Bug with amount of active cores
cgistlaker
Post by cgistlaker »
Processor: Intel 14500 20 cores.
GPU: RTX 4060 8GB
FAH: 8.3.5
Steps to reproduce
1. Start folding with default settings -> 19 of 20 cores are active
2. Change slider to 20 active cores -> 20 of 20 cores are active
3. Change slider back to 19 cores
Actual result
18 of 20 cores are active
Expected result
Screenshots of settings and result
https://ibb.co/QM9kQJC
https://ibb.co/rsXfWNt
Re: Bug with amount of active cores
Post by calxalot »
The GPU took one cpu thread.
18 + 1 = 19, which you allocated to folding.
cgistlaker
But in default settings slider is also on 19, and on default settings all 19 cores are running.
