Intel iGPU support available (iGP Gen >=7)
Any announcements about FAH policy, servers and new projects will be made here.
"Phase 1"
Limited support for Intel iGPUs is now available.
1) FAHClient must be 7.6.21 or greater.
2) Install the latest Intel GPU drivers from http://downloadcenter.intel.com
(It is supported directly as an optional Windows driver.)
3) You will probably have to add the option GPU-BETA set to TRUE for it to work.
For those looking for Linux graphics display support, if using it as a desktop, it is recommended to use the software provided by your operating system distribution vendor.
As I understand it, when any new GPU is used for the first time, it will start getting benchmarking assignments if you set gpu-beta=true. Once a certain quantity of assignments are completed (by you or by somebody else), the GPU will be granted access to the appropriated class of regular projects and the gpu-beta flag can be removed. [Please report back if that seem to be either correct or incorrect.]
You probably will want to remove the pause-on-start client setting that we've recommended in the past.
GPUs must be Intel Gen 9 or greater. Future support for Gen>9 can be expected in the future. For Gen<9, no support is planned.
Drivers for MacOS may be available. I'll update this message when they're found.
Drivers for Linux supplied in the distro are fine: Example on ubuntu: apt install intel-opencl-icd ; sudo usermod -a -G render $LOGNAME ; apt install ocl-icd-opencl-dev
If the GPU will only be used for "compute", you can instead follow instructions from https://dgpu-docs.intel.com/index.html to get a more up-to-date stack.
Full support for Intel run-time drivers can be found here:
https://software.intel.com/content/www/ ... ph-section
The assigned projects are expected to be limited to very small proteins, consistent with the relatively limited computational capabilities of the hardware. For CPU-only computers (such as laptops) the additional heat generated may or may not be a problem.
Comments and discussion should be directed to the new forum
posting.php?mode=post&f=111
