FAHCoreWrapper.exe do not works after system reboot
raven562
Post by raven562 »
Hi there! Got new bug after 7.6.last one update...
What I'm do:
1. fresh install of client
2. configuring it in username, team data, passkey. No other flags are used.
3. running it
problem is - when I reboot my system (it's rare, but happens) FAHCoreWrapper.exe displays error every time it tries to start. On CPU and GPU slots. There is error log:
11:02:33:WU00:FS00:Assigned to work server 128.252.203.10
11:02:33:WU00:FS00:Requesting new work unit for slot 00: READY cpu:10 from 128.252.203.10
11:02:33:WU00:FS00:Connecting to 128.252.203.10:8080
11:02:34:WU00:FS00:Downloading 2.07MiB
11:02:40:WU00:FS00:Download 18.12%
11:02:47:WU00:FS00:Download 30.20%
11:02:53:WU00:FS00:Download 36.23%
11:03:00:WU00:FS00:Download 45.29%
11:03:07:WU00:FS00:Download 60.39%
11:03:16:WU00:FS00:Download 75.49%
11:03:22:WU00:FS00:Download 87.57%
11:03:29:WU00:FS00:Download 99.65%
11:03:29:WU00:FS00:Download complete
11:03:29:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:17202 run:0 clone:954 gen:144 core:0xa7 unit:0x000000ac80fccb0a5f32feaa33f3bcf6
11:03:29:WU00:FS00:Starting
11:03:29:WARNING:WU00:FS00:AS lowered CPUs from 10 to 9
11:03:29:WU00:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11432 -checkpoint 15 -np 9
11:03:29:WU00:FS00:Started FahCore on PID 5360
11:03:32:WU00:FS00:FahCore 0xa7 started
11:03:32:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
11:03:32:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
11:03:32:WU00:FS00:Starting
11:03:32:WARNING:WU00:FS00:AS lowered CPUs from 10 to 9
11:03:32:WU00:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11432 -checkpoint 15 -np 9
11:03:32:WU00:FS00:Started FahCore on PID 12240
11:03:33:WU00:FS00:FahCore 0xa7 started
11:03:33:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
11:03:33:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
11:04:32:WU00:FS00:Starting
11:04:32:WARNING:WU00:FS00:AS lowered CPUs from 10 to 9
11:04:32:WU00:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11432 -checkpoint 15 -np 9
11:04:32:WU00:FS00:Started FahCore on PID 8800
11:04:36:WU00:FS00:FahCore 0xa7 started
11:04:36:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
11:04:36:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
When I reinstall client everything is worked until first system reboot.
What I've do wrong and how to fix that issue?
raven562
Re: FAHCoreWrapper.exe do not works after system reboot
Post by raven562 »
A little exploration indicates that manual closing and starting FAH utility allows to continue calculations. But that is unusual behavior, everything should work without that manipulations, I guess
Please post the beginning section of the log, the first 100-200 lines contains important information for troubleshooting such as your OS, system hardware and and client settings being used.
raven562
Post by raven562 »
Will post beginning of my log after next system reboot, OK.
raven562
Post by raven562 »
I've got new(old) error messages after system reboot, here is my log:
*********************** Log Started 2020-09-12T08:58:18Z ***********************
08:58:18:Trying to access database...
08:58:18:Successfully acquired database lock
08:58:18:Read GPUs.txt
08:58:19:Enabled folding slot 00: PAUSED cpu:10 (waiting for idle)
08:58:19:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] (waiting for idle)
08:58:19:****************************** FAHClient ******************************
08:58:19:        Version: 7.6.13
08:58:19:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:58:19:      Copyright: 2020 foldingathome.org
08:58:19:       Homepage: https://foldingathome.org/
08:58:19:           Date: Apr 27 2020
08:58:19:           Time: 21:21:01
08:58:19:       Revision: 5a652817f46116b6e135503af97f18e094414e3b
08:58:19:         Branch: master
08:58:19:       Compiler: Visual C++ 2008
08:58:19:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:58:19:       Platform: win32 10
08:58:19:           Bits: 32
08:58:19:           Mode: Release
08:58:19:         Config: w:\Users\admin\AppData\Roaming\FAHClient\config.xml
08:58:19:******************************** CBang ********************************
08:58:19:           Date: Apr 24 2020
08:58:19:           Time: 17:07:55
08:58:19:       Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
08:58:19:           Bits: 32
08:58:19:******************************* System ********************************
08:58:19:            CPU: AMD Ryzen 5 3600 6-Core Processor
08:58:19:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
08:58:19:           CPUs: 12
08:58:19:         Memory: 31.92GiB
08:58:19:    Free Memory: 28.84GiB
08:58:19:        Threads: WINDOWS_THREADS
08:58:19:     OS Version: 6.2
08:58:19:    Has Battery: false
08:58:19:     On Battery: false
08:58:19:     UTC Offset: 3
08:58:19:            PID: 11388
08:58:19:            CWD: w:\Users\admin\AppData\Roaming\FAHClient
08:58:19:  Win32 Service: false
08:58:19:             OS: Windows 10 Enterprise LTSC 2019
08:58:19:        OS Arch: AMD64
08:58:19:           GPUs: 1
08:58:19:          GPU 0: Bus:8 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
08:58:19:                 470/480/570/580/590]
08:58:19:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': 5
08:58:19:                 =0945= C:070==K9 <>4C;L.
08:58:19:
08:58:19:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:3004.8
08:58:19:******************************* libFAH ********************************
08:58:19:           Date: Apr 15 2020
08:58:19:           Time: 14:53:14
08:58:19:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
08:58:19:           Bits: 32
08:58:19:***********************************************************************
08:58:19:<config>
08:58:19:  <!-- Folding Slot Configuration -->
08:58:19:  <cause v='COVID_19'/>
08:58:19:
08:58:19:  <!-- Network -->
08:58:19:  <proxy v=':8080'/>
08:58:19:
08:58:19:  <!-- User Information -->
08:58:19:  <passkey v='*****'/>
08:58:19:  <team v='47191'/>
08:58:19:  <user v='raven562'/>
08:58:19:
08:58:19:  <!-- Folding Slots -->
08:58:19:  <slot id='0' type='CPU'>
08:58:19:    <idle v='true'/>
08:58:19:    <paused v='False'/>
08:58:19:  </slot>
08:58:19:  <slot id='1' type='GPU'>
08:58:19:  </slot>
08:58:19:</config>
13:39:47:2:127.0.0.1:New Web session
13:39:48:7:127.0.0.1:New Web session
13:55:08:14:127.0.0.1:New Web session
13:55:09:19:127.0.0.1:New Web session
13:55:29:WU00:FS01:Starting
13:55:29:WU00:FS01:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
13:55:29:WU00:FS01:Started FahCore on PID 10660
13:55:34:WU00:FS01:FahCore 0x22 started
13:55:34:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
13:55:34:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
13:55:34:WU02:FS00:Starting
13:55:34:WARNING:WU02:FS00:AS lowered CPUs from 10 to 9
13:55:34:WU02:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -np 9
13:55:34:WU02:FS00:Started FahCore on PID 6080
13:55:36:WU02:FS00:FahCore 0xa7 started
13:55:36:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
13:55:36:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
13:55:36:WU00:FS01:Starting
13:55:36:WU00:FS01:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
13:55:36:WU00:FS01:Started FahCore on PID 1736
13:55:36:WU00:FS01:FahCore 0x22 started
13:55:37:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
13:55:37:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
13:55:37:WU02:FS00:Starting
13:55:37:WARNING:WU02:FS00:AS lowered CPUs from 10 to 9
13:55:37:WU02:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -np 9
13:55:37:WU02:FS00:Started FahCore on PID 7580
13:55:37:WU02:FS00:FahCore 0xa7 started
13:55:37:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
13:55:37:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
and FAHCoreWrapper makes attempts to start, because error messages continuous to popup...
raven562
Post by raven562 »
And so on, even if I restart tasks via web-control page
13:56:11:Removing old file 'configs/config-20200907-142141.xml'
13:56:11:Saving configuration to config.xml
13:56:11:<config>
13:56:11:  <!-- Folding Slot Configuration -->
13:56:11:  <cause v='COVID_19'/>
13:56:11:
13:56:11:  <!-- Network -->
13:56:11:  <proxy v=':8080'/>
13:56:11:
13:56:11:  <!-- User Information -->
13:56:11:  <passkey v='*****'/>
13:56:11:  <team v='47191'/>
13:56:11:  <user v='raven562'/>
13:56:11:
13:56:11:  <!-- Folding Slots -->
13:56:11:  <slot id='0' type='CPU'>
13:56:11:    <paused v='False'/>
13:56:11:  </slot>
13:56:11:  <slot id='1' type='GPU'/>
13:56:11:</config>
13:56:36:WU00:FS01:Starting
13:56:36:WU00:FS01:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
13:56:36:WU00:FS01:Started FahCore on PID 9816
13:56:39:WU00:FS01:FahCore 0x22 started
13:56:39:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
13:56:39:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
13:56:39:WU02:FS00:Starting
13:56:39:WARNING:WU02:FS00:AS lowered CPUs from 10 to 9
13:56:39:WU02:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -np 9
13:56:39:WU02:FS00:Started FahCore on PID 5024
13:56:39:WU02:FS00:FahCore 0xa7 started
13:56:39:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
13:56:39:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
13:56:43:FS00:Paused
13:56:43:FS01:Paused
13:57:12:Removing old file 'configs/config-20200907-161129.xml'
13:57:12:Saving configuration to config.xml
13:57:12:<config>
13:57:12:  <!-- Folding Slot Configuration -->
13:57:12:  <cause v='COVID_19'/>
13:57:12:
13:57:12:  <!-- Network -->
13:57:12:  <proxy v=':8080'/>
13:57:12:
13:57:12:  <!-- User Information -->
13:57:12:  <passkey v='*****'/>
13:57:12:  <team v='47191'/>
13:57:12:  <user v='raven562'/>
13:57:12:
13:57:12:  <!-- Folding Slots -->
13:57:12:  <slot id='0' type='CPU'>
13:57:12:    <paused v='true'/>
13:57:12:  </slot>
13:57:12:  <slot id='1' type='GPU'>
13:57:12:  </slot>
13:57:12:</config>
13:59:52:FS00:Unpaused
13:59:52:FS01:Unpaused
13:59:52:WU00:FS01:Starting
13:59:52:WU00:FS01:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
13:59:52:WU00:FS01:Started FahCore on PID 6192
13:59:54:WU00:FS01:FahCore 0x22 started
13:59:54:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
13:59:54:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
13:59:54:WU02:FS00:Starting
13:59:54:WARNING:WU02:FS00:AS lowered CPUs from 10 to 9
13:59:54:WU02:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -np 9
13:59:54:WU02:FS00:Started FahCore on PID 12168
13:59:54:WU02:FS00:FahCore 0xa7 started
13:59:54:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
13:59:54:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
14:00:05:FS00:Paused
14:00:05:FS01:Paused
14:00:21:FS00:Unpaused
14:00:21:FS01:Unpaused
14:00:52:WU00:FS01:Starting
14:00:52:WU00:FS01:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.11/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:00:52:WU00:FS01:Started FahCore on PID 6548
14:00:54:WU00:FS01:FahCore 0x22 started
14:00:54:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
14:00:54:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
14:00:54:WARNING:WU00:FS01:Too many errors, failing
14:00:54:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:16918 run:138 clone:44 gen:29 core:0x22 unit:0x0000002e0002894c5f17617b04fa6d9a
14:00:54:WU00:FS01:Connecting to 155.247.166.220:8080
14:00:54:WU02:FS00:Starting
14:00:54:WARNING:WU02:FS00:AS lowered CPUs from 10 to 9
14:00:54:WU02:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -np 9
14:00:54:WU02:FS00:Started FahCore on PID 2920
14:00:54:WU02:FS00:FahCore 0xa7 started
14:00:54:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:00:54:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
14:00:54:WARNING:WU02:FS00:Too many errors, failing
14:00:54:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:16403 run:701 clone:2 gen:192 core:0xa7 unit:0x000000d796880e6e5e8be0b6ea7db220
14:00:54:WU02:FS00:Connecting to 150.136.14.110:8080
14:00:55:WU01:FS00:Connecting to assign1.foldingathome.org:80
14:00:55:WU03:FS01:Connecting to assign1.foldingathome.org:80
14:00:55:WU02:FS00:Server responded WORK_ACK (400)
14:00:55:WU02:FS00:Cleaning up
14:00:56:WU00:FS01:Server responded WORK_ACK (400)
14:00:56:WU00:FS01:Cleaning up
14:00:56:WU03:FS01:Assigned to work server 155.247.166.220
14:00:56:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 155.247.166.220
14:00:56:WU03:FS01:Connecting to 155.247.166.220:8080
14:00:56:WU01:FS00:Assigned to work server 128.252.203.9
14:00:56:WU01:FS00:Requesting new work unit for slot 00: READY cpu:10 from 128.252.203.9
14:00:56:WU01:FS00:Connecting to 128.252.203.9:8080
14:00:57:WU01:FS00:Downloading 7.54MiB
14:00:58:WU03:FS01:Downloading 28.19MiB
14:01:03:WU01:FS00:Download 63.79%
14:01:05:WU03:FS01:Download 0.44%
14:01:06:WU01:FS00:Download complete
14:01:06:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14483 run:0 clone:778 gen:190 core:0xa7 unit:0x000000d580fccb095f171a3af270f109
14:01:06:WU01:FS00:Starting
14:01:06:WU01:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -np 10
14:01:06:WU01:FS00:Started FahCore on PID 10180
14:01:08:WU01:FS00:FahCore 0xa7 started
14:01:08:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:01:08:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
14:01:08:WU01:FS00:Starting
14:01:08:WU01:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -np 10
14:01:08:WU01:FS00:Started FahCore on PID 6272
14:01:09:WU01:FS00:FahCore 0xa7 started
14:01:09:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:01:09:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
14:01:14:WU03:FS01:Download 0.67%
14:01:16:Removing old file 'configs/config-20200907-180319.xml'
14:01:16:Saving configuration to config.xml
14:01:16:<config>
14:01:16:  <!-- Folding Slot Configuration -->
14:01:16:  <cause v='COVID_19'/>
14:01:16:
14:01:16:  <!-- Network -->
14:01:16:  <proxy v=':8080'/>
14:01:16:
14:01:16:  <!-- User Information -->
14:01:16:  <passkey v='*****'/>
14:01:16:  <team v='47191'/>
14:01:16:  <user v='raven562'/>
14:01:16:
14:01:16:  <!-- Folding Slots -->
14:01:16:  <slot id='0' type='CPU'/>
14:01:16:  <slot id='1' type='GPU'/>
14:01:16:</config>
14:01:21:WU03:FS01:Download 0.89%
14:01:27:WU03:FS01:Download 1.11%
14:01:37:WU03:FS01:Download 1.55%
14:01:45:WU03:FS01:Download 2.00%
14:01:56:WU03:FS01:Download 2.44%
14:02:08:WU01:FS00:Starting
14:02:08:WU01:FS00:Running FahCore: "w:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" w:\Users\admin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/win/64bit-avx-256/a7-0.0.19/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 11388 -checkpoint 15 -np 10
14:02:08:WU01:FS00:Started FahCore on PID 4424
14:02:08:WU03:FS01:Download 2.88%
14:02:10:WU01:FS00:FahCore 0xa7 started
14:02:10:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:02:10:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741502 = 0xc0000142)
Since you have an AMD GPU, it might be possible that you're potentially encountering some bugs in the current version of FahCore_22 (0.0.11). The next release of FahCore_22 (0.0.12) might have some fixes. ETA for the release is very soon :)
PantherX appears to have misread the log and just focused on the Core_22 errors, the errors shown on startup of a CPU or GPU project WU using the A7 or 22 folding cores are the same. The error message is being passed through from Windows, it is not being generated within the folding cores or the wrapper process. Further information should be findable in the Windows error logs.
Looking over the configuration I don't see anything particularly wrong. though running under the admin account is not usual or necessary. Being run from the "W" drive is not the default, but it looks like the correct paths were passed to the client.
Getting back to the Windows error, briefly searching online seems to indicate failure to access a file or DLL, the errors reported in the Windows logs may help in determining which files. Since this happens after each reboot, but not after installing, it sounds like a permission is being changed or reset when your system is shutdown or started.
JohnChodera
Pande Group Member
Post by JohnChodera »
This might be good to file in the issue tracker: https://github.com/foldingathome/fah-issues/issues
~ John Chodera // MSKCC
raven562
Post by raven562 »
JohnChodera wrote:This might be good to file in the issue tracker: https://github.com/foldingathome/fah-issues/issues
Thanks for answers!
I've look through that link to GITHUB. Do not find common issues on all 13 pages. Gonna try to find answers in Windows logs...
P.S.: FAH were paused all day and when I try to start it everything is working fine. Don't know what fixes it. "It's a kind of magic", you know :) Some type of timer, maybe?
All activities were games, Youtube...
raven562
Post by raven562 »
Hi! I've done several system reboot and noticed, that issue with FAHWrapper errors is gone. Didn't do anything, just 3-5 reboots during one day.
Anyway everything is OK now, thank you for your response. Gonna folding@home further :)
Just wondering if you have any anti-spyware, anti-malware, anti-virus, anti-phishing, etc. software which could potentially interfere. If you have, you may want to exclude these locations (even in Windows Security Center):
BTW, I just realized that you're not using the default drive. If you're using a software for mapping or folder re-direction, that could potentially cause an issue.
Have you been starting FAH using the shortcut that FAH installs?
Did that change ... or did you fix the clone of it that you've been running?
raven562
Post by raven562 »
PantherX wrote:Just wondering if you have any anti-spyware, anti-malware, anti-virus, anti-phishing, etc. software which could potentially interfere. If you have, you may want to exclude these locations (even in Windows Security Center):
Hi, PantherX!
Thanks for advice, I've set exclusion in Kaspersky Internet Security (KIS). It is not a potential problem spot right now. I think if there were security issue between FAH and KIS, KIS reports me about that. Leave KIS settings for test.
I do not use any drive mapping software (as i know). My system boots up from *.VHD drive via custom boot loader (not mine design), so I don't know if these circumstances affects FAH software; I do not use any virtual machines. BTW I'm 6 month in project and only problem I got before - lack of tasks in March, early April.
That particular issue with FARCOREWRAPPER.exe appears first time I upgrade to a new version. And magically disappears after several system reboot two or three days ago :)
raven562
Post by raven562 »
bruce wrote:Have you been starting FAH using the shortcut that FAH installs?
Hi, Bruce!
I launch usual FAH installer and then do not start FAH manually, it's starts automatically. There were several attempts to restart FAH manually while FAHCoreWrapper.exe encounters error, but I can't say that were successful attempts.
I've done several system restart after that and that's magically solves problem. (Sorry for mistiming :) English times (lingual) a bit difficult for me :) )
Do not fix any clones of FAH, not so competent to do that. Do not know what the "clones" are? That is processes I see in task manager?
Now I see that everything is working fine, so issue with FAHCoreWrapper.exe seems to be magically solved. I think in that way because:
1. Do not see any error messages and FAH is calculating right now.
2. Do not see any error messages after system restart (There were 2 reboots).
3. FAH client easily changes states between "on idle" and " while I'm working" and back. Using that option while gaming.
