Help With Optimization
CronWrath
Post by CronWrath »
Hello all,
I'm brand new to F@H and have very little knowledge about computer hardware. In 2012, I purchased a computer with some inheritance money, but didn't have any knowledge of hardware then either. I tried to future proof as best I could, so I probably have some decent specs, but it's probably not a great combination altogether. I've been folding for one whole day, but according to my task manager, my GPU is only working at 2%, while my CPU is consistently above 80%. I'll share my specs, according to F@HControl, if anyone wants to give me some advice:
CPU: Intel (R) Core (TM) i7-3770K CPU @ 3.50GHz
CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
CPUs: 8
Memory: 11.96GiB
Free Memory: 3.54GiB
Threads: WINDOWS_THREADS
OS Version: 6.2
OS: Windows 10 Home
OS Arch: AMD64
GPUs: 1
GPU 0: Bus: 1 Slot: 0 Func: 0 AMD: 5 R575A (Radeon R7 250X/HD 7700/8760)
Also, should I be concerned at all about overheating anything? I downloaded CoreTemps and my CPUs run upwards of 95C.
Any help would be GREATLY appreciated.
Re: Help With Optimization
Welcome to Folding@Home!
1) Task manager 'lies' GPUs, it is showing how much CPU time is spent feeding your GPU. While there are many app for seeing the GPU utilization, I prefer the sensors tab of GPU-Z it will tell you way more than you need to know.
2) It is always best to make sure your GPU drivers are up to date.
https://www.amd.com/en/support/graphics ... on-r7-250x
3) There is a good chance using 4 threads (F@H calls them CPUs) will be with in 20% of using all 8 threads. And cooler.
Open FAHControl, click Configure, click Slots, and select cpu then click Edit.
On this screen is an option to set the number of threads you will use. Again, F@H calls them CPUs. By default F@H sets this to -1 meaning let the software decide.
You can click the up arrow to 4, and say OK and Save until you are at the main screen then choose Exit.
Ask more questions if you want more help, a copy of the first 200 lines of your Log would help us help.
viewtopic.php?f=24&t=26036
CronWrath
Post by CronWrath »
Thanks for the help!
I downloaded the GPU-Z; very helpful!
I updated my drivers through windows. I assume that there aren't updates if I check and it says they're up to date?
I have set my CPUs to 4 threads, no change on the temp yet, but I just changed them, so we'll see in the morning.
Here is my log. Hopefully it's useful and not too long. I did try messing around with some configuration stuff, but I think it's all back to where it should be.
*********************** Log Started 2021-02-26T14:52:14Z ***********************
14:52:14:******************************* libFAH ********************************
14:52:14:           Date: Oct 20 2020
14:52:14:           Time: 13:36:55
14:52:14:       Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
14:52:14:         Branch: master
14:52:14:       Compiler: Visual C++ 2015
14:52:14:        Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
14:52:14:       Platform: win32 10
14:52:14:           Bits: 32
14:52:14:           Mode: Release
14:52:14:****************************** FAHClient ******************************
14:52:14:        Version: 7.6.21
14:52:14:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:52:14:      Copyright: 2020 foldingathome.org
14:52:14:       Homepage: https://foldingathome.org/
14:52:14:           Time: 13:41:04
14:52:14:       Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
14:52:14:           Bits: 32
14:52:14:           Args: --open-web-control
14:52:14:******************************** CBang ********************************
14:52:14:           Time: 11:36:18
14:52:14:       Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
14:52:14:           Bits: 32
14:52:14:******************************* System ********************************
14:52:14:            CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
14:52:14:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:52:14:           CPUs: 8
14:52:14:         Memory: 11.96GiB
14:52:14:    Free Memory: 3.54GiB
14:52:14:        Threads: WINDOWS_THREADS
14:52:14:     OS Version: 6.2
14:52:14:    Has Battery: false
14:52:14:     On Battery: false
14:52:14:     UTC Offset: -8
14:52:14:            PID: 13924
14:52:14:            CWD: C:\ProgramData\FAHClient
14:52:14:  Win32 Service: false
14:52:14:             OS: Windows 10 Home
14:52:14:        OS Arch: AMD64
14:52:14:           GPUs: 1
14:52:14:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 R575A [Radeon R7 250X/HD 7700/8760]
14:52:14:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:52:14:                 specified module could not be found.
14:52:14:
14:52:14:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3075.13
14:52:14:***********************************************************************
14:52:14:<config>
14:52:14:  <!-- Folding Slots -->
14:52:14:</config>
14:52:14:Trying to access database...
14:52:14:Successfully acquired database lock
14:52:14:FS00:Initialized folding slot 00: cpu:6
14:52:14:FS01:Initialized folding slot 01: gpu:1:0 R575A [Radeon R7 250X/HD 7700/8760]
14:52:57:16:127.0.0.1:New Web session
14:53:15:Saving configuration to config.xml
14:53:15:<config>
14:53:15:  <!-- Folding Slots -->
14:53:15:  <slot id='0' type='CPU'/>
14:53:15:  <slot id='1' type='GPU'>
14:53:15:    <pci-bus v='1'/>
14:53:15:    <pci-slot v='0'/>
14:53:15:  </slot>
14:53:15:</config>
14:53:15:Set client configured
14:53:15:WU00:FS00:Connecting to assign1.foldingathome.org:80
14:53:15:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:53:16:WU01:FS01:Connecting to assign1.foldingathome.org:80
14:53:16:WU00:FS00:Assigned to work server 129.32.209.201
14:53:16:WU00:FS00:Requesting new work unit for slot 00: cpu:6 from 129.32.209.201
14:53:16:WU00:FS00:Connecting to 129.32.209.201:8080
14:53:16:WU00:FS00:Downloading 6.65MiB
14:53:16:WU01:FS01:Assigned to work server 206.223.170.146
14:53:16:WU01:FS01:Requesting new work unit for slot 01: gpu:1:0 R575A [Radeon R7 250X/HD 7700/8760] from 206.223.170.146
14:53:16:WU01:FS01:Connecting to 206.223.170.146:8080
14:53:20:WU01:FS01:Downloading 21.69MiB
14:53:21:WU00:FS00:Download complete
14:53:21:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:16927 run:15 clone:784 gen:137 core:0xa7 unit:0x00000310000000890000421f0000000f
14:53:21:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah
14:53:21:WU00:FS00:Connecting to cores.foldingathome.org:80
14:53:21:WU00:FS00:FahCore a7: Downloading 6.71MiB
14:53:24:WU00:FS00:FahCore a7: Download complete
14:53:24:WU00:FS00:Valid core signature
14:53:24:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe
14:53:24:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/libfftw3f-3.dll
14:53:24:WU00:FS00:Starting
14:53:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13924 -checkpoint 15 -np 6
14:53:24:WU00:FS00:Started FahCore on PID 14344
14:53:25:WU00:FS00:Core PID:1772
14:53:25:WU00:FS00:FahCore 0xa7 started
14:53:25:WU00:FS00:0xa7:*********************** Log Started 2021-02-26T14:53:25Z ***********************
14:53:25:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:53:25:WU00:FS00:0xa7:       Type: 0xa7
14:53:25:WU00:FS00:0xa7:       Core: Gromacs
14:53:25:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 14344 -checkpoint 15 -np
14:53:25:WU00:FS00:0xa7:             6
14:53:25:WU00:FS00:0xa7:************************************ CBang *************************************
14:53:25:WU00:FS00:0xa7:       Date: Nov 27 2019
14:53:25:WU00:FS00:0xa7:       Time: 03:40:09
14:53:25:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
14:53:25:WU00:FS00:0xa7:     Branch: master
14:53:25:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:53:25:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:53:25:WU00:FS00:0xa7:   Platform: win32 10
14:53:25:WU00:FS00:0xa7:       Bits: 64
14:53:25:WU00:FS00:0xa7:       Mode: Release
14:53:25:WU00:FS00:0xa7:************************************ System ************************************
14:53:25:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
14:53:25:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:53:25:WU00:FS00:0xa7:       CPUs: 8
14:53:25:WU00:FS00:0xa7:     Memory: 11.96GiB
14:53:25:WU00:FS00:0xa7:Free Memory: 3.19GiB
14:53:25:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:53:25:WU00:FS00:0xa7: OS Version: 6.2
14:53:25:WU00:FS00:0xa7:Has Battery: false
14:53:25:WU00:FS00:0xa7: On Battery: false
14:53:25:WU00:FS00:0xa7: UTC Offset: -8
14:53:25:WU00:FS00:0xa7:        PID: 1772
14:53:25:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
14:53:25:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:53:25:WU00:FS00:0xa7:    Version: 0.0.19
14:53:25:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:53:25:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:53:25:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:53:25:WU00:FS00:0xa7:       Date: Nov 25 2019
14:53:25:WU00:FS00:0xa7:       Time: 17:12:41
14:53:25:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
14:53:25:WU00:FS00:0xa7:************************************ Build *************************************
14:53:25:WU00:FS00:0xa7:       SIMD: avx_256
14:53:25:WU00:FS00:0xa7:********************************************************************************
14:53:25:WU00:FS00:0xa7:Project: 16927 (Run 15, Clone 784, Gen 137)
14:53:25:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
14:53:25:WU00:FS00:0xa7:Reading tar file core.xml
14:53:25:WU00:FS00:0xa7:Reading tar file frame137.tpr
14:53:25:WU00:FS00:0xa7:Digital signatures verified
14:53:25:WU00:FS00:0xa7:Calling: mdrun -s frame137.tpr -o frame137.trr -cpt 15 -nt 6
14:53:25:WU00:FS00:0xa7:Steps: first=68500000 total=500000
14:53:26:WU01:FS01:Download 41.49%
14:53:28:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
14:53:32:WU01:FS01:Download 100.00%
14:53:32:WU01:FS01:Download complete
14:53:32:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:17433 run:0 clone:835 gen:66 core:0x22 unit:0x00000343000000420000441900000000
14:53:32:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
14:53:32:WU01:FS01:Connecting to cores.foldingathome.org:80
14:53:32:WU01:FS01:FahCore 22: Downloading 77.67MiB
14:53:38:WU01:FS01:FahCore 22: 22.21%
14:53:44:WU01:FS01:FahCore 22: 59.07%
14:53:50:WU01:FS01:FahCore 22: 96.41%
14:53:50:WU01:FS01:FahCore 22: Download complete
14:53:50:WU01:FS01:Valid core signature
14:53:50:WU01:FS01:Unpacked 8.33MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe
14:53:51:WU01:FS01:Unpacked 3.06MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc-builtins64_92.dll
14:53:51:WU01:FS01:Unpacked 3.13MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMM.dll
14:53:51:WU01:FS01:Unpacked 2.07MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMOpenCL.dll
14:53:51:WU01:FS01:Unpacked 14.82MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/nvrtc64_92.dll
14:53:52:WU01:FS01:Unpacked 82.99MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/cufft64_92.dll
14:53:53:WU01:FS01:Unpacked 275.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCudaCompiler.dll
14:53:53:WU01:FS01:Unpacked 1.95MiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCUDA.dll
14:53:53:WU01:FS01:Unpacked 786.00KiB to cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/OpenMMCPU.dll
14:53:53:WU01:FS01:Starting
14:53:53:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 13924 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0 -gpu-usage 100
14:53:53:WU01:FS01:Started FahCore on PID 11628
14:53:54:WU01:FS01:Core PID:16876
14:53:54:WU01:FS01:FahCore 0x22 started
14:53:54:WU01:FS01:0x22:*********************** Log Started 2021-02-26T14:53:54Z ***********************
14:53:54:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:53:54:WU01:FS01:0x22:       Core: Core22
14:53:54:WU01:FS01:0x22:       Type: 0x22
14:53:54:WU01:FS01:0x22:    Version: 0.0.13
14:53:54:WU01:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:53:54:WU01:FS01:0x22:  Copyright: 2020 foldingathome.org
14:53:54:WU01:FS01:0x22:   Homepage: https://foldingathome.org/
14:53:54:WU01:FS01:0x22:       Date: Sep 19 2020
14:53:54:WU01:FS01:0x22:       Time: 02:35:58
14:53:54:WU01:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
14:53:54:WU01:FS01:0x22:     Branch: core22-0.0.13
14:53:54:WU01:FS01:0x22:   Compiler: Visual C++ 2015
14:53:54:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:53:54:WU01:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
14:53:54:WU01:FS01:0x22:   Platform: win32 10
14:53:54:WU01:FS01:0x22:       Bits: 64
14:53:54:WU01:FS01:0x22:       Mode: Release
14:53:54:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:53:54:WU01:FS01:0x22:             <peastman@stanford.edu>
14:53:54:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 11628 -checkpoint 15
14:53:54:WU01:FS01:0x22:             -opencl-platform 0 -opencl-device 0 -gpu-vendor amd -gpu 0
14:53:54:WU01:FS01:0x22:             -gpu-usage 100
14:53:54:WU01:FS01:0x22:************************************ libFAH ************************************
14:53:54:WU01:FS01:0x22:       Date: Sep 7 2020
14:53:54:WU01:FS01:0x22:       Time: 19:09:56
14:53:54:WU01:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:53:54:WU01:FS01:0x22:     Branch: HEAD
14:53:54:WU01:FS01:0x22:************************************ CBang *************************************
14:53:54:WU01:FS01:0x22:       Time: 19:08:30
14:53:54:WU01:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:53:54:WU01:FS01:0x22:************************************ System ************************************
14:53:54:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
14:53:54:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:53:54:WU01:FS01:0x22:       CPUs: 8
14:53:54:WU01:FS01:0x22:     Memory: 11.96GiB
14:53:54:WU01:FS01:0x22:Free Memory: 3.10GiB
14:53:54:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
14:53:54:WU01:FS01:0x22: OS Version: 6.2
14:53:54:WU01:FS01:0x22:Has Battery: false
14:53:54:WU01:FS01:0x22: On Battery: false
14:53:54:WU01:FS01:0x22: UTC Offset: -8
14:53:54:WU01:FS01:0x22:        PID: 16876
14:53:54:WU01:FS01:0x22:        CWD: C:\ProgramData\FAHClient\work
14:53:54:WU01:FS01:0x22:************************************ OpenMM ************************************
14:53:54:WU01:FS01:0x22:   Revision: 189320d0
14:53:54:WU01:FS01:0x22:********************************************************************************
14:53:54:WU01:FS01:0x22:Project: 17433 (Run 0, Clone 835, Gen 66)
14:53:54:WU01:FS01:0x22:Unit: 0x00000000000000000000000000000000
14:53:54:WU01:FS01:0x22:Reading tar file core.xml
14:53:54:WU01:FS01:0x22:Reading tar file integrator.xml.bz2
14:53:54:WU01:FS01:0x22:Reading tar file state.xml.bz2
14:53:54:WU01:FS01:0x22:Reading tar file system.xml.bz2
14:53:54:WU01:FS01:0x22:Digital signatures verified
14:53:54:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:53:54:WU01:FS01:0x22:Version 0.0.13
14:53:55:WU01:FS01:0x22:  Checkpoint write interval: 25000 steps (2%) [50 total]
14:53:55:WU01:FS01:0x22:  JSON viewer frame write interval: 12500 steps (1%) [100 total]
14:53:55:WU01:FS01:0x22:  XTC frame write interval: 10000 steps (0.8%) [125 total]
14:53:55:WU01:FS01:0x22:  Global context and integrator variables write interval: disabled
14:53:55:WU01:FS01:0x22:There are 3 platforms available.
14:53:55:WU01:FS01:0x22:Platform 0: Reference
14:53:55:WU01:FS01:0x22:Platform 1: CPU
14:53:55:WU01:FS01:0x22:Platform 2: OpenCL
14:53:55:WU01:FS01:0x22:  opencl-device 0 specified
14:54:32:WU01:FS01:0x22:Attempting to create OpenCL context:
14:54:32:WU01:FS01:0x22:  Configuring platform OpenCL
14:54:47:WU01:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
14:54:47:WU01:FS01:0x22:Completed 0 out of 1250000 steps (0%)
14:54:50:WU01:FS01:0x22:Checkpoint completed at step 0
14:57:09:FS00:Shutting core down
14:57:09:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 1772
14:57:09:WU00:FS00:0xa7:Exiting, please wait. . .
14:57:11:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
14:57:11:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:57:11:WU00:FS00:Starting
14:57:11:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
14:57:11:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
14:57:11:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13924 -checkpoint 15 -np 6
14:57:11:WU00:FS00:Started FahCore on PID 17880
14:57:11:WU00:FS00:Core PID:17904
14:57:11:WU00:FS00:FahCore 0xa7 started
14:57:12:WU00:FS00:0xa7:*********************** Log Started 2021-02-26T14:57:11Z ***********************
14:57:12:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:57:12:WU00:FS00:0xa7:       Type: 0xa7
14:57:12:WU00:FS00:0xa7:       Core: Gromacs
14:57:12:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 17880 -checkpoint 15 -np
14:57:12:WU00:FS00:0xa7:             6
14:57:12:WU00:FS00:0xa7:************************************ CBang *************************************
14:57:12:WU00:FS00:0xa7:       Date: Nov 27 2019
14:57:12:WU00:FS00:0xa7:       Time: 03:40:09
14:57:12:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
14:57:12:WU00:FS00:0xa7:     Branch: master
14:57:12:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:57:12:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:57:12:WU00:FS00:0xa7:   Platform: win32 10
14:57:12:WU00:FS00:0xa7:       Bits: 64
14:57:12:WU00:FS00:0xa7:       Mode: Release
14:57:12:WU00:FS00:0xa7:************************************ System ************************************
14:57:12:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
14:57:12:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:57:12:WU00:FS00:0xa7:       CPUs: 8
14:57:12:WU00:FS00:0xa7:     Memory: 11.96GiB
14:57:12:WU00:FS00:0xa7:Free Memory: 2.81GiB
14:57:12:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:57:12:WU00:FS00:0xa7: OS Version: 6.2
14:57:12:WU00:FS00:0xa7:Has Battery: false
14:57:12:WU00:FS00:0xa7: On Battery: false
14:57:12:WU00:FS00:0xa7: UTC Offset: -8
14:57:12:WU00:FS00:0xa7:        PID: 17904
14:57:12:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
14:57:12:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:57:12:WU00:FS00:0xa7:    Version: 0.0.19
14:57:12:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:57:12:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:57:12:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:57:12:WU00:FS00:0xa7:       Date: Nov 25 2019
14:57:12:WU00:FS00:0xa7:       Time: 17:12:41
14:57:12:WU00:FS00:0xa7:   Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
14:57:12:WU00:FS00:0xa7:************************************ Build *************************************
14:57:12:WU00:FS00:0xa7:       SIMD: avx_256
14:57:12:WU00:FS00:0xa7:********************************************************************************
14:57:12:WU00:FS00:0xa7:Project: 16927 (Run 15, Clone 784, Gen 137)
14:57:12:WU00:FS00:0xa7:Unit: 0x00000000000000000000000000000000
14:57:12:WU00:FS00:0xa7:Digital signatures verified
14:57:12:WU00:FS00:0xa7:Calling: mdrun -s frame137.tpr -o frame137.trr -cpi state.cpt -cpt 15 -nt 6
14:57:12:WU00:FS00:0xa7:Steps: first=68500000 total=500000
14:57:13:WU00:FS00:0xa7:Completed 3362 out of 500000 steps (0%)
14:57:19:Saving configuration to config.xml
14:57:19:<config>
14:57:19:  <!-- Folding Slot Configuration -->
14:57:19:  <cause v='HIGH_PRIORITY'/>
14:57:19:
14:57:19:  <!-- Slot Control -->
14:57:19:  <power v='FULL'/>
14:57:19:
14:57:19:  <!-- User Information -->
14:57:19:  <passkey v='*****'/>
14:57:19:  <team v='234980'/>
14:57:19:  <user v='pw2byp6pducb'/>
14:57:19:
14:57:19:  <!-- Folding Slots -->
14:57:19:  <slot id='0' type='CPU'/>
14:57:19:  <slot id='1' type='GPU'>
14:57:19:    <pci-bus v='1'/>
14:57:19:    <pci-slot v='0'/>
14:57:19:  </slot>
14:57:19:</config>
14:58:30:37:127.0.0.1:New Web session
14:58:57:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
14:59:20:FS00:Shutting core down
14:59:20:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 17904
14:59:20:WU00:FS00:0xa7:Exiting, please wait. . .
14:59:21:Saving configuration to config.xml
14:59:21:<config>
14:59:21:  <!-- Folding Slot Configuration -->
14:59:21:  <cause v='HIGH_PRIORITY'/>
14:59:21:
14:59:21:  <!-- Slot Control -->
14:59:21:  <power v='MEDIUM'/>
14:59:21:
14:59:21:  <!-- User Information -->
14:59:21:  <passkey v='*****'/>
14:59:21:  <team v='234980'/>
14:59:21:  <user v='pw2byp6pducb'/>
14:59:21:
14:59:21:  <!-- Folding Slots -->
14:59:21:  <slot id='0' type='CPU'/>
14:59:21:  <slot id='1' type='GPU'>
14:59:21:    <pci-bus v='1'/>
14:59:21:    <pci-slot v='0'/>
14:59:21:  </slot>
14:59:21:</config>
14:59:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
14:59:23:WU00:FS00:Starting
14:59:23:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
14:59:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 13924 -checkpoint 15 -np 6
14:59:23:WU00:FS00:Started FahCore on PID 16392
14:59:23:WU00:FS00:Core PID:16584
14:59:23:WU00:FS00:FahCore 0xa7 started
14:59:24:WU00:FS00:0xa7:*********************** Log Started 2021-02-26T14:59:23Z ***********************
14:59:24:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:59:24:WU00:FS00:0xa7:       Type: 0xa7
14:59:24:WU00:FS00:0xa7:       Core: Gromacs
14:59:24:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 706 -lifeline 16392 -checkpoint 15 -np
14:59:24:WU00:FS00:0xa7:             6
14:59:24:WU00:FS00:0xa7:************************************ CBang *************************************
14:59:24:WU00:FS00:0xa7:       Date: Nov 27 2019
14:59:24:WU00:FS00:0xa7:       Time: 03:40:09
14:59:24:WU00:FS00:0xa7:   Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
14:59:24:WU00:FS00:0xa7:     Branch: master
14:59:24:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:59:24:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:59:24:WU00:FS00:0xa7:   Platform: win32 10
14:59:24:WU00:FS00:0xa7:       Bits: 64
14:59:24:WU00:FS00:0xa7:       Mode: Release
14:59:24:WU00:FS00:0xa7:************************************ System ************************************
CronWrath wrote:I updated my drivers through windows. I assume that there aren't updates if I check and it says they're up to date?
If you are doing GPU folding, you will want to update your drivers using a download from AMD, not through Windows Update. MS driver installers leave out the OpenCL support that is required for folding.
As Joe_H says, you want updates from AMD. MS updates will shut down Folding. Your log says
I am not sure how recent 3075.13 is but I think it is 2018. I linked above to the latest.
Your log show a great deal of detail about how a new install gets ready to fold, but as far as I read, it shows no problems.
You have 8 CPUs but will use one for GPU support so it shifts to 7, but F@H hates large primes and multiples of large primes, so it shifts to 6 and requests a Work Unit.
It recognizes your GPU and requests a Work Unit for it
You receive an Core_a7 WU for you CPU and the program realizes it has no idea how to run an a7 core and downloads the correct Core
14:53:21:WU00:FS00:Downloading core from http://cores.foldingathome.org/win/64bi ... ore_a7.fah
It knows you are running 64 bit windows and that your CPU has a 256 bit AVX SIMD unit so uses it. This is the best Core_a7 knows about, so you are top notch here. (Core_a8 is newer but you did not get an a8 WU. Both a7 and a8 are rurrent CPU cores)
Then it starts folding on your CPU
It finds the Floating Point math SIMD engine and uses it
Then it finishes the download of the Core_22 GPU WU and realizes it has never run one of those before and downloads Core_22 (There may be Core_21 WUs still out there, but I have not seen one in a year)
14:53:32:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bi ... ore_22.fah
Again, we can see it knows you are on 64 bit Windows
We can see it knows you are running the OpenCL version of Core_22 on an AMD GPU
We run out of log before either process their WUs, but ideally you can see that happening now.
CronWrath
Post by CronWrath »
JimboPalmer wrote:2) It is always best to make sure your GPU drivers are up to date.
So the driver you posted is for the Radeon R7 250X, which is what the FAHControl says, but I actually have a Radeon HD 7700 GHz. I'm not sure why it's listing both. Maybe it can't tell the difference or they're equivalent? Either way, AMD doesn't have a driver specifically for the 7700GHz, but it does have a driver for the 7770Ghz. Are these the same driver-wise?
Also, as far as my temps go, I keep seeing that they shouldn't be at 90C if I want them to last long. Is there a way to keep this down? Maybe just physically cleaning out my PC (it has been awhile)?
Thanks everybody for your help!
https://www.techpowerup.com/gpu-specs/a ... verde.g100
AMD makes a chip called Cape Verde internally, and by running it at different speeds, attaching more RAM, and enabling or disable more or less of the chip make about 20 different commercial cards, all with Cape Verde. Yours has 1 Ghz speed, (thus the name) 1 gigabyte of VRAM, and 640 shaders* enabled. It is the same chip and same number of shaders as the R7 250X, which has more RAM but a slower speed.
I expect the same driver to work. But here is a link right to your flavor.
https://www.amd.com/en/support/previous ... hz-edition
To lower temps you can continue to reduce the number of CPUs in the instructions above: try 2 CPUs and see if temps lower.
Here is a review of Cape Verde in 2012, as you can see above, they made many more 'flavors' later.
https://pcper.com/2012/02/amd-radeon-hd ... pu-review/
*Think of a shader (or stream processor) as a Floating Point Math engine, more of them does more folding.
As JimboPalmer has written, AMD used this Cape Verde chip in many cards over several years. Depending on the exact cards involved, many share the same PCI device ID number as used by the F@h client. The only way to distinguish between them involves using a third field that F@h currently does not use, and may not use in future clients as it doesn't change how the card will be used.
AMD does this across their lineup of GPUs. Often a card in a newer series is basically a renamed card using pretty much the same hardware as a card in an older series. In your case the HD 7770 GHz first sold in 2012 was sold as the OEM HD 8760 about a year later, and then as the R7 250X another year later. AMD was still selling a Cape Verde based card in 2016 as the R7 350 and OEM R7 450.
Bottom line:
As Jimbo and Joe have said in the details above, my Cape Verde and your Cape Verde may be called by different model numbers, but they'll still perform exactly the same steps with exactly the same drivers but at different overall speeds.
CronWrath
Post by CronWrath »
Thanks so much everyone! I've learned a lot and feel much more confident in my folding.
I'm not planning to right now, but when I do, what suggestions would anyone have about upgrades? I'm not sure what tech is the most outdated on my machine.
Also, I cleaned all the dust out of my case and lowered my temps from around 90-95C down to 50-60.
Post by Neil-B »
That is one heck of an improvement - Congratulations :)
As to upgrades ... Hmmm ... I'll stick my neck out here ... For folders looking for efficiency and highest throughput then for the most part the GPU is the focus (as long as everything else can support it) ... Add to that that currently NVIDIA GPUs have an advantage in that FaH can now utilise CUDA and generally seem to be less of a pain as far as drivers are concerned ... Therefore my thought would be look at picking up the best nvidia gpu you can ... However the issue at the moment is that all new gpus are just so price hiked due to current shortages that even my ASUS STRIX RTX3070 OC which I managed to get from a reputable reseller for UK£690 has been increased by ASUS now to UK£920 ... At the price I got is it wasn't cheap but it is a top notch gpu - at current price I wouldnb't buy it tbh ... watching the market and seeing what happens if you are in no hurry may well be a good move :)
Burlingtonian
Hardware configuration: 2 iMacs and 1 dedicated Windows 10 Pro rig with 1 RTX 2070 Super and 1 RTX 2060 KO
Post by Burlingtonian »
Over the last few months, I have twice seen a decrease of about 25% in my daily PPD over a period of several days. In both instances, updating the Nvidia drivers on my primary Windows 10 rig returned my PPD to "normal". There were of course Windows updates as well (there always are) but it appeared to be the Nvidia driver update that solved the PPD issue. I do not understand why the mere availability of a new Nvidia driver would impact my PPD in this manner. Is this just coincidental with the reboot of the computer or is there possibly something else going on?
iero
Post by iero »
Burlingtonian wrote:Over the last few months, I have twice seen a decrease of about 25% in my daily PPD over a period of several days. In both instances, updating the Nvidia drivers on my primary Windows 10 rig returned my PPD to "normal". There were of course Windows updates as well (there always are) but it appeared to be the Nvidia driver update that solved the PPD issue. I do not understand why the mere availability of a new Nvidia driver would impact my PPD in this manner. Is this just coincidental with the reboot of the computer or is there possibly something else going on?
I would say that for Windows, up time definitely plays a role in performance, since process/threads and handles (for the CPU) seem to "hang". For the GPU part, from experience, I restart every 5 days max, but haven't observed a behavior like yours.
GPU only
RTX 3060 12GB Gigabyte Gaming OC [currently mining]
Folding since 14/02/2021
Burlingtonian
iero wrote:I would say that for Windows, up time definitely plays a role in performance, since process/threads and handles (for the CPU) seem to "hang". For the GPU part, from experience, I restart every 5 days max, but haven't observed a behavior like yours.
Thanks for the recommendation. Probably good advice to clean up the Windows 10 "debris field" on at least a weekly basis. Will make it a habit going forward.
Your opinions differ from mine. (That doesn't make either one of us right or wrong ... we just see things differently.)
My kits run for weeks without reboots. (When WindowsUpdate insists on a reboot, I try to postpone it, depending on what is being changed.)
Linux manages to run for months at a time without a reboot.
Driver updates for older GPUs are almost never important to FAH. Driver updates for new hardware can re-optimize the way the hardware performs FAH's calculations, but for the most part GPU drivers seem to be constantly fixing things for specific games. They rarely change anything that matters to FAH. [and no, I'm not a gamer]
