more .... bad work units
Forcinghavok
Post by Forcinghavok »
I have 2 different WU's that are failing or 2 different logs. Any idea what's going on? Let me guess, its my software or computer?
*********************** Log Started 2021-05-16T14:59:54Z ***********************
14:59:54:******************************* libFAH ********************************
14:59:54:           Date: Oct 20 2020
14:59:54:           Time: 13:36:55
14:59:54:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:59:54:         Branch: master
14:59:54:       Compiler: Visual C++ 2015
14:59:54:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:59:54:       Platform: win32 10
14:59:54:           Bits: 32
14:59:54:           Mode: Release
14:59:54:****************************** FAHClient ******************************
14:59:54:        Version: 7.6.21
14:59:54:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:59:54:      Copyright: 2020 foldingathome.org
14:59:54:       Homepage: https://foldingathome.org/
14:59:54:           Time: 13:41:04
14:59:54:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:59:54:           Bits: 32
14:59:54:         Config: C:\ProgramData\FAHClient\config.xml
14:59:54:******************************** CBang ********************************
14:59:54:           Time: 11:36:18
14:59:54:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:59:54:           Bits: 32
14:59:54:******************************* System ********************************
14:59:54:            CPU: AMD FX(tm)-8350 Eight-Core Processor
14:59:54:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
14:59:54:           CPUs: 8
14:59:54:         Memory: 15.90GiB
14:59:54:    Free Memory: 13.46GiB
14:59:54:        Threads: WINDOWS_THREADS
14:59:54:     OS Version: 6.2
14:59:54:    Has Battery: false
14:59:54:     On Battery: false
14:59:54:     UTC Offset: -4
14:59:54:            PID: 8736
14:59:54:            CWD: C:\ProgramData\FAHClient
14:59:54:  Win32 Service: false
14:59:54:             OS: Windows 10 Home
14:59:54:        OS Arch: AMD64
14:59:54:           GPUs: 1
14:59:54:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
14:59:54:                 470/480/570/580/590]
14:59:54:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:59:54:                 specified module could not be found.
14:59:54:
14:59:54:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3240.6
14:59:54:***********************************************************************
14:59:54:<config>
14:59:54:  <!-- Folding Core -->
14:59:54:  <checkpoint v='3'/>
14:59:54:
14:59:54:  <!-- Network -->
14:59:54:  <proxy v=':8080'/>
14:59:54:
14:59:54:  <!-- Slot Control -->
14:59:54:  <pause-on-battery v='false'/>
14:59:54:  <power v='full'/>
14:59:54:
14:59:54:  <!-- User Information -->
14:59:54:  <team v='2092'/>
14:59:54:  <user v='ForcingHavok'/>
14:59:54:
14:59:54:  <!-- Folding Slots -->
14:59:54:  <slot id='0' type='CPU'>
14:59:54:    <cpus v='4'/>
14:59:54:  </slot>
14:59:54:  <slot id='1' type='GPU'>
14:59:54:    <pci-bus v='1'/>
14:59:54:    <pci-slot v='0'/>
14:59:54:  </slot>
14:59:54:</config>
14:59:54:Trying to access database...
14:59:54:Successfully acquired database lock
14:59:54:FS00:Initialized folding slot 00: cpu:4
14:59:54:FS01:Initialized folding slot 01: gpu:1:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
14:59:54:WU00:FS01:Starting
14:59:54:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
14:59:54:WU00:FS01:Started FahCore on PID 368
14:59:54:WU00:FS01:Core PID:5728
14:59:54:WU00:FS01:FahCore 0x22 started
14:59:55:WU01:FS00:Starting
14:59:55:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -np 4
14:59:55:WU01:FS00:Started FahCore on PID 5540
14:59:55:WU01:FS00:Core PID:5720
14:59:55:WU01:FS00:FahCore 0xa8 started
15:00:00:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:00:00:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:00:01:WU00:FS01:Starting
15:00:01:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
15:00:01:WU00:FS01:Started FahCore on PID 876
15:00:01:WU00:FS01:Core PID:692
15:00:01:WU00:FS01:FahCore 0x22 started
15:00:01:WU01:FS00:Starting
15:00:01:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -np 4
15:00:01:WU01:FS00:Started FahCore on PID 1012
15:00:01:WU01:FS00:Core PID:7964
15:00:01:WU01:FS00:FahCore 0xa8 started
15:00:02:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:00:02:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:00:55:Removing old file 'configs/config-20210513-024042.xml'
15:00:55:Saving configuration to config.xml
15:00:55:<config>
15:00:55:  <!-- Folding Core -->
15:00:55:  <checkpoint v='3'/>
15:00:55:
15:00:55:  <!-- Network -->
15:00:55:  <proxy v=':8080'/>
15:00:55:
15:00:55:  <!-- Slot Control -->
15:00:55:  <pause-on-battery v='false'/>
15:00:55:  <power v='full'/>
15:00:55:
15:00:55:  <!-- User Information -->
15:00:55:  <team v='2092'/>
15:00:55:  <user v='ForcingHavok'/>
15:00:55:
15:00:55:  <!-- Folding Slots -->
15:00:55:  <slot id='0' type='CPU'>
15:00:55:    <cpus v='4'/>
15:00:55:    <idle v='true'/>
15:00:55:  </slot>
15:00:55:  <slot id='1' type='GPU'>
15:00:55:    <pci-bus v='1'/>
15:00:55:    <pci-slot v='0'/>
15:00:55:  </slot>
15:00:55:</config>
16:24:09:WU00:FS01:Starting
16:24:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
16:24:09:WU00:FS01:Started FahCore on PID 6328
16:24:09:WU00:FS01:Core PID:6988
16:24:09:WU00:FS01:FahCore 0x22 started
16:24:09:WU01:FS00:Starting
16:24:09:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -np 4
16:24:09:WU01:FS00:Started FahCore on PID 8492
16:24:09:WU01:FS00:Core PID:2532
16:24:09:WU01:FS00:FahCore 0xa8 started
16:24:09:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:24:10:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:24:17:Removing old file 'configs/config-20210513-043939.xml'
16:24:17:Saving configuration to config.xml
16:24:17:<config>
16:24:17:  <!-- Folding Core -->
16:24:17:  <checkpoint v='3'/>
16:24:17:
16:24:17:  <!-- Network -->
16:24:17:  <proxy v=':8080'/>
16:24:17:
16:24:17:  <!-- Slot Control -->
16:24:17:  <pause-on-battery v='false'/>
16:24:17:  <power v='full'/>
16:24:17:
16:24:17:  <!-- User Information -->
16:24:17:  <team v='2092'/>
16:24:17:  <user v='ForcingHavok'/>
16:24:17:
16:24:17:  <!-- Folding Slots -->
16:24:17:  <slot id='0' type='CPU'>
16:24:17:    <cpus v='4'/>
16:24:17:  </slot>
16:24:17:  <slot id='1' type='GPU'>
16:24:17:    <pci-bus v='1'/>
16:24:17:    <pci-slot v='0'/>
16:24:17:  </slot>
16:24:17:</config>
16:25:09:WU00:FS01:Starting
16:25:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
16:25:09:WU00:FS01:Started FahCore on PID 10020
16:25:09:WU00:FS01:Core PID:9200
16:25:09:WU00:FS01:FahCore 0x22 started
16:25:09:WU01:FS00:Starting
16:25:09:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -np 4
16:25:09:WU01:FS00:Started FahCore on PID 7704
16:25:09:WU01:FS00:Core PID:5756
16:25:09:WU01:FS00:FahCore 0xa8 started
16:25:10:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:25:10:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:26:09:WU00:FS01:Starting
16:26:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
16:26:09:WU00:FS01:Started FahCore on PID 10164
16:26:09:WU00:FS01:Core PID:8320
16:26:09:WU00:FS01:FahCore 0x22 started
16:26:09:WU01:FS00:Starting
16:26:09:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 01 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -np 4
16:26:09:WU01:FS00:Started FahCore on PID 2232
16:26:09:WU01:FS00:Core PID:5848
16:26:09:WU01:FS00:FahCore 0xa8 started
16:26:10:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:26:10:WARNING:WU00:FS01:Too many errors, failing
16:26:10:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:13448 run:212 clone:45 gen:1 core:0x22 unit:0x0000002d0000000100003488000000d4
16:26:10:WU00:FS01:Connecting to 54.157.202.86:8080
16:26:10:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:26:10:WARNING:WU01:FS00:Too many errors, failing
16:26:10:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:16959 run:29 clone:598 gen:37 core:0xa8 unit:0x00000256000000250000423f0000001d
16:26:10:WU01:FS00:Connecting to 129.32.209.205:8080
16:26:11:WU00:FS01:Server responded WORK_ACK (400)
16:26:11:WU02:FS00:Connecting to assign1.foldingathome.org:80
16:26:11:WU00:FS01:Cleaning up
16:26:11:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:26:11:WU01:FS00:Server responded WORK_ACK (400)
16:26:11:WU01:FS00:Cleaning up
16:26:12:WU02:FS00:Assigned to work server 129.32.209.205
16:26:12:WU02:FS00:Requesting new work unit for slot 00: cpu:4 from 129.32.209.205
16:26:12:WU02:FS00:Connecting to 129.32.209.205:8080
16:26:12:WU03:FS01:Assigned to work server 128.174.73.74
16:26:12:WU03:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 128.174.73.74
16:26:12:WU03:FS01:Connecting to 128.174.73.74:8080
16:26:13:WU02:FS00:Downloading 1.47MiB
16:26:13:WU02:FS00:Download complete
16:26:13:ERROR:WU03:FS01:Exception: Server did not assign work unit
16:26:14:WU03:FS01:Connecting to assign1.foldingathome.org:80
16:26:14:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16959 run:14 clone:187 gen:57 core:0xa8 unit:0x000000bb000000390000423f0000000e
16:26:14:WU02:FS00:Starting
16:26:14:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 02 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -np 4
16:26:14:WU02:FS00:Started FahCore on PID 9964
16:26:14:WU02:FS00:Core PID:3492
16:26:14:WU02:FS00:FahCore 0xa8 started
16:26:14:WU02:FS00:0xa8:*********************** Log Started 2021-05-16T16:26:14Z ***********************
16:26:14:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
16:26:14:WU02:FS00:0xa8:       Core: Gromacs
16:26:14:WU02:FS00:0xa8:       Type: 0xa8
16:26:14:WU02:FS00:0xa8:    Version: 0.0.12
16:26:14:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:26:14:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
16:26:14:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
16:26:14:WU02:FS00:0xa8:       Date: Jan 16 2021
16:26:14:WU02:FS00:0xa8:       Time: 11:56:07
16:26:14:WU02:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
16:26:14:WU02:FS00:0xa8:     Branch: master
16:26:14:WU02:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
16:26:14:WU02:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
16:26:14:WU02:FS00:0xa8:   Platform: win32 10
16:26:14:WU02:FS00:0xa8:       Bits: 64
16:26:14:WU02:FS00:0xa8:       Mode: Release
16:26:14:WU02:FS00:0xa8:       SIMD: avx_256
16:26:14:WU02:FS00:0xa8:     OpenMP: ON
16:26:14:WU02:FS00:0xa8:       CUDA: OFF
16:26:14:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9964 -checkpoint 3 -np 4
16:26:14:WU02:FS00:0xa8:************************************ libFAH ************************************
16:26:14:WU02:FS00:0xa8:       Time: 11:24:13
16:26:14:WU02:FS00:0xa8:************************************ CBang *************************************
16:26:14:WU02:FS00:0xa8:       Time: 11:23:53
16:26:14:WU02:FS00:0xa8:************************************ System ************************************
16:26:14:WU02:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
16:26:14:WU02:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
16:26:15:WU02:FS00:0xa8:       CPUs: 8
16:26:15:WU02:FS00:0xa8:     Memory: 15.90GiB
16:26:15:WU02:FS00:0xa8:Free Memory: 9.20GiB
16:26:15:WU02:FS00:0xa8:    Threads: WINDOWS_THREADS
16:26:15:WU02:FS00:0xa8: OS Version: 6.2
16:26:15:WU02:FS00:0xa8:Has Battery: false
16:26:15:WU02:FS00:0xa8: On Battery: false
16:26:15:WU02:FS00:0xa8: UTC Offset: -4
16:26:15:WU02:FS00:0xa8:        PID: 3492
16:26:15:WU02:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
16:26:15:WU02:FS00:0xa8:********************************************************************************
16:26:15:WU02:FS00:0xa8:Project: 16959 (Run 14, Clone 187, Gen 57)
16:26:15:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
16:26:15:WU02:FS00:0xa8:Reading tar file core.xml
16:26:15:WU02:FS00:0xa8:Reading tar file frame57.tpr
16:26:15:WU02:FS00:0xa8:Digital signatures verified
16:26:15:WU02:FS00:0xa8:Calling: mdrun -c frame57.gro -s frame57.tpr -x frame57.xtc -cpt 3 -nt 4 -ntmpi 1
16:26:15:WU02:FS00:0xa8:Steps: first=142500000 total=145000000
16:26:15:WU02:FS00:0xa8:Completed 1 out of 2500000 steps (0%)
16:26:15:WU03:FS01:Assigned to work server 54.157.202.86
16:26:15:WU03:FS01:Requesting new work unit for slot 01: gpu:1:0 Ellesmere XT [Radeon RX 470/480/570/580/590] from 54.157.202.86
16:26:15:WU03:FS01:Connecting to 54.157.202.86:8080
16:26:17:WU03:FS01:Downloading 7.70MiB
16:26:17:WU03:FS01:Download complete
16:26:18:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:13448 run:435 clone:80 gen:1 core:0x22 unit:0x000000500000000100003488000001b3
16:26:18:WU03:FS01:Starting
16:26:18:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 8736 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
16:26:18:WU03:FS01:Started FahCore on PID 5860
16:26:18:WU03:FS01:Core PID:1464
16:26:18:WU03:FS01:FahCore 0x22 started
16:26:19:WU03:FS01:0x22:*********************** Log Started 2021-05-16T16:26:18Z ***********************
16:26:19:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:26:19:WU03:FS01:0x22:       Core: Core22
16:26:19:WU03:FS01:0x22:       Type: 0x22
16:26:19:WU03:FS01:0x22:    Version: 0.0.13
16:26:19:WU03:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:26:19:WU03:FS01:0x22:  Copyright: 2020 foldingathome.org
16:26:19:WU03:FS01:0x22:   Homepage: https://foldingathome.org/
16:26:19:WU03:FS01:0x22:       Date: Sep 19 2020
16:26:19:WU03:FS01:0x22:       Time: 02:35:58
16:26:19:WU03:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
16:26:19:WU03:FS01:0x22:     Branch: core22-0.0.13
16:26:19:WU03:FS01:0x22:   Compiler: Visual C++ 2015
16:26:19:WU03:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
16:26:19:WU03:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
16:26:19:WU03:FS01:0x22:   Platform: win32 10
16:26:19:WU03:FS01:0x22:       Bits: 64
16:26:19:WU03:FS01:0x22:       Mode: Release
16:26:19:WU03:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
16:26:19:WU03:FS01:0x22:             <peastman@stanford.edu>
16:26:19:WU03:FS01:0x22:       Args: -dir 03 -suffix 01 -version 706 -lifeline 5860 -checkpoint 3
16:26:19:WU03:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
16:26:19:WU03:FS01:0x22:             -gpu-usage 100
16:26:19:WU03:FS01:0x22:************************************ libFAH ************************************
16:26:19:WU03:FS01:0x22:       Date: Sep 7 2020
16:26:19:WU03:FS01:0x22:       Time: 19:09:56
16:26:19:WU03:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
16:26:19:WU03:FS01:0x22:     Branch: HEAD
16:26:19:WU03:FS01:0x22:************************************ CBang *************************************
16:26:19:WU03:FS01:0x22:       Time: 19:08:30
16:26:19:WU03:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
16:26:19:WU03:FS01:0x22:************************************ System ************************************
16:26:19:WU03:FS01:0x22:        CPU: AMD FX(tm)-8350 Eight-Core Processor
16:26:19:WU03:FS01:0x22:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
16:26:19:WU03:FS01:0x22:       CPUs: 8
16:26:19:WU03:FS01:0x22:     Memory: 15.90GiB
16:26:19:WU03:FS01:0x22:Free Memory: 9.10GiB
16:26:19:WU03:FS01:0x22:    Threads: WINDOWS_THREADS
16:26:19:WU03:FS01:0x22: OS Version: 6.2
16:26:19:WU03:FS01:0x22:Has Battery: false
16:26:19:WU03:FS01:0x22: On Battery: false
16:26:19:WU03:FS01:0x22: UTC Offset: -4
16:26:19:WU03:FS01:0x22:        PID: 1464
16:26:19:WU03:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
16:26:19:WU03:FS01:0x22:************************************ OpenMM ************************************
16:26:19:WU03:FS01:0x22:   Revision: 189320d0
16:26:19:WU03:FS01:0x22:********************************************************************************
16:26:19:WU03:FS01:0x22:Project: 13448 (Run 435, Clone 80, Gen 1)
16:26:19:WU03:FS01:0x22:Unit: 0x00000000000000000000000000000000
16:26:19:WU03:FS01:0x22:Reading tar file core.xml
16:26:19:WU03:FS01:0x22:Reading tar file integrator.xml.bz2
16:26:19:WU03:FS01:0x22:Reading tar file state.xml.bz2
16:26:19:WU03:FS01:0x22:Reading tar file system.xml.bz2
16:26:19:WU03:FS01:0x22:Digital signatures verified
16:26:19:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:26:19:WU03:FS01:0x22:Version 0.0.13
16:26:19:WU03:FS01:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
16:26:19:WU03:FS01:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
16:26:19:WU03:FS01:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
16:26:19:WU03:FS01:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
16:26:19:WU03:FS01:0x22:There are 3 platforms available.
16:26:19:WU03:FS01:0x22:Platform 0: Reference
16:26:19:WU03:FS01:0x22:Platform 1: CPU
16:26:19:WU03:FS01:0x22:Platform 2: OpenCL
16:26:19:WU03:FS01:0x22:  opencl-device 0 specified
16:26:36:WU03:FS01:0x22:Attempting to create OpenCL context:
16:26:36:WU03:FS01:0x22:  Configuring platform OpenCL
16:26:51:WU03:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
16:26:51:WU03:FS01:0x22:Completed 0 out of 1000000 steps (0%)
16:26:52:WU03:FS01:0x22:Checkpoint completed at step 0
16:31:28:WU03:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
16:36:09:WU03:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
2nd one
*********************** Log Started 2021-05-16T18:52:46Z ***********************
18:52:46:******************************* libFAH ********************************
18:52:46:           Date: Oct 20 2020
18:52:46:           Time: 13:36:55
18:52:46:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
18:52:46:         Branch: master
18:52:46:       Compiler: Visual C++ 2015
18:52:46:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:52:46:       Platform: win32 10
18:52:46:           Bits: 32
18:52:46:           Mode: Release
18:52:46:****************************** FAHClient ******************************
18:52:46:        Version: 7.6.21
18:52:46:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:52:46:      Copyright: 2020 foldingathome.org
18:52:46:       Homepage: https://foldingathome.org/
18:52:46:           Time: 13:41:04
18:52:46:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
18:52:46:           Bits: 32
18:52:46:         Config: C:\ProgramData\FAHClient\config.xml
18:52:46:******************************** CBang ********************************
18:52:46:           Time: 11:36:18
18:52:46:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
18:52:46:           Bits: 32
18:52:46:******************************* System ********************************
18:52:46:            CPU: AMD FX(tm)-8350 Eight-Core Processor
18:52:46:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
18:52:46:           CPUs: 8
18:52:46:         Memory: 15.90GiB
18:52:46:    Free Memory: 13.29GiB
18:52:46:        Threads: WINDOWS_THREADS
18:52:46:     OS Version: 6.2
18:52:46:    Has Battery: false
18:52:46:     On Battery: false
18:52:46:     UTC Offset: -4
18:52:46:            PID: 9284
18:52:46:            CWD: C:\ProgramData\FAHClient
18:52:46:  Win32 Service: false
18:52:46:             OS: Windows 10 Home
18:52:46:        OS Arch: AMD64
18:52:46:           GPUs: 1
18:52:46:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
18:52:46:                 470/480/570/580/590]
18:52:46:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:52:46:                 specified module could not be found.
18:52:46:
18:52:46:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3240.6
18:52:46:***********************************************************************
18:52:46:<config>
18:52:46:  <!-- Folding Core -->
18:52:46:  <checkpoint v='3'/>
18:52:46:
18:52:46:  <!-- Network -->
18:52:46:  <proxy v=':8080'/>
18:52:46:
18:52:46:  <!-- Slot Control -->
18:52:46:  <pause-on-battery v='false'/>
18:52:46:  <power v='full'/>
18:52:46:
18:52:46:  <!-- User Information -->
18:52:46:  <team v='2092'/>
18:52:46:  <user v='ForcingHavok'/>
18:52:46:
18:52:46:  <!-- Folding Slots -->
18:52:46:  <slot id='0' type='CPU'>
18:52:46:    <cpus v='4'/>
18:52:46:  </slot>
18:52:46:  <slot id='1' type='GPU'>
18:52:46:    <pci-bus v='1'/>
18:52:46:    <pci-slot v='0'/>
18:52:46:  </slot>
18:52:46:</config>
18:52:46:Trying to access database...
18:52:46:Successfully acquired database lock
18:52:46:FS00:Initialized folding slot 00: cpu:4
18:52:46:FS01:Initialized folding slot 01: gpu:1:0 Ellesmere XT [Radeon RX 470/480/570/580/590]
18:52:46:WU02:FS00:Starting
18:52:46:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a8-0.0.12/Core_a8.fah/FahCore_a8.exe -dir 02 -suffix 01 -version 706 -lifeline 9284 -checkpoint 3 -np 4
18:52:46:WU02:FS00:Started FahCore on PID 9432
18:52:46:WU02:FS00:Core PID:9456
18:52:46:WU02:FS00:FahCore 0xa8 started
18:52:46:WU03:FS01:Starting
18:52:46:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 9284 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
18:52:46:WU03:FS01:Started FahCore on PID 9464
18:52:47:WU03:FS01:Core PID:9504
18:52:47:WU03:FS01:FahCore 0x22 started
18:52:48:WU02:FS00:0xa8:*********************** Log Started 2021-05-16T18:52:47Z ***********************
18:52:48:WU02:FS00:0xa8:************************** Gromacs Folding@home Core ***************************
18:52:48:WU02:FS00:0xa8:       Core: Gromacs
18:52:48:WU02:FS00:0xa8:       Type: 0xa8
18:52:48:WU02:FS00:0xa8:    Version: 0.0.12
18:52:48:WU02:FS00:0xa8:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:52:48:WU02:FS00:0xa8:  Copyright: 2020 foldingathome.org
18:52:48:WU02:FS00:0xa8:   Homepage: https://foldingathome.org/
18:52:48:WU02:FS00:0xa8:       Date: Jan 16 2021
18:52:48:WU02:FS00:0xa8:       Time: 11:56:07
18:52:48:WU02:FS00:0xa8:   Revision: c5816759c404e4b65f9f364c3d1ef554a67c4225
18:52:48:WU02:FS00:0xa8:     Branch: master
18:52:48:WU02:FS00:0xa8:   Compiler: Visual C++ 2019 16.7
18:52:48:WU02:FS00:0xa8:    Options: /TP /std:c++14 /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
18:52:48:WU02:FS00:0xa8:   Platform: win32 10
18:52:48:WU02:FS00:0xa8:       Bits: 64
18:52:48:WU02:FS00:0xa8:       Mode: Release
18:52:48:WU02:FS00:0xa8:       SIMD: avx_256
18:52:48:WU02:FS00:0xa8:     OpenMP: ON
18:52:48:WU02:FS00:0xa8:       CUDA: OFF
18:52:48:WU02:FS00:0xa8:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9432 -checkpoint 3 -np 4
18:52:48:WU02:FS00:0xa8:************************************ libFAH ************************************
18:52:48:WU02:FS00:0xa8:       Time: 11:24:13
18:52:48:WU02:FS00:0xa8:************************************ CBang *************************************
18:52:48:WU02:FS00:0xa8:       Time: 11:23:53
18:52:48:WU02:FS00:0xa8:************************************ System ************************************
18:52:48:WU02:FS00:0xa8:        CPU: AMD FX(tm)-8350 Eight-Core Processor
18:52:48:WU02:FS00:0xa8:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
18:52:48:WU02:FS00:0xa8:       CPUs: 8
18:52:48:WU02:FS00:0xa8:     Memory: 15.90GiB
18:52:48:WU02:FS00:0xa8:Free Memory: 13.24GiB
18:52:48:WU02:FS00:0xa8:    Threads: WINDOWS_THREADS
18:52:48:WU02:FS00:0xa8: OS Version: 6.2
18:52:48:WU02:FS00:0xa8:Has Battery: false
18:52:48:WU02:FS00:0xa8: On Battery: false
18:52:48:WU02:FS00:0xa8: UTC Offset: -4
18:52:48:WU02:FS00:0xa8:        PID: 9456
18:52:48:WU02:FS00:0xa8:        CWD: C:\ProgramData\FAHClient\work
18:52:48:WU02:FS00:0xa8:********************************************************************************
18:52:48:WU02:FS00:0xa8:Project: 16959 (Run 14, Clone 187, Gen 57)
18:52:48:WU02:FS00:0xa8:Unit: 0x00000000000000000000000000000000
18:52:48:WU02:FS00:0xa8:Digital signatures verified
18:52:48:WU02:FS00:0xa8:Calling: mdrun -c frame57.gro -s frame57.tpr -x frame57.xtc -cpi state.cpt -cpt 3 -nt 4 -ntmpi 1
18:52:48:WU02:FS00:0xa8:Steps: first=142500000 total=145000000
18:52:49:WU02:FS00:0xa8:Completed 14552 out of 2500000 steps (0%)
18:52:49:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:52:49:WU03:FS01:Starting
18:52:49:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 9284 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
18:52:49:WU03:FS01:Started FahCore on PID 9572
18:52:49:WU03:FS01:Core PID:9596
18:52:49:WU03:FS01:FahCore 0x22 started
18:52:50:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:53:50:WU03:FS01:Starting
18:53:50:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 9284 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
18:53:50:WU03:FS01:Started FahCore on PID 6288
18:53:50:WU03:FS01:Core PID:9648
18:53:50:WU03:FS01:FahCore 0x22 started
18:53:50:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
Re: more .... bad work units
Have you downloaded and installed the drivers for your GPU from AMD including OpenCL?
gunnarre
Post by gunnarre »
The WU from 13448 failed on two other GPUs, but is successful on a fourth, so I find it likely that the WU is unstable and should be more limited in the GPUs it's assigned to. That is, unless the WU was assigned to three unstable machines in a row, which is unlikely though possible.
The failures on project 16959 are stranger, since this is a CPU project (core a08) and other folders are completing the same WU successfully. There does seem to be something seriously wrong with your hardware if this is happening. It could also be software related - like if an anti-virus software is automatically aborting the folding cores every time they start.
I'm more worried about the fact the it doesn't display any useful error in the logs ... :?
JimF
Post by JimF »
Forcinghavok wrote:Any idea what's going on? Let me guess, its my software or computer?
You aren't overclocking the CPU are you?
Forcinghavok
Correct, nothing is overclocked. All hardware is at default state. Except GPU which has increased fan and power. It's funny you guys always say something is wrong with my hardware but never have an issue with your software. Do you think you guys are the best programmers or what?
PaulTV
Post by PaulTV »
Nah, they probably don't think they are the best programmers around, Most people here are volunteers, just fellow folders, trying to help each other out.
Ryzen 5600X / RTX 3070 Ti / Ubuntu 22.04
Ryzen 5600 / RTX 3060 Ti / Windows 11
PaulTV
Post by PaulTV »
I'm not an expert myself either, just curious fellow folder.
What bugs me is that both CPU and GPU jobs are failing (as Gunnarre also pointed out), and they are failing immediately after the core is started. When a job fails to start, it's not very likely the cause is overheating hardware. If it'd be something causing hardware instability (overheating, overclocking, underclocking, underpowered PSU, whatever), I'd expect a job to fail later, not immediately on startup. With the complexity and wide variaty of GPU cards, I could imagine there are all kinds of edge cases that jobs may not run on specific graphics cards, but CPUs are way more standard. Since both CPU and GPU jobs fail (immediately) the compute hardware itself may not be the problem here.
So the question is, what is causing those jobs to fail immediately.
* Might be a corruption in the installation of the FAH software. You could try to reinstall (if you don't have username and passkey stored elsewhere, keep a copy of c:\ProgramData\FAHClient\config.xml for later reference.
* Might be that the WU data is corrupted on download. Might be something like a virus scanner, or something else in the download pipeline.
* Do you see failures on specific projects only, or is it more generic?
Please keep in mind that even if everything is standard and up to date and otherwise working as expected, you have a specific combination of OS, settings, drivers, virus scanners, hardware, internet router, etc etc. It may be that something very specific triggers a possible bug in the FAH software, or it may not be caused by FAH at all. The only remotely useful info in the logging is: FahCore returned: BAD_WORK_UNIT (114 = 0x72).
If i'd have access to the source code or developers (I don't - maybe someone who is reading this thread does) I'd ask what may be causing this error. That may give a hint on what to chase specifically.
In c:\ProgramData\FAHClient\work you can find sub directories per work unit. A subdir like that under normal circumstances contains a log file as well, with slightly more information than the general logs. Example:
Project: 16969 (Run 16, Clone 1082, Gen 14)
Reading tar file frame14.tpr
Calling: mdrun -c frame14.gro -s frame14.tpr -x frame14.xtc -cpt 15 -nt 14 -ntmpi 1
Steps: first=35000000 total=37500000
Could you please check if a log file like that is kept for such a failing WU?
JimF
Post by JimF »
While you are at it, check the memory also. Memtest is often used, though I have seldom had it find the real problem. If you use four sticks of memory, pull out two and use only slots 2 and 4.
