Just brought a new box online
P5Q-Pro
Q9550
4 G ram
Brought up the windows Smp Client under Vista Home premium; and watched it take forever to slug through one Wu
frame times were right at 15 min. The Wu finished & uploaded ok.
I then swapped out the HDD. for one that has Fedora 8 x86_64;
Under linux, I'm running 2 SMP clients , And each one is showing 10 min frame times..
For you experts out there, is it reasonable that Linux can run 2 Clients faster than Vista can run 1?
Or did I mess up the vista install?
Just curious?
SMP Frame times Linux vs Vista
Re: SMP Frame times Linux vs Vista
The linux client was running an A2 core (which Windows cannot run). The A2 WUs run much faster than the older A1 WUs.
I would also recommend running only one SMP client at a time, as that is how the Pande group prefers it be done.
Folding@home: 24/7
- RTX 4070 Ti
- RTX 4070 Ti
^w^ing
- Hardware configuration: C2D E6400 2.13 GHz @ 3.2 GHz
Asus EN8800GTS 640 (G80) @ 660/792/1700 running the 6.23 w/ core11 v1.19
forceware 260.89
Asus P5N-E SLi
2GB 800MHz DDRII (2xCorsair TwinX 512MB)
WinXP 32 SP3 - Location: Prague
I pray for a native linux gpu2 client so I can finally run SMP with a2 core and gpu client at the same time >.< right now the linux SMP clients get all the fun stuff.
