Unit.runtime = 0 when running a GPU project.
speed2048
Post by speed2048 »
I have observed that the unit.runtime= 0 ( when connected via WebSocket ) when running a GPU Project. This does not occur if I am running a non GPU client.
Re: Unit.runtime = 0 when running a GPU project.
Post by calxalot »
I believe unit runtime is zero until a WU has been successfully completed for that project number.
Some limited history data is stored in client.db, which is used when estimating ppd and eta.
speed2048
Post by speed2048 »
So only GPU projects will exhibit this behavoir?
Post by calxalot »
I wouldn’t think so.
The code using runtime looks generic, not specific to WU or core type.
