Debian PC with GTX 745 stuck on red clock
jak_2456
Post by jak_2456 »
Hello! I am trying to fold on a Debian 12 PC with a GTX 745, but I have been getting a red clock icon every time I try to fold. I am running the official NVIDIA drivers.
arisu
Re: Debian PC with GTX 745 stuck on red clock
Post by arisu »
Post a copy of your logs.
Most likely there are no available projects for that GPU because it is so old. If your logs have a lot of messages with an error that says "No appropriate assignment", then that would be the reason.
Post by muziqaz »
No assignments available. Which means no work available for that very old GPU
FAH Omega tester
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
Post by dschief »
I had the same issue trying to run GTX760's in Ubuntu_Mate 24.04.
Amazon has ASUS RTX3050's for 200.00 ea { deprecated to 8bits & PCIe Bus power only! no 8 pin connector}
but they will pump out about 900K PPD. Be sure to update to the latest driver
jak_2456
Post by jak_2456 »
I just looked at the logs and I keep getting "no appropriate assignment" as well as an HTTP_SERVICE_UNAVAILABLE. I was able to fold with the same setup on Linux Mint.
Post by muziqaz »
Linux distro has nothing to do with this.
Your GPU is getting old, well, it is very old. Every day there will be less and less work available to it. Especially when nVidia more and more forgets about it
FAH Omega tester
arisu
Post by arisu »
jak_2456 wrote: Mon May 12, 2025 8:38 pm I just looked at the logs and I keep getting "no appropriate assignment" as well as an HTTP_SERVICE_UNAVAILABLE. I was able to fold with the same setup on Linux Mint.
The setup is supported so you will get work units from time to time, but there will be times where there are no available work units small enough for it to complete. You can keep FAH running like you are now. When work is available, you will receive it. You can also turn on CPU folding which has more work available even for older systems.
jak_2456
Post by jak_2456 »
Strange enough, switching to Linux Mint fixed the problem. I still get the red clock with CPU folding, but GPU folding works.
arisu
Post by arisu »
If you get a red clock when CPU folding then that means you've configured less than three cores, which is currently not supported. If you have three or more cores configured for folding then the CPU will always get work.
Switching to Linux Mint wouldn't change anything about the GPU. There was probably a batch of work units that was recently released that supports your GPU, and switching to Linux Mint just coincided with that.
