Localhost connect problem
Jonechaos
Post by Jonechaos »
A newly configured workstation could not connect to localhost(127.0.0.1:36330). The connection status changed to online after connecting, but immediately changed back to connecting. I tried everything I knew, but still doesn't work. I am desperate to get help.
My system:
CPUS:Two EPYC 7452 32Core Processor ,2 way cpus in system
GPU: RTX A4000
Motherboard:Supermirco H12DSi-N6
OS:Windows 10 workstation
Jonechaos
Re: Localhost connect problem
Post by Jonechaos »
By the way, the log shows that:
ERROR:Receive error:997: íà I/O í(the garbled text cannot be type out here)
Jonechaos
Post by Jonechaos »
*********************** Log Started 2023-11-09T08:56:07Z ***********************
08:56:07:******************************* libFAH ********************************
08:56:07:           Date: Oct 20 2020
08:56:07:           Time: 13:36:55
08:56:07:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
08:56:07:         Branch: master
08:56:07:       Compiler: Visual C++ 2015
08:56:07:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
08:56:07:       Platform: win32 10
08:56:07:           Bits: 32
08:56:07:           Mode: Release
08:56:07:****************************** FAHClient ******************************
08:56:07:        Version: 7.6.21
08:56:07:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:56:07:      Copyright: 2020 foldingathome.org
08:56:07:       Homepage: https://foldingathome.org/
08:56:07:           Time: 13:41:04
08:56:07:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
08:56:07:           Bits: 32
08:56:07:           Args: --open-web-control
08:56:07:         Config: C:\ProgramData\FAHClient\config.xml
08:56:07:******************************** CBang ********************************
08:56:07:           Time: 11:36:18
08:56:07:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
08:56:07:           Bits: 32
08:56:07:******************************* System ********************************
08:56:07:            CPU: AMD EPYC 7452 32-Core Processor
08:56:07:         CPU ID: AuthenticAMD Family 23 Model 49 Stepping 0
08:56:07:           CPUs: 32
08:56:07:         Memory: 127.87GiB
08:56:07:    Free Memory: 123.30GiB
08:56:07:        Threads: WINDOWS_THREADS
08:56:07:     OS Version: 6.2
08:56:07:    Has Battery: false
08:56:07:     On Battery: false
08:56:07:     UTC Offset: 8
08:56:07:            PID: 5408
08:56:07:            CWD: C:\ProgramData\FAHClient
08:56:07:  Win32 Service: false
08:56:07:             OS: Windows 10 Enterprise
08:56:07:        OS Arch: AMD64
08:56:07:           GPUs: 1
08:56:07:          GPU 0: Bus:65 Slot:0 Func:0 NVIDIA:8 GA104GL [RTX A4000]
08:56:07:  CUDA Device 0: Platform:0 Device:0 Bus:65 Slot:0 Compute:8.6 Driver:12.0
08:56:07:OpenCL Device 0: Platform:0 Device:0 Bus:65 Slot:0 Compute:3.0 Driver:528.95
08:56:07:***********************************************************************
08:56:07:<config>
08:56:07:  <!-- Folding Slots -->
08:56:07:  <slot id='0' type='CPU'>
08:56:07:    <paused v='true'/>
08:56:07:  </slot>
08:56:07:  <slot id='1' type='GPU'>
08:56:07:    <pci-bus v='65'/>
08:56:07:    <pci-slot v='0'/>
08:56:07:  </slot>
08:56:07:</config>
08:56:07:Trying to access database...
08:56:07:Successfully acquired database lock
08:56:07:FS00:Initialized folding slot 00: cpu:30
08:56:07:FS01:Initialized folding slot 01: gpu:65:0 GA104GL [RTX A4000]
08:56:24:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:06:51:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:06:54:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:07:49:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:07:50:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:08:00:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:08:11:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:08:12:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:08:20:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:08:24:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:08:45:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:08:51:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:08:58:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:09:05:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:09:07:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:09:12:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:09:19:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:09:20:Saving configuration to config.xml
09:09:20:<config>
09:09:20:  <!-- Network -->
09:09:20:  <proxy v=':8080'/>
09:09:20:  <proxy-enable v='true'/>
09:09:20:
09:09:20:  <!-- Folding Slots -->
09:09:20:  <slot id='0' type='CPU'>
09:09:20:    <paused v='true'/>
09:09:20:  </slot>
09:09:20:  <slot id='1' type='GPU'>
09:09:20:    <pci-bus v='65'/>
09:09:20:    <pci-slot v='0'/>
09:09:20:  </slot>
09:09:20:</config>
09:09:22:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:09:39:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:09:49:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:09:57:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:10:02:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:10:05:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:10:18:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:10:45:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:10:55:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:00:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:01:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:08:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:13:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:17:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:21:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:26:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:38:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:44:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:11:46:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:02:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:13:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:20:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:23:Saving configuration to config.xml
09:12:23:<config>
09:12:23:  <!-- Network -->
09:12:23:  <proxy v=':8080'/>
09:12:23:  <proxy-enable v='true'/>
09:12:23:
09:12:23:  <!-- User Information -->
09:12:23:  <passkey v='*****'/>
09:12:23:  <team v='3213'/>
09:12:23:  <user v='Wolf'/>
09:12:23:
09:12:23:  <!-- Folding Slots -->
09:12:23:  <slot id='0' type='CPU'>
09:12:23:    <paused v='true'/>
09:12:23:  </slot>
09:12:23:  <slot id='1' type='GPU'>
09:12:23:    <pci-bus v='65'/>
09:12:23:    <pci-slot v='0'/>
09:12:23:  </slot>
09:12:23:</config>
09:12:24:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:26:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:45:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:47:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:56:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:12:57:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:13:11:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:13:17:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:13:19:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:13:22:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:13:36:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:13:37:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:13:42:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:13:48:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:04:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:06:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:11:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:26:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:34:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:37:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:43:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:49:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:55:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:14:57:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:15:05:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:15:05:FS00:Unpaused
09:15:05:FS01:Unpaused
09:15:06:WU00:FS00:Connecting to :8080
09:15:06:WU01:FS01:Connecting to :8080
09:15:08:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:08:WU00:FS00:Connecting to :8080
09:15:09:WARNING:WU01:FS01:Failed to get ID from 'assign1.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:09:WU01:FS01:Connecting to :8080
09:15:11:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:15:11:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:11:WU00:FS00:Connecting to :8080
09:15:11:WARNING:WU01:FS01:Failed to get ID from 'assign2.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:11:WU01:FS01:Connecting to :8080
09:15:14:WARNING:WU01:FS01:Failed to get ID from 'assign3.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:14:WU01:FS01:Connecting to :8080
09:15:14:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:14:WU00:FS00:Connecting to :8080
09:15:16:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:16:ERROR:WU00:FS00:Exception: Could not get an assignment ID
09:15:16:WARNING:WU01:FS01:Failed to get ID from 'assign4.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:16:ERROR:WU01:FS01:Exception: Could not get an assignment ID
09:15:17:WU00:FS00:Connecting to :8080
09:15:17:WU01:FS01:Connecting to :8080
09:15:17:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:15:19:WARNING:WU01:FS01:Failed to get ID from 'assign1.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:19:WU01:FS01:Connecting to :8080
09:15:19:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:19:WU00:FS00:Connecting to :8080
09:15:22:WARNING:WU01:FS01:Failed to get ID from 'assign2.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:22:WU01:FS01:Connecting to :8080
09:15:22:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:22:WU00:FS00:Connecting to :8080
09:15:25:WARNING:WU01:FS01:Failed to get ID from 'assign3.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:25:WU01:FS01:Connecting to :8080
09:15:25:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:25:WU00:FS00:Connecting to :8080
09:15:26:Saving configuration to config.xml
09:15:26:<config>
09:15:26:  <!-- Folding Core -->
09:15:26:  <checkpoint v='10'/>
09:15:26:
09:15:26:  <!-- Network -->
09:15:26:  <proxy v=':8080'/>
09:15:26:  <proxy-enable v='true'/>
09:15:26:
09:15:26:  <!-- Slot Control -->
09:15:26:  <power v='full'/>
09:15:26:
09:15:26:  <!-- User Information -->
09:15:26:  <passkey v='*****'/>
09:15:26:  <team v='3213'/>
09:15:26:  <user v='Wolf'/>
09:15:26:
09:15:26:  <!-- Folding Slots -->
09:15:26:  <slot id='0' type='CPU'/>
09:15:26:  <slot id='1' type='GPU'>
09:15:26:    <pci-bus v='65'/>
09:15:26:    <pci-slot v='0'/>
09:15:26:  </slot>
09:15:26:</config>
09:15:27:WARNING:WU01:FS01:Failed to get ID from 'assign4.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:27:ERROR:WU01:FS01:Exception: Could not get an assignment ID
09:15:28:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:15:28:ERROR:WU00:FS00:Exception: Could not get an assignment ID
09:16:02:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:16:17:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:16:17:WU00:FS00:Connecting to :8080
09:16:17:WU01:FS01:Connecting to :8080
09:16:19:WARNING:WU01:FS01:Failed to get ID from 'assign1.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:16:19:WU01:FS01:Connecting to :8080
09:16:19:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:16:19:WU00:FS00:Connecting to :8080
09:16:21:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:16:22:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:16:22:WU00:FS00:Connecting to :8080
09:16:22:WARNING:WU01:FS01:Failed to get ID from 'assign2.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:16:22:WU01:FS01:Connecting to :8080
09:16:25:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:16:25:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:16:25:WU00:FS00:Connecting to :8080
09:16:25:WARNING:WU01:FS01:Failed to get ID from 'assign3.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:16:25:WU01:FS01:Connecting to :8080
09:16:28:WARNING:WU01:FS01:Failed to get ID from 'assign4.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:16:28:ERROR:WU01:FS01:Exception: Could not get an assignment ID
09:16:28:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:16:28:ERROR:WU00:FS00:Exception: Could not get an assignment ID
09:17:11:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:17:20:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:17:22:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:17:28:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:17:32:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:17:54:WU00:FS00:Connecting to :8080
09:17:55:WU01:FS01:Connecting to :8080
09:17:55:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:17:57:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:17:57:WARNING:WU00:FS00:Failed to get ID from 'assign1.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:17:57:WU00:FS00:Connecting to :8080
09:17:57:WARNING:WU01:FS01:Failed to get ID from 'assign1.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:17:57:WU01:FS01:Connecting to :8080
09:17:59:WARNING:WU00:FS00:Failed to get ID from 'assign2.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:17:59:WU00:FS00:Connecting to :8080
09:18:00:WARNING:WU01:FS01:Failed to get ID from 'assign2.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:18:00:WU01:FS01:Connecting to :8080
09:18:01:ERROR:Receive error: 997: Íà I/O Í\(ÛL-
09:18:02:WARNING:WU00:FS00:Failed to get ID from 'assign3.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:18:02:WU00:FS00:Connecting to :8080
09:18:02:WARNING:WU01:FS01:Failed to get ID from 'assign3.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:18:02:WU01:FS01:Connecting to :8080
09:18:04:WARNING:WU00:FS00:Failed to get ID from 'assign4.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:18:04:ERROR:WU00:FS00:Exception: Could not get an assignment ID
09:18:05:WARNING:WU01:FS01:Failed to get ID from 'assign4.foldingathome.org:80': Failed to connect to :8080: 1Žî¡—:ïÒÝàÕÞ¥
09:18:05:ERROR:WU01:FS01:Exception: Could not get an assignment ID
Reason: added code tags to log
bikeaddict
Post by bikeaddict »
Someone else who previously had this error 997 and an AsRock X470 motherboard reported that a BIOS update fixed the problem.
If you don't have the latest AMD chipset drivers, you could also try that.
Hope you mean the OS is Windows 10 Pro for Workstations in order to support multiple sockets and that many threads.
Since CPU work units usually support at most 32 threads, you will need to create four folding slots of 32 threads each to get the most out of these CPUs.
Jonechaos
Post by Jonechaos »
bikeaddict wrote: Thu Nov 09, 2023 4:30 pm Someone else who previously had this error 997 and an AsRock X470 motherboard reported that a BIOS update fixed the problem.
I already tried the latest AMD chip driver, but it`s useless.And yes my OS is Windows 10 Pro for Workstations.I will try update my motherboard BIOS and see it works or not.
Jonechaos
Post by Jonechaos »
I tried BIOS update and nothing change. It still can not connect to localhost(127.0.0.1:36330).The connection status changed to online after connecting, but immediately changed back to connecting.Any other way?
bikeaddict
Could see if the problem also happens under Linux. That might show if it's a Windows problem or a hardware problem.
Performance may be better on Linux than Windows anyway. At least on GPU work units, Linux performance is better most of the time. The LAR Systems database doesn't split CPU stats by OS, unfortunately.
Why do you have this in your settings ?
Disable proxy or use a valid address for the proxy setting ...
Jonechaos
Post by Jonechaos »
toTOW wrote: Sat Nov 11, 2023 8:09 pm Why do you have this in your settings ?
I don`t konw why do I have this in my settings.I check my system and its already disable proxy. I`m not a expert for code or software, can you tell me how disable proxy in FAH ?
bikeaddict
In FAHControl on the Proxy tab, uncheck "Enable proxy configuration"
https://foldingathome.org/support/faq/i ... de/?lng=en
If it's not checked and the proxy-enable v='true' line is still showing in the log output, it may be confused. You can try checking it, saving, then go back and uncheck and save again. The last resort is to carefully edit the file in Notepad and delete those two proxy lines. The service may have to be restarted or a reboot may be required for the change to take effect. Or there's even deleting the file or reinstalling F@H and generating a new one by configuring again.
The line that should be removed from config.xml is this one:
This line in the configuration is normal looking at a file from my own system without proxies enabled:
 <proxy v=':8080'/>
Jonechaos
Post by Jonechaos »
bikeaddict wrote: Mon Nov 13, 2023 2:18 pm In FAHControl on the Proxy tab, uncheck "Enable proxy configuration"
I tried but its no use. And I tride Joe_H`s post too.My config.xml looks like that :
<config>
<!--Network-->
<proxy v='False'/>
<!--Slot Control-->
<pause-on battery v='false'/>
<!--Folding Slots-->
<slot id='0'type='CPU'>
  <idle v='true'/>
  <paused v='true'/>
  <pci-bus v='65'/>
  <pci-slot v='0'/>
 </solt>
</config>
bikeaddict
From posts by others with the "Receive error: 997" problem, it may be caused by running FAHControl and might not be a real problem that prevents folding.
The log file you posted showed it attempting to get a connection to the assign1 and assign2 servers, but was failing due to the proxy on port 8080 being enabled. What does the log show now with the new config file? If it's still trying to connect to port 8080, a reboot or client reinstall may be needed.
Post by calxalot »
Proxy option should be deleted
Battery option name is pause-on-battery
bollix47
Post by bollix47 »
</solt> is a typo
Should be
</slot>
