Project: 4458 (Run 169, Clone 0, Gen 1)
silas_the_monk
Hardware configuration: 1. EEE PC (Linux)
2. HP Windows Vista
Post by silas_the_monk »
It seems to me that this run got to 94%, shut down as it was running on batteries
and got wiped. Is this correct?
[07:30:35] Folding@Home Gromacs Core
[07:30:35] Version 1.90 (March 8, 2006)
[07:30:35]
[07:30:35] Preparing to commence simulation
[07:30:35] - Looking at optimizations...
[07:30:35] - Created dyn
[07:30:35] - Files status OK
[07:30:36] - Expanded 238702 -> 1166721 (decompressed 488.7 percent)
[07:30:36] - Starting from initial work packet
[07:30:36]
[07:30:36] Project: 4458 (Run 169, Clone 0, Gen 1)
[07:30:36]
[07:30:36] Assembly optimizations on if available.
[07:30:36] Entering M.D.
[07:30:42] Protein: p4458_Seq51_Amber03
[07:30:42]
[07:30:42] Writing local files
[07:31:57] Extra SSE boost OK.
[07:31:58] Writing local files
[07:31:58] Completed 0 out of 1500000 steps (0%)
[07:56:40] Writing local files
[07:56:40] Completed 15000 out of 1500000 steps (1%)
[08:21:36] Writing local files
[08:21:36] Completed 30000 out of 1500000 steps (2%)
[08:46:46] Writing local files
[08:46:46] Completed 45000 out of 1500000 steps (3%)
[09:19:00] + Paused
[09:19:00] + Running on battery power. Pausing work until computer is plugged in.
[20:04:58] + Working ...
[20:04:58] + Off battery, restarting core.
[20:04:58] Suspending work thread...
[20:04:58] Resuming work thread...
[20:15:30] Writing local files
[20:15:30] Completed 60000 out of 1500000 steps (4%)
[20:41:09] Writing local files
[20:41:09] Completed 75000 out of 1500000 steps (5%)
[21:06:20] Writing local files
[21:06:20] Completed 90000 out of 1500000 steps (6%)
[08:30:51] Writing local files
[08:30:51] Completed 1395000 out of 1500000 steps (93%)
[08:55:31] Writing local files
[08:55:31] Completed 1410000 out of 1500000 steps (94%)
[09:12:39] + Paused
[09:12:39] + Running on battery power. Pausing work until computer is plugged in.
--- Opening Log file [January 9 21:00:01 UTC]
# Windows CPU Systray Edition #################################################
http://folding.stanford.edu
Launch directory: C:\Users\Nicholas\AppData\Roaming\Folding@home-x86
[21:00:01] - Ask before connecting: No
[21:00:01] - User name: silas_the_monk (Team 82447)
[21:00:01] - User ID: 28DEBC280E99DAA6
[21:00:01] - Machine ID: 1
[21:00:01]
[21:00:01] Loaded queue successfully.
[21:00:01] Initialization complete
[21:00:01]
[21:00:01] + Processing work unit
[21:00:01] Core required: FahCore_78.exe
[21:00:01] Core found.
[21:00:01] Working on queue slot 07 [January 9 21:00:01 UTC]
[21:00:01] + Working ...
[21:00:02]
[21:00:02] *------------------------------*
[21:00:02] Folding@Home Gromacs Core
[21:00:02] Version 1.90 (March 8, 2006)
[21:00:02]
Re: Project: 4458 (Run 169, Clone 0, Gen 1)
What happen to the computer while you where running on battery :?:
silas_the_monk
2. HP Windows Vista
toTOW wrote:What happen to the computer while you where running on battery :?:
Nothing special. IS there a way of checking centrally what happened to this WU?
No we can't.
But it will help if you post more of the FAHlog ... in your previous one, we don't see if the WU resumed fine or not ... :?
silas_the_monk
2. HP Windows Vista
This is the relevant portion. Actually I remember now that I when I plugged the computer back in the Folding at home did not start automatically.
So I started it. That is the gap between 09:12:39 and 21:00:01.
[09:12:39] + Paused
Looking again I found this:
[21:00:02]
[21:00:02] Preparing to commence simulation
[21:00:02] - Ensuring status. Please wait.
[21:00:19] - Looking at optimizations...
[21:00:19] - Working with standard loops on this execution.
[21:00:19] - Previous termination of core was improper.
[21:00:19] - Files status OK
[21:00:19] - Expanded 238702 -> 1166721 (decompressed 488.7 percent)
[21:00:19] - Checksums don't match (work/wudata_07.xtc)
[21:00:19] - Starting from initial work packet
[21:00:19]
[21:00:19] Project: 4458 (Run 169, Clone 0, Gen 1)
[21:00:19]
[21:00:19] Entering M.D.
[21:00:26] Protein: p4458_Seq51_Amber03
[21:00:26]
[21:00:26] Writing local files
[21:01:42] Writing local files
[21:01:42] Completed 0 out of 1500000 steps  (0%)
[21:57:38] Writing local files
[21:57:38] Completed 15000 out of 1500000 steps  (1%)
[22:53:44] Writing local files
[22:53:44] Completed 30000 out of 1500000 steps  (2%)
[23:45:56] + Paused
[23:45:56] + Running on battery power. Pausing work until computer is plugged in.
[23:46:56] + Working ...
[23:46:56] + Off battery, restarting core.
[23:46:56] Suspending work thread...
[23:46:56] Resuming work thread...
[23:50:38] Writing local files
[23:50:38] Completed 45000 out of 1500000 steps  (3%)
[00:49:11] Writing local files
[00:49:12] Completed 60000 out of 1500000 steps  (4%)
[01:13:55] Opening C:\Users\Nicholas\AppData\Roaming\Folding@home-x86\MyFolding.html...
The client didn't close in a nice way :
Do you know why ?
In the process, the checkpoint file has been corrupted :
silas_the_monk
2. HP Windows Vista
Hmm. The machine did hang once recently, maybe then. In fact I can see that now it is working on the same WU and at 27%. :cry:
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Is this similar to the issue of pausing the client and then shutting down the computer w/o stopping the client? Iirc, that's known to trash the unit (at least it worked that way for me, when my son did that. ;-) ).
