Nvidia GPU not working (Linux) and software center question
Ncard00
Post by Ncard00 »
How come my RTX 3060 Nvidia GPU doesn't work with Folding@Home on the latest version of Ubuntu?
And when will the folding@Home software be added to the Ubuntu software center?
Re: Nvidia GPU not working (Linux) and software center question
Post by muziqaz »
It will not be added to software centre
FAH Omega tester
arisu
Post by arisu »
Ncard00 wrote: Tue Apr 22, 2025 8:16 am How come my RTX 3060 Nvidia GPU doesn't work with Folding@Home on the latest version of Ubuntu?
You need to give more information than that. What is the output of your logs? Please post the log output. But common reasons it may not work are:
  • You are using Nouveau instead of the official Nvidia driver
  • You do not have CUDA installed (the library that lets your GPU be used for computations instead of just graphics)
  • You are not running FAH as the fah-client user, or the fah-client user is not in the render group
Maybe "sudo ubuntu-drivers install --gpgpu" would help with the first two? And the third should be solved by installing the FAH package with "sudo dpkg -i" which I assume you've already done. But you've got to post the logs to get real help.
Ncard00 wrote: Tue Apr 22, 2025 8:16 am And when will the folding@Home software be added to the Ubuntu software center?
When someone sends a message to the Ubuntu maintainer mailing list and requests to become the maintainer of it (and actually maintains it).
Post by muziqaz »
FAH will not be added to any of the software centres, unless someone actually takes responsibility to maintain it. We had Snap version of FAHclient. It was not done properly and caused crashes which were not present on normal version of fahclient.
It took me months to hunt down the maintainer to remove it from Snap. They said that they no longer maintained it due to real life responsibilities, which is understandable, but does not help FAH in any way
FAH Omega tester
arisu
Post by arisu »
Yes, the "and actually maintains it" is the most important part. :)
It should be easy enough and I would offer to do it myself buuuut I also could disappear so I'm not the best person to do it.
pcwolf
Hardware configuration: Manjaro Linux - AsRock B550 Taichi - Ryzen 5950X - NVidia RTX 4070ti
FAH v8-4.3
Post by pcwolf »
Arch linux package Folding v8.4.9-1 last update December 2024 is available in AUR.
