macOS Catalina local Online Inactive Not folding
Hi! My first post, as I need help ASAP.
Using latest macOS Catalina and F@h client, but recently stopped folding at all. Web interface moved to Power: Full/"While I'm working", but only Yellow and Ready, not Green and Running. FAHControl shows Client: local Online Inactive.
MacBookPro16,1 (16-inch, 2019), 2.4 GHz 8-core Intel Core i9, 32 GB 2667 MHz DDR4, AMD Radeon Pro 5500M 8M, 4 TB NVMExpress
Tried uninstalling and re-installing, but still same and not folding.
Clicking other things not changing the situation.
Need help to start folding @ home once again.
Thanks in advance!
~ Dr.MORO
Thanks in advance!
~ Dr.MORO
Re: macOS Catalina local Online Inactive Not folding
Welcome to the F@H Forum Dr.MORO,
Can you please post the log file? Ensure you include the first 100 lines which will inform us of what the system configuration is and what the client settings are. If you require guidance, please view this topic: viewtopic.php?f=24&t=26036
There's been a recent problem with a folding core for OS X. If you uninstalled it completely, it should also empty the directory "/Library/Application\ Support/FAHClient/cores" (not ~/Library etc). Are you sure the folding cores were deleted before you re-installed?
The macOS uninstaller does not delete any data files.
You would need to manually delete any stuck core A8 work unit.
I think the command line could also work.
Something like (completely untested):
FAHClient —send-command delete 00
Don’t try this unless someone verifies it first.
I uninstalled FAH and deleted A8 of cores. However, no improvement was available.
I expected 7.6.9 (released 17-Apr) might work, but download is not permitted.
Burlingtonian
- Hardware configuration: 2 iMacs and 1 dedicated Windows 10 Pro rig with 1 RTX 2070 Super and 1 RTX 2060 KO
@hiron138
Not sure if this is the same issue but both of my iMacs stopped folding last week with the error message WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)". May have been related to WU 16810 although that no longer seems to be an issue. My remedy:
1. Stop FAH Control
2. Delete the FAH Work folder at /Library/Application Support/FAHClient/ Note: Administrator password required.
3.Restart FAH Control
Worked for me.
1. Stop FAH Control
Worked for me.
A fixed version of Core_A8 was released late Friday and should download if the bad version was deleted. Easiest way to get current copies of the folding cores is to remove the cores folder in /Library/Application Support/FAHClient with folding stopped. When folding is resumed, new copies of the folding cores will be downloaded as needed.
Project 16810 is the only one currently in full release that uses Core_A8, but there are some projects that will be coming in the near future that will also use it. Projects using Core_A7 were not part of this issue.
Hi everyone, and Thanks for all the input.
First off, Below is the first 100 or so lines from the log.txt file.
Next, I started by deleting the "work" folder, and re-started F@H.
Nope, FAHControl shows Client: local Updating Inactive, and the web control client just continues flashing & reloading every second annoyingly.
Returned "work' folder back where it was. But flashing continues. Not good.
Then, removed the core folder entirely, but flashing continues. However, the FAHControl say Client: local Online Running.
Yet still, no folding, and checking the newly generated log in FAHControl app, it's just a string of errors:
Should I just uninstall FAH by the uninstaller, and delete the /Library/Application Support/FAHClient folder, then re-install?
Just a bit worried that my account info will be lost when restarting FAH.
Any additional help and advice would be appreciated.
Thanks!
~ Dr.MORO
*********************** Log Started 2020-09-27T20:03:46Z ***********************
20:03:46:Trying to access database...
20:03:46:Successfully acquired database lock
20:03:46:Read GPUs.txt
20:03:46:Enabled folding slot 00: READY cpu:16
[91m20:03:46:ERROR:Failed to register for display power changes[0m
20:03:46:****************************** FAHClient ******************************
20:03:46: Version: 7.6.13
20:03:46: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:03:46: Copyright: 2020 foldingathome.org
20:03:46: Homepage: https://foldingathome.org/
20:03:46: Date: Apr 27 2020
20:03:46: Time: 21:20:45
20:03:46: Revision: 5a652817f46116b6e135503af97f18e094414e3b
20:03:46: Branch: master
20:03:46: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
20:03:46: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
20:03:46: -Wno-unused-local-typedefs -stdlib=libc++
20:03:46: Platform: darwin 19.2.0
20:03:46: Bits: 64
20:03:46: Mode: Release
20:03:46: Config: /Library/Application Support/FAHClient/config.xml
20:03:46:******************************** CBang ********************************
20:03:46: Date: Apr 24 2020
20:03:46: Time: 17:07:50
20:03:46: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
20:03:46: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
20:03:46: Bits: 64
20:03:46:******************************* System ********************************
20:03:46: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
20:03:46: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
20:03:46: CPUs: 16
20:03:46: Memory: 32.00GiB
20:03:46:Free Memory: 29.06GiB
20:03:46: Threads: POSIX_THREADS
20:03:46: OS Version: 10.15
20:03:46:Has Battery: true
20:03:46: On Battery: false
20:03:46: UTC Offset: -4
20:03:46: PID: 137
20:03:46: CWD: /Library/Application Support/FAHClient
20:03:46: OS: Darwin 19.6.0 x86_64
20:03:46: OS Arch: AMD64
20:03:46: GPUs: 2
20:03:46: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
20:03:46: GPU 1: Bus:3 Slot:0 Func:0 AMD:6 Navi 14 [Radeon RX 5500/5500M / Pro
20:03:46: 5500M]
20:03:46: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
20:03:46: dlopen(libcuda.dylib, 1): image not found
20:03:46: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
20:03:46: dlopen(libOpenCL.dylib, 1): image not found
20:03:46:******************************* libFAH ********************************
20:03:46: Date: Apr 15 2020
20:03:46: Time: 14:43:28
20:03:46: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
20:03:46: Bits: 64
20:03:46:***********************************************************************
20:03:46:<config>
20:03:46: <!-- Slot Control -->
20:03:46: <power v='full'/>
20:03:46:
20:03:46: <!-- User Information -->
20:03:46: <passkey v='*****'/>
20:03:46: <team v='265651'/>
20:03:46: <user v='Dr.MORO-MBP16'/>
20:03:46:
20:03:46: <!-- Folding Slots -->
20:03:46: <slot id='0' type='CPU'/>
20:03:46:</config>
20:03:46:WU00:FS00:Starting
20:03:46:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 137 -checkpoint 15 -np 16
20:03:46:WU00:FS00:Started FahCore on PID 635
20:03:47:WU00:FS00:Core PID:702
20:03:47:WU00:FS00:FahCore 0xa8 started
20:03:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:03:47:WU00:FS00:Starting
20:03:47:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 137 -checkpoint 15 -np 16
20:03:47:WU00:FS00:Started FahCore on PID 740
20:03:47:WU00:FS00:Core PID:746
20:03:48:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:04:48:WU00:FS00:Starting
20:04:48:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 137 -checkpoint 15 -np 16
20:04:48:WU00:FS00:Started FahCore on PID 2554
20:04:48:WU00:FS00:Core PID:2555
20:04:48:WU00:FS00:FahCore 0xa8 started
20:04:49:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:05:48:WU00:FS00:Starting
20:05:48:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx2-256/a8-0.0.7/Core_a8.fah/FahCore_a8" -dir 00 -suffix 01 -version 706 -lifeline 137 -checkpoint 15 -np 16
20:05:48:WU00:FS00:Started FahCore on PID 2801
20:05:48:WU00:FS00:Core PID:2802
20:05:48:WU00:FS00:FahCore 0xa8 started
20:05:48:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:06:34:ERROR:Exception: Mutex 0x00007ffeec612b70 unlock failed: Operation not permitted
22:06:35:ERROR:Exception: Mutex 0x00007ffeec612b70 unlock failed: Operation not permitted
22:06:36:ERROR:Exception: Mutex 0x00007ffeec612b70 unlock failed: Operation not permitted
22:06:36:ERROR:Exception: Mutex 0x00007ffeec612b70 unlock failed: Operation not permittedJust a bit worried that my account info will be lost when restarting FAH.
Thanks!
~ Dr.MORO
Ok, just removed 'cores' and 'work' folders left behind after the uninstall, and re-installed FAH from latest downloaded macOS client.
No new 'cores' folder created somehow, and FAHControl app shows Client: local Updating Inactive.
Newest log is like this, showing a different error, perhaps. Totally lost of what is going on here...
*********************** Log Started 2020-09-27T22:25:48Z ***********************
22:25:48:Trying to access database...
22:25:48:Successfully acquired database lock
22:25:48:Read GPUs.txt
22:25:48:Enabled folding slot 00: PAUSED cpu:16 (by user)
[91m22:25:48:ERROR:Exception: Could not bind socket to 0.0.0.0:7396: Address already in use[0m
[91m22:25:48:ERROR:Exception: Could not bind socket to 0.0.0.0:36330: Address already in use[0m
22:25:48:****************************** FAHClient ******************************
22:25:48: Version: 7.6.13
22:25:48: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:25:48: Copyright: 2020 foldingathome.org
22:25:48: Homepage: https://foldingathome.org/
22:25:48: Date: Apr 27 2020
22:25:48: Time: 21:20:45
22:25:48: Revision: 5a652817f46116b6e135503af97f18e094414e3b
22:25:48: Branch: master
22:25:48: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
22:25:48: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
22:25:48: -Wno-unused-local-typedefs -stdlib=libc++
22:25:48: Platform: darwin 19.2.0
22:25:48: Bits: 64
22:25:48: Mode: Release
22:25:48: Config: /Library/Application Support/FAHClient/config.xml
22:25:48:******************************** CBang ********************************
22:25:48: Date: Apr 24 2020
22:25:48: Time: 17:07:50
22:25:48: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
22:25:48: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
22:25:48: Bits: 64
22:25:48:******************************* System ********************************
22:25:48: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
22:25:48: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
22:25:48: CPUs: 16
22:25:48: Memory: 32.00GiB
22:25:48:Free Memory: 47.15MiB
22:25:48: Threads: POSIX_THREADS
22:25:48: OS Version: 10.15
22:25:48:Has Battery: true
22:25:48: On Battery: false
22:25:48: UTC Offset: -4
22:25:48: PID: 7265
22:25:48: CWD: /Library/Application Support/FAHClient
22:25:48: OS: Darwin 19.6.0 x86_64
22:25:48: OS Arch: AMD64
22:25:48: GPUs: 2
22:25:48: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
22:25:48: GPU 1: Bus:3 Slot:0 Func:0 AMD:6 Navi 14 [Radeon RX 5500/5500M / Pro
22:25:48: 5500M]
22:25:48: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
22:25:48: dlopen(libcuda.dylib, 1): image not found
22:25:48: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
22:25:48: dlopen(libOpenCL.dylib, 1): image not found
22:25:48:******************************* libFAH ********************************
22:25:48: Date: Apr 15 2020
22:25:48: Time: 14:43:28
22:25:48: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
22:25:48: Bits: 64
22:25:48:***********************************************************************
22:25:48:<config>
22:25:48: <!-- Slot Control -->
22:25:48: <power v='full'/>
22:25:48:
22:25:48: <!-- User Information -->
22:25:48: <passkey v='*****'/>
22:25:48: <team v='265651'/>
22:25:48: <user v='Dr.MORO-MBP16'/>
22:25:48:
22:25:48: <!-- Folding Slots -->
22:25:48: <slot id='0' type='CPU'>
22:25:48: <paused v='true'/>
22:25:48: </slot>
22:25:48:</config>
22:25:49:Set client configured
You just need to unpause folding.
Nope, done that. Still 'Client: local Updating Inactive'calxalot wrote:You just need to unpause folding.
No folding, no updating, nothing happening with FAH.
Ok, checked Activity Monitor, and noticed two (2) FAHClient were running. Quit one of them, and now Client: local Connecting Inactive.
Some progress?
Yes, all the cores are actually at full throttle now. Yet somehow still Client: local Connecting Inactive, though. Web client page also trying to connect, but not fully loading. Weird...
Noticed new 'cores' and 'work' folders have been created as well. Getting there???
I will restart my Mac, and see what happens.
Present new log as follows:
*********************** Log Started 2020-09-28T00:03:52Z ***********************
00:03:52:Trying to access database...
00:03:52:Successfully acquired database lock
00:03:52:Read GPUs.txt
00:03:52:Enabled folding slot 00: READY cpu:16
[91m00:03:52:ERROR:Exception: Could not bind socket to 0.0.0.0:7396: Address already in use[0m
[91m00:03:52:ERROR:Exception: Could not bind socket to 0.0.0.0:36330: Address already in use[0m
00:03:52:****************************** FAHClient ******************************
00:03:52: Version: 7.6.13
00:03:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:03:52: Copyright: 2020 foldingathome.org
00:03:52: Homepage: https://foldingathome.org/
00:03:52: Date: Apr 27 2020
00:03:52: Time: 21:20:45
00:03:52: Revision: 5a652817f46116b6e135503af97f18e094414e3b
00:03:52: Branch: master
00:03:52: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
00:03:52: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
00:03:52: -Wno-unused-local-typedefs -stdlib=libc++
00:03:52: Platform: darwin 19.2.0
00:03:52: Bits: 64
00:03:52: Mode: Release
00:03:52: Config: /Library/Application Support/FAHClient/config.xml
00:03:52:******************************** CBang ********************************
00:03:52: Date: Apr 24 2020
00:03:52: Time: 17:07:50
00:03:52: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
00:03:52: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
00:03:52: Bits: 64
00:03:52:******************************* System ********************************
00:03:52: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
00:03:52: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
00:03:52: CPUs: 16
00:03:52: Memory: 32.00GiB
00:03:52:Free Memory: 82.13MiB
00:03:52: Threads: POSIX_THREADS
00:03:52: OS Version: 10.15
00:03:52:Has Battery: true
00:03:52: On Battery: false
00:03:52: UTC Offset: -4
00:03:52: PID: 10202
00:03:52: CWD: /Library/Application Support/FAHClient
00:03:52: OS: Darwin 19.6.0 x86_64
00:03:52: OS Arch: AMD64
00:03:52: GPUs: 2
00:03:52: GPU 0: Bus:0 Slot:2 Func:0 INTEL:1 Gen9p5/GT2 [UHD Graphics 630]
00:03:52: GPU 1: Bus:3 Slot:0 Func:0 AMD:6 Navi 14 [Radeon RX 5500/5500M / Pro
00:03:52: 5500M]
00:03:52: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
00:03:52: dlopen(libcuda.dylib, 1): image not found
00:03:52: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
00:03:52: dlopen(libOpenCL.dylib, 1): image not found
00:03:52:******************************* libFAH ********************************
00:03:52: Date: Apr 15 2020
00:03:52: Time: 14:43:28
00:03:52: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
00:03:52: Bits: 64
00:03:52:***********************************************************************
00:03:52:<config>
00:03:52: <!-- Slot Control -->
00:03:52: <power v='FULL'/>
00:03:52:
00:03:52: <!-- User Information -->
00:03:52: <passkey v='*****'/>
00:03:52: <team v='265651'/>
00:03:52: <user v='Dr.MORO-MBP16'/>
00:03:52:
00:03:52: <!-- Folding Slots -->
00:03:52: <slot id='0' type='CPU'/>
00:03:52:</config>
00:03:52:WU00:FS00:Connecting to assign1.foldingathome.org:80
00:03:53:WU00:FS00:Connecting to assign1.foldingathome.org:80
00:03:53:WU00:FS00:Assigned to work server 155.247.164.214
00:03:53:WU00:FS00:Requesting new work unit for slot 00: READY cpu:16 from 155.247.164.214
00:03:53:WU00:FS00:Connecting to 155.247.164.214:8080
00:03:54:WU00:FS00:Downloading 2.83MiB
00:03:54:WU00:FS00:Download complete
00:03:55:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14827 run:1923 clone:4 gen:1 core:0xa7 unit:0x000000019bf7a4d65ea662c5fabd0a3b
00:03:55:WU00:FS00:Downloading core from http://cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah
00:03:55:WU00:FS00:Connecting to cores.foldingathome.org:80
00:03:55:WU00:FS00:FahCore a7: Downloading 6.54MiB
00:04:01:WU00:FS00:FahCore a7: 74.56%
00:04:02:WU00:FS00:FahCore a7: Download complete
00:04:02:WU00:FS00:Valid core signature
00:04:02:WU00:FS00:Unpacked 17.02MiB to cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7
00:04:02:WU00:FS00:Starting
00:04:02:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/osx/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 706 -lifeline 10202 -checkpoint 15 -np 16
00:04:02:WU00:FS00:Started FahCore on PID 10214
00:04:02:WU00:FS00:Core PID:10215
00:04:02:WU00:FS00:FahCore 0xa7 started
00:04:03:WU00:FS00:0xa7:*********************** Log Started 2020-09-28T00:04:02Z ***********************
00:04:03:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:04:03:WU00:FS00:0xa7: Type: 0xa7
00:04:03:WU00:FS00:0xa7: Core: Gromacs
00:04:03:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 10214 -checkpoint 15 -np
00:04:03:WU00:FS00:0xa7: 16
00:04:03:WU00:FS00:0xa7:************************************ CBang *************************************
00:04:03:WU00:FS00:0xa7: Date: Nov 27 2019
00:04:03:WU00:FS00:0xa7: Time: 03:27:01
00:04:03:WU00:FS00:0xa7: Revision: d25803215b59272441049dfa05a0a9bf7a6e3c48
00:04:03:WU00:FS00:0xa7: Branch: master
00:04:03:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
00:04:03:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
00:04:03:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
00:04:03:WU00:FS00:0xa7: Platform: darwin 19.0.0
00:04:03:WU00:FS00:0xa7: Bits: 64
00:04:03:WU00:FS00:0xa7: Mode: Release
00:04:03:WU00:FS00:0xa7:************************************ System ************************************
00:04:03:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz
00:04:03:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
00:04:03:WU00:FS00:0xa7: CPUs: 16
00:04:03:WU00:FS00:0xa7: Memory: 32.00GiB
00:04:03:WU00:FS00:0xa7:Free Memory: 53.21MiB
00:04:03:WU00:FS00:0xa7: Threads: POSIX_THREADS
00:04:03:WU00:FS00:0xa7: OS Version: 10.15
00:04:03:WU00:FS00:0xa7:Has Battery: true
00:04:03:WU00:FS00:0xa7: On Battery: false
00:04:03:WU00:FS00:0xa7: UTC Offset: -4
00:04:03:WU00:FS00:0xa7: PID: 10215
00:04:03:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
00:04:03:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
00:04:03:WU00:FS00:0xa7: Version: 0.0.19
00:04:03:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:04:03:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
00:04:03:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
00:04:03:WU00:FS00:0xa7: Date: Nov 25 2019
00:04:03:WU00:FS00:0xa7: Time: 16:41:59
00:04:03:WU00:FS00:0xa7: Revision: d5b5c747532224f986b7cd02c968ed9a20c16d6e
00:04:03:WU00:FS00:0xa7:************************************ Build *************************************
00:04:03:WU00:FS00:0xa7: SIMD: avx_256
00:04:03:WU00:FS00:0xa7:********************************************************************************
00:04:03:WU00:FS00:0xa7:Project: 14827 (Run 1923, Clone 4, Gen 1)
00:04:03:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d65ea662c5fabd0a3b
00:04:03:WU00:FS00:0xa7:Reading tar file core.xml
00:04:03:WU00:FS00:0xa7:Reading tar file frame1.tpr
00:04:03:WU00:FS00:0xa7:Digital signatures verified
00:04:03:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 16
00:04:03:WU00:FS00:0xa7:Steps: first=0 total=250000
00:04:05:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
00:04:55:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
00:05:45:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
00:06:37:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
00:07:31:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
00:08:24:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
00:09:19:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
00:10:14:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
00:11:12:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
00:12:07:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
00:13:06:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
Hmmm, I may have spoke too soon...
Once again, in the middle of a new work unit, FAH has stopped folding somehow. I tried to pause the folding by clicking the web client to 'Light' & 'Only when idle'. I did pause, but once trying to restart the folding, setting to light or medium and 'While I'm working', it does not fold and stays inactive.
More strangely, when setting to 'Full' and 'While I'm working', it DOES start folding again!!! WTH???
So, now my issue is I can fold, but only at FULL, but not at medium nor light. Super weird...
Something not working with the web control and the FAHControl app???
Okay, so there is a delay for about a minute until the web control reconfigures everything and starts folding again.Dr.MORO wrote:Hmmm, I may have spoke too soon...
ALL GOOD NOW!!!
I AM FOLDING!
Thanks everyone!
Generally speaking, you can fold on all CPUs and still run most daily applications without much slowdown and/or user impact. Give it a shot and see what happens. I am glad that you got it working in the end
Thanks! Yes, I know I CAN run at FULL all day, folding at very fast pace.PantherX wrote:Generally speaking, you can fold on all CPUs and still run most daily applications without much slowdown and/or user impact. Give it a shot and see what happens. I am glad that you got it working in the end
I just do not like the fan blasting at full power all day while I'm working on in.
I just crank it up just before I go to bed, and ramp down right after I wake up next morning. TON of folding while I sleep.
