Suggestion: add option to pause one slot only
Peter_Hucker
Hardware configuration: Ryzen 9 3900XT: 24 cores, 128GB RAM, 1TB NVME, 4TB HDD, R9 Nano (Fiji) GPU.
Ryzen 9 3900X: 24 cores, 64GB RAM, 250GB NVME.
Xeon X5650 dual CPU server: 24 cores, 64GB RAM, 250GB NVME, R9 290(Hawaii) GPU.
Xeon X5650 dual CPU server: 24 cores, 64GB RAM, 250GB NVME.
I3-6100: 4 cores, 32GB RAM, 250GB NVME, 2 of R9 2980X (Tahiti) GPUs.
5 other smaller computers.
Post by Peter_Hucker »
Currently I can only pause an entire computer in the web control. People may want to pause GPU work only, to play a game etc. Or only pause the GPU the game will be played on in a multiple GPU system.
Re: Suggestion: add option to pause one slot only
Post by calxalot »
There are no slots in v8.
You can use Resource Groups.
viewtopic.php?t=39101
Peter_Hucker
I've used the wrong terminology (you changed the name for no reason), but my point still stands. There is a CPU task and 2 GPU tasks running on a computer for example. I want to pause just one GPU task.
Post by calxalot »
It’s not just terminology. Slots and Resource Groups are not the same.
Anyway, what you want can be done with Resource Groups. Please try them.
Post by calxalot »
If what you’re asking for is to be able to pause individual Work Units in a group, please feel free to make an enhancement request on the client
https://github.com/FoldingAtHome/fah-cl ... tet/issues
Peter_Hucker
I guess I could put every single GPU or CPU into it's own resource group, but it's a lot of effort I shouldn't have to expend.
I requested it in here. Why should I have to go to github too?
Post by calxalot »
Because the lead developer almost never is on this forum.
If you put your request on github, developers will see it and it won’t get lost.
This forum, to me, is mainly a place for volunteers to try to help others with the software.
Peter_Hucker
Post by calxalot »
If you’re asking to pause work units, you should say exactly that instead of saying slots. You are talking to very literal developers.
Peter_Hucker
ROFL! Done.
