Hello,
I created a Team "9317" but none of my stats are reporting to my team despite the fact that I created a team and input that team on each client along with my username I want all my stats to report under which is "Caltrans95662." I have a bunch of completed WU's under the username but nothing under my team name. What am I doing wrong? Thank you in advance for the help.
Team Status
parkut
- Hardware configuration: Running exclusively Linux headless blades. All are dedicated crunching machines.
Re: Team Status
https://stats.foldingathome.org/donor/581775097
Did you restart your system after assigning the team number?
Re: Team Status
Did you create the team through this page - https://apps.foldingathome.org/team ? Once it has been created you will get a Team number that gets entered into the folding client. Points earned by WUs downloaded and returned with that team number entered will be credited to the team, prior WUs remain credited to whatever team they were folded under or the default Team 0.
Edit: A restart should not be required after entering the team number.
Re: Team Status
Is this the team you created? https://statsclassic.foldingathome.org/team/1062718
If so, then the number you should enter into the client is 1062718. If you entered '9317', that team does not exist and any points will be credited to the default team.
parkut
Re: Team Status
Entering Caltrans95662 here: https://apps.foldingathome.org/cpu shows three machines active and returning results for team 0 (anonymous default team).
Sat, 01 Jan 2022 17:49:05 GMT (12:49 Eastern)
These CPUs have returned work in the last 90 days:
CPUid IP Address Team Slot OS Last credit Got bonus Last returned Project Run Clone Gen
68F5AF617097469B xxx.xxx.xxx.41 0 x86 Windows 8,195.46 1 2022-01-01 00:07:45 18206 5861 0 90
D995C361507B2FCA xxx.xxx.xxx.41 0 x86 Windows 105,756 1 2022-01-01 14:47:49 18414 149 1 31
1E48B26166EE384A xxx.xxx.xxx.41 0 x86 Windows 8,183.3 1 2022-01-01 17:17:50 18436 483 5 51
