how can I maximize get the most out of my pc
pghguins
Hardware configuration: AGEIA PhysX 100 Series PCI Card(probally not being used in folding)
Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
3GB System Ram
NVIDIA GeForce 8800 Ultra
Post by pghguins »
Hey so i've been using F@H since I heard about it a few months ago and because I have decent hardware. Also when I got my PS3 I have it fold when I'm not watching movies/gaming. Just wanted to know how I can get the most out of my PC. I am currently running the GPU2 nvida. Heres some of what I know about my hardware.
3GB System Ram
I've tried running the cpu systray and gpu2 at the same time but the cpu one never seemed to get anything done... Any suggestions on what I should be runnning?
Thanks
Re: how can I maximize get the most out of my pc
Welcome to the folding forum, pghguins
Find the copy of FAHlog.txt that's in the directory where you installed the cpu client and post it here. We can help with that.
You started with the GPU client which is much faster than the CPU client, so getting the CPU client running will be a small change, but even small contributions are good for the project.
The PhysX processor does not provide enough accuracy to be useful for FAH. viewtopic.php?f=42&t=3605&p=34587#p34602
pghguins
3GB System Ram
Post by pghguins »
Hi, after I posted that I tried again by downloading the x86 cpu client again and it seems to be working only much slower than the gpu one. Here is the fahlog.txt with the section where it downloaded removed for better readability. If someone could tell me if this looks all normal or not I'm not sure really. Seems alittle slow.
Launch directory: C:\Users\Jimmy\Desktop\Folding@home-Win32-x86-623
Executable: C:\Users\Jimmy\Desktop\Folding@home-Win32-x86-623\Folding@home-Win32-x86.exe
[20:32:04] Configuring Folding@Home...
[20:33:27] - Ask before connecting: No
[20:33:27] - User name: pghguins (Team 60339)
[20:33:27] - User ID: 3AC5E4510123E578
[20:33:27] - Machine ID: 1
[20:33:27]
[20:33:27] Work directory not found. Creating...
[20:33:27] Could not open work queue, generating new queue...
[20:33:27] - Preparing to get new work unit...
[20:33:27] + Attempting to get work packet
[20:33:27] - Connecting to assignment server
[20:33:28] - Successful: assigned to (171.67.108.13).
[20:33:28] + News From Folding@Home: Welcome to Folding@Home
[20:33:28] Loaded queue successfully.
[20:33:30] + Closed connections
[20:33:30]
[20:33:30] + Processing work unit
[20:33:30] Core required: FahCore_78.exe
[20:33:30] Core not found.
[20:33:30] - Core is not present or corrupted.
[20:33:30] - Attempting to download new core...
[20:33:30] + Downloading new core: FahCore_78.exe
//It downloaded here
[20:33:32] + 825633 bytes downloaded
[20:33:32] Verifying core Core_78.fah...
[20:33:32] Signature is VALID
[20:33:32]
[20:33:32] Trying to unzip core FahCore_78.exe
[20:33:32] Decompressed FahCore_78.exe (2338816 bytes) successfully
[20:33:37] + Core successfully engaged
[20:33:42]
[20:33:42] + Processing work unit
[20:33:42] Core required: FahCore_78.exe
[20:33:42] Core found.
[20:33:42] Working on queue slot 01 [December 20 20:33:42 UTC]
[20:33:42] + Working ...
[20:33:42]
[20:33:42] *------------------------------*
[20:33:42] Folding@Home Gromacs Core
[20:33:42] Version 1.90 (March 8, 2006)
[20:33:42]
[20:33:42] Preparing to commence simulation
[20:33:42] - Looking at optimizations...
[20:33:42] - Created dyn
[20:33:42] - Files status OK
[20:33:42] - Expanded 238647 -> 1168241 (decompressed 489.5 percent)
[20:33:42] - Starting from initial work packet
[20:33:42]
[20:33:42] Project: 4439 (Run 121, Clone 1, Gen 3)
[20:33:42]
[20:33:43] Assembly optimizations on if available.
[20:33:43] Entering M.D.
[20:33:48] Protein: p4439_Seq41_Amber03
[20:33:48]
[20:33:48] Writing local files
[20:35:11] Extra SSE boost OK.
[20:35:11] Writing local files
[20:35:11] Completed 0 out of 1500000 steps (0%)
[20:49:18] Writing local files
[20:49:18] Completed 15000 out of 1500000 steps (1%)
[21:03:16] Writing local files
[21:03:16] Completed 30000 out of 1500000 steps (2%)
[21:17:30] Writing local files
[21:17:30] Completed 45000 out of 1500000 steps (3%)
John_Weatherman
Post by John_Weatherman »
Seems ok to me ... keep on foldin' ! :)
pghguins wrote:Seems alittle slow.
Is that an E6700 or a Q6700?
If you read my earlier post, I said it will seem slow by comparison. The classic client uses only one of the cores in your 6700 Core2 chip. The nominal speed for that client is 110 points per day on a 2.8 GHz P4. Any one of your cores is faster than the benchmark machine, so you'll earn points faster than that, but it's still small compared to the GPU.
Project 4439 is worth 225 points. Three frames in 42m19s means 100 frames in 23.509 hours or 1.02 WUs per day so 1.02*225=229.7 PPD. Not bad, compared to the 110 PPD on a somewhat slower machine.
spazzychalk
Post by spazzychalk »
one thing i always tell people to do is go start/run/msconfig and go to startup and uncheck everything you dont NEED running automatically. some stuff you dont use, and some stuff you use but can get it through the start menu you dont need it running. all that crap in the system tray can cause thrashing too even at idle. dont forget to copy a shortcut to folding and paste it into your startup folder.
