8.5.5 client doesn't detect GPU
BestWeb
Post by BestWeb »
Hello everyone!
My computer runs Windows 11. Previously, I had client version 8.4.4. Everything worked fine on it.
But for some reason, I decided to update to 8.5.5.
And this version doesn't detect the GPU on my computer.
The worst part... I installed client 8.4.9, which worked before. But now the GPU isn't detected on it either.
I haven't changed the Windows version, and I haven't updated the NVIDIA drivers.
I just updated the client, and now the functionality is broken.
Could you tell me what the problem might be and how to fix it?
LOG Client
*********************** Log Started 2026-01-31T14:44:41Z ***********************
14:44:41:I1:*********************** Folding@home Client ***********************
14:44:41:I1:    Version: 8.5.5
14:44:41:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:44:41:I1:        Org: foldingathome.org
14:44:41:I1:  Copyright: 2023-2025, foldingathome.org
14:44:41:I1:   Homepage: https://foldingathome.org/
14:44:41:I1:    License: GPL-3.0-or-later
14:44:41:I1:        URL: https://v8-5.foldingathome.org/
14:44:41:I1:       Date: Dec 1 2025
14:44:41:I1:       Time: 13:40:46
14:44:41:I1:   Revision: 2c6fbaa45e4ee4854195a9f0d4b86300975b6543
14:44:41:I1:     Branch: master
14:44:41:I1:   Compiler: Visual C++
14:44:41:I1:    Options: $( /TP $) /std:c++17 /nologo /EHa /wd4297 /wd4103 /O2
14:44:41:I1:             /Zc:throwingNew /MT
14:44:41:I1:   Platform: win32 10
14:44:41:I1:       Bits: 64
14:44:41:I1:       Mode: Release
14:44:41:I1:       Args: --open-web-control
14:44:41:I1:****************************** CBang ******************************
14:44:41:I1:    Version: 1.7.2
14:44:41:I1:        Org: Cauldron Development
14:44:41:I1:  Copyright: Cauldron Development, 2003-2025
14:44:41:I1:   Homepage: https://cauldrondevelopment.com/
14:44:41:I1:    License: LGPL-2.1-or-later
14:44:41:I1:       Date: Dec 3 2025
14:44:41:I1:       Time: 11:44:07
14:44:41:I1:   Revision: 83a4be55c1b21d5383650f51a7887fd9c25b836c
14:44:41:I1:***************************** System ******************************
14:44:41:I1:        CPU: Intel(R) Core(TM) i5-14600K
14:44:41:I1:     CPU ID: GenuineIntel Family 6 Model 183 Stepping 1
14:44:41:I1:       CPUs: 20
14:44:41:I1:     Memory: 63.78GiB
14:44:41:I1:Free Memory: 58.07GiB
14:44:41:I1: OS Version: 6.2
14:44:41:I1:Has Battery: false
14:44:41:I1: On Battery: false
14:44:41:I1:   Hostname: gamepc
14:44:41:I1: UTC Offset: 3
14:44:41:I1:        PID: 14636
14:44:41:I1:        CWD: C:\ProgramData\FAHClient
14:44:41:I1:       Exec: C:\Program Files\FAHClient\FAHClient.exe
14:44:41:I1:*******************************************************************
14:44:41:I2:<config/>
14:44:41:I1:Opening Database
14:44:41:I1:F@H ID = W_ZHumLviVCVLtr8
14:44:41:I3:Loading default resource group
14:44:41:I2:Listening for HTTP on 127.0.0.1:7396
14:44:41:I3:Loaded 0 wus.
14:44:41:I2:No previous gpus.json
14:44:41:I1:Started Windows systray control
14:44:41:I1:Default:Added new work unit: cpus:20 gpus:
14:44:41:I1:WU20:Requesting WU assignment for user BestWeb team 0
14:44:41:I2:OUT1:> GET /machine/W_ZHumLviVCVLtr8i HTTP/1.1
14:44:41:I2:OUT3:> POST /api/assign HTTP/1.1
14:44:41:I2:OUT2:> GET /gpus HTTP/1.1
14:44:42:I2:OUT3:< HTTP/1.1 200 HTTP_OK
14:44:42:I1:WU20:Received WU assignment JfnDAd0HYlXNqwmLx97GI8Dt_uIPK1BZ_tw_O82HGX4
14:44:42:I1:WU20:Downloading WU
14:44:42:I2:OUT1:< HTTP/1.1 200 HTTP_OK
14:44:42:I2:OUT4:> POST /api/assign HTTP/1.1
14:44:42:I2:OUT5:> GET /ws/client HTTP/1.1
14:44:43:I1:WU20:DOWNLOAD 100% 219B of 219B
14:44:43:I2:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
14:44:43:I1:Logging into node account
14:44:43:I2:REQ6:< GET /api/websocket HTTP/1.1
14:44:44:I1:WU20:DOWNLOAD 100% 5.79MiB of 5.79MiB
14:44:44:I2:OUT4:< HTTP/1.1 200 HTTP_OK
14:44:44:I1:WU20:Received WU P18240 R1144 C0 G918
14:44:44:I1:Loaded cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe
14:44:44:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir JfnDAd0HYlXNqwmLx97GI8Dt_uIPK1BZ_tw_O82HGX4 -suffix 01 -version 8.5.5 -lifeline 14636 -np 20
14:44:44:I3:WU20:Started FahCore on PID 17052
14:44:44:I1:WU20:*********************** Log Started 2026-01-31T14:44:44Z ***********************
14:44:44:I1:WU20:************************** Gromacs Folding@home Core ***************************
14:44:44:I1:WU20:       Core: Gromacs
14:44:44:I1:WU20:       Type: 0xa8
14:44:44:I1:WU20:    Version: 0.0.12
14:44:44:I1:WU20:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:44:44:I1:WU20:  Copyright: 2020 foldingathome.org
14:44:44:I1:WU20:   Homepage: https://foldingathome.org/
14:44:44:I1:WU20:       Date: Jan 16 2021
14:44:44:I1:WU20:       Time: 12:29:40
14:44:44:I1:WU20:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
14:44:44:I1:WU20:     Branch: master
14:44:44:I1:WU20:   Compiler: Visual C++ 2019 16.7
14:44:44:I1:WU20:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:44:44:I1:WU20:   Platform: win32 10
14:44:44:I1:WU20:       Bits: 64
14:44:44:I1:WU20:       Mode: Release
14:44:44:I1:WU20:       SIMD: avx2_256
14:44:44:I1:WU20:     OpenMP: ON
14:44:44:I1:WU20:       CUDA: OFF
14:44:44:I1:WU20:       Args: -dir JfnDAd0HYlXNqwmLx97GI8Dt_uIPK1BZ_tw_O82HGX4 -suffix 01
14:44:44:I1:WU20:             -version 8.5.5 -lifeline 14636 -np 20
14:44:44:I1:WU20:************************************ libFAH ************************************
14:44:44:I1:WU20:       Time: 11:24:13
14:44:44:I1:WU20:************************************ CBang *************************************
14:44:44:I1:WU20:       Time: 11:23:53
14:44:44:I1:WU20:************************************ System ************************************
14:44:44:I1:WU20:        CPU: Intel(R) Core(TM) i5-14600K
14:44:44:I1:WU20:     CPU ID: GenuineIntel Family 6 Model 183 Stepping 1
14:44:44:I1:WU20:       CPUs: 20
14:44:44:I1:WU20:     Memory: 63.78GiB
14:44:44:I1:WU20:Free Memory: 57.37GiB
14:44:44:I1:WU20:    Threads: WINDOWS_THREADS
14:44:44:I1:WU20: OS Version: 6.2
14:44:44:I1:WU20:Has Battery: false
14:44:44:I1:WU20: On Battery: false
14:44:44:I1:WU20: UTC Offset: 3
14:44:44:I1:WU20:        PID: 17052
14:44:44:I1:WU20:        CWD: C:\ProgramData\FAHClient\work
14:44:44:I1:WU20:********************************************************************************
14:44:44:I1:WU20:Project: 18240 (Run 1144, Clone 0, Gen 918)
14:44:44:I1:WU20:Unit: 0x00000000000000000000000000000000
14:44:44:I1:WU20:Reading tar file core.xml
14:44:44:I1:WU20:Reading tar file frame918.tpr
14:44:44:I1:WU20:Digital signatures verified
14:44:44:I1:WU20:Calling: mdrun -c frame918.gro -s frame918.tpr -x frame918.xtc -cpt 5 -nt 20 -ntmpi 1
14:44:44:I1:WU20:Steps: first=229500000 total=229750000
14:44:45:I1:WU20:Completed 1 out of 250000 steps (0%)
14:44:45:I1:Machine state fold
14:44:49:I1:Machine state fold
14:45:05:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
14:45:05:I2:OUT7:> GET /machine/W_ZHumLviVCVLtr8i HTTP/1.1
14:45:06:I2:OUT7:< HTTP/1.1 200 HTTP_OK
14:45:06:I2:OUT5:> GET /ws/client HTTP/1.1
14:45:07:I2:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
14:45:07:I1:Logging into node account
14:45:18:I1:WU20:Completed 2500 out of 250000 steps (1%)
14:45:27:I1:Account websocket closed: PROTOCOL msg=Failed to read header start
14:45:27:I2:OUT8:> GET /machine/W_ZHumLviVCVLtr8i HTTP/1.1
Re: 8.5.5 client doesn't detect GPU
Post by muziqaz »
what does system info section of web ui show you?
FAH Omega tester
DrBB1
Post by DrBB1 »
muziqaz wrote: Sat Jan 31, 2026 6:21 pm what does system info section of web ui show you?
I also recently upgraded to 8.5.5 and I am getting the same message ("Waiting for GPU detection"), but I don't even fold using a GPU (Intel). Is this the "system information" you requested from BestWeb to help troubleshoot the issue? If not, please provide specific guidance.
https://drive.google.com/file/d/1XEPE-1 ... sp=sharing
DrBB1
Post by muziqaz »
DrBB1 wrote: Sat Jan 31, 2026 9:32 pm
Your gpu is supported by the client
FAH Omega tester
DrBB1
Post by DrBB1 »
The URL I shared says "false" under "GPU: SUPPORTED," and all my other WUs have folded with 10 CPUs using Core: "0xa8," Be that as it may, folding has halted 19.7% into folding Project 19228. Here is the relevant portion of the last logfile:
18:45:29:I3:WU838:Started FahCore on PID 21704
18:45:29:I1:WU838:*********************** Log Started 2026-01-29T18:45:29Z ***********************
18:45:29:I1:WU838:************************** Gromacs Folding@home Core ***************************
18:45:29:I1:WU838:       Core: Gromacs
18:45:29:I1:WU838:       Type: 0xa8
18:45:29:I1:WU838:    Version: 0.0.12
18:45:29:I1:WU838:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:45:29:I1:WU838:  Copyright: 2020 foldingathome.org
18:45:29:I1:WU838:   Homepage: https://foldingathome.org/
18:45:29:I1:WU838:       Date: Jan 16 2021
18:45:29:I1:WU838:       Time: 12:29:40
18:45:29:I1:WU838:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
18:45:29:I1:WU838:     Branch: master
18:45:29:I1:WU838:   Compiler: Visual C++ 2019 16.7
18:45:29:I1:WU838:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:45:29:I1:WU838:   Platform: win32 10
18:45:29:I1:WU838:       Bits: 64
18:45:29:I1:WU838:       Mode: Release
18:45:29:I1:WU838:       SIMD: avx2_256
18:45:29:I1:WU838:     OpenMP: ON
18:45:29:I1:WU838:       CUDA: OFF
18:45:29:I1:WU838:       Args: -dir VNQRQSWWZ-_ZKBeYgukPwE5xX_RHXd4Mn12okQNTRd4 -suffix 01
18:45:29:I1:WU838:             -version 8.4.9 -lifeline 23600 -np 10
18:45:29:I1:WU838:************************************ libFAH ************************************
18:45:29:I1:WU838:       Time: 11:24:13
18:45:29:I1:WU838:************************************ CBang *************************************
18:45:29:I1:WU838:       Time: 11:23:53
18:45:29:I1:WU838:************************************ System ************************************
18:45:29:I1:WU838:        CPU: Intel(R) Core(TM) Ultra 5 225
18:45:29:I1:WU838:     CPU ID: GenuineIntel Family 6 Model 198 Stepping 2
18:45:29:I1:WU838:       CPUs: 10
18:45:29:I1:WU838:     Memory: 15.46GiB
18:45:29:I1:WU838:Free Memory: 6.09GiB
18:45:29:I1:WU838:    Threads: WINDOWS_THREADS
18:45:29:I1:WU838: OS Version: 6.2
18:45:29:I1:WU838:Has Battery: false
18:45:29:I1:WU838: On Battery: false
18:45:29:I1:WU838: UTC Offset: -5
18:45:29:I1:WU838:        PID: 21704
18:45:29:I1:WU838:        CWD: C:\ProgramData\FAHClient\work
18:45:29:I1:WU838:********************************************************************************
18:45:29:I1:WU838:Project: 19228 (Run 7639, Clone 10, Gen 0)
18:45:29:I1:WU838:Unit: 0x00000000000000000000000000000000
18:45:29:I1:WU838:Reading tar file core.xml
18:45:29:I1:WU838:Reading tar file md0.tpr
18:45:29:I1:WU838:Digital signatures verified
18:45:29:I1:WU838:Calling: mdrun -c md0.gro -s md0.tpr -x md0.xtc -cpt 5 -nt 10 -ntmpi 1
18:45:29:I1:WU838:Steps: first=0 total=500000
18:45:31:I1:OUT91:< HTTP/1.1 200 HTTP_OK
18:45:31:I1:WU837:Credited
18:45:37:I1:WU838:Completed 1 out of 500000 steps (0%)
18:48:29:I1:WU838:Completed 5000 out of 500000 steps (1%)
18:51:23:I1:WU838:Completed 10000 out of 500000 steps (2%)
18:54:17:I1:WU838:Completed 15000 out of 500000 steps (3%)
18:57:11:I1:WU838:Completed 20000 out of 500000 steps (4%)
19:00:07:I1:WU838:Completed 25000 out of 500000 steps (5%)
19:03:25:I1:WU838:Completed 30000 out of 500000 steps (6%)
19:06:37:I1:WU838:Completed 35000 out of 500000 steps (7%)
19:09:45:I1:WU838:Completed 40000 out of 500000 steps (8%)
19:12:51:I1:WU838:Completed 45000 out of 500000 steps (9%)
19:16:10:I1:WU838:Completed 50000 out of 500000 steps (10%)
19:19:26:I1:WU838:Completed 55000 out of 500000 steps (11%)
19:22:46:I1:WU838:Completed 60000 out of 500000 steps (12%)
19:26:08:I1:WU838:Completed 65000 out of 500000 steps (13%)
19:29:29:I1:WU838:Completed 70000 out of 500000 steps (14%)
19:32:50:I1:WU838:Completed 75000 out of 500000 steps (15%)
19:36:17:I1:WU838:Completed 80000 out of 500000 steps (16%)
19:39:32:I1:WU838:Completed 85000 out of 500000 steps (17%)
19:42:58:I1:WU838:Completed 90000 out of 500000 steps (18%)
19:46:13:I1:WU838:Completed 95000 out of 500000 steps (19%)
19:48:32:I1:WU838:WARNING:Console control signal 1 on PID 21704
19:48:32:I1:WU838:Exiting, please wait. . .
19:48:33:I1:WU838:Folding@home Core Shutdown: INTERRUPTED
19:48:33:I1:WU838:Core returned INTERRUPTED (102)
19:48:34:I1:Clean exit
I appreciate your help. Let me know if there is additional information you need. TIA.
DrBB1
Post by muziqaz »
DrBB1 wrote: Sat Jan 31, 2026 10:04 pm
Yes, I am blind. Your GPU is not supported by choice (either too slow, or does not have required hardware to work reliably with FAH).
In system settings, set the CPU slider to 6, and use process lasso to tie fahcore_a8 to your CPU P cores
FAH Omega tester
DrBB1
Post by DrBB1 »
I solved my problem by uninstalling 8.5.5 and reinstalling 8.4.9.
BestWeb, I suggest doing another uninstall/reinstall, but rebooting your computer before the reinstall. If that doesn't work, consider restoring Windows to a point before you installed 8.5.5.
DrBB1
Post by muziqaz »
DrBB1 wrote: Sat Jan 31, 2026 11:06 pm I solved my problem by uninstalling 8.5.5 and reinstalling 8.4.9.
I really don't think OS restoration is required just because FAHclient does not see your GPU. That is an overkill of epic proportions.
Also, you didn't have a problem. Your intel iGPU is disabled by us, and not by specific fahclient version
FAH Omega tester
Post by calxalot »
Make sure any unsupported iGPU is not selected in any group.
BestWeb
Post by BestWeb »
Screenshot --> https://disk.yandex.ru/i/OC1fw6NV5AhOig
BestWeb
Post by BestWeb »
I tried to remove 8.5.5. I rebooted the computer. I did unlink/link for the computer in the web interface.
I installed version 8.4.9 again, but the GPU stopped being detected in version 8.4.9 as well.
It's like a mystery... :twisted:
I don't see any point in restoring Windows. Nothing changed in the system. The drivers were not updated, and the system updates were not installed.
Now, I want to somehow make version 8.5.5 see my computer's GPU.
BestWeb
Post by BestWeb »
Maybe I see the problem, but I don't know how to fix it.
I just installed the client, version 8.4.9.
And here's the log when I first launch it...
Am I understanding correctly that "Token" in my profile in the web interface and "F@H ID" in the log are the same value?
But for me, these values ​​are different.
Is this how it should be?
I don't like the second-to-last message in the log :(
If not, how can I make them the same?
My Token (from Web Interface) ---> Y3q8oY3ryvli6y-deleted
F@H ID (from Log) ---> DVUBVFahOd6QR2e-deleted
08:59:59:I1: Version: 8.4.9
08:59:59:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:59:59:I1: Org: foldingathome.org
08:59:59:I1: Copyright: 2023-2024, foldingathome.org
08:59:59:I1: Homepage: https://foldingathome.org/
08:59:59:I1: License: GPL-3.0-or-later
08:59:59:I1: URL: https://v8-4.foldingathome.org/
08:59:59:I1: Date: Nov 20 2024
08:59:59:I1: Time: 14:47:46
08:59:59:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
08:59:59:I1: Branch: master
08:59:59:I1: Compiler: Visual C++
08:59:59:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
08:59:59:I1: /Zc:throwingNew /MT
08:59:59:I1: Platform: win32 10
08:59:59:I1: Bits: 64
08:59:59:I1: Mode: Release
08:59:59:I1: Args: --open-web-control
08:59:59:I1:****************************** CBang ******************************
08:59:59:I1: Version: 1.7.2
08:59:59:I1: Org: Cauldron Development
08:59:59:I1: Copyright: Cauldron Development, 2003-2024
08:59:59:I1: Homepage: https://cauldrondevelopment.com/
08:59:59:I1: License: LGPL-2.1-or-later
08:59:59:I1: Time: 09:04:40
08:59:59:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
08:59:59:I1:***************************** System ******************************
08:59:59:I1: CPU: Intel(R) Core(TM) i5-14600K
08:59:59:I1: CPU ID: GenuineIntel Family 6 Model 183 Stepping 1
08:59:59:I1: CPUs: 20
08:59:59:I1: Memory: 63.78GiB
08:59:59:I1:Free Memory: 58.04GiB
08:59:59:I1: OS Version: 6.2
08:59:59:I1:Has Battery: false
08:59:59:I1: On Battery: false
08:59:59:I1: Hostname: gamepc
08:59:59:I1: UTC Offset: 3
08:59:59:I1: PID: 8384
08:59:59:I1: CWD: C:\ProgramData\FAHClient
08:59:59:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
08:59:59:I1:*******************************************************************
08:59:59:I2:<config/>
08:59:59:I1:Opening Database
08:59:59:I1:Generating RSA key......................................................++++-.................................................................................++++-
08:59:59:I1:F@H ID = DVUBVFahOd6QR2e-deleted
08:59:59:I3:Loading default resource group
08:59:59:I1:Listening for HTTP on 127.0.0.1:7396
08:59:59:I3:Loaded 0 wus.
08:59:59:I1:Started Windows systray control
08:59:59:I1:OUT1:> GET https://api.foldingathome.org/gpus HTTP/1.1
09:00:02:I1:OUT3:> PUT https://api.foldingathome.org/machine/DVUBVFahOd6QR2e-deleted HTTP/1.1
09:00:03:I1:OUT3:< HTTP/1.1 200 HTTP_OK
09:00:03:I1:Account linked
09:00:03:I1:OUT4:> GET https://api.foldingathome.org/machine/DVUBVFahOd6QR2e-deleted HTTP/1.1
09:00:04:I1:OUT4:< HTTP/1.1 200 HTTP_OK
09:00:04:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
09:00:04:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
09:00:04:I1:Logging into node account
09:01:00:W :Failed to update GPUs
09:01:06:I1:OUT6:> GET https://api.foldingathome.org/gpus HTTP/1.1
Post by calxalot »
F@H ID and Account token are supposed to be different.
Post by muziqaz »
So client sees what your system presents to it. In Windows it is usually straight forward. If a GPU was detected in 8.4.9 it will be detected in 8.5.5, especially in windows. It is possible that Windows pushed their own driver version, which messed things up, or driver crashed. Try reinstalling the GPU driver, use drivers provided by nvidia
FAH Omega tester
BestWeb
Post by BestWeb »
Everything turned out to be much simpler.
We (in Russia) have government agency :evil:
It supposedly protects us from the malicious influence of the West ;)
By blocking WhatsApp, Telegram, and other services, as well as entire subnets of foreign internet providers.
I updated the client by completely uninstalling the previous version.
It turns out that the new version, after launching, additionally downloads some files/data. These are needed to detect the presence of a GPU in the system.
Here's how to do it:
1. Install the new version of the client.
2. Enable the VPN on your computer.
3. Launch the client. The client downloads the necessary files from the internet. The GPU is detected. Configure everything.
4. Shut down the client. Turn off the VPN.
5. Launch the client in normal mode (without the VPN). Everything works :)
