HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
homeshark
Post by homeshark »
FYI
I know this was reported in other posts as being resolved for others - however - my farm (even after redeploying the VMs as a troubleshooting step) still can't procure GPU WUs and some CPU WUs. Seeing if there is still a known issue/outage?
Output from today 8/25/2025
14:21:24:E :OUT32:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
14:21:24:I1:WU2:Retry #23 in 8 mins 32 secs
14:29:54:I1:WU1:Completed 600000 out of 5000000 steps (12%)
14:29:56:I1:WU2:Requesting WU assignment for user xxx team ###
14:29:57:I1:OUT33:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
14:29:58:I1:OUT33:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
14:29:58:E :OUT33:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
14:29:58:I1:WU2:Retry #24 in 8 mins 32 secs
14:38:30:I1:WU2:Requesting WU assignment for user xxx team ###
14:38:30:I1:OUT34:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
14:38:30:I1:OUT34:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
14:38:30:E :OUT34:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
14:38:30:I1:WU2:Retry #25 in 8 mins 32 secs
14:41:17:I1:WU1:Completed 650000 out of 5000000 steps (13%)
14:47:02:I1:WU2:Requesting WU assignment for user xxx team ###
14:47:03:I1:OUT35:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
14:47:03:I1:OUT35:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
14:47:03:E :OUT35:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
14:47:03:I1:WU2:Retry #26 in 8 mins 32 secs
14:52:41:I1:WU1:Completed 700000 out of 5000000 steps (14%)
14:55:35:I1:WU2:Requesting WU assignment for user xxx team ###
14:55:35:I1:OUT36:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
14:55:36:I1:OUT36:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
14:55:36:E :OUT36:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
14:55:36:I1:WU2:Retry #27 in 8 mins 32 secs
15:04:03:I1:WU1:Completed 750000 out of 5000000 steps (15%)
15:04:04:I1:WU1:Checkpoint completed at step 750000
15:04:08:I1:WU2:Requesting WU assignment for user xxx team ###
15:04:08:I1:OUT37:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
15:04:09:I1:OUT37:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
15:04:09:E :OUT37:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
15:04:09:I1:WU2:Retry #28 in 8 mins 32 secs
Re: HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
Post by muziqaz »
There might not be enough CPU work for 4 threads.
All of your GPUs seem to be folding, except 00002, which might not have it enabled in your settings.
FAH Omega tester
belloq
Post by belloq »
My CPU folders are all sitting idle right now also. Yes, they are 4 CPU each. I will try adjusting to see if they can get something.
EDIT: No difference in selecting 6 or 8 CPUs. Same errors.
19:04:08:I1:Machine state pause
19:04:17:I1:Machine state fold
19:04:17:I1:Default:Added new work unit: cpus:6 gpus:
19:04:17:I1:WU2318:Requesting WU assignment for user belloq team 259998
19:04:17:I1:OUT543:> POST https://assign3.foldingathome.org/api/assign HTTP/1.1
19:04:17:I1:OUT543:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:04:17:E :OUT543:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:04:17:I1:WU2318:Retry #1 in 2 secs
19:04:19:I1:WU2318:Requesting WU assignment for user belloq team 259998
19:04:19:I1:OUT544:> POST https://assign4.foldingathome.org/api/assign HTTP/1.1
19:04:20:I1:OUT544:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:04:20:E :OUT544:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:04:20:I1:WU2318:Retry #2 in 4 secs
19:04:24:I1:WU2318:Requesting WU assignment for user belloq team 259998
19:04:24:I1:OUT545:> POST https://assign5.foldingathome.org/api/assign HTTP/1.1
19:04:24:I1:OUT545:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:04:24:E :OUT545:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:04:24:I1:WU2318:Retry #3 in 8 secs
19:04:31:I1:Machine state pause
19:04:37:I1:Machine state fold
19:04:37:I1:Default:Added new work unit: cpus:8 gpus:
19:04:37:I1:WU2319:Requesting WU assignment for user belloq team 259998
19:04:37:I1:OUT546:> POST https://assign6.foldingathome.org/api/assign HTTP/1.1
19:04:37:I1:OUT546:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:04:37:E :OUT546:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:04:37:I1:WU2319:Retry #1 in 2 secs
19:04:39:I1:WU2319:Requesting WU assignment for user belloq team 259998
19:04:39:I1:OUT547:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
19:04:39:I1:OUT547:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:04:39:E :OUT547:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
19:04:39:I1:WU2319:Retry #2 in 4 secs
19:04:43:I1:WU2319:Requesting WU assignment for user belloq team 259998
19:04:44:I1:OUT548:> POST https://assign2.foldingathome.org/api/assign HTTP/1.1
19:04:44:I1:OUT548:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
19:04:44:E :OUT548:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
EDIT2: I bumped them to 12 CPUs and were able to get WUs.
belloq
Post by belloq »
After it downloaded the WUs, I set the CPUs back to 4 and unpaused. It seems to be running fine and will finish the WU in about 3h, well ahead of the 3d deadline.
belloq
Post by belloq »
The issue continues. I am only able to get a WU by setting CPU=12. Tried 6, 8, 9, 10.
It seems rather ridiculous that the min CPU for these WUs is 12, considering that 4 CPUs completes the work in 3h.
Post by muziqaz »
belloq wrote: Tue Aug 26, 2025 10:12 pm The issue continues. I am only able to get a WU by setting CPU=12. Tried 6, 8, 9, 10.
You need to relax. You were explained what the situation is right now, and it will not change any time soon, unless there is new projects for CPUs coming in. And for a moment there isn't.
FAH Omega tester
Wedge009
Post by Wedge009 »
muziqaz wrote: Mon Aug 25, 2025 3:33 pm There might not be enough CPU work for 4 threads.
Is there a place where we can look for information on what's available? A few days ago I noticed trouble getting CPU work (which is all I do for F@h) but then it seemed to stabilise, while today I notice the situation appears to have returned.
Post by muziqaz »
Wedge009 wrote: Wed Aug 27, 2025 6:18 am
No. There are server stats but they will not show you what are the splits.
Currently we have 800k CPU WUs available. Something is broken that there is no work for low core count clients out of all those WUs
FAH Omega tester
Wedge009
Post by Wedge009 »
Is it always about CPU core counts? My largest host allocates 20 cores and occasionally I see it unable to get any work assignments (during these periods of work shortages).
Post by muziqaz »
Wedge009 wrote: Wed Aug 27, 2025 7:07 am Is it always about CPU core counts? My largest host allocates 20 cores and occasionally I see it unable to get any work assignments (during these periods of work shortages).
Restrictions are per core count and nothing else.
My 30 thread CPUs have not had any hickups
FAH Omega tester
Post by calxalot »
I thought it was a jumble of cpus, os, arch in the constraints
Post by muziqaz »
calxalot wrote: Wed Aug 27, 2025 7:33 am I thought it was a jumble of cpus, os, arch in the constraints
Not for every project though.
I'm trying to get through to Sonya in regards to their constraints, but with no success.
This weekend probably will have to check and see which servers have most WUs and then ask researchers about the constraints.
FAH Omega tester
In the US it is a hard time to get in touch with people at universities. Fall semesters at them are either just started or about to start. New grad students are being brought in, and some are leaving if they are finished with their research for their degrees. Some will just be getting back if they took some time off during the Summer.
muziqaz wrote: Wed Aug 27, 2025 8:58 am I'm trying to get through to Sonya in regards to their constraints, but with no success.
Yes, 144.121.86.56 / fahserver1.flatironinstitute.org has always show weird behaviour for its A9 projects : low assign rate and projects that automatically reduces threads count from 8 to 7 for no reason, no assignment to 12 CPUs, ... :?
By the way, this server is currently down. :(
belloq
Post by belloq »
Is there a FAQ that has an answer for why some projects are requiring a certain # thread CPU count to download the WU, but then, as is my case, I can drop the CPUs down to 4 and it still completes in under 4 hours? It seems like the requirements for 12 or more CPUs isn't really correct in terms of returning a WU before the deadline. Is there more to the CPU requirement than that?
