2 Days of Experience, and doesn't explode!
GTX56O
Hardware configuration: rx570 itx 4gb no oc
Post by GTX56O »
Hello, im Eloy_Beltran_Beltran, Two days ago I installed two RX570 cards
The first card is 8GB, the overclocked to 1400Mhz at 1060mV, and the memory to 2000Mhz at 950mV. With server fans at full speed, I keep it at 70ºC, the other card is the 4GB pulse itx I have only uploaded it to 1370Mhz at 1090mv (... probably lower the voltage a bit) with the frequency of a memory at 1640Mhz, currently the two cards make me 800,000 points per day.
The CPU is AMD ryzen 5 3600x , is on boinc in rosseta proyect. overclock to 4.1Ghz , at 3200Mhz the memory. The temperature is about 68ºC, in Spain .
The other PC have problems with the RX5700XT, :e( i think quit the drivers of raedon software, and reinstall controller drivers of windows, only updated for windows 10.
For cooling , i recomend fans, Delta Fans of 120mm diameter, at 0.8A to 3500rpm, a lot of noise up to 55dB, muahahah, is a rocket
If someone could help me with the rx5700xt card, I would appreciate it, this card runs like two RX570, and has the clock at 2100Mhz. What do you need to know to make it work in Folding at home?
MeeLee
Re: 2 Days of Experience, and doesn't explode!
Post by MeeLee »
It should run from the same drivers. OpenCL is needed. You also need to set GPU to 'true' in advanced config.
Personally I would recommend using risers on the GPU, as they usually run quite hot.
FYI, F@H officially doesn't support overclocking due to instability. Thus, you may need to return to stock settings on your GPU if you encounter issues when folding WUs.
GTX56O
Post by GTX56O »
Currently I do not have instability problems, what I have is a problem with the graphic controllers supposedly, I have open CL installed, but the server tries to communicate and the client does not recognize me, it tries for port 80 and then for 8080.
gunnarre
Post by gunnarre »
Is it trying to connect to something like "192.0.2.1"? If so, that means the GPU is not recognized; the error message could be improved (known issue).
Could you post some logs, especially the first part of the log when you start up the client? Instructions here: viewtopic.php?p=327412&f=24#p327412
GTX56O
Post by GTX56O »
*********************** Log Started 2020-10-07T13:57:25Z ***********************
13:57:25:Trying to access database...
13:57:25:Successfully acquired database lock
13:57:25:Read GPUs.txt
13:57:28:Enabled folding slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
13:57:28:ERROR:No compute devices matched GPU #0 {
13:57:28:ERROR:  "vendor": 4098,
13:57:28:ERROR:  "device": 29471,
13:57:28:ERROR:  "type": 1,
13:57:28:ERROR:  "species": 6,
13:57:28:ERROR:  "description": "Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]"
13:57:28:ERROR:}.  You may need to update your graphics drivers.
13:57:28:****************************** FAHClient ******************************
13:57:28:      Version: 7.6.13
13:57:28:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:57:28:    Copyright: 2020 foldingathome.org
13:57:28:     Homepage: https://foldingathome.org/
13:57:28:         Date: Apr 27 2020
13:57:28:         Time: 21:21:01
13:57:28:     Revision: 5a652817f46116b6e135503af97f18e094414e3b
13:57:28:       Branch: master
13:57:28:     Compiler: Visual C++ 2008
13:57:28:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:57:28:     Platform: win32 10
13:57:28:         Bits: 32
13:57:28:         Mode: Release
13:57:28:       Config: C:\Users\Pepote\AppData\Roaming\FAHClient\config.xml
13:57:28:******************************** CBang ********************************
13:57:28:         Date: Apr 24 2020
13:57:28:         Time: 17:07:55
13:57:28:     Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
13:57:28:         Bits: 32
13:57:28:******************************* System ********************************
13:57:28:          CPU: AMD Ryzen 5 2600X Six-Core Processor
13:57:28:       CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
13:57:28:         CPUs: 12
13:57:28:       Memory: 15.95GiB
13:57:28:  Free Memory: 13.68GiB
13:57:28:      Threads: WINDOWS_THREADS
13:57:28:   OS Version: 6.2
13:57:28:  Has Battery: false
13:57:28:   On Battery: false
13:57:28:   UTC Offset: 2
13:57:28:          PID: 8020
13:57:28:          CWD: C:\Users\Pepote\AppData\Roaming\FAHClient
13:57:28:Win32 Service: false
13:57:28:           OS: Windows 10 Enterprise
13:57:28:      OS Arch: AMD64
13:57:28:         GPUs: 1
13:57:28:        GPU 0: Bus:43 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT /
13:57:28:               5700/5700 XT]
13:57:28:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': No se
13:57:28:               puede encontrar el mdulo especificado.
13:57:28:
13:57:28:       OpenCL: Not detected: clGetDeviceIDs() returned -1
13:57:28:******************************* libFAH ********************************
13:57:28:         Date: Apr 15 2020
13:57:28:         Time: 14:53:14
13:57:28:     Revision: 216968bc7025029c841ed6e36e81a03a316890d3
13:57:28:         Bits: 32
13:57:28:***********************************************************************
13:57:28:<config>
13:57:28:  <!-- Folding Core -->
13:57:28:  <core-priority v='low'/>
13:57:28:
13:57:28:  <!-- Folding Slot Configuration -->
13:57:28:  <cause v='COVID_19'/>
13:57:28:
13:57:28:  <!-- Network -->
13:57:28:  <proxy v=':8080'/>
13:57:28:
13:57:28:  <!-- Slot Control -->
13:57:28:  <power v='full'/>
13:57:28:
13:57:28:  <!-- User Information -->
13:57:28:  <passkey v='*****'/>
13:57:28:  <team v='235044'/>
13:57:28:  <user v='Eloy_Beltran_Beltran'/>
13:57:28:
13:57:28:  <!-- Folding Slots -->
13:57:28:  <slot id='1' type='GPU'/>
13:57:28:</config>
13:57:29:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:57:30:WU00:FS01:Assigned to work server 192.0.2.1
13:57:30:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 192.0.2.1
13:57:30:WU00:FS01:Connecting to 192.0.2.1:8080
13:57:52:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:57:52:WU00:FS01:Connecting to 192.0.2.1:80
13:58:13:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Se produjo un error durante el intento de conexin ya que la parte conectada no respondi adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexin establecida ya que el host conectado no ha podido responder.
13:58:13:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:58:14:WU00:FS01:Assigned to work server 192.0.2.1
13:58:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 192.0.2.1
13:58:14:WU00:FS01:Connecting to 192.0.2.1:8080
13:58:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:58:35:WU00:FS01:Connecting to 192.0.2.1:80
13:58:56:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Se produjo un error durante el intento de conexin ya que la parte conectada no respondi adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexin establecida ya que el host conectado no ha podido responder.
13:59:13:WU00:FS01:Connecting to assign1.foldingathome.org:80
13:59:14:WU00:FS01:Assigned to work server 192.0.2.1
13:59:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 192.0.2.1
13:59:14:WU00:FS01:Connecting to 192.0.2.1:8080
13:59:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:59:35:WU00:FS01:Connecting to 192.0.2.1:80
13:59:57:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Se produjo un error durante el intento de conexin ya que la parte conectada no respondi adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexin establecida ya que el host conectado no ha podido responder.
14:00:50:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:00:51:WU00:FS01:Assigned to work server 192.0.2.1
14:00:51:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 192.0.2.1
14:00:51:WU00:FS01:Connecting to 192.0.2.1:8080
14:01:12:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:01:12:WU00:FS01:Connecting to 192.0.2.1:80
14:01:34:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Se produjo un error durante el intento de conexin ya que la parte conectada no respondi adecuadamente tras un periodo de tiempo, o bien se produjo un error en la conexin establecida ya que el host conectado no ha podido responder.
14:03:28:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:03:28:WU00:FS01:Assigned to work server 192.0.2.1
14:03:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 192.0.2.1
14:03:28:WU00:FS01:Connecting to 192.0.2.1:8080
In other side, i have a system info, Open CL not detected clGetDeviceIDs() returned -1
Reason: added Code tags to log
GTX56O
Post by GTX56O »
I have made it work with the Open CL 1.2 driver by installing the old version of the AMD driver software from August 2019, but only run at 600mhz 30%, i reinstall no the ultimate versión , i reinstall versión of may 2020, the folding at home detect compute:1.2 driver3004.8, now is unestable becasuse the frequency up and down, the target no have overclock, was unnestable because boinc kill the gpu, now the graphic card make 1.050.000 ppd. In other hand, the fans runs to 3500rpm/60= 58.8Hz x 8 leaves =466hz tone of sound, for acoustic isolation i recommend poliuretano pannel. have high absortion coeficient in this frecuencies. In other hand, the frecuency of memory are not effect in the Points per day, the frecuency of the Core, yes, i suppose more rapid.
