FAHControl not woring, but web control does. How to fix?
knopflerbruce
Post by knopflerbruce »
I have a new issue here. It seems like FAHControl is just stuck at "updating", but the GPUs are folding, and show up in web control. Any clue on how to fix this? Win10 64bit, 460.xx driver if it matters.
Re: FAHControl not woring, but web control does. How to fix?
If I had to guess, your firewall is not allowing FAHcontrol out of your pc
FAHControl should not need an external network connection, but it does need an internal connection. It uses port 36330 on the local IP 127.0.0.1 to connect with the FAHClient process. That does need to be allowed, check firewall or security settings to see if that is being blocked or not listed as "Private".
knopflerbruce
I have disabled the firewall completely, still the same. Anything else I can try? This is a dedicated machine.
gs60
Post by gs60 »
This might be worth a look viewtopic.php?f=108&t=35474
knopflerbruce
I reinstalled a few times and it seems like it was something I did to the config, as it's working now. But not sure what, the only difference (I think?) was not setting 0.0.0.0/0 x2 for remote access.
