
17:11:56:WU00:FS01:0x22:       CPUs: 2
17:11:56:WU00:FS01:0x22:     Memory: 15.98GiB
17:11:56:WU00:FS01:0x22:Free Memory: 11.53GiB
17:11:56:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
17:11:56:WU00:FS01:0x22: OS Version: 6.2
17:11:56:WU00:FS01:0x22:Has Battery: false
17:11:56:WU00:FS01:0x22: On Battery: false
17:11:56:WU00:FS01:0x22: UTC Offset: -5
17:11:56:WU00:FS01:0x22:        PID: 5264
17:11:56:WU00:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
17:11:56:WU00:FS01:0x22:************************************ OpenMM ************************************
17:11:56:WU00:FS01:0x22:   Revision: 189320d0
17:11:56:WU00:FS01:0x22:********************************************************************************
17:11:56:WU00:FS01:0x22:Project: 13438 (Run 12618, Clone 0, Gen 0)
17:11:56:WU00:FS01:0x22:Unit: 0x00000000000000000000000000000000
17:11:56:WU00:FS01:0x22:Reading tar file core.xml
17:11:56:WU00:FS01:0x22:Reading tar file integrator.xml.bz2
17:11:56:WU00:FS01:0x22:Reading tar file state.xml.bz2
17:11:56:WU00:FS01:0x22:Reading tar file system.xml.bz2
17:11:56:WU00:FS01:0x22:Digital signatures verified
17:11:56:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:11:56:WU00:FS01:0x22:Version 0.0.13
17:11:57:WU00:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
17:11:57:WU00:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
17:11:57:WU00:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
17:11:57:WU00:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
17:11:57:WU00:FS01:0x22:There are 3 platforms available.
17:11:57:WU00:FS01:0x22:Platform 0: Reference
17:11:57:WU00:FS01:0x22:Platform 1: CPU
17:11:57:WU00:FS01:0x22:Platform 2: OpenCL
17:11:57:WU00:FS01:0x22:  opencl-device 0 specified
17:12:11:WU00:FS01:0x22:Attempting to create OpenCL context:
17:12:11:WU00:FS01:0x22:  Configuring platform OpenCL
17:12:17:WU00:FS01:0x22:Failed to create OpenCL context:
17:12:17:WU00:FS01:0x22:Error compiling kernel: "C:\Users\Owner\AppData\Local\Temp\OCL5264T24.cl", line 21: warning: OpenCL
17:12:17:WU00:FS01:0x22:          extension is now part of core
17:12:17:WU00:FS01:0x22:  #pragma OPENCL EXTENSION cl_khr_fp64 : enable
17:12:17:WU00:FS01:0x22:                           ^
17:12:17:WU00:FS01:0x22:Error:E010:Irreducible ControlFlow Detected
17:12:17:WU00:FS01:0x22:ERROR:125: Failed to create a GPU-enabled OpenMM Context.
17:12:17:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
17:12:17:WU00:FS01:0x22:Saving result file science.log
17:12:17:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
17:12:17:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:12:17:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13438 run:12618 clone:0 gen:0 core:0x22 unit:0x00000000000000000000347e0000314a
17:12:17:WU00:FS01:Uploading 2.76KiB to 18.188.125.154
17:12:17:WU00:FS01:Connecting to 18.188.125.154:8080
17:12:17:WU00:FS01:Upload complete
17:12:18:WU00:FS01:Server responded WORK_ACK (400)
17:12:18:WU00:FS01:Cleaning up
/* End unsuccessful start attempt, begin successful start attempt */
17:12:18:WU01:FS01:Connecting to assign1.foldingathome.org:80
17:12:18:WU01:FS01:Assigned to work server 206.223.170.146
17:12:18:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 R575A [Radeon R7 250/HD 7700] from 206.223.170.146
17:12:18:WU01:FS01:Connecting to 206.223.170.146:8080
17:12:18:WU01:FS01:Downloading 13.44MiB
17:12:20:WU01:FS01:Download complete
17:12:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17424 run:0 clone:1934 gen:112 core:0x22 unit:0x0000078e000000700000441000000000
17:12:21:WU01:FS01:Starting
17:12:21:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 7304 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
17:12:21:WU01:FS01:Started FahCore on PID 10036
17:12:21:WU01:FS01:Core PID:9888
17:12:21:WU01:FS01:FahCore 0x22 started
17:12:21:WU01:FS01:0x22:*********************** Log Started 2021-01-16T17:12:21Z ***********************
17:12:21:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:12:21:WU01:FS01:0x22:       Core: Core22
17:12:21:WU01:FS01:0x22:       Type: 0x22
17:12:21:WU01:FS01:0x22:    Version: 0.0.13
17:12:21:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:12:21:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
17:12:21:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
17:12:21:WU01:FS01:0x22:       Date: Sep 19 2020
17:12:21:WU01:FS01:0x22:       Time: 02:35:58
17:12:21:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
17:12:21:WU01:FS01:0x22:     Branch: core22-0.0.13
17:12:21:WU01:FS01:0x22:   Compiler: Visual C++ 2015
17:12:21:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
17:12:21:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
17:12:21:WU01:FS01:0x22:   Platform: win32 10
17:12:21:WU01:FS01:0x22:       Bits: 64
17:12:21:WU01:FS01:0x22:       Mode: Release
17:12:21:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
17:12:21:WU01:FS01:0x22:             <peastman@stanford.edu>
17:12:21:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 10036 -checkpoint 15
17:12:21:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
17:12:21:WU01:FS01:0x22:             -gpu-usage 100
17:12:21:WU01:FS01:0x22:************************************ libFAH ************************************
17:12:21:WU01:FS01:0x22:       Date: Sep 7 2020
17:12:21:WU01:FS01:0x22:       Time: 19:09:56
17:12:21:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
17:12:21:WU01:FS01:0x22:     Branch: HEAD
17:12:21:WU01:FS01:0x22:************************************ CBang *************************************
17:12:21:WU01:FS01:0x22:       Time: 19:08:30
17:12:21:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
17:12:21:WU01:FS01:0x22:************************************ System ************************************
17:12:21:WU01:FS01:0x22:        CPU: Intel(R) Pentium(R) CPU G840 @ 2.80GHz
17:12:21:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
17:12:21:WU01:FS01:0x22:       CPUs: 2
17:12:21:WU01:FS01:0x22:     Memory: 15.98GiB
17:12:21:WU01:FS01:0x22:Free Memory: 11.54GiB
17:12:21:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
17:12:21:WU01:FS01:0x22: OS Version: 6.2
17:12:21:WU01:FS01:0x22:Has Battery: false
17:12:21:WU01:FS01:0x22: On Battery: false
17:12:21:WU01:FS01:0x22: UTC Offset: -5
17:12:21:WU01:FS01:0x22:        PID: 9888
17:12:21:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
17:12:21:WU01:FS01:0x22:************************************ OpenMM ************************************
17:12:21:WU01:FS01:0x22:   Revision: 189320d0
17:12:21:WU01:FS01:0x22:********************************************************************************
17:12:21:WU01:FS01:0x22:Project: 17424 (Run 0, Clone 1934, Gen 112)
17:12:21:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
17:12:21:WU01:FS01:0x22:Reading tar file core.xml
17:12:21:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
17:12:21:WU01:FS01:0x22:Reading tar file state.xml.bz2
17:12:21:WU01:FS01:0x22:Reading tar file system.xml.bz2
17:12:21:WU01:FS01:0x22:Digital signatures verified
17:12:21:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:12:21:WU01:FS01:0x22:Version 0.0.13
17:12:22:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
17:12:22:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
17:12:22:WU01:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
17:12:22:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
17:12:22:WU01:FS01:0x22:There are 3 platforms available.
17:12:22:WU01:FS01:0x22:Platform 0: Reference
17:12:22:WU01:FS01:0x22:Platform 1: CPU
17:12:22:WU01:FS01:0x22:Platform 2: OpenCL
17:12:22:WU01:FS01:0x22:  opencl-device 0 specified
17:12:39:WU01:FS01:0x22:Attempting to create OpenCL context:
17:12:39:WU01:FS01:0x22:  Configuring platform OpenCL
17:12:51:WU01:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
17:12:51:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
17:12:53:WU01:FS01:0x22:Checkpoint completed at step 0
17:31:11:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
17:49:28:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
17:49:31:WU01:FS01:0x22:Checkpoint completed at step 25000
18:07:49:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
Thanks for reporting the error message midhart90. I have asked so let's see what happens. Could you please provide the first 100 lines of the log file which will show your system configuration and your client setup too?
Post by muziqaz »
This GPU does not support minimum requirements for folding. (Edit), the GPU is very old, and has not been supported with latest OpenCL patches for very long time. It might have huge amounts of bugs and broken functions which give you random errors in folding.
Best solution:
If you start fahcontrol, click on Configure>Slots and click on GPU slot and then click remove and save everything.
FAH Omega tester
