*********************** Log Started 2014-11-27T20:30:49Z ***********************
20:30:49:************************* Folding@home Client *************************
20:30:49: Website: http://folding.stanford.edu/
20:30:49: Copyright: (c) 2009-2014 Stanford University
20:30:49: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:30:49: Args: --child --lifeline 2800 /etc/fahclient/config.xml --run-as
20:30:49: fahclient --pid-file=/var/run/fahclient.pid --daemon
20:30:49: Config: /etc/fahclient/config.xml
20:30:49:******************************** Build ********************************
20:30:49: Version: 7.4.4
20:30:49: Date: Mar 4 2014
20:30:49: Time: 12:02:38
20:30:49: SVN Rev: 4130
20:30:49: Branch: fah/trunk/client
20:30:49: Compiler: GNU 4.4.7
20:30:49: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
20:30:49: -fno-unsafe-math-optimizations -msse2
20:30:49: Platform: linux2 3.2.0-1-amd64
20:30:49: Bits: 64
20:30:49: Mode: Release
20:30:49:******************************* System ********************************
20:30:49: CPU: Intel(R) Xeon(R) CPU E5-2603 v2 @ 1.80GHz
20:30:49: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
20:30:49: CPUs: 8
20:30:49: Memory: 31.37GiB
20:30:49:Free Memory: 30.29GiB
20:30:49: Threads: POSIX_THREADS
20:30:49: OS Version: 3.2
20:30:49:Has Battery: false
20:30:49: On Battery: false
20:30:49: UTC Offset: -5
20:30:49: PID: 2802
20:30:49: CWD: /var/lib/fahclient
20:30:49: OS: Linux 3.2.0-52-generic x86_64
20:30:49: OS Arch: AMD64
20:30:49: GPUs: 1
20:30:49: GPU 0: ATI:5 Tahiti PRO [Radeon HD 7950]
20:30:49: CUDA: Not detected
20:30:49:***********************************************************************
20:30:49:<config>
20:30:49: <!-- Client Control -->
20:30:49: <fold-anon v='true'/>
20:30:49:
20:30:49: <!-- Folding Slot Configuration -->
20:30:49: <gpu v='false'/>
20:30:49:
20:30:49: <!-- Network -->
20:30:49: <proxy v=':8080'/>
20:30:49:
20:30:49: <!-- User Information -->
20:30:49: <passkey v='********************************'/>
20:30:49: <user v='Nolan_Robidoux'/>
20:30:49:
20:30:49: <!-- Folding Slots -->
20:30:49: <slot id='0' type='CPU'/>
20:30:49: <slot id='1' type='GPU'>
20:30:49: <opencl-index v='0'/>
20:30:49: </slot>
20:30:49:</config>
20:30:49:Switching to user fahclient
20:30:49:Trying to access database...
20:30:49:Successfully acquired database lock
20:30:49:Enabled folding slot 00: READY cpu:6
20:30:49:Enabled folding slot 01: READY gpu:0:Tahiti PRO [Radeon HD 7950]
20:30:49:WU02:FS01:Starting
20:30:49:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 2802 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:30:49:WU02:FS01:Started FahCore on PID 2811
20:30:49:WU02:FS01:Core PID:2815
20:30:49:WU02:FS01:FahCore 0x17 started
20:30:49:WU01:FS00:Starting
20:30:49:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 704 -lifeline 2802 -checkpoint 15 -np 6
20:30:49:WU01:FS00:Started FahCore on PID 2818
20:30:49:WU01:FS00:Core PID:2822
20:30:49:WU01:FS00:FahCore 0xa4 started
20:30:50:WU02:FS01:0x17:*********************** Log Started 2014-11-27T20:30:49Z ***********************
20:30:50:WU02:FS01:0x17:Project: 13000 (Run 784, Clone 0, Gen 101)
20:30:50:WU02:FS01:0x17:Unit: 0x000000b2538b3db7531078e36a7032f9
20:30:50:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:30:50:WU02:FS01:0x17:Machine: 1
20:30:50:WU02:FS01:0x17:Digital signatures verified
20:30:50:WU01:FS00:0xa4:
20:30:50:WU01:FS00:0xa4:*------------------------------*
20:30:50:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
20:30:50:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
20:30:50:WU01:FS00:0xa4:Preparing to commence simulation
20:30:50:WU01:FS00:0xa4:- Looking at optimizations...
20:30:50:WU01:FS00:0xa4:- Files status OK
20:30:50:WU01:FS00:0xa4:- Expanded 932292 -> 1546812 (decompressed 165.9 percent)
20:30:50:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=932292 data_size=1546812, decompressed_data_size=1546812 diff=0
20:30:50:WU01:FS00:0xa4:- Digital signature verified
20:30:50:WU01:FS00:0xa4:Project: 9013 (Run 689, Clone 1, Gen 73)
20:30:50:WU01:FS00:0xa4:Assembly optimizations on if available.
20:30:50:WU01:FS00:0xa4:Entering M.D.
20:30:56:WU01:FS00:0xa4:Using Gromacs checkpoints
20:30:56:WU01:FS00:0xa4:Resuming from checkpoint
20:30:56:WU01:FS00:0xa4:Verified 01/wudata_01.log
20:30:56:WU01:FS00:0xa4:Verified 01/wudata_01.trr
20:30:56:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
20:30:56:WU01:FS00:0xa4:Verified 01/wudata_01.edr
20:30:56:WU01:FS00:0xa4:Completed 33675 out of 250000 steps (13%)
20:31:59:WU01:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
20:34:04:WU01:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
20:34:10:WU02:FS01:0x17:Completed 0 out of 5000000 steps (0%)
20:38:00:WU01:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
20:42:06:WU01:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
20:46:11:WU01:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
My system is now:
- OS: Xubuntu 12.04
- Storage:
- Marvell RAID 0 (4x Muskin 120GB Chronos SSDs)
- WD Blue 250GB 5400 rpm SATA II (swap/scratch)
- CPU: 2 x Xeon E5-2603v2
- RAM: 8 x G. Skill DDR3-1066 4GB
- Motherboard: ASUS Z9PE WS
- PSU: 2 x Lepa G1200W
- Driver: Catalyst 14.9
- GFX: HSI 7950 IceQ Boost
Problems: Low PPD. I have a Kill-A-Watt (well two... one per PSU, but only have one active now). I reads 118W on idle. It reads 139W on medium.
aticonfig --odgc
I've used these mining, same OS no problem. Furmark and other GPU benchmarks on Linux... no problem. What can I do?
On my laptop I have an AMD A10 APU and a R290X. CPU does fine. R290X does fine. Integrated GPU... 8850 I think... same thing as my 7950.
