Project: 5900 (Run 11, Clone 91, Gen 8)
G-Byte
Hardware configuration: MaxCore 555(216) @1100m/1566s - M2N32-SLI Phenom 9850 @2860
MaxCore 555(216) @000m/1512s " "
Vmware/Ubantu64 x2
Folding since October 21, 2008
G-Byte: Overclocker.net, Team 37726
Post by G-Byte »
HI there. I've noticed that these new projects don't like my hardware all that much. I've had about 5-7 of them over the past 2 days or so and they all eue on me.
My specs are;
xp sp3
amd 9850
9800gt and 9800gtx+. I have the gpus slightly overclocked and when I noticed that my gtx+ had a 5900 I dropped the oc down.
m2n32-sli deluxe
[20:06:51] Folding@Home GPU Core - Beta
[20:06:51] Version 1.24 (Mon Mar 2 19:49:32 PST 2009)
[20:06:51]
[20:06:51] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[20:06:51] Build host: vspm46
[20:06:51] Board Type: Nvidia
[20:06:51] Core :
[20:06:51] Preparing to commence simulation
[20:06:51] - Looking at optimizations...
[20:06:52] - Created dyn
[20:06:52] - Files status OK
[20:06:52] - Expanded 70248 -> 360060 (decompressed 512.5 percent)
[20:06:52] Called DecompressByteArray: compressed_data_size=70248 data_size=360060, decompressed_data_size=360060 diff=0
[20:06:52] - Digital signature verified
[20:06:52]
[20:06:52] Project: 5900 (Run 11, Clone 91, Gen 8)
[20:06:52]
[20:06:52] Assembly optimizations on if available.
[20:06:52] Entering M.D.
[20:06:58] Tpr hash work/wudata_08.tpr: 145129034 2933395315 874166512 2712036341 519107873
[20:06:59] Working on Protein
[20:06:59] Client config found, loading data.
[20:06:59] Starting GUI Server
[20:08:22] Completed 1%
[20:10:20] Completed 2%
[20:12:16] Completed 3%
[21:20:00] Completed 38%
[21:21:54] Completed 39%
[21:23:59] Completed 40%
[21:25:57] Completed 41%
[21:26:36] SEH code: 3221225477
[21:26:36] Run: exception thrown during GuardedRun
[21:26:36] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[21:26:36] Going to send back what have done -- stepsTotalG=2000000
[21:26:36] Work fraction=0.4119 steps=2000000.
[21:26:40] logfile size=64036 infoLength=64036 edr=0 trr=23
[21:26:40] - Writing 64572 bytes of core data to disk...
[21:26:40] Done: 64060 -> 5157 (compressed to 8.0 percent)
[21:26:40] ... Done.
[21:26:40]
[21:26:40] Folding@home Core Shutdown: EARLY_UNIT_END
[21:26:44] CoreStatus = 72 (114)
[21:26:44] Sending work to server
[21:26:44] Project: 5900 (Run 11, Clone 91, Gen 8)
[21:26:44] - Read packet limit of 540015616... Set to 524286976.
MaxCore 55(216) @1100m/1566s - M2N32-SLI Phenom 9850 @2860
MaxCore 55(216) @999m/1512s "......................................... "
Vmware/Ubantu64 x2
ihaque
Pande Group Member
Re: Project: 5900 (Run 11, Clone 91, Gen 8)
Post by ihaque »
Hi G-Byte,
Yes, these WUs have a higher than normal EUE rate. This is known, and the points for the project take it into account.
codysluder
Post by codysluder »
ihaque wrote:Hi G-Byte,
That isn't a problem for me. The official meaning of "advmethods" is that we may be assigned projects with a higher than normal EUE rate.
Is there a point at which we should decide something is wrong with our machine rather than assuming it's just the way the project is designed?
MichaelB
Post by MichaelB »
Have folded 23 of these WU's in the last 24 hrs or so. All on XP with only the shaders OCed. No EUE's so far.
2 EVGA 9800GT's 1 EVGA 8800GT and 1 EVGA 9800GTX+. 7 to 10° cooler than other WU's.
There is only one report (from G-Byte) the stats DB ... it's too early to conclude about a bad WU or a random instability.
