Is there any way to force the use of a GPU core other than 22? Can I select some project other than Virus 19 and get a different core?
I am trying to determine if I have problems with any other core.
force a core other than 22
Re: force a core other than 22
The project determines which core is required, so it's out of your control.
All GPU projects for COVID-19 currently require FahCore_22.
You can select a preference other than COVID-19, I think there's still some FahCore_21 out there that hand out WUs, but changing preference doesn't guarantee you'll get any of those.
Core_22 is a GPU core. Some older GPU projects use Core_21, but with the priority on COVID-19, they are currently rare. (all GPU COVID-19 projects are Core_22)
Core_a7 is the CPU core.
To the best of my knowledge no you can't force/choose Projects/WUs/Core … You can state a preference for the type of Projects but that is about it … What problems do you think you are having with Core22? - and are these with 0.0.10 or a previous version? … I ask as there are some current Projects that are very variable in a number of ways - but issues are not necessarily due to the core but the experimental type of projects - so it may not be your kit/setup having issues and just be the impact some of the projects are having at the moment.
I am occasionally picking up Core21s as at least one of the research groups is using that still on fairly new projects.
mwroggenbuck
My issues are documented elsewhere viewtopic.php?f=81&t=35482
I am just trying to narrow things down. As stated in the above link, it is frustrating to see a 5 hour run say it is finished, but not able to upload because of an unknown error.
Nobody else seems to have this problem, so I am doing as much investigation as I can. I am running world community grid boinc virus besides this (I give CPU to WCG and GPU to FAH). I have an i7 with 4 cores, 8 threads. I only allocate 4 cores to WCG, and I always have some idle CPU cycles, so I don't think this is the issue. I could stop WCG for a while and see if that helps.
I did switch my project preference to cancer in hopes of getting a core 21 project, but I received a virus 19 project. I know what project you select you may not get. I guess I just confirmed that.
I also tried bumping up the priority of my FAH via the advanced controls. It did not help.
I am open to any suggestions.
Probably P169xx. That was the last time I got a FAHCore_21. I think there is at least one other project still running core_21.Neil-B wrote:I am occasionally picking up Core21s as at least one of the research groups is using that still on fairly new projects.
So looks like leaving your preference to cancer probably optimises your chances of getting a Core21 ... I won't try to help re the problems since they are being covered in the other thread.
