Work Units Details fail to show credited points ?
Mactin
Post by Mactin »
The "Work Unit Detail" page on he Web client fails to show "Logged Credits" for a specific WU processed hours ago.
My client has processed three other WUs since and correctly shows logged credits for each of them,
I know it takes a few minutes for credits to show up, as I write this it has been 7 hours. Have the results been uploaded ?
Also, since the extreme overclocking stats site is down, I can't double check from a second source.
The WU in question is p18240-r693-c2-g444.
06:53:52:I1:WU1022:Requesting WU assignment for user Martin_MBA_M4 team 96377
06:53:53:I1:WU1022:Received WU assignment CFpK6RN2khjr6YuhOKUvcLUuH6T0kchF2YqqEHxruno
06:53:53:I1:WU1022:Downloading WU
06:53:54:I1:WU1022:Received WU P18240 R693 C2 G444
06:53:54:I3:WU1022:Started FahCore on PID 8567
06:53:54:I1:WU1022:*********************** Log Started 2025-08-05T06:53:54Z ***********************
06:53:54:I1:WU1022:************************** Gromacs Folding@home Core ***************************
06:53:54:I1:WU1022: Core: Gromacs
06:53:54:I1:WU1022: Type: 0xa8
06:53:54:I1:WU1022: Version: 0.0.12
06:53:54:I1:WU1022: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:53:54:I1:WU1022: Copyright: 2020 foldingathome.org
06:53:54:I1:WU1022: Homepage: https://foldingathome.org/
06:53:54:I1:WU1022: Date: Jan 16 2021
06:53:54:I1:WU1022: Time: 21:35:50
06:53:54:I1:WU1022: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
06:53:54:I1:WU1022: Branch: master
06:53:54:I1:WU1022: Compiler: GNU Apple LLVM 12.0.0 (clang-1200.0.32.28)
06:53:54:I1:WU1022: Options: -faligned-new -std=c++14 -fsigned-char -stdlib=libc++ -O3
06:53:54:I1:WU1022: -funroll-loops -fno-pie -mmacosx-version-min=11.0
06:53:54:I1:WU1022: Platform: darwin 20.2.0
06:53:54:I1:WU1022: Bits: 64
06:53:54:I1:WU1022: Mode: Release
06:53:54:I1:WU1022: SIMD: arm_neon_asimd
06:53:54:I1:WU1022: OpenMP: ON
06:53:54:I1:WU1022: CUDA: OFF
06:53:54:I1:WU1022: Args: -dir CFpK6RN2khjr6YuhOKUvcLUuH6T0kchF2YqqEHxruno -suffix 01
06:53:54:I1:WU1022: -version 8.4.9 -lifeline 906 -np 10
06:53:54:I1:WU1022:************************************ libFAH ************************************
06:53:54:I1:WU1022: Time: 21:35:27
06:53:54:I1:WU1022:************************************ CBang *************************************
06:53:54:I1:WU1022: Time: 21:35:02
06:53:54:I1:WU1022: -funroll-loops -fno-pie -mmacosx-version-min=11.0 -fPIC
06:53:54:I1:WU1022:************************************ System ************************************
06:53:54:I1:WU1022: CPU: Apple
06:53:54:I1:WU1022: CPU ID: Apple Family 8 Model 0 Stepping 0
06:53:54:I1:WU1022: CPUs: 10
06:53:54:I1:WU1022: Memory: 16.00GiB
06:53:54:I1:WU1022:Free Memory: 1.07GiB
06:53:54:I1:WU1022: Threads: POSIX_THREADS
06:53:54:I1:WU1022: OS Version: 15.6
06:53:54:I1:WU1022:Has Battery: true
06:53:54:I1:WU1022: On Battery: false
06:53:54:I1:WU1022: UTC Offset: -4
06:53:54:I1:WU1022: PID: 8567
06:53:54:I1:WU1022: CWD: /Library/Application Support/FAHClient/work
06:53:54:I1:WU1022:********************************************************************************
06:53:54:I1:WU1022:Project: 18240 (Run 693, Clone 2, Gen 444)
06:53:54:I1:WU1022:Unit: 0x00000000000000000000000000000000
06:53:54:I1:WU1022:Reading tar file core.xml
06:53:54:I1:WU1022:Reading tar file frame444.tpr
06:53:54:I1:WU1022:Digital signatures verified
06:53:54:I1:WU1022:Calling: mdrun -c frame444.gro -s frame444.tpr -x frame444.xtc -cpt 5 -nt 10 -ntmpi 1
06:53:54:I1:WU1022:Steps: first=111000000 total=111250000
06:53:54:I1:WU1022:Completed 1 out of 250000 steps (0%)
06:55:03:I1:WU1022:Completed 2500 out of 250000 steps (1%)
06:56:12:I1:WU1022:Completed 5000 out of 250000 steps (2%)
06:57:21:I1:WU1022:Completed 7500 out of 250000 steps (3%)
08:52:22:I1:WU1022:Completed 242500 out of 250000 steps (97%)
08:53:45:I1:WU1022:Completed 245000 out of 250000 steps (98%)
08:55:09:I1:WU1022:Completed 247500 out of 250000 steps (99%)
08:56:31:I1:WU1022:Completed 250000 out of 250000 steps (100%)
08:56:33:I1:WU1022:Saving result file ../logfile_01.txt
08:56:33:I1:WU1022:Saving result file frame444.gro
08:56:33:I1:WU1022:Saving result file frame444.xtc
08:56:33:I1:WU1022:Saving result file md.log
08:56:33:I1:WU1022:Saving result file science.log
08:56:33:I1:WU1022:Saving result file state.cpt
08:56:33:I1:WU1022:Folding@home Core Shutdown: FINISHED_UNIT
08:56:34:I1:WU1022:Core returned FINISHED_UNIT (100)
08:56:35:I1:WU1022:Uploading WU results
08:56:46:I1:WU1022:Credited
Extra Question : How do I paste an image here ?
Re: Work Units Details fail to show credited points ?
First, the Extreme Overclocking stats site is not down.
Second you can check whether a WU has been credited using the WU Status app from this page - https://apps.foldingathome.org
I did check and it hasn't been entered into the stats database. Delays in that can come from being returned to a collection server instead of the work server it came from, the stats upload once the CS connects back to the WS. Or the WS has lost connection with the stats database server and that needs to be fixed up.
Finally this forum doesn't host images. You would need to use one of the image hosting sites and link to that to post an image here.
Mactin
Post by Mactin »
Thanks for the quick reply :
Joe_H wrote: Tue Aug 05, 2025 5:02 pm First, the Extreme Overclocking stats site is not down.
The link I have been using for 15+ years is returning : "The server at folding.extremeoverclocking.com is taking too long to respond."
It did this about two weeks ago, came back for a few days and went away again a few days ago.
In the time you took to reply, I saw there was a topic about EOC on the forums. I interpret it as being down/gone.
I just started folding again this spring (I wanted to "test" my new M4 MacBookAir) and got addicted and purchased a "gaming" PC just to fold.
I stopped folding in 2020 after doing it for more or less 10-15 years (my first post here is from 2007).
I remember another stats site (kakao, or something similar).
All this to say the link https://apps.foldingathome.org/ is totally new to me. Great tool :-)
Post by muziqaz »
EOC is going through transition period.
FAH Omega tester
Not sure why you are not able to connect to EOC, the link I have been using is still currently working for me. Here on the forum there was an update to the info about EOC, a number of people donated and he has enough to operate at least through the end of this year. He may need to relocate the server.
Kakaostats was around, the person operating the site decided to stop. Someone in S. America took up the code and had a site operating for a while, then stuff happened and they also stopped. The code may still be out there if someone wanted to revive it.
Mactin
Post by Mactin »
EOC connectivity problems are a home-office networking problem.
Yesterday afternoon I took my iPad with me for my bike ride. Midway, in a break, I took my iPad out and connected thru my iPhone hotspot. EOC worked !
This morning, I connected successfully thru my iPhone hotspot again.
I have to diagnose why only EOC does not connect thru my home network.
Have a nice day
Your home network may be using a different DNS and that hasn't updated if the EOC site moved would be my first guess.
Mactin
Post by Mactin »
Joe_H wrote: Tue Aug 05, 2025 5:02 pm I did check and it hasn't been entered into the stats database. Delays in that can come from being returned to a collection server instead of the work server it came from, the stats upload once the CS connects back to the WS. Or the WS has lost connection with the stats database server and that needs to be fixed up.
It has now expired. No signs of the WU having been re-issued and processed by another donor.
I dont care for the points. I do care for the wasted donor resources.
I will followup tomorow.
There has been issues of banned IPs at EOC for a long time ... yours is probably in the list.
Try to contact Jason (from your working connection) : https://www.extremeoverclocking.com/contact_info.php
Mactin
Post by Mactin »
Merci toTOW.
Le lien que tu as fourni ne marches pas !!! J'oubliais que ça marcherait pas plus que les stats.
The link you supplied did not work !!! I has forgotten I had to use my cellphone ISP not my home network ISP.
I wrote to Jason to let him know.
*** Further testing shows you are probably on the right path. I canot access EOC with my neighbours home network (with his wifi but the same ISP).
*** Joe_H suggested looking into my DNS settings. I use Quad9 and switched to Cloudflare, Google, OpenDNS and finally my ISP to always get the same non functioning result.
Edit, 15 minutes later:
Jason took ten minutes to reply to my message to him and unblocked my ISPs IP address.
Merci encore à toTOW
Mactin
Post by Mactin »
WOW !
The Wu referenced in the first post of the thread (on August 9th) was credited TODAY (Sept. 16th)
https://apps.foldingathome.org/wu#proje ... =2&gen=444
It looks funny on EOC, because this Apple M4 CPU has not received a WU in weeks and then 18117 points
Have a nice day
