Failed response: CONNECT on my home server
HyperWin
Post by HyperWin »
Hello! I decided to help with some compute power, installed FAH in docker to my main pc, homelab and vps. On main pc everything works fine, even with VPN enabled. On home server I get repeating "failed response: CONNECT" when it tries to download an assignment. On VPS - uhh... Sorry, I'll send it later, or in another post. Anyways, logs of my homelab:
GID/UID
User UID:    1000
User GID:    1000
Linuxserver.io version: 8.4.9-ls163
Build-date: 2025-04-29T03:33:16+00:00
[custom-init] No custom files found, skipping...
18:10:43:I1:*********************** Folding@home Client ***********************
18:10:43:I1:    Version: 8.4.9
18:10:43:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:10:43:I1:        Org: foldingathome.org
18:10:43:I1:  Copyright: 2023-2024, foldingathome.org
18:10:43:I1:   Homepage: https://foldingathome.org/
18:10:43:I1:    License: GPL-3.0-or-later
18:10:43:I1:        URL: https://v8-4.foldingathome.org/
18:10:43:I1:       Date: Nov 20 2024
18:10:43:I1:       Time: 14:47:19
18:10:43:I1:   Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
18:10:43:I1:     Branch: master
18:10:43:I1:   Compiler: GNU 8.3.0
18:10:43:I1:    Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
18:10:43:I1:             -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
18:10:43:I1:   Platform: linux 4.19.0-27-cloud-amd64
18:10:43:I1:       Bits: 64
18:10:43:I1:       Mode: Release
18:10:43:I1:       Args: --http-addresses 0.0.0.0:7396 --allow 0/0 --account-token
18:10:43:I1:             yLVGvyLUhLPqxhLPPWPCJPWPpNcK6pNcgAfwqgAfkaI --machine-name
18:10:43:I1:             home-server --team 234980 --user l9vnp09s1sxm --cpus 2
18:10:43:I1:****************************** CBang ******************************
18:10:43:I1:    Version: 1.7.2
18:10:43:I1:        Org: Cauldron Development
18:10:43:I1:  Copyright: Cauldron Development, 2003-2024
18:10:43:I1:   Homepage: https://cauldrondevelopment.com/
18:10:43:I1:    License: LGPL-2.1-or-later
18:10:43:I1:       Date: Nov 19 2024
18:10:43:I1:       Time: 21:54:38
18:10:43:I1:   Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
18:10:43:I1:             -fPIC
18:10:43:I1:***************************** System ******************************
18:10:43:I1:        CPU: AMD A10 PRO-7800B R7, 12 Compute Cores 4C+8G
18:10:43:I1:     CPU ID: AuthenticAMD Family 21 Model 48 Stepping 1
18:10:43:I1:       CPUs: 4
18:10:43:I1:     Memory: 22.84GiB
18:10:43:I1:Free Memory: 1.41GiB
18:10:43:I1: OS Version: 6.14
18:10:43:I1:Has Battery: false
18:10:43:I1: On Battery: false
18:10:43:I1:   Hostname: hyper-homeserver
18:10:43:I1: UTC Offset: 0
18:10:43:I1:        PID: 172
18:10:43:I1:        CWD: /config
18:10:43:I1:       Exec: /app/fah-client
18:10:43:I1:*******************************************************************
18:10:43:I2:<config/>
18:10:44:I1:Opening Database
18:10:44:I1:F@H ID = m85WNbcRkzxCCKOtJC7_PbUNoywJXQrW5azV1Nqn-tc
18:10:44:I3:Loading default resource group
18:10:44:I1:Listening for HTTP on 0.0.0.0:7396
18:10:44:I3:Loaded 0 wus.
18:10:44:I3:gpus = {
18:10:44:I3:  "gpu:00:01:00": {"vendor": 4098, "device": 4879, "type": "amd", "supported": false, "description": "Kaveri [Radeon R7]"}
18:10:44:I3:}
18:10:44:I1:Default:Added new work unit: cpus:2 gpus:
18:10:44:I1:WU6:Requesting WU assignment for user l9vnp09s1sxm team 234980
18:10:44:I1:OUT1:> GET https://api.foldingathome.org/machine/m85WNbcRkzxCCKOtJC7_PbUNoywJXQrW5azV1Nqn-tc HTTP/1.1
18:10:44:I1:OUT2:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
Connection to localhost (127.0.0.1) 7396 port [tcp/*] succeeded!
[ls.io-init] done.
18:10:45:I1:OUT2:< HTTP/1.1 503 HTTP_SERVICE_UNAVAILABLE
18:10:45:E :OUT2:HTTP_SERVICE_UNAVAILABLE: {"error":"No appropriate assignment"}
18:10:45:I1:WU6:Retry #1 in 2 secs
And then
02:31:02:I1:WU8:Received WU assignment bW4Dh1eY_1O9fQy_rhwZ7yzoz04s2lGPk-UN3dX3HzA
02:31:02:I1:WU8:Downloading WU
02:32:03:E :OUT81:Failed response: CONNECT
02:32:03:I1:WU8:Retry #1 in 2 secs
02:32:05:I1:WU8:Downloading WU
02:33:06:E :OUT82:Failed response: CONNECT
02:33:06:I1:WU8:Retry #2 in 4 secs
02:33:10:I1:WU8:Downloading WU
02:34:11:E :OUT83:Failed response: CONNECT
02:34:11:I1:WU8:Retry #3 in 8 secs
02:34:19:I1:WU8:Downloading WU
02:35:20:E :OUT84:Failed response: CONNECT
02:35:20:I1:WU8:Retry #4 in 16 secs
02:35:36:I1:WU8:Downloading WU
02:36:37:E :OUT85:Failed response: CONNECT
02:36:37:I1:WU8:Retry #5 in 32 secs
02:37:09:I1:WU8:Downloading WU
02:38:10:E :OUT86:Failed response: CONNECT
02:38:10:I1:WU8:Retry #6 in 1 min 4 secs
02:39:14:I1:WU8:Downloading WU
02:40:15:E :OUT87:Failed response: CONNECT
02:40:15:I1:WU8:Retry #7 in 2 mins 8 secs
02:42:23:I1:WU8:Downloading WU
Re: Failed response: CONNECT on my home server
Post by calxalot »
At the moment, the minimum cpu count to get work is 3
HyperWin
Post by HyperWin »
calxalot wrote: Tue May 20, 2025 3:01 am At the moment, the minimum cpu count to get work is 3
This error is caused by that core count? Sad, I'll probably create some kind of controller to toggle folding on or off on schedule. Though, I changed it from 2 to 4 cores, and the error persists.
Nevermind. Everything works after I restarted the container.
Post by calxalot »
You may need to change the cpu count via web control. After first run, I believe the command line arg is ignored.
HyperWin
Post by HyperWin »
calxalot wrote: Tue May 20, 2025 3:25 am You may need to change the cpu count via web control. After first run, I believe the command line arg is ignored.
Yes, thank you so much, it works now. Are there any solutions for working on schedule?
Also, I got access to my VPS. Logs:
Startup:
───────────────────────────────────────                       GID/UID
User UID:    1000
User GID:    1000                                             ───────────────────────────────────────
Build-date: 2025-04-29T03:33:16+00:00                         ───────────────────────────────────────
03:21:24:I1:*********************** Folding@home Client ***********************                                             03:21:24:I1:    Version: 8.4.9
03:21:24:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>                                                   03:21:24:I1:        Org: foldingathome.org
03:21:24:I1:  Copyright: 2023-2024, foldingathome.org
03:21:24:I1:   Homepage: https://foldingathome.org/
03:21:24:I1:    License: GPL-3.0-or-later
03:21:24:I1:        URL: https://v8-4.foldingathome.org/      03:21:24:I1:       Date: Nov 20 2024
03:21:24:I1:       Time: 14:47:19
03:21:24:I1:   Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
03:21:24:I1:     Branch: master
03:21:24:I1:   Compiler: GNU 8.3.0
03:21:24:I1:    Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char                                          03:21:24:I1:             -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
03:21:24:I1:   Platform: linux 4.19.0-27-cloud-amd64          03:21:24:I1:       Bits: 64
03:21:24:I1:       Mode: Release
03:21:24:I1:       Args: --http-addresses 0.0.0.0:7396 --allow 0/0 --account-token
03:21:24:I1:             yLVGvyLUhLPqxhLPPWPCJPWPpNcK6pNcgAfwqgAfkaI --machine-name vps
03:21:24:I1:             --team 234980 --user l9vnp09s1sxm --cpus 2                                                         03:21:24:I1:****************************** CBang ******************************
03:21:24:I1:    Version: 1.7.2
03:21:24:I1:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>                                                   03:21:24:I1:        Org: Cauldron Development
03:21:24:I1:  Copyright: Cauldron Development, 2003-2024
03:21:24:I1:   Homepage: https://cauldrondevelopment.com/     03:21:24:I1:    License: LGPL-2.1-or-later
03:21:24:I1:       Date: Nov 19 2024
03:21:24:I1:       Time: 21:54:38
03:21:24:I1:   Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5                                                           03:21:24:I1:     Branch: master
03:21:24:I1:             -fPIC
03:21:24:I1:***************************** System ******************************
03:21:24:I1:        CPU: Intel(R) Xeon(R) CPU E5-2658A v3 @ 2.20GHz
03:21:24:I1:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2                                                          03:21:24:I1:       CPUs: 4
03:21:24:I1:     Memory: 3.81GiB
03:21:24:I1:Free Memory: 957.53MiB                            03:21:24:I1: OS Version: 6.12
03:21:24:I1:Has Battery: false
03:21:24:I1: On Battery: false
03:21:24:I1:   Hostname: e4860d6a267a
03:21:24:I1: UTC Offset: 0                                    03:21:24:I1:        PID: 172
03:21:24:I1:        CWD: /config
03:21:24:I1:       Exec: /app/fah-client                      03:21:24:I1:*******************************************************************
03:21:24:I2:<config/>
03:21:24:I1:Opening Database
03:21:24:I1:F@H ID = 1dLIqnHxgQ845LuluYZnipY3xmbiXsVItTPNCWB5BZM
03:21:24:I3:Loading default resource group
03:21:24:I1:Listening for HTTP on 0.0.0.0:7396                03:21:24:I3:Loaded 0 wus.
03:21:24:I1:OUT1:> GET https://api.foldingathome.org/machine/1dLIqnHxgQ845LuluYZnipY3xmbiXsVItTPNCWB5BZM HTTP/1.1
Connection to localhost (127.0.0.1) 7396 port [tcp/*] succeeded!                                                            [ls.io-init] done.
03:21:25:I1:OUT1:< HTTP/1.1 200 HTTP_OK
03:21:26:I1:OUT3:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
Actual errors:
03:23:36:I1:OUT3:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
03:23:36:I1:Logging into node account
03:23:36:I1:Account websocket closed: UNACCEPTABLE msg=
03:23:37:I1:OUT50:> GET https://api.foldingathome.org/machine/1dLIqnHxgQ845LuluYZnipY3xmbiXsVItTPNCWB5BZM HTTP/1.1          03:23:37:I1:OUT50:< HTTP/1.1 200 HTTP_OK
03:23:38:I1:OUT3:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1                                                     03:23:39:I1:OUT3:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
03:23:39:I1:Logging into node account
03:23:39:I1:Account websocket closed: UNACCEPTABLE msg=
03:23:39:I1:OUT51:> GET https://api.foldingathome.org/machine/1dLIqnHxgQ845LuluYZnipY3xmbiXsVItTPNCWB5BZM HTTP/1.1          03:23:41:I1:OUT51:< HTTP/1.1 200 HTTP_OK
03:23:42:I1:OUT3:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1                                                     03:23:42:I1:OUT3:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
03:23:42:I1:Logging into node account
03:23:43:I1:Account websocket closed: UNACCEPTABLE msg=
03:23:43:I1:OUT52:> GET https://api.foldingathome.org/machine/1dLIqnHxgQ845LuluYZnipY3xmbiXsVItTPNCWB5BZM HTTP/1.1          03:23:44:I1:OUT52:< HTTP/1.1 200 HTTP_OK
03:23:45:I1:OUT3:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1                                                     03:23:45:I1:OUT3:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
03:23:45:I1:Logging into node account
03:23:46:I1:Account websocket closed: UNACCEPTABLE msg=
03:23:46:I1:OUT53:> GET https://api.foldingathome.org/machine/1dLIqnHxgQ845LuluYZnipY3xmbiXsVItTPNCWB5BZM HTTP/1.1          03:23:47:I1:OUT53:< HTTP/1.1 200 HTTP_OK
VPS doesn't even appear in machines list in dashboard.
Post by calxalot »
Hmm.
Machine name should not contain spaces.
All system clocks need to be correct.
Someone couldn’t connect to the fah server because their clock was wrong.
HyperWin
Post by HyperWin »
calxalot wrote: Tue May 20, 2025 3:52 am Hmm.
Thank you so much. Thank you. I forced time on VPS to be the same as on my homelab, and now it works properly. Thank you.
arisu
Post by arisu »
For working on a schedule, you could create a user cron job. To edit it (as non-root):
$ crontab -e
In the file put something like this, which would start folding at 10 PM and stop folding at 7 AM:
0 7  * * * /usr/bin/fahctl pause
0 22 * * * /usr/bin/fahctl fold
See crontab(5) for more info on the syntax.
HyperWin
Post by HyperWin »
arisu wrote: Tue May 20, 2025 4:51 am For working on a schedule, you could create a user cron job. To edit it (as non-root):
$ crontab -e
Thank you! Will use it.
HyperWin
Post by HyperWin »
Hello again! Yesterday I migrated my home server from Ubuntu to Fedora, moved my docker data root. After resuming the container, it finished the job successfully, but now it continues to spam the same error. I triple checked time and CPU core count. Attaching logs, just in case.
05:08:27:I1: Version: 8.4.9
05:08:27:I1: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:08:27:I1: Org: foldingathome.org
05:08:27:I1: Copyright: 2023-2024, foldingathome.org
05:08:27:I1: Homepage: https://foldingathome.org/
05:08:27:I1: License: GPL-3.0-or-later
05:08:27:I1: URL: https://v8-4.foldingathome.org/
05:08:27:I1: Date: Nov 20 2024
05:08:27:I1: Time: 14:47:19
05:08:27:I1: Revision: 360fe71b1bd05bb89814bfb97b73a5bda84802d6
05:08:27:I1: Branch: master
05:08:27:I1: Compiler: GNU 8.3.0
05:08:27:I1: Options: -Wsuggest-override -faligned-new -std=c++17 -fsigned-char
05:08:27:I1: -ffunction-sections -fdata-sections -O3 -funroll-loops -fno-pie
05:08:27:I1: Platform: linux 4.19.0-27-cloud-amd64
05:08:27:I1: Bits: 64
05:08:27:I1: Mode: Release
05:08:27:I1: Args: --http-addresses 0.0.0.0:7396 --allow 0/0 --account-token
05:08:27:I1: yLVGvyLUhLPqxhLPPWPCJPWPpNcK6pNcgAfwqgAfkaI --machine-name
05:08:27:I1: home-server --team 234980 --user l9vnp09s1sxm --cpus 2
05:08:27:I1:****************************** CBang ******************************
05:08:27:I1: Version: 1.7.2
05:08:27:I1: Org: Cauldron Development
05:08:27:I1: Copyright: Cauldron Development, 2003-2024
05:08:27:I1: Homepage: https://cauldrondevelopment.com/
05:08:27:I1: License: LGPL-2.1-or-later
05:08:27:I1: Date: Nov 19 2024
05:08:27:I1: Time: 21:54:38
05:08:27:I1: Revision: 443c54e909eb8d8994405a18fb328b5b05a623a5
05:08:27:I1: -fPIC
05:08:27:I1:***************************** System ******************************
05:08:27:I1: CPU: AMD A10 PRO-7800B R7, 12 Compute Cores 4C+8G
05:08:27:I1: CPU ID: AuthenticAMD Family 21 Model 48 Stepping 1
05:08:27:I1: CPUs: 4
05:08:27:I1: Memory: 23.33GiB
05:08:27:I1:Free Memory: 20.94GiB
05:08:27:I1: OS Version: 6.14
05:08:27:I1:Has Battery: false
05:08:27:I1: On Battery: false
05:08:27:I1: Hostname: fedora
05:08:27:I1: UTC Offset: 0
05:08:27:I1: PID: 230
05:08:27:I1: CWD: /config
05:08:27:I1: Exec: /app/fah-client
05:08:27:I1:*******************************************************************
05:08:27:I2:<config/>
05:08:27:I1:Opening Database
05:08:27:I1:F@H ID = m85WNbcRkzxCCKOtJC7_PbUNoywJXQrW5azV1Nqn-tc
05:08:27:I3:Loading default resource group
05:08:27:I1:Listening for HTTP on 0.0.0.0:7396
05:08:27:I3:Loaded 0 wus.
05:08:27:I3:gpus = {
05:08:27:I3: "gpu:00:01:00": {"vendor": 4098, "device": 4879, "type": "amd", "supported": false, "description": "Kaveri [Radeon R7]"}
05:08:27:I3:}
05:08:27:I1:Default:Added new work unit: cpus:3 gpus:
05:08:27:I1:WU15:Requesting WU assignment for user l9vnp09s1sxm team 234980
05:08:27:I1:OUT1:> GET https://api.foldingathome.org/machine/m85WNbcRkzxCCKOtJC7_PbUNoywJXQrW5azV1Nqn-tc HTTP/1.1
05:08:27:I1:OUT2:> POST https://assign1.foldingathome.org/api/assign HTTP/1.1
05:08:28:I1:OUT2:< HTTP/1.1 200 HTTP_OK
05:08:28:I1:WU15:Received WU assignment OeSMJkk22WWgvymuxpVMjrFF3nCS4QA9RjtlWGqyX7o
05:08:28:I1:WU15:Downloading WU
05:08:28:I1:OUT1:< HTTP/1.1 200 HTTP_OK
05:08:29:I1:OUT5:> GET wss://node1.foldingathome.org/ws/client HTTP/1.1
05:08:29:I1:OUT5:< HTTP/1.1 101 HTTP_SWITCHING_PROTOCOLS
05:08:29:I1:Logging into node account
05:09:29:E :OUT4:Failed response: CONNECT
05:09:29:I1:WU15:Retry #1 in 2 secs
05:09:31:I1:WU15:Downloading WU
05:10:32:E :OUT6:Failed response: CONNECT
05:10:32:I1:WU15:Retry #2 in 4 secs
05:10:36:I1:WU15:Downloading WU
05:11:37:E :OUT7:Failed response: CONNECT
05:11:37:I1:WU15:Retry #3 in 8 secs
05:11:45:I1:WU15:Downloading WU
05:12:46:E :OUT8:Failed response: CONNECT
05:12:46:I1:WU15:Retry #4 in 16 secs
05:13:02:I1:WU15:Downloading WU
05:14:03:E :OUT9:Failed response: CONNECT
05:14:03:I1:WU15:Retry #5 in 32 secs
05:14:35:I1:WU15:Downloading WU
05:15:36:E :OUT10:Failed response: CONNECT
05:15:36:I1:WU15:Retry #6 in 1 min 4 secs
05:16:40:I1:WU15:Downloading WU
05:17:41:E :OUT11:Failed response: CONNECT
05:17:41:I1:WU15:Retry #7 in 2 mins 8 secs
05:19:49:I1:WU15:Downloading WU
05:20:50:E :OUT12:Failed response: CONNECT
05:20:50:I1:WU15:Retry #8 in 4 mins 16 secs
Post by muziqaz »
User docker container, they said, it's gonna be dead easy, they said...
For a single device deployment, I prefer manual set up rather than someone else's idea of the set up.
I see more container based issues with FAH than with normal manual deployment. It seems to defeat the purpose of the container as a concept
FAH Omega tester
Post by calxalot »
It looks like the client in the container is unable to connect to the work server.
HyperWin
Post by HyperWin »
muziqaz wrote: Wed May 21, 2025 5:49 am User docker container, they said, it's gonna be dead easy, they said...
I wish it was easier. It is absolutely impossible to build it from source. When I tried to install deb (on Ubuntu) - it was referencing some unknown packages. Tried many ways to get it working, but failed. I'll post all logs and actions later, if I won't get container to work
Post by muziqaz »
HyperWin wrote: Wed May 21, 2025 6:14 am
It shouldn't be referencing any unknown packages. Ubuntu is the easiest distro to fold on. Containers are left for people with some obscure distro set ups
FAH Omega tester
arisu
Post by arisu »
muziqaz wrote: Wed May 21, 2025 6:20 am
Maybe polkitd-pkla? The latest versions of Ubuntu/Kubuntu do not have that, so the client is impossible to install on them it seems: viewtopic.php?p=369247
