20:18:34:FS01:Initialized folding slot 01: gpu:1:0 TU102 [GeForce RTX 2080 Ti Rev. A] M 13448
20:18:34:FS00:Initialized folding slot 00: cpu:8
20:18:34:WARNING:FS02:Guessing ambiguous GPU to OpenCL device mapping for 02: gpu:0:2 Gen9p5/GT2 [UHD Graphics 630]. Consider upgrading your graphics driver or manually setting ``opencl-index`` in this slot's configuration.
20:18:34:WARNING:FS02:Disabling beta GPU slot 02: gpu:0:2 Gen9p5/GT2 [UHD Graphics 630]. Beta GPUs can be tested for no points by setting ``gpu-beta=true`` in the configuration.Is this still in development and it leaked into the wild? Or can we start using the iGPU now?bruce wrote:The Intel GPUs are not supported yet. They are being tested by a select group of beta testers and we're waiting for their reports. Please disable FAH from using the Iris 630. You can set "Pause-on-start" to "true" for that device or you can disable it in the BIOS.
Thanks
