advanced control issue
I just had a windows update as well as the gpu update both install with no issues, however even though my system is still operating like normal the advanced control part when you open it constantly closes as its loading with no error messages. I cant even get in to copy any logs if there were any in there. I've already tried to unistall and ireinstall F@H but still have the same issue.
Re: advanced control issue
If folding is running (is it?) the logs should be written. Look at the two potential locations in this thread: viewtopic.php?f=108&t=36413
You should be able to find them using explorer and see the latest log and the previous 16 in the <logs> subdirectory. I suspect all the logs will be deleted if you reinstalled and selected delete data. Let us know what you found and if the client is actually running. Welcome to the Forum!
Let me know if this helps for the log file your looking for and yes luckly i was wise enough to even setup the remote management so worse case is i can control it in the advanced contol on that. I did however take notice that My gpu had a update a few hours ago and when it finished the update the system did do a restart and that's when the issue started.
*********************** Log Started 2020-11-13T02:01:05Z ***********************
02:01:05:******************************* libFAH ********************************
02:01:05: Date: Oct 20 2020
02:01:05: Time: 13:36:55
02:01:05: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
02:01:05: Branch: master
02:01:05: Compiler: Visual C++ 2015
02:01:05: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
02:01:05: Platform: win32 10
02:01:05: Bits: 32
02:01:05: Mode: Release
02:01:05:****************************** FAHClient ******************************
02:01:05: Version: 7.6.21
02:01:05: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:01:05: Copyright: 2020 foldingathome.org
02:01:05: Homepage: https://foldingathome.org/
02:01:05: Time: 13:41:04
02:01:05: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
02:01:05: Bits: 32
02:01:05: Args: --open-web-control
02:01:05: Config: C:\Users\Kevin\AppData\Roaming\FAHClient\config.xml
02:01:05:******************************** CBang ********************************
02:01:05: Time: 11:36:18
02:01:05: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
02:01:05: Bits: 32
02:01:05:******************************* System ********************************
02:01:05: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
02:01:05: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
02:01:05: CPUs: 16
02:01:05: Memory: 31.92GiB
02:01:05: Free Memory: 26.69GiB
02:01:05: Threads: WINDOWS_THREADS
02:01:05: OS Version: 6.2
02:01:05: Has Battery: false
02:01:05: On Battery: false
02:01:05: UTC Offset: -5
02:01:05: PID: 5248
02:01:05: CWD: C:\Users\Kevin\AppData\Roaming\FAHClient
02:01:05: Win32 Service: false
02:01:05: OS: Windows 10 Enterprise
02:01:05: OS Arch: AMD64
02:01:05: GPUs: 2
02:01:05: GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:6 GM200 [GeForce GTX 980 Ti] 5632
02:01:05: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
02:01:05: M 13448
02:01:05: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.1
02:01:05: CUDA Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:5.2 Driver:11.1
02:01:05:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:457.30
02:01:05:OpenCL Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:1.2 Driver:457.30
02:01:05:***********************************************************************
02:01:05:<config>
02:01:05: <!-- Folding Core -->
02:01:05: <checkpoint v='3'/>
02:01:05: <core-priority v='low'/>
02:01:05:
02:01:05: <!-- Folding Slot Configuration -->
02:01:05: <cause v='COVID_19'/>
02:01:05:
02:01:05: <!-- HTTP Server -->
02:01:05: <allow v='127.0.0.1, 192.168.0.0'/>
02:01:05:
02:01:05: <!-- Network -->
02:01:05: <proxy v=':8080'/>
02:01:05:
02:01:05: <!-- Remote Command Server -->
02:01:05: <password v='*****'/>
02:01:05:
02:01:05: <!-- Slot Control -->
02:01:05: <pause-on-battery v='false'/>
02:01:05: <power v='full'/>
02:01:05:
02:01:05: <!-- User Information -->
02:01:05: <passkey v='*****'/>
02:01:05: <team v='257944'/>
02:01:05: <user v='Kmiller922'/>
02:01:05:
02:01:05: <!-- Folding Slots -->
02:01:05: <slot id='0' type='CPU'/>
02:01:05: <slot id='1' type='GPU'>
02:01:05: <pci-bus v='2'/>
02:01:05: <pci-slot v='0'/>
02:01:05: </slot>
02:01:05: <slot id='2' type='GPU'>
02:01:05: <pci-bus v='1'/>
02:01:05: </slot>
02:01:05:</config>
02:01:05:Trying to access database...
02:01:05:Successfully acquired database lock
02:01:05:FS00:Initialized folding slot 00: cpu:14
02:01:05:FS01:Initialized folding slot 01: gpu:2:0 GM200 [GeForce GTX 980 Ti] 5632
02:01:05:FS02:Initialized folding slot 02: gpu:1:0 TU102 [GeForce RTX 2080 Ti Rev. A] M 13448
02:01:06:WU01:FS01:Starting
02:01:06:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kevin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 5248 -checkpoint 3 -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor nvidia -gpu 1 -gpu-usage 100
02:01:06:WU01:FS01:Started FahCore on PID 10112
02:01:06:WU01:FS01:Core PID:28616
02:01:06:WU01:FS01:FahCore 0x22 started
02:01:06:WU03:FS02:Starting
02:01:06:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kevin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 706 -lifeline 5248 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
02:01:06:WU03:FS02:Started FahCore on PID 14844
02:01:06:WU03:FS02:Core PID:28560
02:01:06:WU03:FS02:FahCore 0x22 started
02:01:06:WU00:FS00:Starting
02:01:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kevin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 5248 -checkpoint 3 -np 14
02:01:06:WU00:FS00:Started FahCore on PID 22140
02:01:07:WU00:FS00:Core PID:1088
02:01:07:WU00:FS00:FahCore 0xa7 started
02:01:07:WU01:FS01:0x22:*********************** Log Started 2020-11-13T02:01:06Z ***********************
02:01:07:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:01:07:WU01:FS01:0x22: Core: Core22
02:01:07:WU01:FS01:0x22: Type: 0x22
02:01:07:WU01:FS01:0x22: Version: 0.0.13
02:01:07:WU01:FS01:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:01:07:WU01:FS01:0x22: Copyright: 2020 foldingathome.org
02:01:07:WU01:FS01:0x22: Homepage: https://foldingathome.org/
02:01:07:WU01:FS01:0x22: Date: Sep 19 2020
02:01:07:WU01:FS01:0x22: Time: 02:35:58
02:01:07:WU01:FS01:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
02:01:07:WU01:FS01:0x22: Branch: core22-0.0.13
02:01:07:WU01:FS01:0x22: Compiler: Visual C++ 2015
02:01:07:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
02:01:07:WU01:FS01:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
02:01:07:WU01:FS01:0x22: Platform: win32 10
02:01:07:WU01:FS01:0x22: Bits: 64
02:01:07:WU01:FS01:0x22: Mode: Release
02:01:07:WU01:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:01:07:WU01:FS01:0x22: <peastman@stanford.edu>
02:01:07:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 10112 -checkpoint 3
02:01:07:WU01:FS01:0x22: -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu-vendor
02:01:07:WU01:FS01:0x22: nvidia -gpu 1 -gpu-usage 100
02:01:07:WU01:FS01:0x22:************************************ libFAH ************************************
02:01:07:WU01:FS01:0x22: Date: Sep 7 2020
02:01:07:WU01:FS01:0x22: Time: 19:09:56
02:01:07:WU01:FS01:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
02:01:07:WU01:FS01:0x22: Branch: HEAD
02:01:07:WU01:FS01:0x22:************************************ CBang *************************************
02:01:07:WU01:FS01:0x22: Time: 19:08:30
02:01:07:WU01:FS01:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
02:01:07:WU01:FS01:0x22:************************************ System ************************************
02:01:07:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
02:01:07:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
02:01:07:WU01:FS01:0x22: CPUs: 16
02:01:07:WU01:FS01:0x22: Memory: 31.92GiB
02:01:07:WU01:FS01:0x22:Free Memory: 26.68GiB
02:01:07:WU01:FS01:0x22: Threads: WINDOWS_THREADS
02:01:07:WU01:FS01:0x22: OS Version: 6.2
02:01:07:WU01:FS01:0x22:Has Battery: false
02:01:07:WU01:FS01:0x22: On Battery: false
02:01:07:WU01:FS01:0x22: UTC Offset: -5
02:01:07:WU01:FS01:0x22: PID: 28616
02:01:07:WU01:FS01:0x22: CWD: C:\Users\Kevin\AppData\Roaming\FAHClient\work
02:01:07:WU01:FS01:0x22:************************************ OpenMM ************************************
02:01:07:WU01:FS01:0x22: Revision: 189320d0
02:01:07:WU01:FS01:0x22:********************************************************************************
02:01:07:WU01:FS01:0x22:Project: 13428 (Run 3707, Clone 33, Gen 0)
02:01:07:WU01:FS01:0x22:Unit: 0x0000000012bc7d9a000000000e7b0021
02:01:07:WU01:FS01:0x22:Digital signatures verified
02:01:07:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:01:07:WU01:FS01:0x22:Version 0.0.13
02:01:07:WU01:FS01:0x22: Checkpoint write interval: 50000 steps (5%) [20 total]
02:01:07:WU01:FS01:0x22: JSON viewer frame write interval: 10000 steps (1%) [100 total]
02:01:07:WU01:FS01:0x22: XTC frame write interval: 250000 steps (25%) [4 total]
02:01:07:WU01:FS01:0x22: Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
02:01:07:WU01:FS01:0x22:There are 4 platforms available.
02:01:07:WU01:FS01:0x22:Platform 0: Reference
02:01:07:WU01:FS01:0x22:Platform 1: CPU
02:01:07:WU01:FS01:0x22:Platform 2: OpenCL
02:01:07:WU01:FS01:0x22: opencl-device 1 specified
02:01:07:WU01:FS01:0x22:Platform 3: CUDA
02:01:07:WU01:FS01:0x22: cuda-device 1 specified
02:01:07:WU03:FS02:0x22:*********************** Log Started 2020-11-13T02:01:06Z ***********************
02:01:07:WU03:FS02:0x22:*************************** Core22 Folding@home Core ***************************
02:01:07:WU03:FS02:0x22: Core: Core22
02:01:07:WU03:FS02:0x22: Type: 0x22
02:01:07:WU03:FS02:0x22: Version: 0.0.13
02:01:07:WU03:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:01:07:WU03:FS02:0x22: Copyright: 2020 foldingathome.org
02:01:07:WU03:FS02:0x22: Homepage: https://foldingathome.org/
02:01:07:WU03:FS02:0x22: Date: Sep 19 2020
02:01:07:WU03:FS02:0x22: Time: 02:35:58
02:01:07:WU03:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
02:01:07:WU03:FS02:0x22: Branch: core22-0.0.13
02:01:07:WU03:FS02:0x22: Compiler: Visual C++ 2015
02:01:07:WU03:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
02:01:07:WU03:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
02:01:07:WU03:FS02:0x22: Platform: win32 10
02:01:07:WU03:FS02:0x22: Bits: 64
02:01:07:WU03:FS02:0x22: Mode: Release
02:01:07:WU03:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:01:07:WU03:FS02:0x22: <peastman@stanford.edu>
02:01:07:WU03:FS02:0x22: Args: -dir 03 -suffix 01 -version 706 -lifeline 14844 -checkpoint 3
02:01:07:WU03:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
02:01:07:WU03:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
02:01:07:WU03:FS02:0x22:************************************ libFAH ************************************
02:01:07:WU03:FS02:0x22: Date: Sep 7 2020
02:01:07:WU03:FS02:0x22: Time: 19:09:56
02:01:07:WU03:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
02:01:07:WU03:FS02:0x22: Branch: HEAD
02:01:07:WU03:FS02:0x22:************************************ CBang *************************************
02:01:07:WU03:FS02:0x22: Time: 19:08:30
02:01:07:WU03:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
02:01:07:WU03:FS02:0x22:************************************ System ************************************
02:01:07:WU03:FS02:0x22: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
02:01:07:WU03:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
02:01:07:WU03:FS02:0x22: CPUs: 16
02:01:07:WU03:FS02:0x22: Memory: 31.92GiB
02:01:07:WU03:FS02:0x22:Free Memory: 26.68GiB
02:01:07:WU03:FS02:0x22: Threads: WINDOWS_THREADS
02:01:07:WU03:FS02:0x22: OS Version: 6.2
02:01:07:WU03:FS02:0x22:Has Battery: false
02:01:07:WU03:FS02:0x22: On Battery: false
02:01:07:WU03:FS02:0x22: UTC Offset: -5
02:01:07:WU03:FS02:0x22: PID: 28560
02:01:07:WU03:FS02:0x22: CWD: C:\Users\Kevin\AppData\Roaming\FAHClient\work
02:01:07:WU03:FS02:0x22:************************************ OpenMM ************************************
02:01:07:WU03:FS02:0x22: Revision: 189320d0
02:01:07:WU03:FS02:0x22:********************************************************************************
02:01:07:WU03:FS02:0x22:Project: 17311 (Run 0, Clone 454, Gen 16)
02:01:07:WU03:FS02:0x22:Unit: 0x0000001112bc7d9a00000000000001c6
02:01:07:WU03:FS02:0x22:Digital signatures verified
02:01:07:WU03:FS02:0x22:Folding@home GPU Core22 Folding@home Core
02:01:07:WU03:FS02:0x22:Version 0.0.13
02:01:07:WU03:FS02:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
02:01:07:WU03:FS02:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
02:01:07:WU03:FS02:0x22: XTC frame write interval: 125000 steps (10%) [10 total]
02:01:07:WU03:FS02:0x22: Global context and integrator variables write interval: disabled
02:01:07:WU03:FS02:0x22:There are 4 platforms available.
02:01:07:WU03:FS02:0x22:Platform 0: Reference
02:01:07:WU03:FS02:0x22:Platform 1: CPU
02:01:07:WU03:FS02:0x22:Platform 2: OpenCL
02:01:07:WU03:FS02:0x22: opencl-device 0 specified
02:01:07:WU03:FS02:0x22:Platform 3: CUDA
02:01:07:WU03:FS02:0x22: cuda-device 0 specified
02:01:07:WU00:FS00:0xa7:*********************** Log Started 2020-11-13T02:01:07Z ***********************
02:01:07:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:01:07:WU00:FS00:0xa7: Type: 0xa7
02:01:07:WU00:FS00:0xa7: Core: Gromacs
02:01:07:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 22140 -checkpoint 3 -np
02:01:07:WU00:FS00:0xa7: 14
02:01:07:WU00:FS00:0xa7:************************************ CBang *************************************
02:01:07:WU00:FS00:0xa7: Date: Nov 27 2019
02:01:07:WU00:FS00:0xa7: Time: 03:40:09
02:01:07:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
02:01:07:WU00:FS00:0xa7: Branch: master
02:01:07:WU00:FS00:0xa7: Compiler: Visual C++ 2008
02:01:07:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:01:07:WU00:FS00:0xa7: Platform: win32 10
02:01:07:WU00:FS00:0xa7: Bits: 64
02:01:07:WU00:FS00:0xa7: Mode: Release
02:01:07:WU00:FS00:0xa7:************************************ System ************************************
02:01:07:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
02:01:07:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
02:01:07:WU00:FS00:0xa7: CPUs: 16
02:01:07:WU00:FS00:0xa7: Memory: 31.92GiB
02:01:07:WU00:FS00:0xa7:Free Memory: 26.62GiB
02:01:07:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
02:01:07:WU00:FS00:0xa7: OS Version: 6.2
02:01:07:WU00:FS00:0xa7:Has Battery: false
02:01:07:WU00:FS00:0xa7: On Battery: false
02:01:07:WU00:FS00:0xa7: UTC Offset: -5
02:01:07:WU00:FS00:0xa7: PID: 1088
02:01:07:WU00:FS00:0xa7: CWD: C:\Users\Kevin\AppData\Roaming\FAHClient\work
02:01:07:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:01:07:WU00:FS00:0xa7: Version: 0.0.19
02:01:07:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:01:07:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
02:01:07:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
02:01:07:WU00:FS00:0xa7: Date: Nov 25 2019
02:01:07:WU00:FS00:0xa7: Time: 17:12:41
02:01:07:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
02:01:07:WU00:FS00:0xa7:************************************ Build *************************************
02:01:07:WU00:FS00:0xa7: SIMD: avx_256
02:01:07:WU00:FS00:0xa7:********************************************************************************
02:01:07:WU00:FS00:0xa7:Project: 16925 (Run 12, Clone 6617, Gen 14)
02:01:07:WU00:FS00:0xa7:Unit: 0x0000001281d528e500000000000c19d9
02:01:07:WU00:FS00:0xa7:Digital signatures verified
02:01:07:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
02:01:07:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
02:01:07:WU00:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -cpi state.cpt -cpt 3 -nt 12
02:01:07:WU00:FS00:0xa7:Steps: first=7000000 total=500000
02:01:09:WU00:FS00:0xa7:Completed 124577 out of 500000 steps (24%)
02:01:17:WU01:FS01:0x22:Attempting to create CUDA context:
02:01:17:WU01:FS01:0x22: Configuring platform CUDA
02:01:17:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
02:01:18:7:127.0.0.1:New Web session
02:01:22:WU01:FS01:0x22: Using CUDA and gpu 1
02:01:22:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
02:01:23:WU03:FS02:0x22:Attempting to create CUDA context:
02:01:23:WU03:FS02:0x22: Configuring platform CUDA
02:01:28:WU03:FS02:0x22: Using CUDA and gpu 0
02:01:29:WU03:FS02:0x22:Completed 1050000 out of 1250000 steps (84%)
02:01:32:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
02:02:25:WU03:FS02:0x22:Completed 1062500 out of 1250000 steps (85%)
02:02:58:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
02:03:20:WU03:FS02:0x22:Completed 1075000 out of 1250000 steps (86%)
02:03:22:WU03:FS02:0x22:Checkpoint completed at step 1075000
02:04:18:WU03:FS02:0x22:Completed 1087500 out of 1250000 steps (87%)
02:04:37:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
02:05:15:WU03:FS02:0x22:Completed 1100000 out of 1250000 steps (88%)
02:05:17:WU03:FS02:0x22:Checkpoint completed at step 1100000
02:06:14:WU03:FS02:0x22:Completed 1112500 out of 1250000 steps (89%)
02:06:21:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
02:07:11:WU03:FS02:0x22:Completed 1125000 out of 1250000 steps (90%)
02:07:13:WU03:FS02:0x22:Checkpoint completed at step 1125000
02:08:05:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
02:08:10:WU03:FS02:0x22:Completed 1137500 out of 1250000 steps (91%)
02:09:08:WU03:FS02:0x22:Completed 1150000 out of 1250000 steps (92%)
02:09:10:WU03:FS02:0x22:Checkpoint completed at step 1150000
02:09:42:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
02:09:43:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
02:10:07:WU03:FS02:0x22:Completed 1162500 out of 1250000 steps (93%)
02:11:05:WU03:FS02:0x22:Completed 1175000 out of 1250000 steps (94%)
02:11:06:WU03:FS02:0x22:Checkpoint completed at step 1175000
02:11:19:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
02:12:04:WU03:FS02:0x22:Completed 1187500 out of 1250000 steps (95%)
02:12:53:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
02:13:01:WU03:FS02:0x22:Completed 1200000 out of 1250000 steps (96%)
02:13:02:WU03:FS02:0x22:Checkpoint completed at step 1200000
02:14:00:WU03:FS02:0x22:Completed 1212500 out of 1250000 steps (97%)
02:14:29:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
02:14:57:WU03:FS02:0x22:Completed 1225000 out of 1250000 steps (98%)
02:14:59:WU03:FS02:0x22:Checkpoint completed at step 1225000
02:15:56:WU03:FS02:0x22:Completed 1237500 out of 1250000 steps (99%)
02:15:57:WU02:FS02:Connecting to assign1.foldingathome.org:80
02:15:57:WU02:FS02:Assigned to work server 18.188.125.154
02:15:57:WU02:FS02:Requesting new work unit for slot 02: gpu:1:0 TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 18.188.125.154
02:15:57:WU02:FS02:Connecting to 18.188.125.154:8080
02:15:59:WU02:FS02:Downloading 15.70MiB
02:16:00:WU02:FS02:Download complete
02:16:01:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:17311 run:0 clone:1808 gen:8 core:0x22 unit:0x0000000a12bc7d9a0000000000000710
02:16:04:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
02:16:53:WU03:FS02:0x22:Completed 1250000 out of 1250000 steps (100%)
02:16:53:WU03:FS02:0x22:Average performance: 375.652 ns/day
02:16:55:WU03:FS02:0x22:Checkpoint completed at step 1250000
02:17:12:WU03:FS02:0x22:Saving result file ..\logfile_01.txt
02:17:12:WU03:FS02:0x22:Saving result file checkpointIntegrator.xml.bz2
02:17:13:WU03:FS02:0x22:Saving result file checkpointState.xml.bz2
02:17:13:WU03:FS02:0x22:Saving result file positions.xtc
02:17:14:WU03:FS02:0x22:Saving result file science.log
02:17:14:WU03:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
02:17:14:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:17:14:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:17311 run:0 clone:454 gen:16 core:0x22 unit:0x0000001112bc7d9a00000000000001c6
02:17:14:WU03:FS02:Uploading 26.53MiB to 18.188.125.154
02:17:14:WU03:FS02:Connecting to 18.188.125.154:8080
02:17:14:WU02:FS02:Starting
02:17:14:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Kevin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 5248 -checkpoint 3 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
02:17:14:WU02:FS02:Started FahCore on PID 26268
02:17:14:WU02:FS02:Core PID:26532
02:17:14:WU02:FS02:FahCore 0x22 started
02:17:15:WU02:FS02:0x22:*********************** Log Started 2020-11-13T02:17:15Z ***********************
02:17:15:WU02:FS02:0x22:*************************** Core22 Folding@home Core ***************************
02:17:15:WU02:FS02:0x22: Core: Core22
02:17:15:WU02:FS02:0x22: Type: 0x22
02:17:15:WU02:FS02:0x22: Version: 0.0.13
02:17:15:WU02:FS02:0x22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:17:15:WU02:FS02:0x22: Copyright: 2020 foldingathome.org
02:17:15:WU02:FS02:0x22: Homepage: https://foldingathome.org/
02:17:15:WU02:FS02:0x22: Date: Sep 19 2020
02:17:15:WU02:FS02:0x22: Time: 02:35:58
02:17:15:WU02:FS02:0x22: Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
02:17:15:WU02:FS02:0x22: Branch: core22-0.0.13
02:17:15:WU02:FS02:0x22: Compiler: Visual C++ 2015
02:17:15:WU02:FS02:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
02:17:15:WU02:FS02:0x22: -DOPENMM_GIT_HASH="\"189320d0\""
02:17:15:WU02:FS02:0x22: Platform: win32 10
02:17:15:WU02:FS02:0x22: Bits: 64
02:17:15:WU02:FS02:0x22: Mode: Release
02:17:15:WU02:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
02:17:15:WU02:FS02:0x22: <peastman@stanford.edu>
02:17:15:WU02:FS02:0x22: Args: -dir 02 -suffix 01 -version 706 -lifeline 26268 -checkpoint 3
02:17:15:WU02:FS02:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
02:17:15:WU02:FS02:0x22: nvidia -gpu 0 -gpu-usage 100
02:17:15:WU02:FS02:0x22:************************************ libFAH ************************************
02:17:15:WU02:FS02:0x22: Date: Sep 7 2020
02:17:15:WU02:FS02:0x22: Time: 19:09:56
02:17:15:WU02:FS02:0x22: Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
02:17:15:WU02:FS02:0x22: Branch: HEAD
02:17:15:WU02:FS02:0x22:************************************ CBang *************************************
02:17:15:WU02:FS02:0x22: Time: 19:08:30
02:17:15:WU02:FS02:0x22: Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
02:17:15:WU02:FS02:0x22:************************************ System ************************************
02:17:15:WU02:FS02:0x22: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
02:17:15:WU02:FS02:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
02:17:15:WU02:FS02:0x22: CPUs: 16
02:17:15:WU02:FS02:0x22: Memory: 31.92GiB
02:17:15:WU02:FS02:0x22:Free Memory: 25.40GiB
02:17:15:WU02:FS02:0x22: Threads: WINDOWS_THREADS
02:17:15:WU02:FS02:0x22: OS Version: 6.2
02:17:15:WU02:FS02:0x22:Has Battery: false
02:17:15:WU02:FS02:0x22: On Battery: false
02:17:15:WU02:FS02:0x22: UTC Offset: -5
02:17:15:WU02:FS02:0x22: PID: 26532
02:17:15:WU02:FS02:0x22: CWD: C:\Users\Kevin\AppData\Roaming\FAHClient\work
02:17:15:WU02:FS02:0x22:************************************ OpenMM ************************************
02:17:15:WU02:FS02:0x22: Revision: 189320d0
02:17:15:WU02:FS02:0x22:********************************************************************************
02:17:15:WU02:FS02:0x22:Project: 17311 (Run 0, Clone 1808, Gen 8)
02:17:15:WU02:FS02:0x22:Unit: 0x0000000a12bc7d9a0000000000000710
02:17:15:WU02:FS02:0x22:Reading tar file core.xml
02:17:15:WU02:FS02:0x22:Reading tar file integrator.xml.bz2
02:17:15:WU02:FS02:0x22:Reading tar file state.xml.bz2
02:17:15:WU02:FS02:0x22:Reading tar file system.xml.bz2
02:17:15:WU02:FS02:0x22:Digital signatures verified
02:17:15:WU02:FS02:0x22:Folding@home GPU Core22 Folding@home Core
02:17:15:WU02:FS02:0x22:Version 0.0.13
02:17:15:WU02:FS02:0x22: Checkpoint write interval: 25000 steps (2%) [50 total]
02:17:15:WU02:FS02:0x22: JSON viewer frame write interval: 12500 steps (1%) [100 total]
02:17:15:WU02:FS02:0x22: XTC frame write interval: 125000 steps (10%) [10 total]
02:17:15:WU02:FS02:0x22: Global context and integrator variables write interval: disabled
02:17:15:WU02:FS02:0x22:There are 4 platforms available.
02:17:15:WU02:FS02:0x22:Platform 0: Reference
02:17:15:WU02:FS02:0x22:Platform 1: CPU
02:17:15:WU02:FS02:0x22:Platform 2: OpenCL
02:17:15:WU02:FS02:0x22: opencl-device 0 specified
02:17:15:WU02:FS02:0x22:Platform 3: CUDA
02:17:15:WU02:FS02:0x22: cuda-device 0 specified
02:17:20:WU03:FS02:Upload 61.02%
02:17:24:WU03:FS02:Upload complete
02:17:24:WU03:FS02:Server responded WORK_ACK (400)
02:17:24:WU03:FS02:Final credit estimate, 242463.00 points
02:17:24:WU03:FS02:Cleaning up
02:17:31:WU02:FS02:0x22:Attempting to create CUDA context:
02:17:31:WU02:FS02:0x22: Configuring platform CUDA
02:17:36:WU02:FS02:0x22: Using CUDA and gpu 0
02:17:37:WU02:FS02:0x22:Completed 0 out of 1250000 steps (0%)
02:17:38:WU02:FS02:0x22:Checkpoint completed at step 0
02:17:40:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
02:18:04:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
02:18:34:WU02:FS02:0x22:Completed 12500 out of 1250000 steps (1%)
02:19:15:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
02:19:31:WU02:FS02:0x22:Completed 25000 out of 1250000 steps (2%)
02:19:32:WU02:FS02:0x22:Checkpoint completed at step 25000
02:20:29:WU02:FS02:0x22:Completed 37500 out of 1250000 steps (3%)
02:20:51:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
02:21:26:WU02:FS02:0x22:Completed 50000 out of 1250000 steps (4%)
02:21:27:WU02:FS02:0x22:Checkpoint completed at step 50000
02:22:25:WU02:FS02:0x22:Completed 62500 out of 1250000 steps (5%)
02:22:30:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
02:23:22:WU02:FS02:0x22:Completed 75000 out of 1250000 steps (6%)
02:23:23:WU02:FS02:0x22:Checkpoint completed at step 75000
02:24:12:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
02:24:21:WU02:FS02:0x22:Completed 87500 out of 1250000 steps (7%)
02:25:18:WU02:FS02:0x22:Completed 100000 out of 1250000 steps (8%)
02:25:19:WU02:FS02:0x22:Checkpoint completed at step 100000
02:25:55:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
02:26:16:WU02:FS02:0x22:Completed 112500 out of 1250000 steps (9%)
02:26:26:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
02:27:13:WU02:FS02:0x22:Completed 125000 out of 1250000 steps (10%)
02:27:15:WU02:FS02:0x22:Checkpoint completed at step 125000
02:27:37:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
02:28:12:WU02:FS02:0x22:Completed 137500 out of 1250000 steps (11%)
02:29:09:WU02:FS02:0x22:Completed 150000 out of 1250000 steps (12%)
02:29:10:WU02:FS02:0x22:Checkpoint completed at step 150000
02:29:16:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
02:30:08:WU02:FS02:0x22:Completed 162500 out of 1250000 steps (13%)
02:30:54:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
02:31:05:WU02:FS02:0x22:Completed 175000 out of 1250000 steps (14%)
02:31:06:WU02:FS02:0x22:Checkpoint completed at step 175000
02:32:03:WU02:FS02:0x22:Completed 187500 out of 1250000 steps (15%)
02:32:30:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
02:33:00:WU02:FS02:0x22:Completed 200000 out of 1250000 steps (16%)
02:33:02:WU02:FS02:0x22:Checkpoint completed at step 200000
I tried to do a full data wipe when I tried to reinstall F@H again but now i dont even have remote control from other system. I can'g get the advanced control for F@H to open at all when i try to it crashes
According to your log above, the client stores the data in C:\Users\Kevin\AppData\Roaming\FAHClient but FAH 7.6.21 actually should store it in C:\ProgramData\FAHClient
Maybe this is the source of the issue.
I would stop the client, uninstall incl. data, then check whether C:\Users\Kevin\AppData\Roaming\FAHClient and/or C:\ProgramData\FAHClient still exist and if yes delete them, then reinstall.
After looking around the lovely hidden files of dear old windows I managed to find the c:\ProgramData\FAHClient folder it turns out that path and the one in the log that I posted are both hidden folders go figure. I will try to purge all data and try to reinstall again. One other thing I did accidently find was if i ran tha FAHControl application manually a command window popped up watching it do its thing when it got to the part for the system tray is where it crashed and hung not sure if that helps at all but cant find a log or location a log file would be for that application.
I've now tried removing everything that had F@H in it anywhere in the system and still having the same issues with advanced control side of it. I wonder if the last update from Nvidia a few days ago is causing the issue and I'm not sure how to go about looking at that. Is there any type of diagonstic tool or something to be able to try to debug what its doing. If one of the admin or program developers need to remote in to see whats going on I'm all for it. Theres still so much research that needs to be done and having the remote management makes keeping tabs on everything so much easier.
One quick note my tower which is the system thats giving me the issue the Nvidia driver updated to Version: 457.30 Release date: 11/09/2020
Now my laptop which is also a Nvidia driver has not updated yet sorry for just noticing this Version: 457.09 Release date:10/29/2020
I hope that this little bit of information may shed some light on the problem for me I might be in a bit over my head on debugging without help
NEWS FLASH:::::::::
Attention All Nvidia Users
Do not do your driver update To Version 457.30 that was Released on 11/9/20 Keep using 457.09 from 10/29/20
This is what was causing the issue of the advanced control for F@H not to open and crash out. I was able to redownload the previous version from Nvidia's web site and roll back the GPU driver and can now access all of F@H without any issues except for me being a complete idiot and not writing a few things down when i had setup the remote management like ip# and such.
II'd like to thank the people that responded and tried to help sometimes you just need some more brain power added to sort a problem out.
Humm... glad that you figured it out and are back to folding. I am not sure why Nvidia drivers would be impacting a single application interface.
I took notice when my son went to play COD Cold War which came out at the same time as the driver update and he started having crashes with that as well. As messed up as it sound i took a look at our laptop which is also folding and noticed the driver had not been updated and everything including the crazy game was working on that. After a lot of banging my head on the wall the light shined on the driver being the only divrence between the two systyems. Of course now I'm having major brain block with the remote setup got it working on the tower with out a problem can see and control both but now for the life of me cant get the laptop to see both. Good old Murphy's Law i guess lol.
- Hardware configuration: i5-8600K OC @ 4.7GHz
2 x GTX 1080
FWIF, I am using 457.30 without issue.Kmiller922 wrote:NEWS FLASH:::::::::
It may be that the main part of that upddate is geared to the rtx cards i'm running a RTX 280 TI I do know most of that update was geared to the newer cards that are out.robinson wrote: FWIF, I am using 457.30 without issue.
Kmiller922, I also noticed when looking through your log that you have checkpoints set at 3 minutes. Unless you have an unstable system or unreliable power, you might consider removing that and using the default 15 minute interval. That will reduce the load on your system, especially if you have spinning disks. Sometimes the problems with advanced control seeing or not seeing your systems can be attributed to the joys of windows networking. You may find it necessary to reboot your system(s) after some configuration changes before they are fully implemented.
I had reduced the checkpoints while trying to debug what was going on I have since rest them back, thanks for the reminder though it's normaly one of the things I tend to forget about resetting after I fix a issue.HendricksSA wrote:Kmiller922, I also noticed when looking through your log that you have checkpoints set at 3 minutes. Unless you have an unstable system or unreliable power, you might consider removing that and using the default 15 minute interval. That will reduce the load on your system, especially if you have spinning disks. Sometimes the problems with advanced control seeing or not seeing your systems can be attributed to the joys of windows networking. You may find it necessary to reboot your system(s) after some configuration changes before they are fully implemented.
I sometimes do something like that. The other thing I do is add "Pause-on-start (True)" to the slot I'm working on so I can undo something that I tried and it didn't work correctly. Then I'm only reminded when I reboot.Kmiller922 wrote:I had reduced the checkpoints while trying to debug what was going on I have since rest them back, thanks for the reminder though it's normal one of the things I tend to forget about resetting after I fix a issue.
