Hey there,
It's been some time since I last visited, so this has been likely discussed before. 4090 here, folding p18448, and I noticed that the GPU utilization hardly reaches 90% (more like 87% average), plus the effective clock in my case is 2970 Mhz vs the set 3000 Mhz. I wonder why that is? I am not CPU bound. Is this a core_22 limitation or am I missing something?
Thanks!
GPU load less than 90%?
Vester
- Hardware configuration: Gigabyte Aorus Z590 Pro AX, Intel i9-10850K, 32GB Crucial Ballistix DDR4-2600, Samsung NVMe EVO 980 Pro 256GB, CoolerMaster liquid cooler ML360, Nvidia Titan X (Pascal), Dell Nvidia RTX 3080 10GB 4Y12V, Pop!_OS.
Re: GPU load less than 90%?
Besides what is mentioned in that topic about a 4070, the 4090 has 16,000 shaders. Not all projects are large enough to keep them all utilized. You will see a difference between projects with about 100,000 atoms in the simulation as compared to those with several hundred thousand.
All clear, thanks, seems about right - at 95% utilization with p18601 now.Joe_H wrote: ↑Sat Jan 14, 2023 4:18 pm Besides what is mentioned in that topic about a 4070, the 4090 has 16,000 shaders. Not all projects are large enough to keep them all utilized. You will see a difference between projects with about 100,000 atoms in the simulation as compared to those with several hundred thousand.
But are there any cause-specific projects which are larger and more appropriate for me then, so that I can set that as a preference?
Mxyzptlk
- Hardware configuration: Lots... Look at my website: www.mxyzptlk.us
Alzheimers seems to get the most out of these cards.
Reason: fixed quoting
Just FYI, with p18601 I am getting about 30 million PPD - insane...
bikeaddict
In late 2020, F&H added support for CUDA on NVIDIA cards. Before that, all GPUs used OpenCL. This gave an increase in PPD of about 50% on the GTX cards I was using then. It's expected that NVIDIA cards will perform better than AMD, but not 8x AFAIK.
