CUDA_PATH and Core22 v0.0.13
Skufer
Post by Skufer »
As per the recent announcement (https://foldingathome.org/2020/09/28/fo ... a-support/) I was happy to see my rig picking up the new version of Core22 last night, however it does not appear to be working for me.
Upon attempting to create the CUDA contex, the core fails to proceed with the message "Error loading CUDA module: CUDA_ERROR_FILE_NOT_FOUND (301)" and falls back to OpenCl:
21:26:02:WU01:FS02:Assigned to work server 18.188.125.154
21:26:02:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:GM200 [GeForce GTX 980 Ti] 5632 from 18.188.125.154
21:26:02:WU01:FS02:Connecting to 18.188.125.154:8080
21:26:03:WU01:FS02:Downloading 6.13MiB
21:26:09:WU01:FS02:Download complete
21:26:09:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13426 run:5354 clone:16 gen:3 core:0x22 unit:0x0000000712bc7d9a5f597cdb0766e6ed
21:26:09:WU01:FS02:Starting
21:26:09:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lolnope\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 12940 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:26:09:WU01:FS02:Started FahCore on PID 12312
21:26:09:WU01:FS02:Core PID:4500
21:26:09:WU01:FS02:FahCore 0x22 started
21:26:09:WU01:FS02:0x22:*********************** Log Started 2020-09-28T21:26:09Z ***********************
21:26:09:WU01:FS02:0x22:*************************** Core22 Folding@home Core ***************************
21:26:09:WU01:FS02:0x22:       Core: Core22
21:26:09:WU01:FS02:0x22:       Type: 0x22
21:26:09:WU01:FS02:0x22:    Version: 0.0.11
21:26:09:WU01:FS02:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:26:09:WU01:FS02:0x22:  Copyright: 2020 foldingathome.org
21:26:09:WU01:FS02:0x22:   Homepage: https://foldingathome.org/
21:26:09:WU01:FS02:0x22:       Date: Jun 26 2020
21:26:09:WU01:FS02:0x22:       Time: 19:49:16
21:26:09:WU01:FS02:0x22:   Revision: 22010df8a4db48db1b35d33e666b64d8ce48689d
21:26:09:WU01:FS02:0x22:     Branch: core22-0.0.11
21:26:09:WU01:FS02:0x22:   Compiler: Visual C++ 2015
21:26:09:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
21:26:09:WU01:FS02:0x22:   Platform: win32 10
21:26:09:WU01:FS02:0x22:       Bits: 64
21:26:09:WU01:FS02:0x22:       Mode: Release
21:26:09:WU01:FS02:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
21:26:09:WU01:FS02:0x22:             <peastman@stanford.edu>
21:26:09:WU01:FS02:0x22:       Args: -dir 01 -suffix 01 -version 706 -lifeline 12312 -checkpoint 15
21:26:09:WU01:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:26:09:WU01:FS02:0x22:             0 -gpu 0
21:26:09:WU01:FS02:0x22:************************************ libFAH ************************************
21:26:09:WU01:FS02:0x22:       Time: 19:47:12
21:26:09:WU01:FS02:0x22:   Revision: 2b383f4f04f38511dff592885d7c0400e72bdf43
21:26:09:WU01:FS02:0x22:     Branch: HEAD
21:26:10:WU01:FS02:0x22:   Compiler: Visual C++ 2015
21:26:10:WU01:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
21:26:10:WU01:FS02:0x22:   Platform: win32 10
21:26:10:WU01:FS02:0x22:       Bits: 64
21:26:10:WU01:FS02:0x22:       Mode: Release
21:26:10:WU01:FS02:0x22:************************************ CBang *************************************
21:26:10:WU01:FS02:0x22:       Date: Jun 26 2020
21:26:10:WU01:FS02:0x22:       Time: 19:46:11
21:26:10:WU01:FS02:0x22:   Revision: f8529962055b0e7bde23e429f5072ff758089dee
21:26:10:WU01:FS02:0x22:     Branch: master
21:26:10:WU01:FS02:0x22:************************************ System ************************************
21:26:10:WU01:FS02:0x22:        CPU: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
21:26:10:WU01:FS02:0x22:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
21:26:10:WU01:FS02:0x22:       CPUs: 12
21:26:10:WU01:FS02:0x22:     Memory: 31.93GiB
21:26:10:WU01:FS02:0x22:Free Memory: 20.97GiB
21:26:10:WU01:FS02:0x22:    Threads: WINDOWS_THREADS
21:26:10:WU01:FS02:0x22: OS Version: 6.2
21:26:10:WU01:FS02:0x22:Has Battery: false
21:26:10:WU01:FS02:0x22: On Battery: false
21:26:10:WU01:FS02:0x22: UTC Offset: 1
21:26:10:WU01:FS02:0x22:        PID: 4500
21:26:10:WU01:FS02:0x22:        CWD: C:\Users\lolnope\AppData\Roaming\FAHClient\work
21:26:10:WU01:FS02:0x22:********************************************************************************
21:26:10:WU01:FS02:0x22:Project: 13426 (Run 5354, Clone 16, Gen 3)
21:26:10:WU01:FS02:0x22:Unit: 0x0000000712bc7d9a5f597cdb0766e6ed
21:26:10:WU01:FS02:0x22:Reading tar file core.xml
21:26:10:WU01:FS02:0x22:Reading tar file integrator.xml
21:26:10:WU01:FS02:0x22:Reading tar file state.xml.bz2
21:26:10:WU01:FS02:0x22:Reading tar file system.xml.bz2
21:26:10:WU01:FS02:0x22:Digital signatures verified
21:26:10:WU01:FS02:0x22:Folding@home GPU Core22 Folding@home Core
21:26:10:WU01:FS02:0x22:Version 0.0.11
21:26:10:WU01:FS02:0x22:  Checkpoint write interval: 50000 steps (5%) [20 total]
21:26:10:WU01:FS02:0x22:  JSON viewer frame write interval: 10000 steps (1%) [100 total]
21:26:10:WU01:FS02:0x22:  XTC frame write interval: 250000 steps (25%) [4 total]
21:26:10:WU01:FS02:0x22:  Global context and integrator variables write interval: 25000 steps (2.5%) [40 total]
21:26:17:WU00:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
21:26:22:Removing old file 'configs/config-20200920-212102.xml'
21:26:22:Saving configuration to config.xml
21:26:22:<config>
21:26:22:  <!-- Network -->
21:26:22:  <proxy v=':8080'/>
21:26:22:
21:26:22:  <!-- Slot Control -->
21:26:22:  <power v='full'/>
21:26:22:
21:26:22:  <!-- User Information -->
21:26:22:  <passkey v='*****'/>
21:26:22:  <team v='60091'/>
21:26:22:  <user v='Skufer'/>
21:26:22:
21:26:22:  <!-- Folding Slots -->
21:26:22:  <slot id='1' type='GPU'/>
21:26:22:  <slot id='2' type='GPU'/>
21:26:22:</config>
21:26:28:WU01:FS02:0x22:Completed 0 out of 1000000 steps (0%)
21:29:07:WU00:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
21:29:16:WU01:FS02:0x22:Completed 10000 out of 1000000 steps (1%)
21:31:56:WU00:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
21:32:03:WU01:FS02:0x22:Completed 20000 out of 1000000 steps (2%)
21:34:39:WU00:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
21:34:42:WU01:FS02:0x22:Completed 30000 out of 1000000 steps (3%)
21:37:20:WU01:FS02:0x22:Completed 40000 out of 1000000 steps (4%)
21:37:22:WU00:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
21:39:59:WU01:FS02:0x22:Completed 50000 out of 1000000 steps (5%)
21:40:05:WU00:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
21:42:39:WU01:FS02:0x22:Completed 60000 out of 1000000 steps (6%)
21:42:48:WU00:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
21:45:17:WU01:FS02:0x22:Completed 70000 out of 1000000 steps (7%)
21:45:31:WU00:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
21:47:55:WU01:FS02:0x22:Completed 80000 out of 1000000 steps (8%)
21:48:13:WU00:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
21:50:34:WU01:FS02:0x22:Completed 90000 out of 1000000 steps (9%)
21:50:55:WU00:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
21:53:12:WU01:FS02:0x22:Completed 100000 out of 1000000 steps (10%)
21:53:38:WU00:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
21:55:52:WU01:FS02:0x22:Completed 110000 out of 1000000 steps (11%)
21:56:21:WU00:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
21:58:30:WU01:FS02:0x22:Completed 120000 out of 1000000 steps (12%)
21:59:04:WU00:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
22:01:08:WU01:FS02:0x22:Completed 130000 out of 1000000 steps (13%)
22:01:46:WU00:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
22:03:47:WU01:FS02:0x22:Completed 140000 out of 1000000 steps (14%)
22:04:28:WU00:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
22:06:25:WU01:FS02:0x22:Completed 150000 out of 1000000 steps (15%)
22:07:11:WU00:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
22:09:05:WU01:FS02:0x22:Completed 160000 out of 1000000 steps (16%)
22:09:50:WU00:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
22:11:43:WU01:FS02:0x22:Completed 170000 out of 1000000 steps (17%)
22:12:27:WU00:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
22:14:21:WU01:FS02:0x22:Completed 180000 out of 1000000 steps (18%)
22:15:05:WU00:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
22:17:00:WU01:FS02:0x22:Completed 190000 out of 1000000 steps (19%)
22:17:43:WU00:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
22:19:38:WU01:FS02:0x22:Completed 200000 out of 1000000 steps (20%)
22:20:21:WU00:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
22:22:18:WU01:FS02:0x22:Completed 210000 out of 1000000 steps (21%)
22:22:59:WU00:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
22:24:56:WU01:FS02:0x22:Completed 220000 out of 1000000 steps (22%)
22:25:37:WU00:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
22:27:35:WU01:FS02:0x22:Completed 230000 out of 1000000 steps (23%)
22:28:15:WU00:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
22:30:13:WU01:FS02:0x22:Completed 240000 out of 1000000 steps (24%)
22:30:53:WU00:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
22:32:52:WU01:FS02:0x22:Completed 250000 out of 1000000 steps (25%)
22:33:31:WU00:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
22:35:36:WU01:FS02:0x22:Completed 260000 out of 1000000 steps (26%)
22:36:09:WU00:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
22:38:18:WU01:FS02:0x22:Completed 270000 out of 1000000 steps (27%)
22:38:47:WU00:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
22:41:01:WU01:FS02:0x22:Completed 280000 out of 1000000 steps (28%)
22:41:24:WU00:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
22:43:45:WU01:FS02:0x22:Completed 290000 out of 1000000 steps (29%)
22:44:02:WU00:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
22:46:28:WU01:FS02:0x22:Completed 300000 out of 1000000 steps (30%)
22:46:40:WU00:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
22:49:12:WU01:FS02:0x22:Completed 310000 out of 1000000 steps (31%)
22:49:19:WU00:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
22:51:55:WU01:FS02:0x22:Completed 320000 out of 1000000 steps (32%)
22:51:57:WU00:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
22:54:34:WU00:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
22:54:38:WU01:FS02:0x22:Completed 330000 out of 1000000 steps (33%)
22:57:12:WU00:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
22:57:21:WU01:FS02:0x22:Completed 340000 out of 1000000 steps (34%)
22:59:50:WU00:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
23:00:04:WU01:FS02:0x22:Completed 350000 out of 1000000 steps (35%)
23:02:29:WU00:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
23:02:48:WU01:FS02:0x22:Completed 360000 out of 1000000 steps (36%)
23:05:07:WU00:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
23:05:31:WU01:FS02:0x22:Completed 370000 out of 1000000 steps (37%)
23:07:44:WU00:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
23:08:14:WU01:FS02:0x22:Completed 380000 out of 1000000 steps (38%)
23:10:22:WU00:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
23:10:56:WU01:FS02:0x22:Completed 390000 out of 1000000 steps (39%)
23:13:00:WU00:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
23:13:40:WU01:FS02:0x22:Completed 400000 out of 1000000 steps (40%)
23:15:43:WU00:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
******************************* Date: 2020-09-28 *******************************
23:16:23:WU01:FS02:0x22:Completed 410000 out of 1000000 steps (41%)
23:18:25:WU00:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
23:19:07:WU01:FS02:0x22:Completed 420000 out of 1000000 steps (42%)
23:21:08:WU00:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
23:21:50:WU01:FS02:0x22:Completed 430000 out of 1000000 steps (43%)
23:23:50:WU00:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
23:24:33:WU01:FS02:0x22:Completed 440000 out of 1000000 steps (44%)
23:26:33:WU00:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
23:27:16:WU01:FS02:0x22:Completed 450000 out of 1000000 steps (45%)
23:29:16:WU00:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
23:30:00:WU01:FS02:0x22:Completed 460000 out of 1000000 steps (46%)
23:31:59:WU00:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
23:32:43:WU01:FS02:0x22:Completed 470000 out of 1000000 steps (47%)
23:34:41:WU00:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
23:35:26:WU01:FS02:0x22:Completed 480000 out of 1000000 steps (48%)
23:37:24:WU00:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
23:38:09:WU01:FS02:0x22:Completed 490000 out of 1000000 steps (49%)
23:40:06:WU00:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
23:40:52:WU01:FS02:0x22:Completed 500000 out of 1000000 steps (50%)
23:42:49:WU00:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
23:43:31:WU01:FS02:0x22:Completed 510000 out of 1000000 steps (51%)
23:45:32:WU00:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
23:46:10:WU01:FS02:0x22:Completed 520000 out of 1000000 steps (52%)
23:48:14:WU00:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
23:48:48:WU01:FS02:0x22:Completed 530000 out of 1000000 steps (53%)
23:50:57:WU00:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
23:51:27:WU01:FS02:0x22:Completed 540000 out of 1000000 steps (54%)
23:53:39:WU00:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
23:54:05:WU01:FS02:0x22:Completed 550000 out of 1000000 steps (55%)
23:56:23:WU00:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
23:56:45:WU01:FS02:0x22:Completed 560000 out of 1000000 steps (56%)
23:59:05:WU00:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
23:59:23:WU01:FS02:0x22:Completed 570000 out of 1000000 steps (57%)
00:01:48:WU00:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
00:02:01:WU01:FS02:0x22:Completed 580000 out of 1000000 steps (58%)
00:04:30:WU00:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
00:04:40:WU01:FS02:0x22:Completed 590000 out of 1000000 steps (59%)
00:07:13:WU00:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
00:07:18:WU01:FS02:0x22:Completed 600000 out of 1000000 steps (60%)
00:09:56:WU00:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
00:09:58:WU01:FS02:0x22:Completed 610000 out of 1000000 steps (61%)
00:12:36:WU01:FS02:0x22:Completed 620000 out of 1000000 steps (62%)
00:12:38:WU00:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
00:15:14:WU01:FS02:0x22:Completed 630000 out of 1000000 steps (63%)
00:15:21:WU00:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
00:17:53:WU01:FS02:0x22:Completed 640000 out of 1000000 steps (64%)
00:18:04:WU00:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
00:18:04:WU02:FS01:Connecting to assign1.foldingathome.org:80
00:18:04:WU02:FS01:Assigned to work server 155.247.166.220
00:18:04:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM200 [GeForce GTX 980 Ti] 5632 from 155.247.166.220
00:18:04:WU02:FS01:Connecting to 155.247.166.220:8080
00:18:05:WU02:FS01:Downloading 9.01MiB
00:18:11:WU02:FS01:Download 94.35%
00:18:11:WU02:FS01:Download complete
00:18:11:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:16921 run:91 clone:46 gen:2 core:0x22 unit:0x000000020002894c5f5bf34b3fcdb585
00:20:31:WU01:FS02:0x22:Completed 650000 out of 1000000 steps (65%)
00:20:46:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
00:20:46:WU00:FS01:0x22:Average performance: 53.1365 ns/day
00:20:50:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
00:20:50:WU00:FS01:0x22:Saving result file checkpointState.xml.bz2
00:20:51:WU00:FS01:0x22:Saving result file globals.csv
00:20:51:WU00:FS01:0x22:Saving result file positions.xtc
00:20:51:WU00:FS01:0x22:Saving result file science.log
00:20:51:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
00:20:51:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:20:51:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13426 run:7452 clone:14 gen:2 core:0x22 unit:0x0000000412bc7d9a5f66500d834fc31a
00:20:51:WU00:FS01:Uploading 5.67MiB to 18.188.125.154
00:20:51:WU00:FS01:Connecting to 18.188.125.154:8080
00:20:51:WU02:FS01:Starting
00:20:51:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\lolnope\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 12940 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
00:20:51:WU02:FS01:Started FahCore on PID 18796
00:20:52:WU02:FS01:Core PID:15068
00:20:52:WU02:FS01:FahCore 0x22 started
00:20:52:WU02:FS01:0x22:*********************** Log Started 2020-09-29T00:20:52Z ***********************
00:20:52:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:20:52:WU02:FS01:0x22:       Core: Core22
00:20:52:WU02:FS01:0x22:       Type: 0x22
00:20:52:WU02:FS01:0x22:    Version: 0.0.13
00:20:52:WU02:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:20:52:WU02:FS01:0x22:  Copyright: 2020 foldingathome.org
00:20:52:WU02:FS01:0x22:   Homepage: https://foldingathome.org/
00:20:52:WU02:FS01:0x22:       Date: Sep 19 2020
00:20:52:WU02:FS01:0x22:       Time: 02:35:58
00:20:52:WU02:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
00:20:52:WU02:FS01:0x22:     Branch: core22-0.0.13
00:20:52:WU02:FS01:0x22:   Compiler: Visual C++ 2015
00:20:52:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
00:20:52:WU02:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
00:20:52:WU02:FS01:0x22:   Platform: win32 10
00:20:52:WU02:FS01:0x22:       Bits: 64
00:20:52:WU02:FS01:0x22:       Mode: Release
00:20:52:WU02:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
00:20:52:WU02:FS01:0x22:             <peastman@stanford.edu>
00:20:52:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 18796 -checkpoint 15
00:20:52:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
00:20:52:WU02:FS01:0x22:             1 -gpu 1
00:20:52:WU02:FS01:0x22:************************************ libFAH ************************************
00:20:52:WU02:FS01:0x22:       Date: Sep 7 2020
00:20:52:WU02:FS01:0x22:       Time: 19:09:56
00:20:52:WU02:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
00:20:52:WU02:FS01:0x22:     Branch: HEAD
00:20:52:WU02:FS01:0x22:************************************ CBang *************************************
00:20:52:WU02:FS01:0x22:       Time: 19:08:30
00:20:52:WU02:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
00:20:52:WU02:FS01:0x22:************************************ System ************************************
00:20:52:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz
00:20:52:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
00:20:52:WU02:FS01:0x22:       CPUs: 12
00:20:52:WU02:FS01:0x22:     Memory: 31.93GiB
00:20:52:WU02:FS01:0x22:Free Memory: 23.35GiB
00:20:52:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
00:20:52:WU02:FS01:0x22: OS Version: 6.2
00:20:52:WU02:FS01:0x22:Has Battery: false
00:20:52:WU02:FS01:0x22: On Battery: false
00:20:52:WU02:FS01:0x22: UTC Offset: 1
00:20:52:WU02:FS01:0x22:        PID: 15068
00:20:52:WU02:FS01:0x22:        CWD: C:\Users\lolnope\AppData\Roaming\FAHClient\work
00:20:52:WU02:FS01:0x22:************************************ OpenMM ************************************
00:20:52:WU02:FS01:0x22:   Revision: 189320d0
00:20:52:WU02:FS01:0x22:********************************************************************************
00:20:52:WU02:FS01:0x22:Project: 16921 (Run 91, Clone 46, Gen 2)
00:20:52:WU02:FS01:0x22:Unit: 0x000000020002894c5f5bf34b3fcdb585
00:20:52:WU02:FS01:0x22:Reading tar file core.xml
00:20:52:WU02:FS01:0x22:Reading tar file integrator.xml
00:20:52:WU02:FS01:0x22:Reading tar file state.xml
00:20:52:WU02:FS01:0x22:Reading tar file system.xml
00:20:52:WU02:FS01:0x22:Digital signatures verified
00:20:52:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:20:52:WU02:FS01:0x22:Version 0.0.13
00:20:52:WU02:FS01:0x22:  Checkpoint write interval: 250000 steps (5%) [20 total]
00:20:52:WU02:FS01:0x22:  JSON viewer frame write interval: 50000 steps (1%) [100 total]
00:20:52:WU02:FS01:0x22:  XTC frame write interval: 250000 steps (5%) [20 total]
00:20:52:WU02:FS01:0x22:  Global context and integrator variables write interval: disabled
00:20:53:WU02:FS01:0x22:There are 4 platforms available.
00:20:53:WU02:FS01:0x22:Platform 0: Reference
00:20:53:WU02:FS01:0x22:Platform 1: CPU
00:20:53:WU02:FS01:0x22:Platform 2: OpenCL
00:20:53:WU02:FS01:0x22:  opencl-device 1 specified
00:20:53:WU02:FS01:0x22:Platform 3: CUDA
00:20:53:WU02:FS01:0x22:  cuda-device 1 specified
00:20:54:WU02:FS01:0x22:Attempting to create CUDA context:
00:20:54:WU02:FS01:0x22:  Configuring platform CUDA
00:20:54:WU02:FS01:0x22:Failed to create CUDA context:
00:20:54:WU02:FS01:0x22:Error loading CUDA module: CUDA_ERROR_FILE_NOT_FOUND (301)
00:20:54:WU02:FS01:0x22:Attempting to create OpenCL context:
00:20:54:WU02:FS01:0x22:  Configuring platform OpenCL
00:20:57:WU00:FS01:Upload 50.70%
00:20:58:WU02:FS01:0x22:  Using OpenCL on platformId 0 and gpu 1
00:20:58:WU02:FS01:0x22:Completed 0 out of 5000000 steps (0%)
00:20:58:WU02:FS01:0x22:Checkpoint completed at step 0
00:21:02:WU00:FS01:Upload complete
00:21:02:WU00:FS01:Server responded WORK_ACK (400)
00:21:02:WU00:FS01:Final credit estimate, 113927.00 points
00:21:02:WU00:FS01:Cleaning up
00:21:51:WU02:FS01:0x22:Completed 50000 out of 5000000 steps (1%)
00:22:45:WU02:FS01:0x22:Completed 100000 out of 5000000 steps (2%)
00:23:11:WU01:FS02:0x22:Completed 660000 out of 1000000 steps (66%)
00:23:38:WU02:FS01:0x22:Completed 150000 out of 5000000 steps (3%)
00:24:31:WU02:FS01:0x22:Completed 200000 out of 5000000 steps (4%)
00:25:24:WU02:FS01:0x22:Completed 250000 out of 5000000 steps (5%)
00:25:24:WU02:FS01:0x22:Checkpoint completed at step 250000
00:25:49:WU01:FS02:0x22:Completed 670000 out of 1000000 steps (67%)
00:26:17:WU02:FS01:0x22:Completed 300000 out of 5000000 steps (6%)
00:27:10:WU02:FS01:0x22:Completed 350000 out of 5000000 steps (7%)
00:28:04:WU02:FS01:0x22:Completed 400000 out of 5000000 steps (8%)
00:28:28:WU01:FS02:0x22:Completed 680000 out of 1000000 steps (68%)
00:28:56:WU02:FS01:0x22:Completed 450000 out of 5000000 steps (9%)
00:29:50:WU02:FS01:0x22:Completed 500000 out of 5000000 steps (10%)
00:29:50:WU02:FS01:0x22:Checkpoint completed at step 500000
00:30:43:WU02:FS01:0x22:Completed 550000 out of 5000000 steps (11%)
00:31:06:WU01:FS02:0x22:Completed 690000 out of 1000000 steps (69%)
00:31:36:WU02:FS01:0x22:Completed 600000 out of 5000000 steps (12%)
00:32:29:WU02:FS01:0x22:Completed 650000 out of 5000000 steps (13%)
After Googling around a bit for OpenMM I found that this is possibly due to my having the NVIDIA GPU Computing Toolkit previously installed which has specified certain environmental paths, which in this case could be overriding those that Core22 expects:
I need to keep the NVIDIA GPU Computing Toolkit installed as is for other applications to function, please can anyone advise how I can also allow FAHCore22 v0.0.13 to use CUDA in this scenario?
Re: CUDA_PATH and Core22 v0.0.13
Post by foldy »
If user have any CUDA toolkit installed then FAH seems to use that instead of the nvidia driver. That is not a good idea, FAH should always run using the nvidia driver for CUDA only.
Workaround could be in a cmd shell remove the CUDA environment settings temporarily and then start FAHclient from that command shell.
SAK917
Post by SAK917 »
Another data point experiencing the same issue:
******************************* Date: 2020-09-29 *******************************
14:45:47:WU00:FS01:Connecting to assign1.foldingathome.org:80
14:45:47:WU00:FS01:Assigned to work server 129.213.157.105
14:45:47:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 129.213.157.105
14:45:47:WU00:FS01:Connecting to 129.213.157.105:8080
14:45:51:WU00:FS01:Downloading 10.63MiB
14:45:54:WU00:FS01:Download complete
14:45:54:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14906 run:223 clone:7 gen:42 core:0x22 unit:0x0000003e81d59d695f4ec9d661efe674
14:46:55:WU00:FS01:Starting
14:46:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" E:\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.13/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 17992 -checkpoint 20 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:46:55:WU00:FS01:Started FahCore on PID 916
14:46:55:WU00:FS01:Core PID:38492
14:46:55:WU00:FS01:FahCore 0x22 started
14:46:55:WU00:FS01:0x22:*********************** Log Started 2020-09-29T14:46:55Z ***********************
14:46:55:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:46:55:WU00:FS01:0x22:       Core: Core22
14:46:55:WU00:FS01:0x22:       Type: 0x22
14:46:55:WU00:FS01:0x22:    Version: 0.0.13
14:46:55:WU00:FS01:0x22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:46:55:WU00:FS01:0x22:  Copyright: 2020 foldingathome.org
14:46:55:WU00:FS01:0x22:   Homepage: https://foldingathome.org/
14:46:55:WU00:FS01:0x22:       Date: Sep 19 2020
14:46:55:WU00:FS01:0x22:       Time: 02:35:58
14:46:55:WU00:FS01:0x22:   Revision: 571cf95de6de2c592c7c3ed48fcfb2e33e9ea7d3
14:46:55:WU00:FS01:0x22:     Branch: core22-0.0.13
14:46:55:WU00:FS01:0x22:   Compiler: Visual C++ 2015
14:46:55:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Ob3 /Zc:throwingNew /MT
14:46:55:WU00:FS01:0x22:             -DOPENMM_GIT_HASH="\"189320d0\""
14:46:55:WU00:FS01:0x22:   Platform: win32 10
14:46:55:WU00:FS01:0x22:       Bits: 64
14:46:55:WU00:FS01:0x22:       Mode: Release
14:46:55:WU00:FS01:0x22:Maintainers: John Chodera <john.chodera@choderalab.org> and Peter Eastman
14:46:55:WU00:FS01:0x22:             <peastman@stanford.edu>
14:46:55:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 706 -lifeline 916 -checkpoint 20
14:46:55:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:46:55:WU00:FS01:0x22:             0 -gpu 0
14:46:55:WU00:FS01:0x22:************************************ libFAH ************************************
14:46:55:WU00:FS01:0x22:       Date: Sep 7 2020
14:46:55:WU00:FS01:0x22:       Time: 19:09:56
14:46:55:WU00:FS01:0x22:   Revision: 44301ed97b996b63fe736bb8073f22209cb2b603
14:46:55:WU00:FS01:0x22:     Branch: HEAD
14:46:55:WU00:FS01:0x22:************************************ CBang *************************************
14:46:55:WU00:FS01:0x22:       Time: 19:08:30
14:46:55:WU00:FS01:0x22:   Revision: 33fcfc2b3ed2195a423606a264718e31e6b3903f
14:46:55:WU00:FS01:0x22:************************************ System ************************************
14:46:55:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
14:46:55:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
14:46:55:WU00:FS01:0x22:       CPUs: 16
14:46:55:WU00:FS01:0x22:     Memory: 31.86GiB
14:46:55:WU00:FS01:0x22:Free Memory: 18.73GiB
14:46:55:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
14:46:55:WU00:FS01:0x22: OS Version: 6.2
14:46:55:WU00:FS01:0x22:Has Battery: false
14:46:55:WU00:FS01:0x22: On Battery: false
14:46:55:WU00:FS01:0x22: UTC Offset: -7
14:46:55:WU00:FS01:0x22:        PID: 38492
14:46:55:WU00:FS01:0x22:        CWD: E:\FAHClient\work
14:46:55:WU00:FS01:0x22:************************************ OpenMM ************************************
14:46:55:WU00:FS01:0x22:   Revision: 189320d0
14:46:55:WU00:FS01:0x22:********************************************************************************
14:46:55:WU00:FS01:0x22:Project: 14906 (Run 223, Clone 7, Gen 42)
14:46:55:WU00:FS01:0x22:Unit: 0x0000003e81d59d695f4ec9d661efe674
14:46:55:WU00:FS01:0x22:Reading tar file core.xml
14:46:55:WU00:FS01:0x22:Reading tar file integrator.xml
14:46:55:WU00:FS01:0x22:Reading tar file state.xml
14:46:55:WU00:FS01:0x22:Reading tar file system.xml
14:46:55:WU00:FS01:0x22:Digital signatures verified
14:46:55:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:46:55:WU00:FS01:0x22:Version 0.0.13
14:46:56:WU00:FS01:0x22:  Checkpoint write interval: 100000 steps (5%) [20 total]
14:46:56:WU00:FS01:0x22:  JSON viewer frame write interval: 20000 steps (1%) [100 total]
14:46:56:WU00:FS01:0x22:  XTC frame write interval: 50000 steps (2.5%) [40 total]
14:46:56:WU00:FS01:0x22:  Global context and integrator variables write interval: disabled
14:46:56:WU00:FS01:0x22:There are 4 platforms available.
14:46:56:WU00:FS01:0x22:Platform 0: Reference
14:46:56:WU00:FS01:0x22:Platform 1: CPU
14:46:56:WU00:FS01:0x22:Platform 2: OpenCL
14:46:56:WU00:FS01:0x22:  opencl-device 0 specified
14:46:56:WU00:FS01:0x22:Platform 3: CUDA
14:46:56:WU00:FS01:0x22:  cuda-device 0 specified
14:47:00:WU00:FS01:0x22:Attempting to create CUDA context:
14:47:00:WU00:FS01:0x22:  Configuring platform CUDA
14:47:00:WU00:FS01:0x22:Failed to create CUDA context:
14:47:00:WU00:FS01:0x22:Error loading CUDA module: CUDA_ERROR_FILE_NOT_FOUND (301)
14:47:00:WU00:FS01:0x22:Attempting to create OpenCL context:
14:47:00:WU00:FS01:0x22:  Configuring platform OpenCL
14:47:02:WU00:FS01:0x22:  Using OpenCL on platformId 0 and gpu 0
14:47:02:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
14:47:02:WU00:FS01:0x22:Checkpoint completed at step 0
14:47:50:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
14:48:39:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
14:49:27:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
14:50:15:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
14:51:03:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
14:51:04:WU00:FS01:0x22:Checkpoint completed at step 100000
14:51:52:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
Config Info:
*********************** Log Started 2020-09-24T19:36:50Z ***********************
19:36:50:Trying to access database...
19:36:50:Successfully acquired database lock
19:36:50:Read GPUs.txt
19:36:51:Enabled folding slot 01: PAUSED gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 (by user)
19:36:51:Enabled folding slot 00: PAUSED cpu:8 (by user)
19:36:51:****************************** FAHClient ******************************
19:36:51:        Version: 7.6.13
19:36:51:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:36:51:      Copyright: 2020 foldingathome.org
19:36:51:       Homepage: https://foldingathome.org/
19:36:51:           Date: Apr 27 2020
19:36:51:           Time: 21:21:01
19:36:51:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
19:36:51:         Branch: master
19:36:51:       Compiler: Visual C++ 2008
19:36:51:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:36:51:       Platform: win32 10
19:36:51:           Bits: 32
19:36:51:           Mode: Release
19:36:51:         Config: E:\FAHClient\config.xml
19:36:51:******************************** CBang ********************************
19:36:51:           Date: Apr 24 2020
19:36:51:           Time: 17:07:55
19:36:51:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
19:36:51:           Bits: 32
19:36:51:******************************* System ********************************
19:36:51:            CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
19:36:51:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:36:51:           CPUs: 16
19:36:51:         Memory: 31.86GiB
19:36:51:    Free Memory: 25.52GiB
19:36:51:        Threads: WINDOWS_THREADS
19:36:51:     OS Version: 6.2
19:36:51:    Has Battery: false
19:36:51:     On Battery: false
19:36:51:     UTC Offset: -7
19:36:51:            PID: 17992
19:36:51:            CWD: E:\FAHClient
19:36:51:  Win32 Service: false
19:36:51:             OS: Windows 10 Enterprise
19:36:51:        OS Arch: AMD64
19:36:51:           GPUs: 2
19:36:51:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
19:36:51:                 M 13448
19:36:51:          GPU 1: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
19:36:51:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
19:36:51:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:452.6
19:36:51:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
19:36:51:******************************* libFAH ********************************
19:36:51:           Date: Apr 15 2020
19:36:51:           Time: 14:53:14
19:36:51:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
19:36:51:           Bits: 32
19:36:51:***********************************************************************
19:36:51:<config>
19:36:51:  <!-- Folding Core -->
19:36:51:  <checkpoint v='20'/>
19:36:51:
19:36:51:  <!-- Folding Slot Configuration -->
19:36:51:  <client-type v='advanced'/>
19:36:51:
19:36:51:  <!-- Network -->
19:36:51:  <proxy v=':8080'/>
19:36:51:
19:36:51:  <!-- User Information -->
19:36:51:  <passkey v='*****'/>
19:36:51:  <team v='xxxxxx'/>
19:36:51:  <user v='xxxxxx'/>
19:36:51:
19:36:51:  <!-- Folding Slots -->
19:36:51:  <slot id='1' type='GPU'>
19:36:51:    <paused v='true'/>
19:36:51:  </slot>
19:36:51:  <slot id='0' type='CPU'>
19:36:51:    <cpus v='8'/>
19:36:51:  </slot>
19:36:51:</config>
19:38:41:FS01:Unpaused
Environment Variables:
CUDA_PATH: C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2
CUDA_PATH_V10_2: C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.2
NVCUDASAMPLES_ROOT: E:\MachineLearning\CUDASamples\v10.2
NVCUDASAMPLES10_2_ROOT: E:\MachineLearning\CUDASamples\v10.2
NVTOOLSEXT_PATH: C:\Program Files\NVIDIA Corporation\NvToolsExt\
Development is aware of the issue.
Skufer
Post by Skufer »
Thanks Bruce!
CarolusMagnus
Hardware configuration: 1. Windows 7 pro 64 bits, Intel Core i7 4790K 4.4 GHz, 24 GB RAM, 512 GB SAMSUNG 860 PRO SSD, NVIDIA RTX 2070 SUPER from MSI (OC up to 1980 MHz)
2. Windows 7 pro 64 bits, AMD Phenom IIx4 3.8 GHz (OC from 3.5 GHz), 4 GB RAM, 256 GB SAMSUNG 850 PRO SSD, AMD RX580 8GB from MSI (OC @ 1400 MHz)
Post by CarolusMagnus »
I had the exact same issue: Windows 7 pro 64 + NVIDIA RTX 2070 S
I didn't need the Toolkit so I removed it to solve the issue; but I had to set opencl-index to 0 (others to -1) to get the FAHCore22 v0.0.13 running.
Wondering: Couldn't figure exactly what file(s) the FAHCore/Client needs from NVIDIA. Is this the runtime DLL, such as cudart64_110.dll ? If so, at what location ?
Skufer
Post by Skufer »
CarolusMagnus wrote:I had the exact same issue: Windows 7 pro 64 + NVIDIA RTX 2070 S
For me, they're located in:
C:\Users\<username>\AppData\Roaming\FAHClient\cores\cores.foldingathome.org\win\64bit\22-0.0.13\Core_22.fah
CarolusMagnus
Ok, thanks, found them:
C:\Users\Charles\AppData\Roaming\FAHClient\cores\cores.foldingathome.org\win\64bit\22-0.0.13\Core_22.fah
These files are not from the NVIDIA local installation: not from the driver, and not from the toolkit. Correct ?
Correct. When the FAHCore is delivered, those files a packaged with it so that a separate SDK doesn't need to be installed. That's fine for folks who have not installed a SDK. Now there may need to be some bugs quashed where any of the potential SDK version is already installed --- when they happen to conflict with the ones included with the FAHCore.
garyo
Hardware configuration: NVIDIA Quadro RTX 6000
Post by garyo »
Happening to me too, just downloaded F@H a couple of days ago -- I have CUDA toolkit installed, Windows 10 (and I need it for my actual work). But it did auto-detect OpenCL and is working fine (1.5M points/day on my Quadro RTX 6000). Would be happy to test any fix if I can be useful.
18:05:20:WU03:FS02:0x22:There are 4 platforms available.
18:05:20:WU03:FS02:0x22:Platform 0: Reference
18:05:20:WU03:FS02:0x22:Platform 1: CPU
18:05:20:WU03:FS02:0x22:Platform 2: OpenCL
18:05:20:WU03:FS02:0x22: opencl-device 0 specified
18:05:20:WU03:FS02:0x22:Platform 3: CUDA
18:05:20:WU03:FS02:0x22: cuda-device 0 specified
18:05:21:WU03:FS02:0x22:Attempting to create CUDA context:
18:05:21:WU03:FS02:0x22: Configuring platform CUDA
18:05:22:WU03:FS02:0x22:Failed to create CUDA context:
18:05:22:WU03:FS02:0x22:Error loading CUDA module: CUDA_ERROR_FILE_NOT_FOUND (301)
18:05:22:WU03:FS02:0x22:Attempting to create OpenCL context:
18:05:22:WU03:FS02:0x22: Configuring platform OpenCL
18:05:27:WU03:FS02:0x22: Using OpenCL on platformId 0 and gpu 0
If you can't remove CUDA toolkit/SDK because you need it to code, you'll have to wait for a next release of the core that fixes this issue.
Some people suggested to remove environment variables (CUDA_PATH I guess) so that they doesn't interfere with FAH, and to use local/session variables when they are needed (at compilation time of your projects for instance).
garyo
Post by garyo »
I removed CUDA_PATH etc. but still no joy. Will wait for next release. Can't complain though, I'm getting 3.2M pts/day with OpenCL. :-)
