New version not working and fahclient having issues
MobileGamesMotion
- Hardware configuration: Windows 7, Intel i7-6600U CPU on a laptop
Hi.
I just installed 7.6, and its broken and the main core is broken. How do I install a version which is not broken like 7.5?
Last edited by MobileGamesMotion on Wed Jun 24, 2020 6:30 pm, edited 1 time in total.
#StayAtHome #AlertNotAnxious #FoldForCOVID
Basic help stuff:viewtopic.php?f=61&t=26036 | Find Your Stats:https://stats.foldingathome.org/donors
https://folding.extremeoverclocking.com/
Re: New version not working
While I am far more interested in helping with 7.6.13, Just post your Log file.
viewtopic.php?f=24&t=26036
You can download the older version
https://download.foldingathome.org/releases/public/release/fah-installer/windows-10-32bit/v7.5/fah-installer_7.5.1_x86.exeTsar of all the Rushers
There is literally no information in your post that could help solve the error, because we don't even know what the error is that you are getting.
Since thousands of people have been running 7.6.x for months, myself, the version is not "broken".
If you still have the installer of the old version, uninstalling the current version and re-installing the other one might be an option - but I seriously doubt that will fix whatever problem you are encountering.
Please post the relevant parts of your log, see viewtopic.php?f=61&t=26036.
7.6.13 is not as such broken, neither are the current cores - Many folders are using these with no issues ... It may be that your installation has some issues but what these could be will depend on many factors such as OS, setup, etc. and if you post your log as JimboPalmer suggests then someone should be able to help you sort them out.
I have been using 7.6 for a while without problem, but a couple of days ago I couldn't get FAH to work at all after a reboot. Re-installing didn't solve the problem, but uninstalling, including checking the box to delete the data, before re-installing fixed it. You won't lose your points so long as you have a record of your passkey.
My guess is that the data was screwed up and maybe that is the problem on MobileGamesMotion's instance.
MobileGamesMotion
Hi, sorry If I did not submit the data needed for you to troubleshoot my problem I did uninstall the fah with data checked multiple times, but the web interface and fahcontrol cannot connect to fahcore, which I did open. FAH did work when I was on an older version, so I'll try that first. Maybe the problem is because the exe file said it was made by a different company???
Cheers!
Cheers!
MobileGamesMotion
Also here is my log
*********************** Log Started 2020-06-24T14:39:48Z ***********************
14:39:48:************************* Folding@home Client *************************
14:39:48: Website: https://foldingathome.org/
14:39:48: Copyright: (c) 2009-2018 foldingathome.org
14:39:48: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:39:48: Args: --open-web-control
14:39:48: Config: <none>
14:39:48:******************************** Build ********************************
14:39:48: Version: 7.5.1
14:39:48: Date: May 11 2018
14:39:48: Time: 13:06:32
14:39:48: Repository: Git
14:39:48: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:39:48: Branch: master
14:39:48: Compiler: Visual C++ 2008
14:39:48: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:39:48: Platform: win32 10
14:39:48: Bits: 32
14:39:48: Mode: Release
14:39:48:******************************* System ********************************
14:39:48: CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
14:39:48: CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
14:39:48: CPUs: 4
14:39:48: Memory: 7.88GiB
14:39:48: Free Memory: 1.07GiB
14:39:48: Threads: WINDOWS_THREADS
14:39:48: OS Version: 6.2
14:39:48: Has Battery: true
14:39:48: On Battery: false
14:39:48: UTC Offset: -6
14:39:48: PID: 13036
14:39:48: CWD: C:\Users\zheng\AppData\Roaming\FAHClient
14:39:48: OS: Windows 10 Enterprise
14:39:48: OS Arch: AMD64
14:39:48: GPUs: 0
14:39:48: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:39:48: specified module could not be found.
14:39:48:
14:39:48: OpenCL: Not detected: Win32: 0xc0000094: Tnteger divide by zero
14:39:48:Win32 Service: false
14:39:48:***********************************************************************
14:39:48:<config>
14:39:48: <!-- Folding Slots -->
14:39:48:</config>
14:39:48:Connecting to assign1.foldingathome.org:8080
14:39:49:Updated GPUs.txt
14:39:49:Read GPUs.txt
14:39:49:Trying to access database...
14:39:49:Successfully acquired database lock
14:39:49:Enabled folding slot 00: PAUSED cpu:1 (not configured)
On this white field should be a cpu item, if not click Add.
By default F@H sets the number of CPUs to -1 meaning let the software decide.
You could choose 4 if you wish.
This "fahcore" you are opening, do you mean FAHClient? Normally FAHCore would be referring to one of the folding cores, FAHCore_A7, FAHCore_21 or FAHCore_22. You do not "run" those, they are started by FAHClient and passed the parameters to process a WU. FAHClient needs to be running in the background, started from the shortcut created by installation.
Now that log does show FAHClient was running, at a least as far as starting to configure a CPU folding slot. However there ia an error message I have never seen before:
No idea what would cause that, perhaps no OpenCL support of any kind is installed on your Windows system.
Web Control and FAHControl communicate with FAHClient over the local loopback IP address 127.0.0.1 on ports 7396 and 36330 respectively. Has anything changed in the last few days to a firewall or anti-malware setup that would interfere with that? An improperly configured config.xml file could also be the problem, but that should have been deleted by an uninstall that included data.
14:39:48: OpenCL: Not detected: Win32: 0xc0000094: Tnteger divide by zeroWeb Control and FAHControl communicate with FAHClient over the local loopback IP address 127.0.0.1 on ports 7396 and 36330 respectively. Has anything changed in the last few days to a firewall or anti-malware setup that would interfere with that? An improperly configured config.xml file could also be the problem, but that should have been deleted by an uninstall that included data.
MobileGamesMotion
Hi.
So I did open fahclient, and it did nothing. There is no icon in the icon menu. One thing was the download link for the old version I got had 32bit on it, and my system runs 64bit. I'll try installed the latest version of fah 64bit again. Also, then was a gpu file I found with the log. It is very wierd and contains gpu names I don't have.
MobileGamesMotion
I just tried installing the latest version of fah, and got this:
FAH control stick says connecting.
*********************** Log Started 2020-06-24T16:00:55Z ***********************
16:00:55:Trying to access database...
16:00:55:Successfully acquired database lock
16:00:56:Downloading GPUs.txt from assign1.foldingathome.org:80
16:00:56:Connecting to assign1.foldingathome.org:80
16:00:56:Read GPUs.txt
16:00:56:Enabled folding slot 00: PAUSED cpu:1 (not configured)
16:00:56:Enabled folding slot 01: PAUSED gpu:0:Gen9/GT2 [HD Graphics 520] (not configured)
The client downloads a copy of GPUs.txt, and periodically updates it. It is a combination whitelist and blacklist of various GPUs that the folding client might detect on a system.
If you have a firewall enabled, try temporarily disabling it and see if FAHControl can connect to the FAHClient process. Do the same for any anti-malware software running. If it can connect then, you will need to check settings in them to allow the connection. MS did push out some big updates recently, often those reset settings in their supplied software to defaults or add new restrictions.
MobileGamesMotion
I let fah through my firewall and my antivirus sees no viruses.
Check to see if the 127.0.0.1 address is listed as in the "Private" zone for connections.
MobileGamesMotion
Yep enabled all the check marks for fah.
