Every time I enter my email and password the message "Login not found."
Every time I try to reset the password the message "Requesting account reset failed"
I am unable to run the projects within my application account.
Login not found.
Re: Login not found.
You are talking about v8 Web Control?
Did you get a verification email after registering?
Note that your fah passkey is not your password.
Creating a passkey does not create an account.
wnf
- Hardware configuration: i5 6400, 16GB Ram, GTX 1050 Ti, Windows 10
I also tried to create the account and the errors remain the same.
I did not receive an email confirming the account created. Only the forum confirmation email.
Assuming 'yes' it is v8...
Your forum login is not your fah account.
You need to register in Web Control.
If you are not receiving a validate email, please try a different email provider, such as gmail.
This email can be different than any other email you have used for forum, passkey, fah user name.
Do not let a password manager fill in passkey in the Register form.
Please read the guide if you haven't.
https://foldingathome.org/v8-3-client-guide/
