Cant Update Core 22
Lajiola
Cant Update Core 22
Post by Lajiola »
Hello,
i cant update the FAH GPU Core 22. The Download stucks all the time at the end.
By now im at try 25 to Redownload it.
The Update for the CPU Core works perfect.
is there any chance to update it manually, the download works with browser for the core22.sah perfect.
But i dont have a clue to unpack it.
*********************** Log Started 2020-10-14T12:12:21Z ***********************
12:12:21:Trying to access database...
12:12:21:Successfully acquired database lock
12:12:21:Read GPUs.txt
12:12:21:Enabled folding slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
12:12:21:****************************** FAHClient ******************************
12:12:21:        Version: 7.6.13
12:12:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:12:21:      Copyright: 2020 foldingathome.org
12:12:21:       Homepage: https://foldingathome.org/
12:12:21:           Date: Apr 27 2020
12:12:21:           Time: 21:21:01
12:12:21:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
12:12:21:         Branch: master
12:12:21:       Compiler: Visual C++ 2008
12:12:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:12:21:       Platform: win32 10
12:12:21:           Bits: 32
12:12:21:           Mode: Release
12:12:21:           Args: --open-web-control
12:12:21:         Config: C:\Users\mail\AppData\Roaming\FAHClient\config.xml
12:12:21:******************************** CBang ********************************
12:12:21:           Date: Apr 24 2020
12:12:21:           Time: 17:07:55
12:12:21:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
12:12:21:           Bits: 32
12:12:21:******************************* System ********************************
12:12:21:            CPU: AMD Ryzen 9 3900X 12-Core Processor
12:12:21:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
12:12:21:           CPUs: 24
12:12:21:         Memory: 31.95GiB
12:12:21:    Free Memory: 21.33GiB
12:12:21:        Threads: WINDOWS_THREADS
12:12:21:     OS Version: 6.2
12:12:21:    Has Battery: false
12:12:21:     On Battery: false
12:12:21:     UTC Offset: 2
12:12:21:            PID: 3248
12:12:21:            CWD: C:\Users\mail\AppData\Roaming\FAHClient
12:12:21:  Win32 Service: false
12:12:21:             OS: Windows 10 Enterprise
12:12:21:        OS Arch: AMD64
12:12:21:           GPUs: 1
12:12:21:          GPU 0: Bus:45 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT
12:12:21:                 / 5700/5700 XT]
12:12:21:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
12:12:21:                 angegebene Modul wurde nicht gefunden.
12:12:21:
12:12:21:OpenCL Device 0: Platform:0 Device:0 Bus:45 Slot:0 Compute:1.2 Driver:3110.7
12:12:21:******************************* libFAH ********************************
12:12:21:           Date: Apr 15 2020
12:12:21:           Time: 14:53:14
12:12:21:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
12:12:21:           Bits: 32
12:12:21:***********************************************************************
12:12:22:<config>
12:12:22:  <!-- Network -->
12:12:22:  <proxy v=':8080'/>
12:12:22:
12:12:22:  <!-- Folding Slots -->
12:12:22:  <slot id='1' type='GPU'/>
12:12:22:</config>
12:12:22:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
12:12:22:WU01:FS01:Connecting to cores.foldingathome.org:80
12:12:22:WU01:FS01:FahCore 22: Downloading 77.67MiB
12:12:23:4:127.0.0.1:New Web session
12:12:28:WU01:FS01:FahCore 22: 0.80%
12:12:34:WU01:FS01:FahCore 22: 1.21%
12:12:40:WU01:FS01:FahCore 22: 1.93%
12:12:46:WU01:FS01:FahCore 22: 2.58%
12:12:52:WU01:FS01:FahCore 22: 3.14%
12:12:58:WU01:FS01:FahCore 22: 3.78%
12:13:04:WU01:FS01:FahCore 22: 4.35%
12:13:10:WU01:FS01:FahCore 22: 4.99%
12:13:16:WU01:FS01:FahCore 22: 5.79%
12:13:22:WU01:FS01:FahCore 22: 6.44%
12:13:28:WU01:FS01:FahCore 22: 6.92%
12:13:34:WU01:FS01:FahCore 22: 7.48%
12:13:40:WU01:FS01:FahCore 22: 7.89%
12:13:46:WU01:FS01:FahCore 22: 8.45%
12:13:52:WU01:FS01:FahCore 22: 9.09%
12:13:58:WU01:FS01:FahCore 22: 9.66%
12:14:04:WU01:FS01:FahCore 22: 10.30%
12:14:10:WU01:FS01:FahCore 22: 10.78%
12:14:16:WU01:FS01:FahCore 22: 11.27%
12:14:22:WU01:FS01:FahCore 22: 11.83%
12:14:28:WU01:FS01:FahCore 22: 12.31%
12:14:34:WU01:FS01:FahCore 22: 13.12%
12:14:40:WU01:FS01:FahCore 22: 13.76%
12:14:46:WU01:FS01:FahCore 22: 14.49%
12:14:52:WU01:FS01:FahCore 22: 14.97%
12:14:58:WU01:FS01:FahCore 22: 15.53%
12:15:04:WU01:FS01:FahCore 22: 16.01%
12:15:10:WU01:FS01:FahCore 22: 16.58%
12:15:16:WU01:FS01:FahCore 22: 17.14%
12:15:22:WU01:FS01:FahCore 22: 17.70%
12:15:28:WU01:FS01:FahCore 22: 18.27%
12:15:34:WU01:FS01:FahCore 22: 18.75%
12:15:40:WU01:FS01:FahCore 22: 19.23%
12:15:46:WU01:FS01:FahCore 22: 19.80%
12:15:52:WU01:FS01:FahCore 22: 20.36%
12:15:58:WU01:FS01:FahCore 22: 21.08%
12:16:04:WU01:FS01:FahCore 22: 21.65%
12:16:10:WU01:FS01:FahCore 22: 22.13%
12:16:16:WU01:FS01:FahCore 22: 22.69%
12:16:22:WU01:FS01:FahCore 22: 23.34%
12:16:28:WU01:FS01:FahCore 22: 23.90%
12:16:34:WU01:FS01:FahCore 22: 24.38%
12:16:40:WU01:FS01:FahCore 22: 24.95%
12:16:47:WU01:FS01:FahCore 22: 25.43%
12:16:53:WU01:FS01:FahCore 22: 25.75%
12:16:59:WU01:FS01:FahCore 22: 26.56%
12:17:06:WU01:FS01:FahCore 22: 26.96%
12:17:12:WU01:FS01:FahCore 22: 27.44%
12:17:18:WU01:FS01:FahCore 22: 27.76%
12:17:24:WU01:FS01:FahCore 22: 28.33%
12:17:30:WU01:FS01:FahCore 22: 29.05%
12:17:36:WU01:FS01:FahCore 22: 29.61%
12:17:42:WU01:FS01:FahCore 22: 29.86%
12:17:48:WU01:FS01:FahCore 22: 30.18%
12:17:54:WU01:FS01:FahCore 22: 30.58%
12:18:00:WU01:FS01:FahCore 22: 30.98%
12:18:06:WU01:FS01:FahCore 22: 31.71%
12:18:13:WU01:FS01:FahCore 22: 32.27%
12:18:19:WU01:FS01:FahCore 22: 32.59%
12:18:25:WU01:FS01:FahCore 22: 33.32%
12:18:31:WU01:FS01:FahCore 22: 34.12%
12:18:37:WU01:FS01:FahCore 22: 34.84%
12:18:43:WU01:FS01:FahCore 22: 35.25%
12:18:49:WU01:FS01:FahCore 22: 35.81%
12:18:56:WU01:FS01:FahCore 22: 36.21%
12:19:02:WU01:FS01:FahCore 22: 36.78%
12:19:08:WU01:FS01:FahCore 22: 37.42%
12:19:14:WU01:FS01:FahCore 22: 37.90%
12:19:20:WU01:FS01:FahCore 22: 38.39%
12:19:26:WU01:FS01:FahCore 22: 38.71%
12:19:32:WU01:FS01:FahCore 22: 39.11%
12:19:38:WU01:FS01:FahCore 22: 39.51%
12:19:45:WU01:FS01:FahCore 22: 39.99%
12:19:51:WU01:FS01:FahCore 22: 40.64%
12:19:57:WU01:FS01:FahCore 22: 41.28%
12:20:03:WU01:FS01:FahCore 22: 41.85%
12:20:09:WU01:FS01:FahCore 22: 42.49%
12:20:15:WU01:FS01:FahCore 22: 43.05%
12:20:21:WU01:FS01:FahCore 22: 43.62%
12:20:27:WU01:FS01:FahCore 22: 44.10%
12:20:33:WU01:FS01:FahCore 22: 44.66%
12:20:39:WU01:FS01:FahCore 22: 45.47%
12:20:45:WU01:FS01:FahCore 22: 46.11%
12:20:51:WU01:FS01:FahCore 22: 46.51%
12:20:57:WU01:FS01:FahCore 22: 46.92%
12:21:03:WU01:FS01:FahCore 22: 47.48%
12:21:09:WU01:FS01:FahCore 22: 48.04%
12:21:15:WU01:FS01:FahCore 22: 48.61%
12:21:21:WU01:FS01:FahCore 22: 49.09%
12:21:27:WU01:FS01:FahCore 22: 49.49%
12:21:33:WU01:FS01:FahCore 22: 49.81%
12:21:39:WU01:FS01:FahCore 22: 50.38%
12:21:45:WU01:FS01:FahCore 22: 50.94%
12:21:51:WU01:FS01:FahCore 22: 51.42%
12:21:57:WU01:FS01:FahCore 22: 51.90%
12:22:03:WU01:FS01:FahCore 22: 52.39%
12:22:09:WU01:FS01:FahCore 22: 52.87%
12:22:15:WU01:FS01:FahCore 22: 53.59%
12:22:22:WU01:FS01:FahCore 22: 54.08%
12:22:29:WU01:FS01:FahCore 22: 54.56%
12:22:35:WU01:FS01:FahCore 22: 55.04%
12:22:41:WU01:FS01:FahCore 22: 55.77%
12:22:47:WU01:FS01:FahCore 22: 56.33%
12:22:53:WU01:FS01:FahCore 22: 56.81%
12:22:59:WU01:FS01:FahCore 22: 57.22%
12:23:05:WU01:FS01:FahCore 22: 57.54%
12:23:11:WU01:FS01:FahCore 22: 57.94%
12:23:17:WU01:FS01:FahCore 22: 58.50%
12:23:23:WU01:FS01:FahCore 22: 59.23%
12:23:29:WU01:FS01:FahCore 22: 59.95%
12:23:35:WU01:FS01:FahCore 22: 60.43%
12:23:41:WU01:FS01:FahCore 22: 61.00%
12:23:48:WU01:FS01:FahCore 22: 61.96%
12:23:55:WU01:FS01:FahCore 22: 62.53%
12:24:01:WU01:FS01:FahCore 22: 63.17%
12:24:07:WU01:FS01:FahCore 22: 63.81%
12:24:13:WU01:FS01:FahCore 22: 64.30%
12:24:19:WU01:FS01:FahCore 22: 64.86%
12:24:25:WU01:FS01:FahCore 22: 65.50%
12:24:31:WU01:FS01:FahCore 22: 66.31%
12:24:37:WU01:FS01:FahCore 22: 67.03%
12:24:43:WU01:FS01:FahCore 22: 67.60%
12:24:49:WU01:FS01:FahCore 22: 68.08%
12:24:55:WU01:FS01:FahCore 22: 68.72%
12:25:01:WU01:FS01:FahCore 22: 69.29%
12:25:07:WU01:FS01:FahCore 22: 69.69%
12:25:13:WU01:FS01:FahCore 22: 70.33%
12:25:19:WU01:FS01:FahCore 22: 70.82%
12:25:25:WU01:FS01:FahCore 22: 71.22%
12:25:32:WU01:FS01:FahCore 22: 71.86%
12:25:38:WU01:FS01:FahCore 22: 72.43%
12:25:44:WU01:FS01:FahCore 22: 72.83%
12:25:50:WU01:FS01:FahCore 22: 73.55%
12:25:56:WU01:FS01:FahCore 22: 74.12%
12:26:02:WU01:FS01:FahCore 22: 74.68%
12:26:08:WU01:FS01:FahCore 22: 75.16%
12:26:14:WU01:FS01:FahCore 22: 75.81%
12:26:20:WU01:FS01:FahCore 22: 76.45%
12:26:26:WU01:FS01:FahCore 22: 77.01%
12:26:32:WU01:FS01:FahCore 22: 77.33%
12:26:38:WU01:FS01:FahCore 22: 77.82%
12:26:44:WU01:FS01:FahCore 22: 78.62%
12:26:50:WU01:FS01:FahCore 22: 79.51%
12:26:56:WU01:FS01:FahCore 22: 79.99%
12:27:02:WU01:FS01:FahCore 22: 80.63%
12:27:09:WU01:FS01:FahCore 22: 81.20%
12:27:15:WU01:FS01:FahCore 22: 81.68%
12:27:21:WU01:FS01:FahCore 22: 82.16%
12:27:27:WU01:FS01:FahCore 22: 82.81%
12:27:33:WU01:FS01:FahCore 22: 83.29%
12:27:39:WU01:FS01:FahCore 22: 84.17%
12:27:45:WU01:FS01:FahCore 22: 84.90%
12:27:51:WU01:FS01:FahCore 22: 85.46%
12:27:57:WU01:FS01:FahCore 22: 85.86%
12:28:03:WU01:FS01:FahCore 22: 86.35%
12:28:09:WU01:FS01:FahCore 22: 86.83%
12:28:15:WU01:FS01:FahCore 22: 87.47%
12:28:21:WU01:FS01:FahCore 22: 88.04%
12:28:27:WU01:FS01:FahCore 22: 88.76%
12:28:33:WU01:FS01:FahCore 22: 89.24%
12:28:39:WU01:FS01:FahCore 22: 89.73%
12:28:45:WU01:FS01:FahCore 22: 90.29%
12:28:51:WU01:FS01:FahCore 22: 91.26%
12:28:57:WU01:FS01:FahCore 22: 91.74%
12:29:03:WU01:FS01:FahCore 22: 92.30%
12:29:09:WU01:FS01:FahCore 22: 92.62%
12:29:16:WU01:FS01:FahCore 22: 93.03%
12:29:22:WU01:FS01:FahCore 22: 93.59%
12:29:28:WU01:FS01:FahCore 22: 93.99%
12:29:34:WU01:FS01:FahCore 22: 94.56%
12:29:40:WU01:FS01:FahCore 22: 94.96%
12:29:46:WU01:FS01:FahCore 22: 95.36%
12:29:52:WU01:FS01:FahCore 22: 95.92%
12:29:58:WU01:FS01:FahCore 22: 96.49%
12:30:04:WU01:FS01:FahCore 22: 97.05%
12:30:10:WU01:FS01:FahCore 22: 97.69%
12:30:16:WU01:FS01:FahCore 22: 98.18%
12:30:22:WU01:FS01:FahCore 22: 98.58%
12:30:28:WU01:FS01:FahCore 22: 99.06%
12:30:34:WU01:FS01:FahCore 22: 99.87%
gunnarre
Re: Cant Update Core 22
Post by gunnarre »
Some people are experiencing the same problem in Windows. Wondering if it might be related to firewall or anti-virus or something like that. Do you have a list of all applications installed on your computer?
Lajiola
Post by Lajiola »
Only buildin firewall and AV, but i tested it all ready with disabled AV.
Test with Beta 7.6.20
07:28:53:WU01:FS01:FahCore 22: 98.42%
07:28:59:WU01:FS01:FahCore 22: 99.14%
07:30:35:WU01:FS01:FahCore 22: 100.00%
07:30:36:ERROR:WU01:FS01:Exception: Transfer failed
07:30:36:WU01:FS01:Downloading core from http://cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah
07:30:36:WU01:FS01:Connecting to cores.foldingathome.org:80
07:30:36:WU01:FS01:FahCore 22: Downloading 77.67MiB
07:30:42:WU01:FS01:FahCore 22: 0.56%
07:30:48:WU01:FS01:FahCore 22: 1.05%
07:30:54:WU01:FS01:FahCore 22: 1.85%
mhdata
Post by mhdata »
I had some transfer problems with VPN enabled. FAH worked when I disabled it for a moment. Though this only happened once.
I'd try renaming (or deleting/moving) %APPDATA%\FAHClient or at least %APPDATA%\FAHClient\cores
Lajiola
Post by Lajiola »
Hi,
i dont use any VPN. :(
Move / Clear the folder i have alrady done.
The download speed appears to be very slow. What's your connection speed and could you potentially try hot-spotting from your phone to see if that works or not?
gunnarre
Post by gunnarre »
I've seen at least three separate people on the forums have this stalling download of core 22 on Windows, even when anti-virus is turned off. There could be some system commonality between them or some bug in the client which only appears on some Windows installations.
Lajiola
Post by Lajiola »
PantherX wrote:The download speed appears to be very slow. What's your connection speed and could you potentially try hot-spotting from your phone to see if that works or not?
Yeah, Download is very slow, the client download from the website is slow to.
Internet connection works fine
I wonder: Have enough people simultaneously tried to upgrade FAHCore_22 to saturate the bandwidth of the server?
gunnarre
Post by gunnarre »
That seems unlikely since it's the same Windows users who keep experiencing it while other users - both on Windows and Linux - don't have this problem.
If it's the same users, then it's in their system or their ISP.
It's difficult to do anything if it's a problem being imposed by your ISP. If it's in your system, It's your firewall.
Leonardo
Hardware configuration: GPU slots on home-built, purpose-built PCs.
Post by Leonardo »
My system today experienced the same problem, in that the Work Queue status showed "Update_Core" but the Progress indicator showed 0.00. The log showed this:
"Core_00.fah
21:09:12:WU00:FS01:Connecting to cores.foldingathome.org:80
21:09:12:ERROR:WU00:FS01:Exception: FahCore package has wrong core type OPENMM_22 (34)"
To my knowledge, the Core Update failure was not preceded by any software environment changes. Prior to the failure, I made no F@H configuration changes and made no changes to security software (Defender AV and Firewall and Malwarebytes, which is only enabled manually.)
System:
Windows 11 Pro, all updates
Nvidia drivers 516.94
Short answer: The only solution that worked for me was to remove the FAHCLient folder in C:/Users completely and to restore the folder from a previous system backup. The client then immediately downloaded a new work unit and successful commenced folding.
Here is what did NOT work:
• Rebooted the computer (after every attempted fix)
• Turned off Windows Firewall
• Removed all “Fahcore_22.exe” files
• Reinstalled Folding@Home
• Ran sfc/ scannow (no integrity violations)
• Restored deleted Fahcore_22.exe files (from Recycle Bin)
• Copied “cores” folder from another PC running F@H with nearly the same hardware configuration
• Turned off Windows Defender anti-virus
• Deleted all contents from cores.foldingathome.org
• Removed FAHClient folder from Users and copied over FAHClient folder from a recent system backup – this was my solution
I realize that my solution probably does not address the root problem for update failure, but I hope it useful for someone.
Leonardo wrote: Fri Oct 14, 2022 10:09 pm My system today experienced the same problem, in that the Work Queue status showed "Update_Core" but the Progress indicator showed 0.00. The log showed this:
"Core_00.fah
See this topic - viewtopic.php?t=38572.
The problem you encountered was due to a bug in a new version of the WS code the developer was testing, it should be fixed now. The "wrong core type" error message is from a link the developer put in to implement a suggested fix mentioned in that topic. Instead of reinstalling from backup, just deleting the WU and restarting the client software should have been sufficient to get you a new WU and stop downloading a non-existent version of the folding core.
