Proxy problems
darkcube
Proxy problems
Post by darkcube »
I'm trying to run F@H on my office computer but am running into many problems concerning the proxy they have. The problem is, without "IE Proxy" selected i cannot download any WU, If i manually enter my proxy information it still won't download WU. I'm currently running the 5.91 SMP on my quad core, using the IE proxy settings flag, and that is working correctly and downloading WUs fine, but the GPU2 client for my ATI doesn't allow me to choose IE proxy settings. If there is another suggestion to getting this to work please let me know. Blue Coat is the proxy software that we use.
# Windows Console GPU Edition #################################################
                       Folding@Home Client Version 6.12beta8
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\removed\Application Data\Folding@home-gpu
Arguments: -verbosity 9
[14:42:13] - Ask before connecting: No
[14:42:13] - Proxy: <removed>:8080
[14:42:13] - User name: darkcube (Team 86565)
[14:42:13] - User ID: 380D0A3E25C16157
[14:42:13] - Machine ID: 1
[14:42:13]
[14:42:13] Loaded queue successfully.
[14:42:13] Initialization complete
[14:42:13] + Benchmarking ...
[14:42:13] - Preparing to get new work unit...
[14:42:13] + Attempting to get work packet
[14:42:13] - Autosending finished units...
[14:42:13] Trying to send all finished work units
[14:42:13] + No unsent completed units remaining.
[14:42:13] - Autosend completed
[14:42:13] - Will indicate memory of 3326 MB
[14:42:13] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 6
[14:42:13] - Connecting to assignment server
[14:42:13] Connecting to http://assign-GPU.stanford.edu:8080/
[14:42:13] Posted data.
[14:42:13] Initial: 3131; + Could not authenticate Assignment Server response
[14:42:13] Connecting to http://assign-GPU.stanford.edu:80/
[14:42:14] Posted data.
[14:42:14] Initial: 3131; + Could not authenticate Assignment Server 2 response
[14:42:14] + Couldn't get work instructions.
[14:42:14] - Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[14:42:21] + Attempting to get work packet
[14:42:21] - Will indicate memory of 3326 MB
[14:42:21] - Connecting to assignment server
[14:42:21] Connecting to http://assign-GPU.stanford.edu:8080/
[14:42:22] Posted data.
[14:42:22] Initial: 3131; + Could not authenticate Assignment Server response
[14:42:22] Connecting to http://assign-GPU.stanford.edu:80/
[14:42:22] Initial: 3131; + Could not authenticate Assignment Server 2 response
[14:42:22] + Couldn't get work instructions.
[14:42:22] - Attempt #2  to get work failed, and no other work to do.
[14:42:36] + Attempting to get work packet
[14:42:36] - Will indicate memory of 3326 MB
[14:42:36] - Connecting to assignment server
[14:42:36] Connecting to http://assign-GPU.stanford.edu:8080/
[14:42:36] Posted data.
[14:42:36] Initial: 3131; + Could not authenticate Assignment Server response
[14:42:36] Connecting to http://assign-GPU.stanford.edu:80/
[14:42:37] Posted data.
[14:42:37] Initial: 3131; + Could not authenticate Assignment Server 2 response
[14:42:37] + Couldn't get work instructions.
[14:42:37] - Attempt #3  to get work failed, and no other work to do.
Re: Proxy problems
Hello darkcube, welcome to the folding forum.
The USE IE SETTINGS feature was broken when Microsoft made multiple updates to its operating sytems and browser. Because of this, the feature was discontinued in v6 clients.
For most people, using IE SETTINGS might let them download a WU, but typically prevents them from a complete upload of that WU.
The only option going forward is to sort out the problems with the proxy settings, and to not use IE SETTINGS.
As long as your IT people give you a valid proxy username and password, it should work. Also verify with IT that you can use both ports 80 and 8080.
darkcube
Re: Proxy problems
Post by darkcube »
7im,
Unfortunately the proxy settings that we have don't work either (as shown in the log i posted). I am 100% sure the proxy settings are correct and allow both 80 and 8080, they are also the same settings we need to enter into any application in order to access the internet (firefox, ie, etc...). Sadly the proxy that we use is actually maintained by our parent company, so in order to 'troubleshoot' any incorrect settings they might have would require me to go through like three different levels of IT departments, and would most likely result in them just calling F@H "unauthorized software" because they wouldn't want to fix it.
Re: Proxy problems
The proxy settings aren't working in the v6.22 SMP client either (see thread). It may be that proxy is broken in a lot of the v6 clients.
This will need to get tested and fixed ASAP. I'll contact Pande Group about it.
Xilikon
Re: Proxy problems
Post by Xilikon »
I use 6.22 beta 2 SMP client at work with a proxy without problems. However, our proxy doesn't require authentication so it's probably that part which is broken, not the actual proxy code.
uncle_fungus
Re: Proxy problems
Post by uncle_fungus »
Did the previous generation of clients work with your proxy. The client only supports simple authentication, so if you use an NTLM proxy you either need to do some reconfiguration or proxy your proxy.
Re: Proxy problems
uncle_fungus wrote:Did the previous generation of clients work with your proxy. The client only supports simple authentication, so if you use an NTLM proxy you either need to do some reconfiguration or proxy your proxy.
They were previously using the IE SETTINGS feature, so not sure if they worked on Proxy or not. They may not even know either way. Hope they do know, as it would help confirm the issue.
darkcube
Re: Proxy problems
Post by darkcube »
My proxy doesn't require a user name or password so that's probably not the problem, and no just using a proxy instead of "IE SETTINGS" never worked, it doesn't work on 5.91 either. But I did manage to solve the problem by installing squid proxy and redirecting that to my office proxy (if someone can explain why this works go ahead!).
So the good news is this is fixed, and I'm folding away!
uncle_fungus
Re: Proxy problems
Yeah, if "Use IE Settings" was used to get past an NTLM proxy, unfortunately the removal (or rather breakage by MS) of that facility will break your connectivity.
Patriot
Re: Proxy problems
Post by Patriot »
If you could detail how you set up the squid-cache proxy...I have known for some time that I needed to set up a cascading proxy at work but I was getting away with using IE settings...we still use IE6 I wish you stanford did not take that out...you just cut me off.
Now I HAVE to figure out how to get squid working before I am back up.
24kppd went down the drain with that new core and I have been desperately trying to get it back working.
I was oblivious to the expiration till an auto-update rebooted my pc for me and fah never came back up.
Please help with squid setup...I need to do it on redhat and xp.
Patriot
Re: Proxy problems
Post by Patriot »
Couldn't you add a use firefox setttings to the smp :?:
Re: Proxy problems
I don't think so, for the same reason they pulled the "Use IE connecton settings" out of the v6 clients.
