missing points from all projects 19600 since yesterday
mattifolder
Post by mattifolder »
Since yesterday my comuter folded 9 projects 19600 without errors. Also all were uploaded to server without errors. They are not in EOC database. The point summary at my FAH page (https://stats.foldingathome.org/donor/id/15961) ist actually the same as from EOC (https://folding.extremeoverclocking.com ... =&u=371390), so that this can't be only a failure in EOC database.
The upload was done to server 160.45.68.201. Here one section from log file for successfully upload:
16:08:54:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:08:54:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:19600 run:334 clone:0 gen:787 core:0x22 unit:0x000000000000031300004c900000014e
16:08:54:WU01:FS00:Uploading 1.97MiB to 160.45.68.201
16:08:54:WU01:FS00:Connecting to 160.45.68.201:8080
16:08:54:WU00:FS00:Downloading 1.63MiB
16:08:54:WU00:FS00:Download complete
16:08:54:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:19600 run:27 clone:0 gen:754 core:0x22 unit:0x00000000000002f200004c900000001b
16:08:54:WU00:FS00:Starting
16:08:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 15760 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100 -forceasm
16:08:54:WU00:FS00:Started FahCore on PID 6768
16:08:54:WU00:FS00:Core PID:8908
16:08:54:WU00:FS00:FahCore 0x22 started
16:08:55:WU00:FS00:0x22:*********************** Log Started 2023-10-12T16:08:54Z ***********************
16:08:55:WU01:FS00:Upload complete
TheWolf
Re: missing points from all projects 19600 since yesterday
Post by TheWolf »
I seeing the same, very low workunit counts as well. I have six GPU's all fairly high end that has been doing on avg. of 13 to 15 million PPD.
For the past 3 days that unit count has dropped from 150ish to 50 to 60 range with a points drop of around 10m PPD.
Something is very wrong with the points system and unit count.
TheWolf
Post by TheWolf »
To add to this I get alot of WU's from server 160.45.68.201 that only take around 35 mins. to complete and one of the reasions my WU count is so high. With all my cards ranging from Titan Xp, Tesla P100, Tesla P40, RTX 3060 12GB, Titan X "Pascal" and Tesla M40 <= 45 mins.
All but one are working these 19600 WU's so my WU count shouldn't be only 9 for the past 12 hours.
I have sent a message to the researcher running 19600 and the stats database manager.
TheWolf
Post by TheWolf »
Thanks Joe! The 3060 is the only card not running these for some reasion. It gets project 18725 over and over and takes around 4:30 to complete.
I do get other projects on all the other cards, but they are far and few between. I did get one other project that was different I saw today on either
the Titan X or P100 but I didn't catch the project number and I do see a extra WU at 3pm I'm sure it was that one.
mattifolder
Joe_H wrote: Thu Oct 12, 2023 8:18 pm I have sent a message to the researcher running 19600 and the stats database manager.
Thank you. :)
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Good eye Mattifolder!
I had a couple as well, starting on the 11th. All prior to that seem to have been credited.
Fold them if you get them!
TheWolf
Post by TheWolf »
I just set some to finish until this is fixed. No since wasting power the power bill is 400+ esch month as is.
Others I chaned the config to see if they pick up something different. If not I will shut those down too.
Hope to see this fixed soon other wise I will just stop folding.
Good luck with a fix.
mattifolder
There are also points for a 19506 project missing.
TheWolf
Post by TheWolf »
Good morning, still seeing the same thing lots of work sent back without getting any points.
On a good note its my BD turned 68 and on one rig I picked up a 19504 project, but it from server 201
so I do not expect to aee any points for it either. Server 201 has to be super backlogged after four days
of not giving donors any updates for their hard work?
Zac67
No credit from project 19600
Post by Zac67 »
Merged with existing topic - j
Today I've had the second WU (at least) from that project without getting any credit:
06:54:05:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:54:05:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:19600 run:880 clone:0 gen:565 core:0x22 unit:0x000000000000023500004c9000000370
06:54:05:WU00:FS01:Uploading 2.61MiB to 160.45.68.201
06:54:05:WU00:FS01:Connecting to 160.45.68.201:8080
06:54:06:WU00:FS01:Upload complete
06:54:06:WU00:FS01:Server responded WORK_ACK (400)
06:54:06:WU00:FS01:Final credit estimate, 55916.00 points
fz4z
Post by fz4z »
I have access to a different graph that shows the total points and hours being logged by the stats database, that does not show such a dip. I suspect there is also a problem with generating the flat files that EOC downloads to use for its stats display.
Zac67
Post by Zac67 »
My first missing credit WU from that project that's still in the logs is from 4 Oct, so this issue isn't really new. I'm blackholing 160.45.68.201 until this is sorted out.
