v8.3.4 - Not Folding (Solved)
DocJonz
Post by DocJonz »
I had v8.1.18 running previously on Ubuntu 22.04.3, with 2x RTX 3070s, and have just put v8.3.4 on ...
When it starts, no Folding initiates. In the Folding settings page, it detects 8 CPUs, but doesn't do anything with them, and the GPU entries are empty.
The Log below seems to suggest it can see the GPUs, CUDA and OpenCL, so I'm a little stumped :?:
********************** Log Started 2024-02-13T18:07:53Z ***********************
18:07:53:I1:*********************** Folding@home Client ***********************
18:07:53:I1: Version: 8.3.4
18:07:53:I1: Author: Joseph Coffland
18:07:53:I1: Org: foldingathome.org
18:07:53:I1: Copyright: 2023-2024, foldingathome.org
18:07:53:I1: Homepage: https://foldingathome.org/
18:07:53:I1: License: GPL-3.0-or-later
18:07:53:I1: URL: https://beta.foldingathome.org/
18:07:53:I1: Date: Feb 7 2024
18:07:53:I1: Time: 10:49:14
18:07:53:I1: Revision: 432ec23c0cad21b0d889fe6cfabfb694fa6440e3
18:07:53:I1: Branch: master
18:07:53:I1: Compiler: GNU 8.3.0
18:07:53:I1: Options: -faligned-new -std=c++17 -fsigned-char -ffunction-sections
18:07:53:I1: -fdata-sections -O3 -funroll-loops -fno-pie
18:07:53:I1: Platform: linux 4.19.0-26-cloud-amd64
18:07:53:I1: Bits: 64
18:07:53:I1: Mode: Release
18:07:53:I1: Args: --config=/etc/fah-client/config.xml
18:07:53:I1: --log=/var/log/fah-client/log.txt
18:07:53:I1: --log-rotate-dir=/var/log/fah-client/
18:07:53:I1: Config: /etc/fah-client/config.xml
18:07:53:I1:****************************** CBang ******************************
18:07:53:I1: Version: 1.7.2
18:07:53:I1: Org: Cauldron Development LLC
18:07:53:I1: Copyright: Cauldron Development LLC, 2003-2024
18:07:53:I1: Homepage: https://cauldrondevelopment.com/
18:07:53:I1: License: LGPL-2.1-or-later
18:07:53:I1: Time: 10:48:51
18:07:53:I1: Revision: f07e7b0ea470bfa8c73d253164056ce63d3d3bca
18:07:53:I1: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
18:07:53:I1:***************************** System ******************************
18:07:53:I1: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
18:07:53:I1: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:07:53:I1: CPUs: 8
18:07:53:I1: Memory: 7.69GiB
18:07:53:I1:Free Memory: 4.64GiB
18:07:53:I1: OS Version: 5.15
18:07:53:I1:Has Battery: false
18:07:53:I1: On Battery: false
18:07:53:I1: Hostname: Tester
18:07:53:I1: UTC Offset: 0
18:07:53:I1: PID: 5922
18:07:53:I1: CWD: /var/lib/fah-client
18:07:53:I1: Exec: /usr/bin/fah-client
18:07:53:I1:*******************************************************************
18:07:53:I2:
18:07:53:I1:Opening Database
18:07:53:I1:F@H ID = JlfY57OvY9Z3CHog6y6eBm7Kok3dnJJ_FwnX9heeRwE
18:07:53:I3:Loading default group
18:07:53:I3:Loading default resource group
18:07:53:I1:Listening for HTTP on 127.0.0.1:7396
18:07:53:I3:Loaded 0 wus.
18:07:53:I3:gpus = {
18:07:53:I3: "gpu:01:00:00": {
18:07:53:I3: "vendor": 4318,
18:07:53:I3: "type": "nvidia",
18:07:53:I3: "description": "NVIDIA GeForce RTX 3070",
18:07:53:I3: "uuid": "44503597-8502-2cf9-b481-a8a2ebd4dc72",
18:07:53:I3: "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "535.154"},
18:07:53:I3: "cuda": {"platform": 0, "device": 0, "compute": "8.6", "driver": "12.2"},
18:07:53:I3: "device": 9352,
18:07:53:I3: "supported": true
18:07:53:I3: },
18:07:53:I3: "gpu:02:00:00": {
18:07:53:I3: "uuid": "7fffab24-2950-ee62-4967-e413ffdbc3bd",
18:07:53:I3: "opencl": {"platform": 0, "device": 1, "compute": "3.0", "driver": "535.154"},
18:07:53:I3: "cuda": {"platform": 0, "device": 1, "compute": "8.6", "driver": "12.2"},
18:07:53:I3: }
18:07:53:I3:}
Re: v8.3.4 - Not Folding
Post by calxalot »
The GPUs are not listed at all in the group settings view?
jloflin
Post by jloflin »
*********************** Log Started 2024-02-13T20:05:42Z ***********************
20:05:42:I1:*********************** Folding@home Client ***********************
20:05:42:I1: Version: 8.3.4
20:05:42:I1: Author: Joseph Coffland
20:05:42:I1: Org: foldingathome.org
20:05:42:I1: Copyright: 2023-2024, foldingathome.org
20:05:42:I1: Homepage: https://foldingathome.org/
20:05:42:I1: License: GPL-3.0-or-later
20:05:42:I1: URL: https://beta.foldingathome.org/
20:05:42:I1: Date: Feb 7 2024
20:05:42:I1: Time: 10:49:14
20:05:42:I1: Revision: 432ec23c0cad21b0d889fe6cfabfb694fa6440e3
20:05:42:I1: Branch: master
20:05:42:I1: Compiler: GNU 8.3.0
20:05:42:I1: Options: -faligned-new -std=c++17 -fsigned-char -ffunction-sections
20:05:42:I1: -fdata-sections -O3 -funroll-loops -fno-pie
20:05:42:I1: Platform: linux 4.19.0-26-cloud-amd64
20:05:42:I1: Bits: 64
20:05:42:I1: Mode: Release
20:05:42:I1: Args: --config=/etc/fah-client/config.xml
20:05:42:I1: --log=/var/log/fah-client/log.txt
20:05:42:I1: --log-rotate-dir=/var/log/fah-client/
20:05:42:I1: Config: /etc/fah-client/config.xml
20:05:42:I1:****************************** CBang ******************************
20:05:42:I1: Version: 1.7.2
20:05:42:I1: Org: Cauldron Development LLC
20:05:42:I1: Copyright: Cauldron Development LLC, 2003-2024
20:05:42:I1: Homepage: https://cauldrondevelopment.com/
20:05:42:I1: License: LGPL-2.1-or-later
20:05:42:I1: Time: 10:48:51
20:05:42:I1: Revision: f07e7b0ea470bfa8c73d253164056ce63d3d3bca
20:05:42:I1: -fdata-sections -O3 -funroll-loops -fno-pie -fPIC
20:05:42:I1:***************************** System ******************************
20:05:42:I1: CPU: AMD Ryzen 9 3900X 12-Core Processor
20:05:42:I1: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:05:42:I1: CPUs: 24
20:05:42:I1: Memory: 31.26GiB
20:05:42:I1:Free Memory: 30.49GiB
20:05:42:I1: OS Version: 5.15
20:05:42:I1:Has Battery: false
20:05:42:I1: On Battery: false
20:05:42:I1: Hostname:
20:05:42:I1: UTC Offset: -7
20:05:42:I1: PID: 1231
20:05:42:I1: CWD: /var/lib/fah-client
20:05:42:I1: Exec: /usr/bin/fah-client
20:05:42:I1:*******************************************************************
20:05:42:I2:
20:05:42:I1:Opening Database
20:05:42:I1:F@H ID = gayDOPRI3uEMFCt0-pv_m0ULLZjTaBtQ1ljsczpTD60
20:05:42:I3:Loading default group
20:05:42:I3:Loading default resource group
20:05:42:I1:Listening for HTTP on 127.0.0.1:7396
20:05:42:I3:WU71640:Loading work unit 71640 with ID w3L1YQ0Qo_ZRwJpi1lx5h4z3OgRFOtaVRygL8ZdCcIk
20:05:42:I3:WU71654:Loading work unit 71654 with ID yt8iurve23WkEvnFkAj38QBE65EEbU27qs36ZLWchOE
20:05:42:I3:Loaded 2 wus.
20:05:42:I3:gpus = {
20:05:42:I3: "gpu:14:00:00": {
20:05:42:I3: "vendor": 4318,
20:05:42:I3: "type": "nvidia",
20:05:42:I3: "description": "NVIDIA GeForce RTX 2060",
20:05:42:I3: "uuid": "26e65209-559c-d43c-6d1e-be980f9248f3",
20:05:42:I3: "opencl": {"platform": 0, "device": 0, "compute": "3.0", "driver": "545.29"},
20:05:42:I3: "cuda": {"platform": 0, "device": 0, "compute": "7.5", "driver": "12.3"},
20:05:42:I3: "device": 7944,
20:05:42:I3: "supported": true
20:05:42:I3: }
20:05:42:I3:}
I have the same problem with V.8.3.4 on Linux Mint 21.3. I was running V8.1.18 successfully, I downloaded the V8.3.4 deb, paused folding and installed the new client. When I went to the FAH client tab in my browser to restart the client, I had to go to the settings page and re-enter my name, team and passkey. I was able to save that successfully, but I am unable to save the number of cpu's I want to use, and the gpu line is blank. When I set the cpu number to 22 and hit save, I see 22 cpu's on the main page, but if I return to the settings page, the cpu line is at 12.
The main folding page on the tab shows downloading for both the cpu and gpu lines for the last few hours but there is no progress. The Pause Folding button does not work. The etc/fah-client/config.xml file content is:
<config/>
and nothing else.
I have screenshots of the Main FAH page and the Settings page from my browser, but I don't know how to upload them to here. I, too, am stumped.
Post by calxalot »
The Web Control url for v8.3.4 is
Post by calxalot »
The old url will probably redirect in the future.
I emailed the lead developer just now.
jloflin wrote: Wed Feb 14, 2024 1:53 am ... The etc/fah-client/config.xml file content is:
<config/>
and nothing else.
The v8 client only reads an existing config.xml file if one is present from an install of a prior v7 client. It does not store its settings in that file but a client.db file. Not sure what is going on with your install otherwise, I am still getting used to the v8 client and so far have only used it with macOS systems for CPU folding.
Post by calxalot »
They are using the old web control url.
Post by calxalot »
We’re in a weird released to beta but not released state while documentation is being done.
The old url not redirecting is an oversight, I think.
Post by calxalot »
Folks using v8.1.18 are supposed to be redirected to
https://v8-1.foldingathome.org
jloflin
Post by jloflin »
calxalot wrote: Wed Feb 14, 2024 2:00 am The Web Control url for v8.3.4 is
That did it. Thank you!
DocJonz
Re: v8.3.4 - Not Folding (Solved)
Post by DocJonz »
Sorted using this, thanks.
