Project: 4596 (Run 25, Clone 150, Gen 27)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Maybe another bad WU?
[05:35:59] + Closed connections
[05:35:59]
[05:35:59] + Processing work unit
[05:35:59] Core required: FahCore_82.exe
[05:35:59] Core found.
[05:35:59] Working on Unit 08 [August 26 05:35:59]
[05:35:59] + Working ...
[05:35:59] - Calling 'FahCore_82.exe -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 3368 -version 503'
[05:35:59]
[05:35:59] *------------------------------*
[05:35:59] Folding@Home PMD Core
[05:35:59] Version 1.03 (September 7, 2005)
[05:35:59]
[05:35:59] Preparing to commence simulation
[05:35:59] - Looking at optimizations...
[05:35:59] - Created dyn
[05:35:59] - Files status OK
[05:35:59] - Expanded 15746 -> 107612 (decompressed 683.4 percent)
[05:35:59]
[05:35:59] Project: 4596 (Run 25, Clone 150, Gen 27)
[05:35:59]
[05:35:59] Assembly optimizations on if available.
[05:35:59] Entering M.D.
[05:36:04] + New frame time estimate; Working...
[05:36:06] Going to send back what have done.
[05:36:06] logfile size: 5649
[05:36:06] - Writing 6169 bytes of core data to disk...
[05:36:06]   ... Done.
[05:36:06]
[05:36:06] Folding@home Core Shutdown: EARLY_UNIT_END
[05:36:09] + New frame time estimate; Working...
[05:36:10] CoreStatus = 72 (114)
[05:36:10] Sending work to server
[05:36:10] + Attempting to send results
[05:36:10] - Reading file work/wuresults_08.dat from core
[05:36:10]   (Read 6169 bytes from disk)
[05:36:10] Connecting to http://169.230.26.30:8080/
[05:36:10] Posted data.
[05:36:10] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[05:36:10] - Uploaded at ~14 kB/s
[05:36:10] - Averaged speed for that direction ~44 kB/s
[05:36:10] + Results successfully sent
[05:36:10] Thank you for your contribution to Folding@Home.
Re: Project: 4596 (Run 25, Clone 150, Gen 27)
Yes :( (6 other similar reports)
anko1
Post by anko1 »
Thanks, toTOW, for your responses. I'm reporting these under the assumption that it's helpful to the project. If not, let me know and I'll stop bothering everyone. ;-)
Edit - PS - I'm hoping the the other reports were found with your special mod tool. I tried searching for these units in this forum using the project as copied from the logs.
Yes of course I was using my (magic ?) tool ;)
Your reports are useful : as soon as Vince will see them, he'll manually remove the WU and see what's going wrong with it :)
anko1
Post by anko1 »
Thanks, toTow. I meant "mod" as in moderator tool, but magic works for me, too!
toTOW wrote:Yes of course I was using my (magic ?) tool ;)
Some WUs need to be manually removed and others are processed automatically. Getting all the servers to handle them the same way is on the list of desired enhancements. The reports are good, in either case, especially when other donors can search for them and add their comment to the same thread.
nwkelley
Pande Group Member
Post by nwkelley »
thanks guys i'll make sure vince see's this one ;)
(if by chance he hasn't already)
