Folding@home client crashed
Hi guys, I'm having an issue with the Folding@home client. As soon as I start the calculations, the program crashes. There is no error message. It just quits.
I'm using Windows 11 with the latest updates. I have the latest client version.
Can anyone help me?
Log:
04:39:03:I3:WU1:Loading work unit 1 with ID eimjwGcwb6rhVWENi1fYmhaIptoRDJUugaCGGh4fOMU
04:39:03:I3:WU1:Started FahCore on PID 47972
04:39:03:I1:WU1:*********************** Log Started 2025-06-15T04:39:03Z ***********************
04:39:03:I1:WU1:************************** Gromacs Folding@home Core ***************************
04:39:03:I1:WU1: Core: Gromacs
04:39:03:I1:WU1: Type: 0xa8
04:39:03:I1:WU1: Version: 0.0.12
04:39:03:I1:WU1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:39:03:I1:WU1: Copyright: 2020 foldingathome.org
04:39:03:I1:WU1: Homepage: https://foldingathome.org/
04:39:03:I1:WU1: Date: Jan 16 2021
04:39:03:I1:WU1: Time: 12:29:40
04:39:03:I1:WU1: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
04:39:03:I1:WU1: Branch: master
04:39:03:I1:WU1: Compiler: Visual C++ 2019 16.7
04:39:03:I1:WU1: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
04:39:03:I1:WU1: Platform: win32 10
04:39:03:I1:WU1: Bits: 64
04:39:03:I1:WU1: Mode: Release
04:39:03:I1:WU1: SIMD: avx2_256
04:39:03:I1:WU1: OpenMP: ON
04:39:03:I1:WU1: CUDA: OFF
04:39:03:I1:WU1: Args: -dir eimjwGcwb6rhVWENi1fYmhaIptoRDJUugaCGGh4fOMU -suffix 01
04:39:03:I1:WU1: -version 8.4.9 -lifeline 14628 -np 16
04:39:03:I1:WU1:************************************ libFAH ************************************
04:39:03:I1:WU1: Time: 11:24:13
04:39:03:I1:WU1:************************************ CBang *************************************
04:39:03:I1:WU1: Time: 11:23:53
04:39:03:I1:WU1:************************************ System ************************************
04:39:03:I1:WU1: CPU: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
04:39:03:I1:WU1: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
04:39:03:I1:WU1: CPUs: 16
04:39:03:I1:WU1: Memory: 15.78GiB
04:39:03:I1:WU1:Free Memory: 10.24GiB
04:39:03:I1:WU1: Threads: WINDOWS_THREADS
04:39:03:I1:WU1: OS Version: 6.2
04:39:03:I1:WU1:Has Battery: false
04:39:03:I1:WU1: On Battery: false
04:39:03:I1:WU1: UTC Offset: 2
04:39:03:I1:WU1: PID: 47972
04:39:03:I1:WU1: CWD: C:\ProgramData\FAHClient\work
04:39:03:I1:WU1:********************************************************************************
04:39:03:I1:WU1:Project: 19227 (Run 9434, Clone 7, Gen 3)
04:39:03:I1:WU1:Unit: 0x00000000000000000000000000000000
04:39:03:I1:WU1:Digital signatures verified
04:39:03:I1:WU1:Calling: mdrun -c md3.gro -s md3.tpr -x md3.xtc -cpi state.cpt -cpt 5 -nt 16 -ntmpi 1
04:39:04:I1:WU1:Steps: first=1500000 total=2000000
04:39:14:I1:WU1:Completed 1352 out of 500000 steps (0%)
Kind regards
Xaat
Can anyone help me?
Log:
Kind regards
Xaat
- Hardware configuration: 9950x, 9950x3D, 5950x, 5800x3D
7900xtx, RX9070, Radeon 7, 5700xt, 6900xt, Intel B580 - Location: London
Re: Folding@home client crashed
Fahlog does not show any crashes.
It shows the start of folding
The crash is not in the log...the logs ends randomly.
Can you paste the last 20 or so lines from the files "science.log" and "md.log"? They contain the raw log output of the folding core and should be present in the folder C:\ProgramData\FAHClient\work\<bunch of characters>\01 and may contain information on the crash that was not picked up by the client.
I would hope you can make an effort and show us the crash, otherwise we are troubleshooting perfectly working system from our point of view
I think what OP is saying is that what he showed is all that there is, and the client just terminates without any error messages which is being interpreted as a crash because it was uncommanded.
If the client terminates without anything in the logs, then it is unstable hardware. RAM is the biggest suspect.
If client crashes due to its own fault usually leaves some traces.
Event viewer would be another good place to see what happened to the client.
In the Windows event log, under Windows logs, in the Application log, do you see any entries with event ID 1001 or 1002?
Event ID 1001 is an actual application crash, which will look something like this:
Fault bucket 2026874940613447519, type 5
Event Name: RADAR_PRE_LEAK_64
Response: Not available
Cab Id: 0
Problem signature:
P1: FAHClient.exe
P2: 0.0.0.0
P3: 10.0.26100.2.0.0
Event ID 1002 is an application hang, which will look something like this:
The program FAHClient.exe version x.x.x.x stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
If you don't have either of those, then it is being shut down "gracefully," which probably means a missing file or dependency of some kind.
Cab Id: 0
Problem signature:
P1: FAHClient.exe
P2: 0.0.0.0
@arisu
Computing: M-Number M-Flops % Flops
NB Free energy kernel 5015.175510 5015.176 0.1
Pair Search distance check 486.493140 4378.438 0.1
NxN Ewald Elec. + LJ [F] 32198.392832 3284236.069 39.2
NxN Ewald Elec. + LJ [V&F] 339.736736 47563.143 0.6
NxN Ewald Elec. [F] 26040.812256 1588489.548 18.9
NxN Ewald Elec. [V&F] 274.782624 23081.740 0.3
1,4 nonbonded interactions 29.268141 2634.133 0.0
Calc Weights 390.609162 14061.930 0.2
Spread Q Bspline 112495.438656 224990.877 2.7
Gather F Bspline 112495.438656 674972.632 8.1
3D-FFT 307802.744568 2462421.957 29.4
Solve PME 67.286016 4306.305 0.1
Shift-X 1.359316 8.156 0.0
Angles 20.330901 3415.591 0.0
Propers 31.589964 7234.102 0.1
Impropers 2.426991 504.814 0.0
Pos. Restr. 0.693297 34.665 0.0
Virial 13.113765 236.048 0.0
Update 130.203054 4036.295 0.0
Stop-CM 1.262222 12.622 0.0
Calc-Ekin 26.118286 705.194 0.0
Lincs 22.628034 1357.682 0.0
Lincs-Mat 488.038176 1952.153 0.0
Constraint-V 282.854448 2262.836 0.0
Constraint-Vir 13.098645 314.367 0.0
Settle 79.199460 25581.426 0.3
Total 8383807.897 100.0
R E A L C Y C L E A N D T I M E A C C O U N T I N G
On 1 MPI rank, each using 16 OpenMP threads
Computing: Num Num Call Wall time Giga-Cycles
Ranks Threads Count (s) total sum %
Neighbor search 1 16 14 0.170 10.376 0.2
Force 1 16 1341 12.741 777.349 17.0
PME mesh 1 16 1341 59.318 3619.149 79.1
NB X/F buffer ops. 1 16 2668 0.438 26.746 0.6
Write traj. 1 16 1 0.611 37.305 0.8
Update 1 16 2682 0.778 47.440 1.0
Constraints 1 16 2682 0.577 35.228 0.8
Rest 0.367 22.395 0.5
Total 75.000 4575.986 100.0
Breakdown of PME mesh computation
PME spread 1 16 5364 14.547 887.574 19.4
PME gather 1 16 5364 20.759 1266.590 27.7
PME 3D-FFT 1 16 10728 21.311 1300.249 28.4
PME solve LJ 1 16 2682 1.511 92.164 2.0
PME solve Elec 1 16 2682 1.134 69.166 1.5
Core t (s) Wall t (s) (%)
Time: 1200.000 75.000 1600.0
(ns/day) (hour/ns)
Performance: 3.090 7.768
Finished mdrun on rank 0 Sun Jun 15 06:40:29 2025
on-default thread affinity set probably by the OpenMP library,
disabling internal thread affinity
Setting the maximum number of constraint warnings to 2147483647
starting mdrun 'simulation system in water'
2000000 steps, 4000.0 ps (continuing from step 1501201, 3002.4 ps).
Received the remote second INT/TERM signal, stopping within 11 steps
Folding@home Core Shutdown: INTERRUPTED
Time: 160.000 10.000 1600.0
(ns/day) (hour/ns)
Performance: 2.609 9.198
The current CPU can measure timings more accurately than the code in
GROMACS was configured to use. This might affect your simulation
speed as accurate timings are needed for load-balancing.
Please consider rebuilding GROMACS with the GMX_USE_RDTSCP=ON CMake option.
Reading file md3.tpr, VERSION 2020.2 (single precision)
This run will default to '-update gpu' as requested by the GMX_FORCE_UPDATE_DEFAULT_GPU environment variable. GPU update with domain decomposition lacks substantial testing and should be used with caution.
Changing nstlist from 10 to 100, rlist from 1 to 1.005
Update task on the GPU was required, by the GMX_FORCE_UPDATE_DEFAULT_GPU environment variable, but the following condition(s) were not satisfied:
Either PME or short-ranged non-bonded interaction tasks must run on the GPU.
Compatible GPUs must have been found.
Only a CUDA build is supported.
Only the md integrator is supported.
Free energy perturbations are not supported.
The number of coupled constraints is higher than supported in the CUDA LINCS code.
Will use CPU version of update.
Using 1 MPI thread
Lost lifeline PID 14628, exiting
Using 16 OpenMP threads
Non-default thread affinity set probably by the OpenMP library,
2000000 steps, 4000.0 ps (continuing from step 1501351, 3002.7 ps).
(ns/day) (hour/ns)
(ns/day) (hour/ns)
(ns/day) (hour/ns)
Using 1 MPI thread
(ns/day) (hour/ns)
So the core is aware that it is being terminated, but the client is not? Is what you posted before that (the client log) the last lines of the client log file, or the last lines that you see in the web interface?
Then the Windows Event Log should be checked for FAHClient crashing or being aborted by another process. That is about the only other action that would cause the exits seen. The line:
indicates the core was no longer connected to FAHClient, the core will exit when that happens usually. Though in the past occasionally a core process would continue and only die when it reached point where it needed to communicate with the client.Lost lifeline PID 14628, exiting
@joe_h nothing in the Windows Event Log, about a FAHClient crash.
@arisu last log from client log file.
C:\ProgramData\Fah-client directory should contain all the historic logs. Redact any private info (like passkey, or ID), and paste it into pastebin or something
Oh, I didn't even notice that it said lost lifeline! That means something is suddenly killing the client and not allowing it to terminate cleanly, and the core kills itself after realizing that the client (its parent and "lifeline") has disappeared. That explains why there is no log from the client.
@muziqaz Sorry for the long wait. I've been really busy. Here's the log file.
*********************** Log Started 2025-06-28T11:12:05Z ***********************
11:12:05:I1:*********************** Folding@home Client ***********************
11:12:05:I1: Version: 8.4.9
11:12:05:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:12:05:I1: Org: foldingathome.org
11:12:05:I1: Copyright: 2023-2024, foldingathome.org
11:12:05:I1: Homepage: https://foldingathome.org/
11:12:05:I1: License: GPL-3.0-or-later
11:12:05:I1: URL: https://v8-4.foldingathome.org/
11:12:05:I1: Date: Nov 20 2024
11:12:05:I1: Time: 14:47:46
11:12:05:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
11:12:05:I1: Branch: master
11:12:05:I1: Compiler: Visual C++
11:12:05:I1: Options: $( /TP $) /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2
11:12:05:I1: /Zc:throwingNew /MT
11:12:05:I1: Platform: win32 10
11:12:05:I1: Bits: 64
11:12:05:I1: Mode: Release
11:12:05:I1:****************************** CBang ******************************
11:12:05:I1: Version: 1.7.2
11:12:05:I1: Org: Cauldron Development
11:12:05:I1: Copyright: Cauldron Development, 2003-2024
11:12:05:I1: Homepage: https://cauldrondevelopment.com/
11:12:05:I1: License: LGPL-2.1-or-later
11:12:05:I1: Time: 09:04:40
11:12:05:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
11:12:05:I1:***************************** System ******************************
11:12:05:I1: CPU: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
11:12:05:I1: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
11:12:05:I1: CPUs: 16
11:12:05:I1: Memory: 15.78GiB
11:12:05:I1:Free Memory: 10.48GiB
11:12:05:I1: OS Version: 6.2
11:12:05:I1:Has Battery: false
11:12:05:I1: On Battery: false
11:12:05:I1: Hostname: DESKTOP-89SK7V4
11:12:05:I1: UTC Offset: 2
11:12:05:I1: PID: 16164
11:12:05:I1: CWD: C:\ProgramData\FAHClient
11:12:05:I1: Exec: C:\Program Files\FAHClient\FAHClient.exe
11:12:05:I1:*******************************************************************
11:12:05:I2:<config/>
11:12:05:I1:Opening Database
11:12:05:I1:F@H ID = yF1au-FazmHkfSwg4RpIznOJNsgFLi-hhi8vFiMbROg
11:12:05:I3:Loading default resource group
11:12:05:I1:Listening for HTTP on 127.0.0.1:7396
11:12:05:I3:WU1:Loading work unit 1 with ID eimjwGcwb6rhVWENi1fYmhaIptoRDJUugaCGGh4fOMU
11:12:05:I3:Loaded 1 wus.
11:12:05:I1:Started Windows systray control
11:12:06:I3:gpus = {
11:12:06:I3: "gpu:00:02:00": {"vendor": 32902, "device": 39877, "type": "intel", "supported": false, "description": "CML GT2 [UHD Graphics 630]"},
11:12:06:I3: "gpu:01:00:00": {"vendor": 4318, "device": 7357, "type": "nvidia", "supported": false, "description": "GP107GLM [Quadro P620]"}
11:12:06:I3:}
11:12:06:I1:WU1:Unit expired, deleting
11:12:06:I1:OUT1:> GET https://api.foldingathome.org/machine/y ... i8vFiMbROg HTTP/1.1
11:12:06:I1:OUT2:> GET https://api.foldingathome.org/gpus HTTP/1.1
11:12:06:I1:OUT1:< HTTP/1.1 200 HTTP_OK
11:12:07:I1:OUT3:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
11:12:07:I1:OUT2:< HTTP/1.1 200 HTTP_OK
11:12:07:I1:OUT3:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
11:12:07:I1:Logging into node account
11:12:08:I1:Default:Added new work unit: cpus:16 gpus:
11:12:08:I1:WU2:Requesting WU assignment for user Prime2k team 0
11:12:08:I1:OUT4:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
11:12:08:I1:OUT4:< HTTP/1.1 200 HTTP_OK
11:12:08:I1:WU2:Received WU assignment h-ah_qHq8gqjB7AW999lqTj6p8KfeGcqIHrDC1wobN8
11:12:08:I1:WU2:Downloading WU
11:12:09:I1:OUT5:> POST https://vav21.fah.temple.edu/api/assign HTTP/1.1
11:12:10:I1:OUT5:< HTTP/1.1 200 HTTP_OK
11:12:10:I1:WU2:Received WU P18498 R63 C16 G171
11:12:10:I1:Loaded cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe
11:12:10:I3:Running FahCore: C:\ProgramData\FAHClient\cores/fahcore-a8-win-64bit-avx2_256-0.0.12/FahCore_a8.exe -dir h-ah_qHq8gqjB7AW999lqTj6p8KfeGcqIHrDC1wobN8 -suffix 01 -version 8.4.9 -lifeline 16164 -np 16
11:12:10:I3:WU2:Started FahCore on PID 5656
11:12:10:I1:WU2:*********************** Log Started 2025-06-28T11:12:10Z ***********************
11:12:10:I1:WU2:************************** Gromacs Folding@home Core ***************************
11:12:10:I1:WU2: Core: Gromacs
11:12:10:I1:WU2: Type: 0xa8
11:12:10:I1:WU2: Version: 0.0.12
11:12:10:I1:WU2: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:12:10:I1:WU2: Copyright: 2020 foldingathome.org
11:12:10:I1:WU2: Homepage: https://foldingathome.org/
11:12:10:I1:WU2: Date: Jan 16 2021
11:12:10:I1:WU2: Time: 12:29:40
11:12:10:I1:WU2: Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
11:12:10:I1:WU2: Branch: master
11:12:10:I1:WU2: Compiler: Visual C++ 2019 16.7
11:12:10:I1:WU2: Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
11:12:10:I1:WU2: Platform: win32 10
11:12:10:I1:WU2: Bits: 64
11:12:10:I1:WU2: Mode: Release
11:12:10:I1:WU2: SIMD: avx2_256
11:12:10:I1:WU2: OpenMP: ON
11:12:10:I1:WU2: CUDA: OFF
11:12:10:I1:WU2: Args: -dir h-ah_qHq8gqjB7AW999lqTj6p8KfeGcqIHrDC1wobN8 -suffix 01
11:12:10:I1:WU2: -version 8.4.9 -lifeline 16164 -np 16
11:12:10:I1:WU2:************************************ libFAH ************************************
11:12:10:I1:WU2: Time: 11:24:13
11:12:10:I1:WU2:************************************ CBang *************************************
11:12:10:I1:WU2: Time: 11:23:53
11:12:10:I1:WU2:************************************ System ************************************
11:12:10:I1:WU2: CPU: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz
11:12:10:I1:WU2: CPU ID: GenuineIntel Family 6 Model 165 Stepping 5
11:12:10:I1:WU2: CPUs: 16
11:12:10:I1:WU2: Memory: 15.78GiB
11:12:10:I1:WU2:Free Memory: 10.48GiB
11:12:10:I1:WU2: Threads: WINDOWS_THREADS
11:12:10:I1:WU2: OS Version: 6.2
11:12:10:I1:WU2:Has Battery: false
11:12:10:I1:WU2: On Battery: false
11:12:10:I1:WU2: UTC Offset: 2
11:12:10:I1:WU2: PID: 5656
11:12:10:I1:WU2: CWD: C:\ProgramData\FAHClient\work
11:12:10:I1:WU2:********************************************************************************
11:12:10:I1:WU2:Project: 18498 (Run 63, Clone 16, Gen 171)
11:12:10:I1:WU2:Unit: 0x00000000000000000000000000000000
11:12:10:I1:WU2:Reading tar file core.xml
11:12:10:I1:WU2:Reading tar file frame171.tpr
11:12:10:I1:WU2:Digital signatures verified
11:12:10:I1:WU2:Calling: mdrun -c frame171.gro -s frame171.tpr -x frame171.xtc -cpt 5 -nt 16 -ntmpi 1
11:12:10:I1:WU2:Steps: first=855000000 total=860000000
11:12:10:I1:WU2:Completed 1 out of 5000000 steps (0%)
11:12:18:I1:WU2:WARNING:Console control signal 1 on PID 5656
11:12:18:I1:WU2:Exiting, please wait. . .
11:12:18:I1:WU2:Folding@home Core Shutdown: INTERRUPTED
11:12:19:I1:WU2:Core returned INTERRUPTED (102)
11:12:20:I1:Clean exit
11:12:06:I3:}
