Client is running, but machines page says no folding machines found
malkie
Post by malkie »
Hi there!!
I installed the 8.3.18 client and started it up - I see the icon in the tray, and it says "Folding active". My computer CPU is at 94%, vs 5-15% when I pause the client.
When I go to the page https://v8-3.foldingathome.org/machines it says "No folding machines found. Login or install the Folding@home client software."
On the page https://v8-3.foldingathome.org/account there's an active "Logout" button, indicating (I believe!) that I'm logged in. In any case, I tried logging out and logging in again, and quitting then restarting the client. No change :)
The Client Guide /CONNECTING MACHINES TO YOUR ACCOUNT says I should be able to manually connect machines to my account:
"Manually connecting machines may be necessary if the local machine is already connected to another account. You can change its connection using the link icon in the Account Settings."
However, my Account Settings page has no such icon.
I also checked to see if I have a config.xml associated with F@H, in case I might be able to "... pass the account token using the account-token configuration option in the config.xml configuration file ...", as shown in The Client Guide /MANUALLY CONNECTING MACHINES. However, I can find no such file.
I assume that I must be doing something wrong that is stupidly obvious, but I don't know what. I'm out of ideas.
Any suggestions?
TIA!
Windows 11, version 23H2 with latest updates
Re: Client is running, but machines page says no folding machines found
Post by calxalot »
If you are using Brave browser, you need to use “Shields Down” for the web control site.
malkie
Post by malkie »
calxalot wrote: Tue Jul 16, 2024 6:06 pm If you are using Brave browser, you need to use “Shields Down” for the web control site.
Oh - thanks!!
I should have thought of that!
Post by calxalot »
Not obvious, unfortunately. I’ve known this for months, yet still get surprised occasionally during testing. I asked Joseph to add a note to web control.
malkie
Post by malkie »
calxalot wrote: Tue Jul 16, 2024 7:12 pm Not obvious, unfortunately. I’ve known this for months, yet still get surprised occasionally during testing. I asked Joseph to add a note to web control.
The reason I said I should have thought of that is that I had a problem with another web site that was solved by lowering shields, so it should have occurred to me to check.
Anyway, thanks for the quick reply.
sohang3112
Post by sohang3112 »
@calxalot This problem is occurring to me while using Firefox 137 (latest), not Brave browser (in Fedora 41 linux). Do you know of any solution for how to fix it?
NOTE: I'm using FAHClient 7.6.21, since latest (version 8) doesn't provide RPM.
Post by calxalot »
v8 web control doesn’t support v7.
v7 has its own web control that is localhost only by default and is not secure.
Post by calxalot »
You currently have to build your own rpm.
https://github.com/FoldingAtHome/fah-cl ... ING-RPM.md
g.mark
Post by g.mark »
And for v8.5 on Firefox 146? This is windows 11 and getting the same issue.
I have the client installed, logged in, and I can run the client, but it says no folding machines found.
Post by calxalot »
Look for errors in your browser JavaScript console.
Look for security settings to allow insecure content for foldingathome.org
