Linux Version V7.6.21 ignores config.xml
alteir
Post by alteir »
Hello,
I´m running client Version V7.6.21 (fahclient-7.6.21-1.x86_64.rpm) on CentOS 8.4 Server. After installing the client, it start immediately computation (FahCore_8). I used /etc/farclient.config.xml but the system ignores the setting and
does everthing as "anonymous".
I tryed to install FAHcontroll in Version 7.6.21, but very thing t tested the WU are done as anonymous.
Anyway I have a few more questions.
1.) After reboot the FAHwrapper starts immediately compute WUs. How can I pause/stop this process? Kill FahCore_8 or wrapper does not work. It restart directly.
2.) running /etc/init.d FAHClient start seems to work, but the error message .....database logged..... will not run this process.
What I´m doing wrong?
aetch
Re: Linux Version V7.6.21 ignores config.xml
Post by aetch »
"/etc/farclient.config.xml" is wrong
it should be "/etc/fahclient/config.xml"
if that doesn't work try the config file located at /var/lib/fahclient/config.xml
take a look at this thread viewtopic.php?f=16&t=37337
it covers how to configure remote access
it also includes a dump of one of my configs which has the "pause-on-start" setting
Don't forget to restart the client (or the whole system) after you edit the config.xml file ...
alteir
Post by alteir »
Hi,
/var/lib/fahclient/config.xml was working!
Thanks for the help!
