GPU stuck on waiting for idle and can't use instead of CPU
I've been trying to put all the load from my CPU to my GPU recently. In the advanced control panel my GPU is supposedly waiting for idle even tough I don't want it to. Is there any way to disable that and let my gpu run whilst working?
Re: GPU stuck on waiting for idle and can't use instead of C
Welcome to Folding@Home!
If we had the first 200 lines of your log, we would know what your software thought the hangup was.
viewtopic.php?f=24&t=26036
With that log, we can help!
Does your mouse/keyboard wake up the machine. It's the OS that decides if it's idle. FAH just checks with the OS.
Welcome to the F@H Forum synapsies,
In Advanced Control, set the Folding Power to Medium or Higher. Also, you can double check that on idle setting is disabled by right-clicking on the GPU Slot and ensuring that there's no tick next to On Idle.
As you asked here is the entirety of my logs. I'm not sure if it's 200 lines but hope I can help.
*********************** Log Started 2020-05-27T10:00:52Z ***********************
10:00:52:************************* Folding@home Client *************************
10:00:52: Website: https://foldingathome.org/
10:00:52: Copyright: (c) 2009-2018 foldingathome.org
10:00:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:00:52: Args: --open-web-control
10:00:52: Config: C:\Users\Win10\AppData\Roaming\FAHClient\config.xml
10:00:52:******************************** Build ********************************
10:00:52: Version: 7.5.1
10:00:52: Date: May 11 2018
10:00:52: Time: 13:06:32
10:00:52: Repository: Git
10:00:52: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:00:52: Branch: master
10:00:52: Compiler: Visual C++ 2008
10:00:52: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:00:52: Platform: win32 10
10:00:52: Bits: 32
10:00:52: Mode: Release
10:00:52:******************************* System ********************************
10:00:52: CPU: AMD Ryzen 5 3600 6-Core Processor
10:00:52: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
10:00:52: CPUs: 12
10:00:52: Memory: 15.94GiB
10:00:52: Free Memory: 9.15GiB
10:00:52: Threads: WINDOWS_THREADS
10:00:52: OS Version: 6.2
10:00:52: Has Battery: false
10:00:52: On Battery: false
10:00:52: UTC Offset: 2
10:00:52: PID: 18520
10:00:52: CWD: C:\Users\Win10\AppData\Roaming\FAHClient
10:00:52: OS: Windows 10 Enterprise
10:00:52: OS Arch: AMD64
10:00:52: GPUs: 1
10:00:52: GPU 0: Bus:9 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT /
10:00:52: 5700/5700 XT]
10:00:52: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
10:00:52: specified module could not be found.
10:00:52:
10:00:52:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:3004.8
10:00:52: Win32 Service: false
10:00:52:***********************************************************************
10:00:52:<config>
10:00:52: <!-- Network -->
10:00:52: <proxy v=':8080'/>
10:00:52:
10:00:52: <!-- Slot Control -->
10:00:52: <power v='LIGHT'/>
10:00:52:
10:00:52: <!-- User Information -->
10:00:52: <passkey v='********************************'/>
10:00:52: <team v='242314'/>
10:00:52: <user v='winter'/>
10:00:52:
10:00:52: <!-- Folding Slots -->
10:00:52: <slot id='0' type='CPU'/>
10:00:52: <slot id='1' type='GPU'/>
10:00:52:</config>
10:00:52:Trying to access database...
10:00:52:Successfully acquired database lock
10:00:52:Enabled folding slot 00: READY cpu:5
10:00:52:Enabled folding slot 01: PAUSED gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] (waiting for idle)
10:00:53:WU00:FS00:Starting
10:00:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Win10\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 18520 -checkpoint 15 -np 5
10:00:53:WU00:FS00:Started FahCore on PID 19520
10:00:54:WU00:FS00:Core PID:5972
10:00:54:WU00:FS00:FahCore 0xa7 started
10:00:54:WU00:FS00:0xa7:*********************** Log Started 2020-05-27T10:00:54Z ***********************
10:00:54:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:00:54:WU00:FS00:0xa7: Type: 0xa7
10:00:54:WU00:FS00:0xa7: Core: Gromacs
10:00:54:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 19520 -checkpoint 15 -np
10:00:54:WU00:FS00:0xa7: 5
10:00:54:WU00:FS00:0xa7:************************************ CBang *************************************
10:00:54:WU00:FS00:0xa7: Date: Oct 26 2019
10:00:54:WU00:FS00:0xa7: Time: 01:38:25
10:00:54:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:00:54:WU00:FS00:0xa7: Branch: master
10:00:54:WU00:FS00:0xa7: Compiler: Visual C++ 2008
10:00:54:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:00:54:WU00:FS00:0xa7: Platform: win32 10
10:00:54:WU00:FS00:0xa7: Bits: 64
10:00:54:WU00:FS00:0xa7: Mode: Release
10:00:54:WU00:FS00:0xa7:************************************ System ************************************
10:00:54:WU00:FS00:0xa7: CPU: AMD Ryzen 5 3600 6-Core Processor
10:00:54:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
10:00:54:WU00:FS00:0xa7: CPUs: 12
10:00:54:WU00:FS00:0xa7: Memory: 15.94GiB
10:00:54:WU00:FS00:0xa7:Free Memory: 9.11GiB
10:00:54:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
10:00:54:WU00:FS00:0xa7: OS Version: 6.2
10:00:54:WU00:FS00:0xa7:Has Battery: false
10:00:54:WU00:FS00:0xa7: On Battery: false
10:00:54:WU00:FS00:0xa7: UTC Offset: 2
10:00:54:WU00:FS00:0xa7: PID: 5972
10:00:54:WU00:FS00:0xa7: CWD: C:\Users\Win10\AppData\Roaming\FAHClient\work
10:00:54:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:00:54:WU00:FS00:0xa7: Version: 0.0.18
10:00:54:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:00:54:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
10:00:54:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
10:00:54:WU00:FS00:0xa7: Time: 01:52:30
10:00:54:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:00:54:WU00:FS00:0xa7:************************************ Build *************************************
10:00:54:WU00:FS00:0xa7: SIMD: avx_256
10:00:54:WU00:FS00:0xa7:********************************************************************************
10:00:54:WU00:FS00:0xa7:Project: 14824 (Run 2095, Clone 1, Gen 58)
10:00:54:WU00:FS00:0xa7:Unit: 0x000000439bf7a4d55ea343d0eb8833e8
10:00:54:WU00:FS00:0xa7:Digital signatures verified
10:00:54:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
10:00:54:WU00:FS00:0xa7:Calling: mdrun -s frame58.tpr -o frame58.trr -cpi state.cpt -cpt 15 -nt 4
10:00:54:WU00:FS00:0xa7:Steps: first=0 total=250000
10:00:55:WU00:FS00:0xa7:Completed 94217 out of 250000 steps (37%)
10:00:56:8:127.0.0.1:New Web connection
10:01:24:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
10:02:55:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
10:04:29:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
You have two options.
Option 1 - Change Folding Power
You can move your Folding Power from Light to Medium. That will cause:
CPU -> To fold 24/7 using 10 CPUs
GPU -> To fold 24/7
Option 2 - Tweak GPU Slot
Open up Advanced Control (AKA FAHControl) and right-click the GPU slot and untick the "On Idle" option. That will cause:
CPU -> To fold 24/7 using 4 CPUs
GPU -> To fold 24/7
GPU -> To fold 24/7
GPU -> To fold 24/7
