8.5.5 doesn't work for me, but 8.4.9 does
CapeJohn31
Post by CapeJohn31 »
I had an issue yesterday where 8.5.5 wasn't working (see "Oops. How do I get started again?")
I got going when I installed 8.4.9 and was running fine. I upgraded to 8.5.5 and it stopped. So I've got back to 8.4.9
8.5.5 works fine on my laptop, but not on my PC which has a NVIDIA graphics card.
Cheers
John
Re: 8.5.5 doesn't work for me, but 8.4.9 does
Post by calxalot »
With v8-4.foldingathome.org
make sure all unsupported GPUs are deselected. Then 8.5.5 might work.
Kate
Post by Kate »
In 8.5.5 my client is on hold telling me that it is awaiting confirmation that my unsupported GPU is supported. Back to 8.4.9 and everything is working again and the unsupported GPU is deselected.
8.5.5 lacks the checkbox for deselecting the GPU ...
so?
What the previous response is telling you is to use the v8.4 Web Control to make the setting. Some have needed to install v8.4.9, make the setting, and then reinstall v8.5.5.
Kate
Post by Kate »
Yes, well understood. Reinstalling 8.4.9 reveals for me that the GPU is switched off.
Reinstalling 8.5.5 simply ignored that and it claims to wait for approval of the GPU.
I wiped all FAH components and reinstalled anew but that did not help. Still saying the GPU is ON and awaiting approval.
Any suggestions?
