Hi,
I can't connect to the client at my work, only at home. I think it's because when I installed FAH, I selected connect only to private network.
I can't find how to correct that in the options of the advanced or web views.
can't connect from work
Patrick Australien
- Hardware configuration: PC Gamer MSI MAG META 5
- OS: Windows 10 Famille 64 Bits
- MB : B450M PRO-VDH MAX (MSI)
- CPU : AMD Ryzen 5 3600 - 6 cores/12 threads - 3600 MHz
- Ventirad : Pure Rock Slim (Be quiet!)
- GPU : NVIDIA GeForce GTX 1660 SUPER (MSI)
- RAM : 2x8GB DDR4-2666 (Integral)
- SSD NVMe : Western Digital PC SN730 NVMe (512Go)
- HDD : Western Digital WDC WD10EZEX-22MFCA0 (1To) - Location: Nîmes-France
Re: can't connect from work
Hello
Maybe in Windows.
https://pureinfotech.com/allow-apps-fir ... indows-10/
Open Windows Security.
Click on Firewall & network protection.
Click the Allow an app through firewall link. ...
Click the Change settings button.
Check the app or feature you want to allow through the firewall on Windows 10.
Check on which type of networks an app can access the network: Private, Public
Click the OK button.
Maybe in Windows.
simonvilleneuve
Hey, thank you for this answer! I've done that too, but nothing's change. I've screenshot it. How I can put an image here?Patrick Australien wrote:Hello
Maybe in Windows.![]()
Please see this topic - viewtopic.php?f=18&t=17794 - with tips on troubleshooting connections.
My guess would be that at work you are behind a firewall that does not allow non-recognized software to make HTTP(s) connections to download and upload. The firewall would allow recognized browsers such as IE, Edge, Firefox, Safari and so on to make these types of connections over ports 80 and 8080. If this is the case, work IT staff would need to add an exception for the FAHClient part of the F@h client to access the internet and transfer files.
That brings up the Terms of Use for the F@h software. It includes that if you are running on work equipment that you should have written permission. Many companies would include the use of their network as work equipment.
... and the PC on your desk probably isn't one you brought from home. The company's IS folks probably have a policy that you should follow.
