Certificate Problem
schoolfield
Certificate Problem
Post by schoolfield »
schoolfield
schoolfieldatearthlinkdotnet
My User Statics page show up-to-date and correct information, but both my score certificate and WU certificate show "0." I have posted about this problem several times without resolution or even a response. I think it your server has rejected my other posts because I included my email ID.
Re: Certificate Problem
There is anti spam limits on new forum users. No email address or URLs can be posted. So your forum history only shows this one single post. Welcome!
Try this link http://fah-web.stanford.edu/awards/cert ... choolfield
Sounds like I have heard of this problem before. You might try the forum search. Something about user names with full email addresses goofing up the Certificate URL. Just modify the URL to only show your name, not the rest of the encrypted characters to hide your email addy.
rplate
Hardware configuration: Windows 10 || CPU: Intel i5-6500 3.20 GHz || GPU: AMD Radeon R9 290
Post by rplate »
Hi I am having the same problem. My username is Ryan_Plate and I see zero's on the certificates for both WU's and Score.
Here is the link for the score I see: http://fah-web2.stanford.edu/awards/cac ... .65988.jpg
compdewd
Hardware configuration: [1] Debian 8 64-bit: EVGA NVIDIA GTX 650 Ti, MSI NVIDIA GTX 460, AMD FX-8120
[2] Windows 7 64-bit: MSI NVIDIA GTX 460, AMD Phenom II X4
Post by compdewd »
rplate, try 7im's suggestion using this URL:
http://fah-web.stanford.edu/awards/cert ... Ryan_Plate
I currently see 65,000 points for you on the certificate using that URL
rplate
Post by rplate »
That worked, thanks!
TKONN42
Re: phpbb3 technical issues
Post by TKONN42 »
On this release and previous when I try for a certificate it always presents as 0 points earned.
Donor TKONN42
Team Default (includes all those WU returned without valid team number) (0)
Score 2364226 (certificate)
Donor Rank 15421 of 1674192
WU 1368 (certificate)
Date of last
work unit 2013-02-22 07:18:19
Technically, the certificates are not phpBB issues, but I'm able to get a valid certificate. I went to http://fah-web2.stanford.edu/cgi-bin/ma ... =userstats and using my handle, I did find points and did get a certificate.
Then I entered the name TKONN42, it didn't find your points. Where are you finding the scores that you're reporting?
bollix47
Post by bollix47 »
Went to: http://fah-web2.stanford.edu/cgi-bin/ma ... me=Tkonn42
Certificates for TKONN42: http://fah-web2.stanford.edu/awards/cac ... 364226.jpg
http://fah-web2.stanford.edu/awards/cac ... 2.1368.jpg
davidcoton
Post by davidcoton »
Interesting. I've noticed the "0 points" certificate for a long time, but it doesn't worry me. However, I can confirm there is a problem.
Try this:
http://fah-web2.stanford.edu/awards/cac ... 020934.jpg
If it looks right, then I have the jpg image -- I'll post it in return for instructions as to how and where!
David
bollix47
Post by bollix47 »
Strange indeed. When I go to your official stats: http://fah-web2.stanford.edu/cgi-bin/ma ... DavidCoton
I get:
http://fah-web2.stanford.edu/awards/cac ... 020934.jpg - certificate shows 19 million points
http://fah-web2.stanford.edu/awards/cac ... .19124.jpg - certificate shows 19 thousand workunits
Perhaps something like clearing your cache might help.
I did notice that your link has davidcoton and mine shows DavidCoton but it appears to be the same link otherwise.
davidcoton
Tried clearing the cache.
1) New access to certificate page still shows 0 points
2) My link above still shows zero points
3) Your link (AFAICT to the same page!) shows correctly :e?: :eo
There's a nightmare for the bughunters.
Results seem to be the same in IE.
EDIT: Just read your last line, the capitalisation may be the issue -- navigation is not case sensitive but score lookup is, perhaps? Starting with the Capitalised form in the address makes it all work.
David
bollix47
Post by bollix47 »
Can you confirm that you restarted your browser after clearing the cache? Also, did you go to the same official stats link that I used above?
davidcoton
See Edit above. It is the capitalisation that is the issue. However, my username on both F@H itself and this forum should be all lower case. The Capitalised form that produces the correct certificate is actually not correct!
David
bollix47
Post by bollix47 »
Agree that it's some kind of case issue. Hopefully this thread will help track down the problem. Thanks.
davidcoton
I've checked a bit further. EOC and Kakao both show my username Capitalised, although I have the lower case form in the v7 FAHControl configuration. I think it's likely I first registered as DavidCoton, then I changed the form (possibly on switching PCs, or on a major reinstallation of F@H). Obviously FAHControl and the web servers can cope with the change, but the points/units lookup for the certificates can't.
So, for anyone else with this problem, as a quick fix, check the exact form of your username. Maybe the lookup can be made caseless sometime.
David
