Whitelist 2070 RTX Please
tomscigars
For some reason my RTX 2070 Super isn't on the list anymore. Can it be added? I've folded 85 million, but that's stopped now because of this.
NVIDIA GeForce RTX 2070 Super
Device ID 10DE 1EC7 - 10DE 13AA
Re: Whitelist 2070 RTX Please
I wonder if there is a link between your issue and the issue another folder was having - both appear to be 2070s that were working and now aren't ... viewtopic.php?f=66&t=35698&start=15#p339260
tomscigars
VERY interesting. Maybe it's related. I put my log file below.
I reloaded Windows 10 from scratch, reset the BIOS, verified all drivers and updates are installed. I then installed F&H as normal, but it isn't pickup up my GPU.
*********************** Log Started 2020-07-08T15:14:51Z ***********************
15:14:51:Trying to access database...
15:14:51:Successfully acquired database lock
15:14:52:Downloading GPUs.txt from assign1.foldingathome.org:80
15:14:52:Connecting to assign1.foldingathome.org:80
15:14:52:Read GPUs.txt
15:14:52:Enabled folding slot 00: READY cpu:16
15:14:52:****************************** FAHClient ******************************
15:14:52: Version: 7.6.13
15:14:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:14:52: Copyright: 2020 foldingathome.org
15:14:52: Homepage: https://foldingathome.org/
15:14:52: Date: Apr 27 2020
15:14:52: Time: 21:21:01
15:14:52: Revision: 5a652817f46116b6e135503af97f18e094414e3b
15:14:52: Branch: master
15:14:52: Compiler: Visual C++ 2008
15:14:52: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:14:52: Platform: win32 10
15:14:52: Bits: 32
15:14:52: Mode: Release
15:14:52: Args: --open-web-control
15:14:52: Config: C:\Users\tom_a\AppData\Roaming\FAHClient\config.xml
15:14:52:******************************** CBang ********************************
15:14:52: Date: Apr 24 2020
15:14:52: Time: 17:07:55
15:14:52: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
15:14:52: Bits: 32
15:14:52:******************************* System ********************************
15:14:52: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
15:14:52: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
15:14:52: CPUs: 16
15:14:52: Memory: 31.95GiB
15:14:52: Free Memory: 27.03GiB
15:14:52: Threads: WINDOWS_THREADS
15:14:52: OS Version: 6.2
15:14:52: Has Battery: false
15:14:52: On Battery: false
15:14:52: UTC Offset: -4
15:14:52: PID: 6488
15:14:52: CWD: C:\Users\tom_a\AppData\Roaming\FAHClient
15:14:52: Win32 Service: false
15:14:52: OS: Windows 10 Enterprise
15:14:52: OS Arch: AMD64
15:14:52: GPUs: 0
15:14:52: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
15:14:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:451.48
15:14:52:******************************* libFAH ********************************
15:14:52: Date: Apr 15 2020
15:14:52: Time: 14:53:14
15:14:52: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
15:14:52: Bits: 32
15:14:52:***********************************************************************
15:14:52:<config>
15:14:52: <!-- Network -->
15:14:52: <proxy v=':8080'/>
15:14:52:
15:14:52: <!-- Slot Control -->
15:14:52: <power v='full'/>
15:14:52:
15:14:52: <!-- User Information -->
15:14:52: <passkey v='*****'/>
15:14:52: <team v='223518'/>
15:14:52: <user v='TomsCigars'/>
15:14:52:
15:14:52: <!-- Folding Slots -->
15:14:52: <slot id='0' type='CPU'/>
15:14:52:</config>
15:14:52:WU00:FS00:Starting
15:14:52:WARNING:WU00:FS00:AS lowered CPUs from 16 to 15
15:14:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tom_a\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 6488 -checkpoint 15 -np 15
15:14:52:WU00:FS00:Started FahCore on PID 2340
15:14:52:WU00:FS00:Core PID:18948
15:14:52:WU00:FS00:FahCore 0xa7 started
15:14:53:WU00:FS00:0xa7:*********************** Log Started 2020-07-08T15:14:52Z ***********************
15:14:53:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:14:53:WU00:FS00:0xa7: Type: 0xa7
15:14:53:WU00:FS00:0xa7: Core: Gromacs
15:14:53:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 2340 -checkpoint 15 -np
15:14:53:WU00:FS00:0xa7: 15
15:14:53:WU00:FS00:0xa7:************************************ CBang *************************************
15:14:53:WU00:FS00:0xa7: Date: Oct 26 2019
15:14:53:WU00:FS00:0xa7: Time: 01:38:25
15:14:53:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:14:53:WU00:FS00:0xa7: Branch: master
15:14:53:WU00:FS00:0xa7: Compiler: Visual C++ 2008
15:14:53:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:14:53:WU00:FS00:0xa7: Platform: win32 10
15:14:53:WU00:FS00:0xa7: Bits: 64
15:14:53:WU00:FS00:0xa7: Mode: Release
15:14:53:WU00:FS00:0xa7:************************************ System ************************************
15:14:53:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
15:14:53:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
15:14:53:WU00:FS00:0xa7: CPUs: 16
15:14:53:WU00:FS00:0xa7: Memory: 31.95GiB
15:14:53:WU00:FS00:0xa7:Free Memory: 27.02GiB
15:14:53:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
15:14:53:WU00:FS00:0xa7: OS Version: 6.2
15:14:53:WU00:FS00:0xa7:Has Battery: false
15:14:53:WU00:FS00:0xa7: On Battery: false
15:14:53:WU00:FS00:0xa7: UTC Offset: -4
15:14:53:WU00:FS00:0xa7: PID: 18948
15:14:53:WU00:FS00:0xa7: CWD: C:\Users\tom_a\AppData\Roaming\FAHClient\work
15:14:53:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:14:53:WU00:FS00:0xa7: Version: 0.0.18
15:14:53:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:14:53:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:14:53:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:14:53:WU00:FS00:0xa7: Time: 01:52:30
15:14:53:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:14:53:WU00:FS00:0xa7:************************************ Build *************************************
15:14:53:WU00:FS00:0xa7: SIMD: avx_256
15:14:53:WU00:FS00:0xa7:********************************************************************************
15:14:53:WU00:FS00:0xa7:Project: 14235 (Run 45, Clone 0, Gen 54)
15:14:53:WU00:FS00:0xa7:Unit: 0x0000004acedfaa925ea376f37f674871
15:14:53:WU00:FS00:0xa7:Digital signatures verified
15:14:53:WU00:FS00:0xa7:Calling: mdrun -s frame54.tpr -o frame54.trr -x frame54.xtc -cpi state.cpt -cpt 15 -nt 15
15:14:53:WU00:FS00:0xa7:Steps: first=13500000 total=250000
15:14:55:WU00:FS00:0xa7:Completed 58792 out of 250000 steps (23%)
15:14:55:17:127.0.0.1:New Web session
15:15:11:32:127.0.0.1:New Web session
15:15:46:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
15:17:29:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
15:19:15:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
15:21:01:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
15:22:42:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
15:24:22:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
15:26:07:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
15:27:51:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
15:29:36:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
15:31:20:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
15:33:04:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
15:34:45:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
15:36:30:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
15:38:12:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
Reason: change Quote tags to Code for log segments
The symptoms are a tad different but in both cases there is an association to GPUs.txt ... Could you look at past logs where your 2070 was working and post the top part with the GPU slot identified - I am intrigued to see if it is the same as the other case.
... and if you edit your post, select all the log text then click on the code button above the edit pane it will add tags that will display the log in a scrollable window
tomscigars
I appreciate the replies! Unfortunately, I didn't think to do that before reloading the entire system. My fault for not investigating first. I figured re-doing everything would fix it.
no problems .. skimmed over the bit that mentioned the rebuild - sorry !!
... the drivers are the nvidia ones right? ... the numbers look familiar
tomscigars
All good! I appreciate the replies either way : )
I download the drivers right from Nvidia's website. Everything is freshly installed last night and into this morning.
damn - sounds like you pulled an all nighter !! .. Hopefully one of the regular GPU gurus will spot this
tomscigars
Very weird indeed. A few days ago I noticed F&H was barely using my GPU, so I figured I'd do an uninstall/reinstall. Since that didn't work, I figured it's an old load of Win 10, so a fresh install was due anyway.
I also reset the BIOS to default, except for XMP (3200).
That barely using GPU sounds awfully like the symptoms in the other thread
tomscigars
For months F&H hammered my GPU as it should, then suddenly it was barely breaking 42 degrees C when being used by F&H. Then the uninstall/reinstall debocle happened. It's sure;y not a hardware or Windows issue. I'm suspecting the GPUs.txt file, as I couldn't fine my GPU's device ID. Wish I kept the old file, but I researched backwards, so it's gone unfortunately.
Would have to find an old version of GPUs.txt, but it appears this version of the 2070 Super and its device ID are not in the current version. Whether it was an editing error or something else I can not tell. In any case, even if the local copy had the entry from being older, the copy on the Assignment and Work Servers is the controlling one.
This variant of 2070 Super is back in the list ...
tomscigars
I must have not seen it. I just deleted the GPUs.txt file and allowed it to re-download, but it still won't let me add a GPU slot. Something weird with this client software for sure.
Actually I just re-searched a new copy of GPUs.txt, and can't find it. Device ID 10DE 1EC7 - 10DE 13AA.
tomscigars
Here are the results of searching GPUs.txt file for "2070" I searched other parts of the device ID string with no returned results, other than the "10de" string, which returned a lot of unrelated results. My particular card isn't in there, no?
0x10de:0x06d1:2:2:GF100 [Tesla C2050 / C2070] 1028
0x10de:0x06d8:2:2:GF100 [Quadro 6000] 1028
0x10de:0x06df:2:2:GF100 [M2070-Q] 1028
0x10de:0x084f:0:0:MCP78S [GeForce 8100/nForce 720a] Blacklist
0x10de:0x1e84:2:8:TU104 [GeForce RTX 2070 SUPER] 8218
0x10de:0x1e93:2:7:TU104M [GeForce RTX 2080 SUPER Mobile / Max-Q]
0x10de:0x1ec2:2:7:TU104 [GeForce RTX 2070 SUPER]
0x10de:0x1ed1:2:7:TU104BM [GeForce RTX 2070 SUPER Mobile / Max-Q] 5530
0x10de:0x1f02:2:7:TU106 [GeForce RTX 2070] M 6497
0x10de:0x1f07:2:7:TU106 [GeForce RTX 2070 Rev. A] M 7465
0x10de:0x1f10:2:7:TU106M [GeForce RTX 2070 Mobile] 6636
0x10de:0x1f14:2:7:TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
0x10de:0x1f50:2:7:TU106BM [GeForce RTX 2070 Mobile] 6636
0x10de:0x1f54:2:7:TU106BM [GeForce RTX 2070 Mobile]
