Significantly low PPD only on Windows
mutlucan
Post by mutlucan »
Previously I was folding on GTX 750 ti. Now upgraded to 3060 Ti. I reinstalled drivers using GF Experience's clean install option. Uninstalled FAH including data. Installed again but I'm getting about 500,000 PPD instead of 3,000,000 and I only get base credit.
I tried to fold on Fedora on the same rig and got about 3m PPD just fine. I was able to get the same project (18601) on both OSs' so it shouldn't be related to the project. I've completed more than 13 WUs and things didn't get any better after my bonus key is activated.
Another thing is on Windows, despite low PPD and credit, completion time is not terribly long. It finishes WUs in 3 hours, just like on Linux on the same project.
Here are the logs on Windows:
*********************** Log Started 2023-01-21T04:10:14Z ***********************
04:10:14:******************************* libFAH ********************************
04:10:14:           Date: Oct 20 2020
04:10:14:           Time: 13:36:55
04:10:14:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
04:10:14:         Branch: master
04:10:14:       Compiler: Visual C++ 2015
04:10:14:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
04:10:14:       Platform: win32 10
04:10:14:           Bits: 32
04:10:14:           Mode: Release
04:10:14:****************************** FAHClient ******************************
04:10:14:        Version: 7.6.21
04:10:14:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:10:14:      Copyright: 2020 foldingathome.org
04:10:14:       Homepage: https://foldingathome.org/
04:10:14:           Time: 13:41:04
04:10:14:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
04:10:14:           Bits: 32
04:10:14:         Config: C:\ProgramData\FAHClient\config.xml
04:10:14:******************************** CBang ********************************
04:10:14:           Time: 11:36:18
04:10:14:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
04:10:14:           Bits: 32
04:10:14:******************************* System ********************************
04:10:14:            CPU: AMD Ryzen 7 3700X 8-Core Processor
04:10:14:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
04:10:14:           CPUs: 6
04:10:14:         Memory: 10.00GiB
04:10:14:    Free Memory: 5.87GiB
04:10:14:        Threads: WINDOWS_THREADS
04:10:14:     OS Version: 6.2
04:10:14:    Has Battery: false
04:10:14:     On Battery: false
04:10:14:     UTC Offset: 3
04:10:14:            PID: 15292
04:10:14:            CWD: C:\ProgramData\FAHClient
04:10:14:  Win32 Service: false
04:10:14:             OS: Windows 10 Enterprise
04:10:14:        OS Arch: AMD64
04:10:14:           GPUs: 1
04:10:14:          GPU 0: Bus:0 Slot:6 Func:0 NVIDIA:8 GA104 [GeForce RTX 3060 Ti]
04:10:14:  CUDA Device 0: Platform:0 Device:0 Bus:0 Slot:6 Compute:8.6 Driver:12.0
04:10:14:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:0 Compute:3.0 Driver:528.2
04:10:14:***********************************************************************
04:10:15:<config>
04:10:15:  <!-- HTTP Server -->
04:10:15:  <allow v='0.0.0.0/0'/>
04:10:15:
04:10:15:  <!-- Network -->
04:10:15:  <proxy v=':8080'/>
04:10:15:
04:10:15:  <!-- Remote Command Server -->
04:10:15:  <command-allow-no-pass v='0.0.0.0/0'/>
04:10:15:
04:10:15:  <!-- Slot Control -->
04:10:15:  <power v='full'/>
04:10:15:
04:10:15:  <!-- Folding Slots -->
04:10:15:  <slot id='1' type='GPU'>
04:10:15:    <paused v='true'/>
04:10:15:    <pci-bus v='0'/>
04:10:15:    <pci-slot v='6'/>
04:10:15:  </slot>
04:10:15:</config>
04:10:15:Trying to access database...
04:10:15:Successfully acquired database lock
04:10:15:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:6 GA104 [GeForce RTX 3060 Ti].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
04:10:15:FS01:Initialized folding slot 01: gpu:0:6 GA104 [GeForce RTX 3060 Ti]
04:11:38:FS01:Unpaused
04:11:38:WU01:FS01:Starting
04:11:38:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 15292 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
04:11:38:WU01:FS01:Started FahCore on PID 15308
04:11:39:WU01:FS01:Core PID:12584
04:11:39:WU01:FS01:FahCore 0x22 started
04:11:39:WU01:FS01:0x22:*********************** Log Started 2023-01-21T04:11:39Z ***********************
04:11:39:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:11:39:WU01:FS01:0x22:       Core: Core22
04:11:39:WU01:FS01:0x22:       Type: 0x22
04:11:39:WU01:FS01:0x22:    Version: 0.0.20
04:11:39:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:11:39:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
04:11:39:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
04:11:39:WU01:FS01:0x22:       Date: Jan 20 2022
04:11:39:WU01:FS01:0x22:       Time: 01:15:36
04:11:39:WU01:FS01:0x22:   Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
04:11:39:WU01:FS01:0x22:     Branch: HEAD
04:11:39:WU01:FS01:0x22:   Compiler: Visual C++
04:11:39:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
04:11:39:WU01:FS01:0x22:             -DOPENMM_VERSION="\"7.7.0\""
04:11:39:WU01:FS01:0x22:   Platform: win32 10
04:11:39:WU01:FS01:0x22:       Bits: 64
04:11:39:WU01:FS01:0x22:       Mode: Release
04:11:39:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
04:11:39:WU01:FS01:0x22:             <peastman@stanford.edu>
04:11:39:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 15308 -checkpoint 15
04:11:39:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
04:11:39:WU01:FS01:0x22:             nvidia -gpu 0 -gpu-usage 100
04:11:39:WU01:FS01:0x22:************************************ libFAH ************************************
04:11:39:WU01:FS01:0x22:       Time: 01:14:17
04:11:39:WU01:FS01:0x22:   Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
04:11:39:WU01:FS01:0x22:************************************ CBang *************************************
04:11:39:WU01:FS01:0x22:       Time: 01:13:20
04:11:39:WU01:FS01:0x22:   Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
04:11:40:WU01:FS01:0x22:       Bits: 64
04:11:40:WU01:FS01:0x22:       Mode: Release
04:11:40:WU01:FS01:0x22:************************************ System ************************************
04:11:40:WU01:FS01:0x22:        CPU: AMD Ryzen 7 3700X 8-Core Processor
04:11:40:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
04:11:40:WU01:FS01:0x22:       CPUs: 6
04:11:40:WU01:FS01:0x22:     Memory: 10.00GiB
04:11:40:WU01:FS01:0x22:Free Memory: 7.14GiB
04:11:40:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
04:11:40:WU01:FS01:0x22: OS Version: 6.2
04:11:40:WU01:FS01:0x22:Has Battery: false
04:11:40:WU01:FS01:0x22: On Battery: false
04:11:40:WU01:FS01:0x22: UTC Offset: 3
04:11:40:WU01:FS01:0x22:        PID: 12584
04:11:40:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
04:11:40:WU01:FS01:0x22:************************************ OpenMM ************************************
04:11:40:WU01:FS01:0x22:    Version: 7.7.0
04:11:40:WU01:FS01:0x22:********************************************************************************
04:11:40:WU01:FS01:0x22:Project: 18601 (Run 8919, Clone 4, Gen 26)
04:11:40:WU01:FS01:0x22:Reading tar file core.xml
04:11:40:WU01:FS01:0x22:Reading tar file integrator.xml
04:11:40:WU01:FS01:0x22:Reading tar file state.xml.bz2
04:11:40:WU01:FS01:0x22:Reading tar file system.xml.bz2
04:11:40:WU01:FS01:0x22:Digital signatures verified
04:11:40:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:11:40:WU01:FS01:0x22:Version 0.0.20
04:11:40:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
04:11:40:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
04:11:40:WU01:FS01:0x22:  XTC frame write interval: 20000 steps (1.6%) [62 total]
04:11:40:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
04:11:40:WU01:FS01:0x22:There are 4 platforms available.
04:11:40:WU01:FS01:0x22:Platform 0: Reference
04:11:40:WU01:FS01:0x22:Platform 1: CPU
04:11:40:WU01:FS01:0x22:Platform 2: OpenCL
04:11:40:WU01:FS01:0x22:  opencl-device 0 specified
04:11:40:WU01:FS01:0x22:Platform 3: CUDA
04:11:40:WU01:FS01:0x22:  cuda-device 0 specified
04:12:05:WU01:FS01:0x22:Attempting to create CUDA context:
04:12:05:WU01:FS01:0x22:  Configuring platform CUDA
04:12:17:Saving configuration to config.xml
04:12:17:<config>
04:12:17:  <!-- HTTP Server -->
04:12:17:  <allow v='0.0.0.0/0'/>
04:12:17:
04:12:17:  <!-- Network -->
04:12:17:  <proxy v=':8080'/>
04:12:17:
04:12:17:  <!-- Remote Command Server -->
04:12:17:  <command-allow-no-pass v='0.0.0.0/0'/>
04:12:17:
04:12:17:  <!-- Slot Control -->
04:12:17:  <power v='full'/>
04:12:17:
04:12:17:  <!-- User Information -->
04:12:17:  <passkey v='*****'/>
04:12:17:  <team v='234980'/>
04:12:17:  <user v='hf7fbcih6tib'/>
04:12:17:
04:12:17:  <!-- Folding Slots -->
04:12:17:  <slot id='1' type='GPU'>
04:12:17:    <pci-bus v='0'/>
04:12:17:    <pci-slot v='6'/>
04:12:17:  </slot>
04:12:17:</config>
04:12:21:WU01:FS01:0x22:  Using CUDA and gpu 0
04:12:21:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
04:12:26:WU01:FS01:0x22:Checkpoint completed at step 0
04:14:27:WU01:FS01:0x22:Completed 12500 out of 1250000 steps (1%)
04:16:25:WU01:FS01:0x22:Completed 25000 out of 1250000 steps (2%)
04:16:30:WU01:FS01:0x22:Checkpoint completed at step 25000
04:18:37:WU01:FS01:0x22:Completed 37500 out of 1250000 steps (3%)
04:20:43:WU01:FS01:0x22:Completed 50000 out of 1250000 steps (4%)
04:20:48:WU01:FS01:0x22:Checkpoint completed at step 50000
04:22:51:WU01:FS01:0x22:Completed 62500 out of 1250000 steps (5%)
04:24:58:WU01:FS01:0x22:Completed 75000 out of 1250000 steps (6%)
04:25:03:WU01:FS01:0x22:Checkpoint completed at step 75000
04:27:12:WU01:FS01:0x22:Completed 87500 out of 1250000 steps (7%)
04:29:25:WU01:FS01:0x22:Completed 100000 out of 1250000 steps (8%)
04:29:32:WU01:FS01:0x22:Checkpoint completed at step 100000
04:31:40:WU01:FS01:0x22:Completed 112500 out of 1250000 steps (9%)
04:33:50:WU01:FS01:0x22:Completed 125000 out of 1250000 steps (10%)
04:33:55:WU01:FS01:0x22:Checkpoint completed at step 125000
04:36:06:WU01:FS01:0x22:Completed 137500 out of 1250000 steps (11%)
04:38:15:WU01:FS01:0x22:Completed 150000 out of 1250000 steps (12%)
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Re: Significantly low PPD only on Windows
Post by BobWilliams757 »
I would double check your windows pass key entry and type it in from scratch rather than copy paste it. If overall times and frame times are the same between the two operating systems your points should be the same.
Base points for project 18601 are only 81,101. If you were getting any more than that then your passkey is working. It might be possible that the work units are not returning in a timely manner, but you would have to go into the logs and check.
If the frame times and overall time are the same then it's most likely not a driver problem with the GPU. In this case since you mentioned just getting base points it is most likely the pass key.
Fold them if you get them!
mutlucan
Post by mutlucan »
It fixed itself. It was indeed probably the passkey. Windows one is actually my roommate's PC. I just boot it with my own Linux drive with my own passkey. It's weird passkey activation took some time even though it was active on the bonus status website.
Thank you.
mutlucan
Post by mutlucan »
The same thing started to happen again.
*********************** Log Started 2023-01-22T23:35:52Z ***********************
23:35:53:WARNING:FS01:Guessing ambiguous GPU to OpenCL device mapping for 01: gpu:0:6 GA104 [GeForce RTX 3060 Ti].  Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
23:36:36:WU01:FS01:0x22:ERROR:Guru Meditation #3cd441cc5347a059.18ea98115cd1bafd (45862819.45862819) '01/01/checkpoint'
23:36:37:WARNING:WU01:FS01:FahCore returned: BAD_FRAME_CHECKSUM (112 = 0x70)
23:36:37:WARNING:WU01:FS01:Fatal error, dumping
******************************* Date: 2023-01-23 *******************************
When I checked the log, previously these happened successively one time. But never again after more than 12 hours. But I'm still getting the same low PPD and only getting exactly the same base point again. My bonus looks active.
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
This one is a bit of a head scratcher to me. Hopefully somebody else can come along and figure out what the strange GPU identification message is, as well as why the pass key doesn't seem to be giving you bonus points.
Just for clarification though this is all taking place in the same machine correct? Only the boot operating system is changing?
This system doesn't look very stable, those errors indicates an issue that might be related to the storage device ... did you check it (mostly CPU/RAM/GPU/PSU) ?
mutlucan
Post by mutlucan »
These error messages only appeared one time. That system has been running for a month. Previously it was running 750 Ti so, PPD was low for that card anyway. And I was using my name and passkey on my roommate's Windows. After getting the new GPU, he got his own name and passkey.
All these were taking place on the same machine, yes. I just boot my own Linux drive on his system. However, it was my passkey. I will try to use my perfectly working passkey on his Windows again and I will use his passkey on my Linux to see if that is the problem.
The hardware seems fine, the only difference was my storage instead of his. But I performed a SMART test and it looks perfectly fine. Actually, I keep forgetting we're running on a VM. So, were are using the same rig, except we have our own GPU and SSD passed through.
mutlucan
Post by mutlucan »
I've swapped the names and passkeys and both machines running normally for now. I'll wait if one of it stuck with base points and low PPD again.
mutlucan
Post by mutlucan »
It happened again with Windows again. So nothing wrong with the passkey either. And I think this happens when I reboot the PC. Not sure, I realised it after rebooting, but I didn't especially check it before rebooting. Something is wrong with Windows or the Windows version of FAHClient.
mutlucan
Post by mutlucan »
Last update for the record:
What breaks was a reboot all the time. I couldn't figure out what fixes it. It randomly goes back to normal in a few hours to a day.
Thankfully, my roommate switched to Linux now. No problem on Linux with the same hardware and passkey.
