Project 3798
Mactin
Project 3798
Post by Mactin »
Two of my (off-site) clients just returned a p3798, how many points ? (I guess 5), which core ?
It does not show up on the project summary page.
Since I understand that these WUs are served from the "new" v5 software, I would like to report a bug.
These p3798 projects cause the Active Processors stats indicator to be incremented falsely by one.
There is only 1 client with client Fred_PC (team Mactin), since it completed four p3798, stats now report 2.
Same with Client PQ_2008 (team Mactin), the are 4 clients, since the p3798, stats report 5.
Thank you
metal03326
Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz)
Re: Project 3798
Post by metal03326 »
Yes, p3798 gives 5 points. It's for the FahCore_78. I don't know if the project caused active processors counter to increase, but mine is sky high too. I have only 4 clients running (3 on one PC and 1 on another) and my stats shows 6 for the last 7 days and 14 for the last 50 days. I'm using Extreme OC to check my stats, so I haven't noticed when the counter got confused.
VijayPande
Pande Group Member
Re: Project 3798
Post by VijayPande »
Thanks. We'll look into the increase in the CPU count issue.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
Re: Project 3798
Mactin wrote:There is only 1 client with client Fred_PC (team Mactin), since it completed four p3798, stats now report 2.
Thank you
Those two clients have UserIDs of 29A7F05AE3XXXXXXXX (last WU was 2008-11-29 12:22:03 Proj=3798) and 12AC33E35AXXXXXXXX (last WU was 2008-11-25 18:11:26 Proj=4611). Which one is right, or is it possible that they are both right?
Mactin
Re: Project 3798
Post by Mactin »
Fred_PC is my niece's PC. It's a P4 (no HT) running at 2.8GHz, I installed on it a single v5.04 client running as a service.
From the records I have (september) her UserID is 12AC33E35AF0A728.
She is not at home now, so I cant get her present log file. But, there is no way she is running two clients, she would not know how to
I keep a record of projets and aproximate times as they are completed.
I noticed that the Active Processor count incremented to 2 has she completed four p3798 in a row yesterday (29-nov) around 20h00U, 5 points each.
Previously : p4611, 26-nov 2h00U, 47 points
p4611, 24-nov 0h00U, 0 points
p4618, 24-nov 0h00U, 84 points
p4605, 20-nov 2h00U, 47 points
p4625, 18-nov 2h00U, 47 points
p4615, 16-nov 20h00U, 119 points
As for PQ_2008, I have not recorded the UserIDs for the 4 clients.
We are having elections here in Québec (8-dec) and I am the volunteer responsible for the computers in our local precinct offices. I installed it on 4 CPUs (two Celerons, two P4s), I would be greatly surprised if someone had installed it elsewhere with the same User name an Team. Everything was running smoothly then a 3798 and as a bonus a 5th Active Processor in the stats !
Is it a coincidence that in both cases where I processed a p3798, I have an extra Active Processor ? This should be easy to replicate in the lab.
Amaruk
Project 3798 (Various)
Post by Amaruk »
Project 3798
This project is just to test some new FAH code.
Just ran 3 of these.
No issues on my end, just wanted to post the client output in case someone is interested.
[01:52:40] Folding@home Core Shutdown: FINISHED_UNIT
[01:52:43] CoreStatus = 64 (100)
[01:52:43] Unit 9 finished with 99 percent of time to deadline remaining.
[01:52:43] Updated performance fraction: 0.981855
[01:52:43] Sending work to server
[01:52:43] Project: 4598 (Run 45, Clone 12, Gen 39)
[01:52:43] + Attempting to send results [December 3 01:52:43 UTC]
[01:52:43] - Reading file work/wuresults_09.dat from core
[01:52:43]   (Read 278284 bytes from disk)
[01:52:43] Connecting to http://169.230.26.30:8080/
[01:52:44] Posted data.
[01:52:44] Initial: 0000; - Uploaded at ~272 kB/s
[01:52:44] - Averaged speed for that direction ~320 kB/s
[01:52:44] + Results successfully sent
[01:52:44] Thank you for your contribution to Folding@Home.
[01:52:44] + Number of Units Completed: 108
[01:52:48] Trying to send all finished work units
[01:52:48] + No unsent completed units remaining.
[01:52:48] - Preparing to get new work unit...
[01:52:48] + Attempting to get work packet
[01:52:48] - Will indicate memory of 1023 MB
[01:52:48] - Connecting to assignment server
[01:52:48] Connecting to http://assign.stanford.edu:8080/
[01:52:48] - Autosending finished units... [December 3 01:52:48 UTC]
[01:52:48] - Autosend completed
[01:52:48] Posted data.
[01:52:48] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[01:52:48] + News From Folding@Home: Welcome to Folding@Home
[01:52:48] Loaded queue successfully.
[01:52:48] Connecting to http://171.64.122.139:8080/
[01:52:50] Posted data.
[01:52:50] Initial: 0000; - Receiving payload (expected size: 238447)
[01:52:50] Conversation time very short, giving reduced weight in bandwidth avg
[01:52:50] - Downloaded at ~465 kB/s
[01:52:50] - Averaged speed for that direction ~218 kB/s
[01:52:50] + Received work.
[01:52:50] Trying to send all finished work units
[01:52:50] + No unsent completed units remaining.
[01:52:50] + Closed connections
[01:52:50]
[01:52:50] + Processing work unit
[01:52:50] Core required: FahCore_78.exe
[01:52:50] Core found.
[01:52:50] Working on queue slot 00 [December 3 01:52:50 UTC]
[01:52:50] + Working ...
[01:52:50] - Calling '.\FahCore_78.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 2376 -version 620'
[01:52:51]
[01:52:51] *------------------------------*
[01:52:51] Folding@Home Gromacs Core
[01:52:51] Version 1.90 (March 8, 2006)
[01:52:51]
[01:52:51] Preparing to commence simulation
[01:52:51] - Looking at optimizations...
[01:52:51] - Created dyn
[01:52:51] - Files status OK
[01:52:51] - Expanded 237935 -> 1167708 (decompressed 490.7 percent)
[01:52:51] - Starting from initial work packet
[01:52:51]
[01:52:51] Project: 3798 (Run 10, Clone 2, Gen 14)
[01:52:51]
[01:52:51] Assembly optimizations on if available.
[01:52:51] Entering M.D.
[01:52:57] Protein: p3798
[01:52:57]
[01:52:57] Writing local files
[01:54:16] Extra SSE boost OK.
[01:54:16] Writing local files
[01:54:16] Completed 0 out of 1500 steps  (0%)
[01:55:06] Writing local files
[01:55:06] Completed 500 out of 1500 steps  (33%)
[01:55:58] Writing local files
[01:55:58] Completed 1000 out of 1500 steps  (67%)
[01:56:47] Writing local files
[01:56:48] Completed 1500 out of 1500 steps  (100%)
[01:56:48] Writing final coordinates.
[01:56:48] Past main M.D. loop
[01:57:48]
[01:57:48] Finished Work Unit:
[01:57:48] - Reading up to 550656 from "work/wudata_00.arc": Read 550656
[01:57:48] - Reading up to 0 from "work/wudata_00.xtc": Read 0
[01:57:48] goefile size: 0
[01:57:48] Leaving Run
[01:57:51] - Writing 573212 bytes of core data to disk...
[01:57:52] Done: 572700 -> 519382 (compressed to 90.6 percent)
[01:57:52]   ... Done.
[01:57:52] - Shutting down core
[01:57:52]
[01:57:52] Folding@home Core Shutdown: FINISHED_UNIT
[01:57:55] CoreStatus = 64 (100)
[01:57:55] Unit 0 finished with 100 percent of time to deadline remaining.
[01:57:55] Updated performance fraction: 0.985131
[01:57:55] Sending work to server
[01:57:55] Project: 3798 (Run 10, Clone 2, Gen 14)
[01:57:55] + Attempting to send results [December 3 01:57:55 UTC]
[01:57:55] - Reading file work/wuresults_00.dat from core
[01:57:55]   (Read 519894 bytes from disk)
[01:57:55] Connecting to http://171.64.122.139:8080/
[01:57:56] Posted data.
[01:57:56] Initial: 0000; - Uploaded at ~508 kB/s
[01:57:56] - Averaged speed for that direction ~357 kB/s
[01:57:56] + Results successfully sent
[01:57:56] Thank you for your contribution to Folding@Home.
[01:57:56] + Number of Units Completed: 109
[01:58:01] Trying to send all finished work units
[01:58:01] + No unsent completed units remaining.
[01:58:01] - Preparing to get new work unit...
[01:58:01] + Attempting to get work packet
[01:58:01] - Will indicate memory of 1023 MB
[01:58:01] - Connecting to assignment server
[01:58:01] Connecting to http://assign.stanford.edu:8080/
[01:58:01] Posted data.
[01:58:01] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[01:58:01] + News From Folding@Home: Welcome to Folding@Home
[01:58:01] Loaded queue successfully.
[01:58:01] Connecting to http://171.64.122.139:8080/
[01:58:02] Posted data.
[01:58:02] Initial: 0000; - Receiving payload (expected size: 238855)
[01:58:03] - Downloaded at ~233 kB/s
[01:58:03] - Averaged speed for that direction ~221 kB/s
[01:58:03] + Received work.
[01:58:03] Trying to send all finished work units
[01:58:03] + No unsent completed units remaining.
[01:58:03] + Closed connections
[01:58:03]
[01:58:03] + Processing work unit
[01:58:03] Core required: FahCore_78.exe
[01:58:03] Core found.
[01:58:03] Working on queue slot 01 [December 3 01:58:03 UTC]
[01:58:03] + Working ...
[01:58:03] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 2376 -version 620'
[01:58:03]
[01:58:03] *------------------------------*
[01:58:03] Folding@Home Gromacs Core
[01:58:03] Version 1.90 (March 8, 2006)
[01:58:03]
[01:58:03] Preparing to commence simulation
[01:58:03] - Looking at optimizations...
[01:58:03] - Created dyn
[01:58:03] - Files status OK
[01:58:03] - Expanded 238343 -> 1167708 (decompressed 489.9 percent)
[01:58:03] - Starting from initial work packet
[01:58:03]
[01:58:03] Project: 3798 (Run 10, Clone 2, Gen 15)
[01:58:03]
[01:58:03] Assembly optimizations on if available.
[01:58:03] Entering M.D.
[01:58:09] Protein: p3798
[01:58:09]
[01:58:09] Writing local files
[01:59:28] Extra SSE boost OK.
[01:59:28] Writing local files
[01:59:28] Completed 0 out of 1500 steps  (0%)
[02:00:18] Writing local files
[02:00:18] Completed 500 out of 1500 steps  (33%)
[02:01:11] Writing local files
[02:01:11] Completed 1000 out of 1500 steps  (67%)
[02:02:01] Writing local files
[02:02:01] Completed 1500 out of 1500 steps  (100%)
[02:02:01] Writing final coordinates.
[02:02:01] Past main M.D. loop
[02:03:01]
[02:03:01] Finished Work Unit:
[02:03:01] - Reading up to 550656 from "work/wudata_01.arc": Read 550656
[02:03:01] - Reading up to 0 from "work/wudata_01.xtc": Read 0
[02:03:01] goefile size: 0
[02:03:01] Leaving Run
[02:03:05] - Writing 573212 bytes of core data to disk...
[02:03:05] Done: 572700 -> 519125 (compressed to 90.6 percent)
[02:03:05]   ... Done.
[02:03:05] - Shutting down core
[02:03:05]
[02:03:05] Folding@home Core Shutdown: FINISHED_UNIT
[02:03:07] CoreStatus = 64 (100)
[02:03:07] Unit 1 finished with 100 percent of time to deadline remaining.
[02:03:07] Updated performance fraction: 0.987753
[02:03:07] Sending work to server
[02:03:07] Project: 3798 (Run 10, Clone 2, Gen 15)
[02:03:07] + Attempting to send results [December 3 02:03:07 UTC]
[02:03:07] - Reading file work/wuresults_01.dat from core
[02:03:07]   (Read 519637 bytes from disk)
[02:03:07] Connecting to http://171.64.122.139:8080/
[02:03:10] Posted data.
[02:03:10] Initial: 0000; - Uploaded at ~169 kB/s
[02:03:10] - Averaged speed for that direction ~320 kB/s
[02:03:10] + Results successfully sent
[02:03:10] Thank you for your contribution to Folding@Home.
[02:03:10] + Number of Units Completed: 110
[02:03:14] Trying to send all finished work units
[02:03:14] + No unsent completed units remaining.
[02:03:14] - Preparing to get new work unit...
[02:03:14] + Attempting to get work packet
[02:03:14] - Will indicate memory of 1023 MB
[02:03:14] - Connecting to assignment server
[02:03:14] Connecting to http://assign.stanford.edu:8080/
[02:03:14] Posted data.
[02:03:14] Initial: 40AB; - Successful: assigned to (171.64.122.139).
[02:03:14] + News From Folding@Home: Welcome to Folding@Home
[02:03:14] Loaded queue successfully.
[02:03:14] Connecting to http://171.64.122.139:8080/
[02:03:16] Posted data.
[02:03:16] Initial: 0000; - Receiving payload (expected size: 238885)
[02:03:17] - Downloaded at ~233 kB/s
[02:03:17] - Averaged speed for that direction ~223 kB/s
[02:03:17] + Received work.
[02:03:17] Trying to send all finished work units
[02:03:17] + No unsent completed units remaining.
[02:03:17] + Closed connections
[02:03:17]
[02:03:17] + Processing work unit
[02:03:17] Core required: FahCore_78.exe
[02:03:17] Core found.
[02:03:17] Working on queue slot 02 [December 3 02:03:17 UTC]
[02:03:17] + Working ...
[02:03:17] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 2376 -version 620'
[02:03:18]
[02:03:18] *------------------------------*
[02:03:18] Folding@Home Gromacs Core
[02:03:18] Version 1.90 (March 8, 2006)
[02:03:18]
[02:03:18] Preparing to commence simulation
[02:03:18] - Looking at optimizations...
[02:03:18] - Created dyn
[02:03:18] - Files status OK
[02:03:18] - Expanded 238373 -> 1167708 (decompressed 489.8 percent)
[02:03:18] - Starting from initial work packet
[02:03:18]
[02:03:18] Project: 3798 (Run 26, Clone 1, Gen 13)
[02:03:18]
[02:03:18] Assembly optimizations on if available.
[02:03:18] Entering M.D.
[02:03:24] Protein: p3798
[02:03:24]
[02:03:24] Writing local files
[02:04:44] Extra SSE boost OK.
[02:04:45] Writing local files
[02:04:45] Completed 0 out of 1500 steps  (0%)
[02:05:37] Writing local files
[02:05:37] Completed 500 out of 1500 steps  (33%)
[02:06:28] Writing local files
[02:06:28] Completed 1000 out of 1500 steps  (67%)
[02:07:24] Writing local files
[02:07:24] Completed 1500 out of 1500 steps  (100%)
[02:07:24] Writing final coordinates.
[02:07:24] Past main M.D. loop
[02:08:25]
[02:08:25] Finished Work Unit:
[02:08:25] - Reading up to 550656 from "work/wudata_02.arc": Read 550656
[02:08:25] - Reading up to 0 from "work/wudata_02.xtc": Read 0
[02:08:25] goefile size: 0
[02:08:25] Leaving Run
[02:08:26] - Writing 573212 bytes of core data to disk...
[02:08:26] Done: 572700 -> 519167 (compressed to 90.6 percent)
[02:08:26]   ... Done.
[02:08:26] - Shutting down core
[02:08:26]
[02:08:26] Folding@home Core Shutdown: FINISHED_UNIT
[02:08:30] CoreStatus = 64 (100)
[02:08:30] Unit 2 finished with 100 percent of time to deadline remaining.
[02:08:30] Updated performance fraction: 0.989840
[02:08:30] Sending work to server
[02:08:30] Project: 3798 (Run 26, Clone 1, Gen 13)
[02:08:30] + Attempting to send results [December 3 02:08:30 UTC]
[02:08:30] - Reading file work/wuresults_02.dat from core
[02:08:30]   (Read 519679 bytes from disk)
[02:08:30] Connecting to http://171.64.122.139:8080/
[02:08:39] Posted data.
[02:08:39] Initial: 0000; - Uploaded at ~56 kB/s
[02:08:39] - Averaged speed for that direction ~267 kB/s
[02:08:39] + Results successfully sent
[02:08:39] Thank you for your contribution to Folding@Home.
[02:08:39] + Number of Units Completed: 111
[02:08:43] Trying to send all finished work units
[02:08:43] + No unsent completed units remaining.
[02:08:43] - Preparing to get new work unit...
[02:08:43] + Attempting to get work packet
[02:08:43] - Will indicate memory of 1023 MB
[02:08:43] - Connecting to assignment server
[02:08:43] Connecting to http://assign.stanford.edu:8080/
[02:08:44] Posted data.
[02:08:44] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[02:08:44] + News From Folding@Home: Welcome to Folding@Home
[02:08:44] Loaded queue successfully.
[02:08:44] Connecting to http://169.230.26.30:8080/
[02:08:44] Initial: 0000; - Receiving payload (expected size: 15417)
[02:08:44] Conversation time very short, giving reduced weight in bandwidth avg
[02:08:44] - Downloaded at ~30 kB/s
[02:08:44] - Averaged speed for that direction ~202 kB/s
[02:08:44] + Received work.
[02:08:44] Trying to send all finished work units
[02:08:44] + No unsent completed units remaining.
[02:08:44] + Closed connections
[02:08:44]
[02:08:44] + Processing work unit
[02:08:44] Core required: FahCore_82.exe
[02:08:44] Core found.
[02:08:44] Working on queue slot 03 [December 3 02:08:44 UTC]
[02:08:44] + Working ...
[02:08:44] - Calling '.\FahCore_82.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 2376 -version 620'
[02:08:44]
[02:08:44] *------------------------------*
[02:08:44] Folding@Home PMD Core
[02:08:44] Version 1.03 (September 7, 2005)
[02:08:44]
[02:08:44] Preparing to commence simulation
[02:08:44] - Looking at optimizations...
[02:08:44] - Created dyn
[02:08:44] - Files status OK
[02:08:44] - Expanded 14905 -> 92699 (decompressed 621.9 percent)
[02:08:44]
[02:08:44] Project: 4623 (Run 33, Clone 3, Gen 33)
[02:08:44]
[02:08:44] Assembly optimizations on if available.
[02:08:44] Entering M.D.
[02:08:51] Protein: p4623_T0_proG-12_minout
[02:08:51]
[02:08:51] Completed 0 out of 2500000 steps  (0%)
anko1
(3.2GHz) HT;Windows XP
Re: Project 3798
Post by anko1 »
I, too, can report phantom processors. That would explain how I got from 8 to 9 to 10 as two of my CPU units picked up these projects. I thought maybe someone was being generous. ;-) User ID on one is: User ID: 14991F842XXXXXXX. I'll have to wait to get access to my other machine that's processed these units and then I'll edit this post.
Edit: Other user id: User ID: 643790372XXXXXXX. However, I have one other machine w/ these units, so why don't I have 11 processes?
Edit 2: Last CPU w/ these WUs, at least for now. :-) User ID: 4F67008A4XXXXXXX
Mactin
Re: Project 3798
Post by Mactin »
I've had another this pas night. User PQ_2008 is now reporting 6 processors (two extra).
BTW, it's still not showing up in Psummary.
Snyde
Re: Project 3798
Post by Snyde »
From threads I have seen, I should not be receiving these. Just wondering why I have received 23 of them so far.
Project: 3798 (Run 11, Clone 0, Gen 48)
Project: 3798 (Run 61, Clone 4, Gen 38)
Project: 3798 (Run 76, Clone 3, Gen 42)
Project: 3798 (Run 79, Clone 0, Gen 27)
Project: 3798 (Run 73, Clone 4, Gen 25)
Project: 3798 (Run 90, Clone 0, Gen 24)
Project: 3798 (Run 97, Clone 1, Gen 20)
Project: 3798 (Run 39, Clone 1, Gen 36)
Project: 3798 (Run 36, Clone 3, Gen 34)
Project: 3798 (Run 38, Clone 3, Gen 40)
Project: 3798 (Run 33, Clone 2, Gen 37)
Project: 3798 (Run 41, Clone 3, Gen 43)
Project: 3798 (Run 40, Clone 1, Gen 34)
Project: 3798 (Run 61, Clone 4, Gen 24)
Project: 3798 (Run 7, Clone 2, Gen 46)
Project: 3798 (Run 18, Clone 1, Gen 47)
Project: 3798 (Run 48, Clone 3, Gen 22)
Project: 3798 (Run 48, Clone 3, Gen 16)
Project: 3798 (Run 18, Clone 1, Gen 33)
Project: 3798 (Run 30, Clone 0, Gen 6)
Project: 3798 (Run 22, Clone 2, Gen 46)
Project: 3798 (Run 73, Clone 3, Gen 47)
FahMon does not seem to recognize this although it is using:
Core required: FahCore_78.exe.
Another as I type this, almost done already: Project: 3798 (Run 3, Clone 0, Gen 49)
I only have one machine receiving these so far, but I am experiencing the extra processor being added as others have reported.
Regards-
jb
anandhanju
Re: Project 3798
Post by anandhanju »
This project has been opened up to regular clients to generate enough data for their tests. The issue with the the phantom processor counts has been reported to PG and they are looking into it. If you notice any other weird behavior, do post here.
I noticed you posted Project: 3798 (Run 73, Clone 3, Gen 47) twice. Did you get this twice or was it just a copy-paste error?
Snyde
Re: Project 3798
Post by Snyde »
anandhanju wrote:This project has been opened up to regular clients to generate enough data for their tests. The issue with the the phantom processor counts has been reported to PG and they are looking into it. If you notice any other weird behavior, do post here.
Error on my part. :oops:
Also noticed one of my other machines has run through 10 or so of these. They get done so quickly I really need to sift through the logs to catch them.Thanks for the info though.
Still kind of odd that FahMon can't seem to fiugure them out. I guess because they get done in chunks of 33-1/3%. I seem to recall FahMon had some problems with the Dbl Gromacs I think due to them chunking out at 2% each step. But that's for another topic...
Regards-
jb
vfolder
Re: Project 3798
Post by vfolder »
I'm currently getting a string of these. Noted the following behavior: unitinfo.txt is set to 0% at beginning of unit ("Writing local files") and set directly to 100% when the unit is 67% complete ("Completed 1000 out of 1500 steps (67%)"). This probably drives FahMon bonkers.
