I got this on a Linux 5.02 client some weeks ago. It shows unknown points in FAHmon. It has taken almost 3 hours per percent to do. It appears to need "Core required: FahCore_a0.exe" I wonder if it is some fluke.....but do not want to dump it as it was assigned to me. What are the points and deadline on this unit? FAHmon gets nothing on it.
thanks
Project: 783 (Run 6, Clone 91, Gen 0)
Re: Project: 783 (Run 6, Clone 91, Gen 0)
It's not displayed on the psummary
We'll have to wait for an answer from Pande Group (the associated server might be down for maintenance ...).
Thanks for your post. I'll figure out the researcher in charge of this project and have them look into it.
Relly
Relly
VijayPande
- Pande Group Member
Which server did you get it from? Could you post some logs?
[15:08:59] ... Done.
[15:08:59] - Shutting down core
[15:08:59]
[15:08:59] Folding@home Core Shutdown: FINISHED_UNIT
[15:08:59] CoreStatus = 64 (100)
[15:08:59] Sending work to server
[15:08:59] + Attempting to send results
[15:09:04] + Results successfully sent
[15:09:04] Thank you for your contribution to Folding@Home.
[15:09:04] + Number of Units Completed: 535
[15:09:04] - Preparing to get new work unit...
[15:09:04] + Attempting to get work packet
[15:09:04] - Connecting to assignment server
[15:09:05] - Successful: assigned to (130.49.240.81).
[15:09:05] + News From Folding@Home: Welcome to Folding@Home
[15:09:05] Loaded queue successfully.
[15:09:05] + Could not connect to Work Server
[15:09:05] - Error: Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[15:09:14] + Attempting to get work packet
[15:09:14] - Connecting to assignment server
[15:09:14] - Successful: assigned to (130.49.240.81).
[15:09:14] + News From Folding@Home: Welcome to Folding@Home
[15:09:15] Loaded queue successfully.
[15:09:15] + Could not connect to Work Server
[15:09:15] - Error: Attempt #2 to get work failed, and no other work to do.
[15:09:39] + Attempting to get work packet
[15:09:39] - Connecting to assignment server
[15:09:41] - Successful: assigned to (130.49.240.81).
[15:09:41] + News From Folding@Home: Welcome to Folding@Home
[15:09:41] Loaded queue successfully.
[15:09:43] + Could not connect to Work Server
[15:09:43] - Error: Attempt #3 to get work failed, and no other work to do.
[15:10:09] + Attempting to get work packet
[15:10:09] - Connecting to assignment server
[15:10:10] - Successful: assigned to (130.49.240.81).
[15:10:10] + News From Folding@Home: Welcome to Folding@Home
[15:10:10] Loaded queue successfully.
[15:10:10] + Could not connect to Work Server
[15:10:10] - Error: Attempt #4 to get work failed, and no other work to do.
[15:10:57] + Attempting to get work packet
[15:10:57] - Connecting to assignment server
[15:10:58] - Successful: assigned to (130.49.240.81).
[15:10:58] + News From Folding@Home: Welcome to Folding@Home
[15:10:58] Loaded queue successfully.
[15:10:58] + Could not connect to Work Server
[15:10:58] - Error: Attempt #5 to get work failed, and no other work to do.
[15:12:20] + Attempting to get work packet
[15:12:20] - Connecting to assignment server
[15:12:21] - Successful: assigned to (130.49.240.81).
[15:12:21] + News From Folding@Home: Welcome to Folding@Home
[15:12:21] Loaded queue successfully.
[15:12:21] + Could not connect to Work Server
[15:12:21] - Error: Attempt #6 to get work failed, and no other work to do.
[15:15:04] + Attempting to get work packet
[15:15:04] - Connecting to assignment server
[15:15:04] - Successful: assigned to (171.64.122.88).
[15:15:04] + News From Folding@Home: Welcome to Folding@Home
[15:15:05] Loaded queue successfully.
[15:15:05] + Could not connect to Work Server
[15:15:05] - Error: Attempt #7 to get work failed, and no other work to do.
[15:20:29] + Attempting to get work packet
[15:20:29] - Connecting to assignment server
[15:20:30] - Successful: assigned to (171.64.122.88).
[15:20:30] + News From Folding@Home: Welcome to Folding@Home
[15:20:30] Loaded queue successfully.
[15:20:30] + Could not connect to Work Server
[15:20:30] - Error: Attempt #8 to get work failed, and no other work to do.
[15:31:20] + Attempting to get work packet
[15:31:20] - Connecting to assignment server
[15:31:20] - Successful: assigned to (130.49.240.81).
[15:31:20] + News From Folding@Home: Welcome to Folding@Home
[15:31:20] Loaded queue successfully.
[15:31:20] + Could not connect to Work Server
[15:31:20] - Error: Attempt #9 to get work failed, and no other work to do.
[15:52:54] + Attempting to get work packet
[15:52:54] - Connecting to assignment server
[15:52:54] - Successful: assigned to (171.64.122.83).
[15:52:54] + News From Folding@Home: Welcome to Folding@Home
[15:52:54] Loaded queue successfully.
[15:52:54] - Couldn't send HTTP request to server
[15:52:54] (Got status 503)
[15:52:54] + Could not connect to Work Server
[15:52:54] - Error: Attempt #10 to get work failed, and no other work to do.
[16:35:45] + Attempting to get work packet
[16:35:45] - Connecting to assignment server
[16:35:45] - Successful: assigned to (171.64.122.138).
[16:35:45] + News From Folding@Home: Welcome to Folding@Home
[16:35:45] Loaded queue successfully.
[16:35:49] + Closed connections
[16:35:49]
[16:35:49] + Processing work unit
[16:35:49] Core required: FahCore_a0.exe
[16:35:49] Core found.
[16:35:49] Working on Unit 09 [July 4 16:35:49]
[16:35:49] + Working ...
[16:35:49]
[16:35:49] *------------------------------*
[16:35:49] Folding@Home Gromacs 3.3 Core
[16:35:49] Version 1.92 (April 17. 2007)
[16:35:49]
[16:35:49] Preparing to commence simulation
[16:35:49] - Looking at optimizations...
[16:35:49] - Created dyn
[16:35:49] - Files status OK
[16:35:50] - Expanded 961100 -> 6252409 (decompressed 650.5 percent)
[16:35:50] - Starting from initial work packet
[16:35:50]
[16:35:50] Project: 783 (Run 6, Clone 91, Gen 0)
[16:35:50]
[16:35:50] Assembly optimizations on if available.
[16:35:50] Entering M.D.
[16:35:57] Protein: Mini chaperonin
[16:35:57] Writing local files
[16:35:57] Extra 3DNow boost OK.
[16:35:57] Extra SSE boost OK.
[16:35:58] Writing local files
[16:35:58] Completed 0 out of 500000 steps (0 percent)
[18:06:49] Writing local files
[18:06:49] Completed 5000 out of 500000 steps (1 percent)
[19:34:18] Writing local files
[19:34:19] Completed 10000 out of 500000 steps (2 percent)
[21:02:15] Writing local files
[21:02:15] Completed 15000 out of 500000 steps (3 percent)
[22:29:58] Writing local filesthanks
Thanks for reporting this. I will alert Lillian about this issue.
Paula.
Paula.
Baowoulf
- Hardware configuration: Pentium 4 2.8 GHz, 512MB DDR Ram, 128MB Radeon 9800, Creative Soundblaster Audigy 4 Pro
iwegian just use the code and /code in brackets [] like you would do if you were going to display a picture hosted on an online website like imageshack or photobucket. I think that's what you wanted to know.
It will end up looking like this Re: Project: 783 (Run 6, Clone 91, Gen 0)
Looks like it did not help much...ppetrone wrote:Thanks for reporting this. I will alert Lillian about this issue.
[11:01:46] Folding@Home Gromacs 3.3 Core
[11:01:46] Version 1.92 (April 17. 2007)
[11:01:46]
[11:01:46] Preparing to commence simulation
[11:01:46] - Looking at optimizations...
[11:01:46] - Files status OK
[11:01:47] - Expanded 961050 -> 6252409 (decompressed 650.5 percent)
[11:01:48]
[11:01:48] Project: 784 (Run 8, Clone 38, Gen 0)
[11:01:48]
[11:01:48] Assembly optimizations on if available.
[11:01:48] Entering M.D.
[11:02:09] (Starting from checkpoint)
[11:02:09] Protein: Mini chaperonin
[11:02:09] Writing local files
[11:02:09] Completed 485527 out of 500000 steps (97%)
[11:02:10] Extra 3DNow boost OK.
[11:02:10] Extra SSE boost OK.
[13:05:52] Writing local files
[13:05:53] Completed 490000 out of 500000 steps (98 percent)
[14:47:28] Writing local files
[14:47:28] Completed 495000 out of 500000 steps (99 percent)
[16:28:28] Writing local files
[16:28:28] Completed 500000 out of 500000 steps (100 percent)
[16:28:28] Writing final coordinates.
[16:28:29] Past main M.D. loop
[16:29:29]
[16:29:29] Finished Work Unit:
[16:29:29] - Reading up to 1043160 from "work/wudata_04.arc": Read 1043160
[16:29:29] - Reading up to 3548132 from "work/wudata_04.xtc": Read 3548132
[16:29:29] goefile size: 0
[16:29:29] logfile size: 541599
[16:29:29] Leaving Run
[16:29:31] - Writing 5149523 bytes of core data to disk...
[16:29:34] Done: 5149011 -> 4517367 (compressed to 87.7 percent)
[16:29:34] ... Done.
[16:29:36] - Shutting down core
[16:29:36]
[16:29:36] Folding@home Core Shutdown: FINISHED_UNIT
[16:29:37] CoreStatus = 64 (100)
[16:29:37] Sending work to server
[16:29:37] + Attempting to send results
[16:32:46] - Couldn't send HTTP request to server
[16:32:46] + Could not connect to Work Server (results)
[16:32:46] (171.64.122.138:8080)
[16:32:46] - Error: Could not transmit unit 04 (completed July 26) to work server.
[16:32:46] Keeping unit 04 in queue.
[16:32:46] + Attempting to send results
[16:35:55] - Couldn't send HTTP request to server
[16:35:55] + Could not connect to Work Server (results)
[16:35:55] (171.64.122.138:8080)
[16:35:55] - Error: Could not transmit unit 04 (completed July 26) to work server.171.64.122.138 VSP71 - full DOWN
Any hope in foreseeable future ?
yours,
endrik
*Bookworms will rule the world
(after we finish the background reading).
endrik
