Noob question
WicktheWild
Noob question
Post by WicktheWild »
I am running a i7 6700k at 4.7ghz and dual fe rtx 2070 super at 1935mhz all under a custom loop. According to hwmonitor everything is running at max and my loop temp says the same about 45c. But i am only showing 300k ppd, shouldnt this be more like 3mil ppd?
If im just a dummy you can say so i wont be offended just want to help research a bit in my free time and can afford the electric bill.
Chad
Re: Noob question
Most often when the reported PPD is low, no passkey has been entered into the client. A large portion of the points come from the Quick Return Bonus (QRB), and that requires a passkey.
WicktheWild
Re: Noob question
Yeah i never entered the passkey
kiore
Re: Noob question
Post by kiore »
WicktheWild wrote:Yeah i never entered the passkey
So request a passkey, enter and complete 10 units with at least 80% success rate and you are away. With the system you describe this should be within a day easily.
bollix47
Re: Noob question
Post by bollix47 »
In case you need more info on passkeys:
https://apps.foldingathome.org/getpasskey
Shirty
Re: Noob question
Post by Shirty »
Once the passkey is active your rig will be good for 2.6-3.2 million ppd :twisted:
WicktheWild
Re: Noob question
Dont think i will fold anymore, shortly after it bsod my pc. And it couldnt find one of my gpus. Took me an hour to get everything back to normal. After i oced my rig i ran occt for a day with zero errors. It is (was) a very stable oc. Wondering if the internal case temp got to high for the mobo. My loop has a 360 rad on intake and a 240 and 120 on the out. Loop temp settled in at 46c.
Re: Noob question
That is up to you. However, OCCT is only a general test, and we have learned from years of reports that systems can be stable under such tests but not folding stable. Running the F@h client is a stress test that will show any weakness not shown by other tests. It would probably work fine with a bit lower OC.
