AMD Radeon RX Vega M GPU causing BSOD
System specs: HP x360, Windows 10 Pro, Intel Core i7-8705G, Intel HD Graphics 630 GPU, AMD Radeon RX Vega M GL GPU, 16GB RAM
When FAH runs on the GPU it constantly (every 3-5 minutes) causes a BSOD. The errors are VIDEO_TDR_FAILURE (error 116) and ATTEMPTED_WRITE_TO_READONLY_MEMORY (error BE).
If I stop the GPU from processing FAH, then the system is stable.
Can anyone help with this? There are not any newer drivers for this on HP or AMD's support sites. The date for the drivers is 2018.
Thanks,
Mike
Thanks,
Mike
Re: AMD Radeon RX Vega M GPU causing BSOD
Mike is it a laptop?
To give you the best help we need the top 200 lines of the log, which show the configuration.
viewtopic.php?f=24&t=26036
Some laptops run the Intel GPU normally to save power, then switch for intense loads to the better GPU. Since F@H does not support Intel GPUs it crashes before things get intense.
you may wish to look for some hint you can always use the AMD, with the caveat that it will use more power and run hotter and louder.
*********************** Log Started 2020-05-14T06:05:03Z ***********************
06:05:03:Trying to access database...
06:05:03:Successfully acquired database lock
06:05:03:Read GPUs.txt
06:05:03:Enabled folding slot 00: PAUSED cpu:7 (by user)
06:05:04:Enabled folding slot 01: PAUSED gpu:0:[Radeon RX Vega M XL] (by user)
06:05:04:****************************** FAHClient ******************************
06:05:04: Version: 7.6.13
06:05:04: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:05:04: Copyright: 2020 foldingathome.org
06:05:04: Homepage: https://foldingathome.org/
06:05:04: Date: Apr 27 2020
06:05:04: Time: 21:21:01
06:05:04: Revision: 5a652817f46116b6e135503af97f18e094414e3b
06:05:04: Branch: master
06:05:04: Compiler: Visual C++ 2008
06:05:04: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:05:04: Platform: win32 10
06:05:04: Bits: 32
06:05:04: Mode: Release
06:05:04: Config: C:\klc\FAHClient\config.xml
06:05:04:******************************** CBang ********************************
06:05:04: Date: Apr 24 2020
06:05:04: Time: 17:07:55
06:05:04: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
06:05:04: Bits: 32
06:05:04:******************************* System ********************************
06:05:04: CPU: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz
06:05:04: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
06:05:04: CPUs: 8
06:05:04: Memory: 15.85GiB
06:05:04: Free Memory: 10.90GiB
06:05:04: Threads: WINDOWS_THREADS
06:05:04: OS Version: 6.2
06:05:04: Has Battery: true
06:05:04: On Battery: false
06:05:04: UTC Offset: -6
06:05:04: PID: 15396
06:05:04: CWD: C:\klc\FAHClient
06:05:04: Win32 Service: false
06:05:04: OS: Windows 10 Enterprise
06:05:04: OS Arch: AMD64
06:05:04: GPUs: 1
06:05:04: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 [Radeon RX Vega M XL]
06:05:04: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
06:05:04: specified module could not be found.
06:05:04:
06:05:04:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2766.5
06:05:04:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
06:05:04:******************************* libFAH ********************************
06:05:04: Date: Apr 15 2020
06:05:04: Time: 14:53:14
06:05:04: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
06:05:04: Bits: 32
06:05:04:***********************************************************************
06:05:04:<config>
06:05:04: <!-- Folding Slot Configuration -->
06:05:04: <cause v='COVID_19'/>
06:05:04:
06:05:04: <!-- Network -->
06:05:04: <proxy v=':8080'/>
06:05:04:
06:05:04: <!-- Slot Control -->
06:05:04: <power v='full'/>
06:05:04:
06:05:04: <!-- User Information -->
06:05:04: <passkey v='*****'/>
06:05:04: <team v='243108'/>
06:05:04: <user v='KeenLogic'/>
06:05:04:
06:05:04: <!-- Folding Slots -->
06:05:04: <slot id='0' type='CPU'>
06:05:04: <paused v='true'/>
06:05:04: </slot>
06:05:04: <slot id='1' type='GPU'>
06:05:04: </slot>
06:05:04:</config>
Yes, it is a laptop
That driver is fairly old, I think current drivers show over 3000.
https://www.techpowerup.com/gpu-specs/r ... m-gl.c3061
While you ALWAYS want a driver from AMD, that chip was sold by Intel, so drivers may be difficult to come by.
I did not find any here
https://www.amd.com/en/support
You might want to take a look at this topic - viewtopic.php?f=83&t=33047#p330091. Another person posted on what drivers they used to get their RX Vega M folding. The intel package with the AMD GPU and their Kaby Laky processor apparently is a bit picky about which drivers and OpenCL support are installed.
I tried that driver and it still crashes.
Here is the log from when it got the BSOD. If I am reading the log right, it looks like the crash may have come from the CPU folding unit and not the GPU folding unit:
*********************** Log Started 2020-05-15T03:16:04Z ***********************
03:16:04:Trying to access database...
03:16:04:Successfully acquired database lock
03:16:04:Downloading GPUs.txt from assign1.foldingathome.org:80
03:16:04:Connecting to assign1.foldingathome.org:80
03:16:04:Read GPUs.txt
03:16:04:Enabled folding slot 00: PAUSED cpu:3 (not configured)
03:16:06:Enabled folding slot 01: PAUSED gpu:0:[Radeon RX Vega M XL] (not configured)
03:16:06:****************************** FAHClient ******************************
03:16:06: Version: 7.6.13
03:16:06: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:16:06: Copyright: 2020 foldingathome.org
03:16:06: Homepage: https://foldingathome.org/
03:16:06: Date: Apr 27 2020
03:16:06: Time: 21:21:01
03:16:06: Revision: 5a652817f46116b6e135503af97f18e094414e3b
03:16:06: Branch: master
03:16:06: Compiler: Visual C++ 2008
03:16:06: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:16:06: Platform: win32 10
03:16:06: Bits: 32
03:16:06: Mode: Release
03:16:06: Args: --open-web-control
03:16:06:******************************** CBang ********************************
03:16:06: Date: Apr 24 2020
03:16:06: Time: 17:07:55
03:16:06: Revision: ea081a3b3b0f4a37c4d0440b4f1bc184197c7797
03:16:06: Bits: 32
03:16:06:******************************* System ********************************
03:16:06: CPU: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz
03:16:06: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:16:06: CPUs: 8
03:16:06: Memory: 15.85GiB
03:16:06: Free Memory: 10.15GiB
03:16:06: Threads: WINDOWS_THREADS
03:16:06: OS Version: 6.2
03:16:06: Has Battery: true
03:16:06: On Battery: false
03:16:06: UTC Offset: -6
03:16:06: PID: 11016
03:16:06: CWD: C:\KLC\FAHClient
03:16:06: Win32 Service: false
03:16:06: OS: Windows 10 Enterprise
03:16:06: OS Arch: AMD64
03:16:06: GPUs: 1
03:16:06: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 [Radeon RX Vega M XL]
03:16:06: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
03:16:06: specified module could not be found.
03:16:06:
03:16:06:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2766.5
03:16:06:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2766.5
03:16:06:OpenCL Device 2: Platform:2 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
03:16:06:******************************* libFAH ********************************
03:16:06: Date: Apr 15 2020
03:16:06: Time: 14:53:14
03:16:06: Revision: 216968bc7025029c841ed6e36e81a03a316890d3
03:16:06: Bits: 32
03:16:06:***********************************************************************
03:16:06:<config>
03:16:06: <!-- Folding Slots -->
03:16:06: <slot id='0' type='CPU'/>
03:16:06: <slot id='1' type='GPU'/>
03:16:06:</config>
03:16:12:17:127.0.0.1:New Web session
03:17:05:Saving configuration to config.xml
03:17:05:<config>
03:17:05: <!-- Folding Slots -->
03:17:05: <slot id='0' type='CPU'/>
03:17:05: <slot id='1' type='GPU'/>
03:17:05:</config>
03:17:05:Set client configured
03:17:05:WU00:FS00:Connecting to assign1.foldingathome.org:80
03:17:05:WU00:FS00:Assigned to work server 206.223.170.146
03:17:05:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 206.223.170.146
03:17:05:WU00:FS00:Connecting to 206.223.170.146:8080
03:17:05:WU00:FS00:Downloading 1.37MiB
03:17:06:WU00:FS00:Download complete
03:17:06:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14534 run:586 clone:1 gen:50 core:0xa7 unit:0x0000003ecedfaa925ea34b231c7ab426
03:17:06:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
03:17:06:WU00:FS00:Connecting to cores.foldingathome.org:80
03:17:06:WU00:FS00:FahCore a7: Downloading 6.71MiB
03:17:07:WU00:FS00:FahCore a7: Download complete
03:17:07:WU00:FS00:Valid core signature
03:17:07:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
03:17:07:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
03:17:07:WU00:FS00:Starting
03:17:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\KLC\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11016 -checkpoint 15 -np 3
03:17:07:WU00:FS00:Started FahCore on PID 17628
03:17:07:WU00:FS00:Core PID:660
03:17:07:WU00:FS00:FahCore 0xa7 started
03:17:08:WU00:FS00:0xa7:*********************** Log Started 2020-05-15T03:17:07Z ***********************
03:17:08:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:17:08:WU00:FS00:0xa7: Type: 0xa7
03:17:08:WU00:FS00:0xa7: Core: Gromacs
03:17:08:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 17628 -checkpoint 15 -np
03:17:08:WU00:FS00:0xa7: 3
03:17:08:WU00:FS00:0xa7:************************************ CBang *************************************
03:17:08:WU00:FS00:0xa7: Date: Oct 26 2019
03:17:08:WU00:FS00:0xa7: Time: 01:38:25
03:17:08:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:17:08:WU00:FS00:0xa7: Branch: master
03:17:08:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:17:08:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:17:08:WU00:FS00:0xa7: Platform: win32 10
03:17:08:WU00:FS00:0xa7: Bits: 64
03:17:08:WU00:FS00:0xa7: Mode: Release
03:17:08:WU00:FS00:0xa7:************************************ System ************************************
03:17:08:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz
03:17:08:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:17:08:WU00:FS00:0xa7: CPUs: 8
03:17:08:WU00:FS00:0xa7: Memory: 15.85GiB
03:17:08:WU00:FS00:0xa7:Free Memory: 9.51GiB
03:17:08:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:17:08:WU00:FS00:0xa7: OS Version: 6.2
03:17:08:WU00:FS00:0xa7:Has Battery: true
03:17:08:WU00:FS00:0xa7: On Battery: false
03:17:08:WU00:FS00:0xa7: UTC Offset: -6
03:17:08:WU00:FS00:0xa7: PID: 660
03:17:08:WU00:FS00:0xa7: CWD: C:\KLC\FAHClient\work
03:17:08:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:17:08:WU00:FS00:0xa7: Version: 0.0.18
03:17:08:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:17:08:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:17:08:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:17:08:WU00:FS00:0xa7: Time: 01:52:30
03:17:08:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:17:08:WU00:FS00:0xa7:************************************ Build *************************************
03:17:08:WU00:FS00:0xa7: SIMD: avx_256
03:17:08:WU00:FS00:0xa7:********************************************************************************
03:17:08:WU00:FS00:0xa7:Project: 14534 (Run 586, Clone 1, Gen 50)
03:17:08:WU00:FS00:0xa7:Unit: 0x0000003ecedfaa925ea34b231c7ab426
03:17:08:WU00:FS00:0xa7:Reading tar file core.xml
03:17:08:WU00:FS00:0xa7:Reading tar file frame50.tpr
03:17:08:WU00:FS00:0xa7:Digital signatures verified
03:17:08:WU00:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpt 15 -nt 3
03:17:08:WU00:FS00:0xa7:Steps: first=50000000 total=1000000
03:17:09:WU00:FS00:0xa7:Completed 1 out of 1000000 steps (0%)
03:20:08:Saving configuration to config.xml
03:20:08:<config>
03:20:08: <!-- User Information -->
03:20:08: <passkey v='*****'/>
03:20:08: <team v='243108'/>
03:20:08: <user v='KeenLogic'/>
03:20:08:
03:20:08: <!-- Folding Slots -->
03:20:08: <slot id='0' type='CPU'/>
03:20:08: <slot id='1' type='GPU'/>
03:20:08:</config>
03:20:17:WU00:FS00:0xa7:Completed 10000 out of 1000000 steps (1%)
03:20:20:FS00:Shutting core down
03:20:20:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 660
03:20:20:WU01:FS01:Connecting to assign1.foldingathome.org:80
03:20:20:WU00:FS00:0xa7:Exiting, please wait. . .
03:20:20:WU01:FS01:Assigned to work server 140.163.4.241
03:20:20:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:[Radeon RX Vega M XL] from 140.163.4.241
03:20:20:WU01:FS01:Connecting to 140.163.4.241:8080
03:20:20:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
03:20:20:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:20:21:WU00:FS00:Starting
03:20:21:WARNING:WU00:FS00:Changed SMP threads from 3 to 7 this can cause some work units to fail
03:20:21:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
03:20:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\KLC\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11016 -checkpoint 15 -np 3
03:20:21:WU00:FS00:Started FahCore on PID 3576
03:20:21:WU00:FS00:Core PID:14292
03:20:21:WU00:FS00:FahCore 0xa7 started
03:20:21:WU00:FS00:0xa7:*********************** Log Started 2020-05-15T03:20:21Z ***********************
03:20:21:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:20:21:WU00:FS00:0xa7: Type: 0xa7
03:20:21:WU00:FS00:0xa7: Core: Gromacs
03:20:21:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 3576 -checkpoint 15 -np 3
03:20:21:WU00:FS00:0xa7:************************************ CBang *************************************
03:20:21:WU00:FS00:0xa7: Date: Oct 26 2019
03:20:21:WU00:FS00:0xa7: Time: 01:38:25
03:20:21:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:20:21:WU00:FS00:0xa7: Branch: master
03:20:21:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:20:21:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:20:21:WU00:FS00:0xa7: Platform: win32 10
03:20:21:WU00:FS00:0xa7: Bits: 64
03:20:21:WU00:FS00:0xa7: Mode: Release
03:20:21:WU00:FS00:0xa7:************************************ System ************************************
03:20:21:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz
03:20:21:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:20:21:WU00:FS00:0xa7: CPUs: 8
03:20:21:WU00:FS00:0xa7: Memory: 15.85GiB
03:20:21:WU00:FS00:0xa7:Free Memory: 9.83GiB
03:20:21:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:20:21:WU00:FS00:0xa7: OS Version: 6.2
03:20:21:WU00:FS00:0xa7:Has Battery: true
03:20:21:WU00:FS00:0xa7: On Battery: false
03:20:21:WU00:FS00:0xa7: UTC Offset: -6
03:20:21:WU00:FS00:0xa7: PID: 14292
03:20:21:WU00:FS00:0xa7: CWD: C:\KLC\FAHClient\work
03:20:21:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:20:21:WU00:FS00:0xa7: Version: 0.0.18
03:20:21:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:20:21:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:20:21:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:20:21:WU00:FS00:0xa7: Time: 01:52:30
03:20:21:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:20:21:WU00:FS00:0xa7:************************************ Build *************************************
03:20:21:WU00:FS00:0xa7: SIMD: avx_256
03:20:21:WU00:FS00:0xa7:********************************************************************************
03:20:21:WU00:FS00:0xa7:Project: 14534 (Run 586, Clone 1, Gen 50)
03:20:21:WU00:FS00:0xa7:Unit: 0x0000003ecedfaa925ea34b231c7ab426
03:20:21:WU00:FS00:0xa7:Digital signatures verified
03:20:21:WU00:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpi state.cpt -cpt 15 -nt 3
03:20:21:WU00:FS00:0xa7:Steps: first=50000000 total=1000000
03:20:22:WU00:FS00:0xa7:Completed 10152 out of 1000000 steps (1%)
03:20:38:WU01:FS01:Downloading 7.85MiB
03:20:44:WU01:FS01:Download 89.17%
03:20:44:WU01:FS01:Download complete
03:20:44:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11744 run:0 clone:3536 gen:104 core:0x22 unit:0x000000988ca304f15e69ee01d3b7497d
03:20:44:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
03:20:44:WU01:FS01:Connecting to cores.foldingathome.org:80
03:20:44:WU01:FS01:FahCore 22: Downloading 4.04MiB
03:20:45:WU01:FS01:FahCore 22: Download complete
03:20:45:WU01:FS01:Valid core signature
03:20:45:WU01:FS01:Unpacked 13.50MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
03:20:45:WU01:FS01:Starting
03:20:45:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\KLC\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 706 -lifeline 11016 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:20:45:WU01:FS01:Started FahCore on PID 17540
03:20:45:WU01:FS01:Core PID:5612
03:20:45:WU01:FS01:FahCore 0x22 started
03:20:46:WU01:FS01:0x22:*********************** Log Started 2020-05-15T03:20:45Z ***********************
03:20:46:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:20:46:WU01:FS01:0x22: Type: 0x22
03:20:46:WU01:FS01:0x22: Core: Core22
03:20:46:WU01:FS01:0x22: Website: https://foldingathome.org/
03:20:46:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
03:20:46:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:20:46:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
03:20:46:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 706 -lifeline 17540 -checkpoint 15
03:20:46:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:20:46:WU01:FS01:0x22: Config: <none>
03:20:46:WU01:FS01:0x22:************************************ Build *************************************
03:20:46:WU01:FS01:0x22: Version: 0.0.5
03:20:46:WU01:FS01:0x22: Date: Apr 22 2020
03:20:46:WU01:FS01:0x22: Time: 04:42:59
03:20:46:WU01:FS01:0x22: Repository: Git
03:20:46:WU01:FS01:0x22: Revision: 2d69202c898bd9bb3e093f51cd32bf411c2a0388
03:20:46:WU01:FS01:0x22: Branch: HEAD
03:20:46:WU01:FS01:0x22: Compiler: Visual C++ 2008
03:20:46:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:20:46:WU01:FS01:0x22: Platform: win32 10
03:20:46:WU01:FS01:0x22: Bits: 64
03:20:46:WU01:FS01:0x22: Mode: Release
03:20:46:WU01:FS01:0x22:************************************ System ************************************
03:20:46:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz
03:20:46:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:20:46:WU01:FS01:0x22: CPUs: 8
03:20:46:WU01:FS01:0x22: Memory: 15.85GiB
03:20:46:WU01:FS01:0x22:Free Memory: 10.07GiB
03:20:46:WU01:FS01:0x22: Threads: WINDOWS_THREADS
03:20:46:WU01:FS01:0x22: OS Version: 6.2
03:20:46:WU01:FS01:0x22:Has Battery: true
03:20:46:WU01:FS01:0x22: On Battery: false
03:20:46:WU01:FS01:0x22: UTC Offset: -6
03:20:46:WU01:FS01:0x22: PID: 5612
03:20:46:WU01:FS01:0x22: CWD: C:\KLC\FAHClient\work
03:20:46:WU01:FS01:0x22: OS: Windows 10 Pro
03:20:46:WU01:FS01:0x22: OS Arch: AMD64
03:20:46:WU01:FS01:0x22:********************************************************************************
03:20:46:WU01:FS01:0x22:Project: 11744 (Run 0, Clone 3536, Gen 104)
03:20:46:WU01:FS01:0x22:Unit: 0x000000988ca304f15e69ee01d3b7497d
03:20:46:WU01:FS01:0x22:Reading tar file core.xml
03:20:46:WU01:FS01:0x22:Reading tar file integrator.xml
03:20:46:WU01:FS01:0x22:Reading tar file state.xml
03:20:46:WU01:FS01:0x22:Reading tar file system.xml
03:20:47:WU01:FS01:0x22:Digital signatures verified
03:20:47:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:20:47:WU01:FS01:0x22:Version 0.0.5
03:21:03:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
03:21:03:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:21:09:Saving configuration to config.xml
03:21:09:<config>
03:21:09: <!-- Slot Control -->
03:21:09: <power v='FULL'/>
03:21:09:
03:21:09: <!-- User Information -->
03:21:09: <passkey v='*****'/>
03:21:09: <team v='243108'/>
03:21:09: <user v='KeenLogic'/>
03:21:09:
03:21:09: <!-- Folding Slots -->
03:21:09: <slot id='0' type='CPU'/>
03:21:09: <slot id='1' type='GPU'/>
03:21:09:</config>
03:24:08:WU00:FS00:0xa7:Completed 20000 out of 1000000 steps (2%)
03:24:29:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
03:25:13:Saving configuration to config.xml
03:25:13:<config>
03:25:13: <!-- Folding Slot Configuration -->
03:25:13: <cause v='COVID_19'/>
03:25:13:
03:25:13: <!-- Network -->
03:25:13: <proxy v=':8080'/>
03:25:13:
03:25:13: <!-- Slot Control -->
03:25:13: <power v='FULL'/>
03:25:13:
03:25:13: <!-- User Information -->
03:25:13: <passkey v='*****'/>
03:25:13: <team v='243108'/>
03:25:13: <user v='KeenLogic'/>
03:25:13:
03:25:13: <!-- Folding Slots -->
03:25:13: <slot id='0' type='CPU'/>
03:25:13: <slot id='1' type='GPU'/>
03:25:13:</config>
03:27:50:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
03:28:28:WU00:FS00:0xa7:Completed 30000 out of 1000000 steps (3%)
03:31:09:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
03:31:46:WU00:FS00:0xa7:ERROR:
03:31:46:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
03:31:46:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
03:31:46:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 4390
03:31:46:WU00:FS00:0xa7:ERROR:Fatal error:
03:31:46:WU00:FS00:0xa7:ERROR:An atom moved too far between two domain decomposition steps
03:31:46:WU00:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated
03:31:46:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
03:31:46:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
03:31:51:WU00:FS00:0xa7:ERROR:
03:31:51:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
03:31:51:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
03:31:51:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 4390
03:31:51:WU00:FS00:0xa7:ERROR:Fatal error:
03:31:51:WU00:FS00:0xa7:ERROR:An atom moved too far between two domain decomposition steps
03:31:51:WU00:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated
03:31:51:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
03:31:51:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
03:31:56:WU00:FS00:0xa7:ERROR:
03:31:56:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
03:31:56:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
03:31:56:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 4390
03:31:56:WU00:FS00:0xa7:ERROR:Fatal error:
03:31:56:WU00:FS00:0xa7:ERROR:An atom moved too far between two domain decomposition steps
03:31:56:WU00:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated
03:31:56:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
03:31:56:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
03:32:01:WU00:FS00:0xa7:ERROR:
03:32:01:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
03:32:01:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
03:32:01:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 4390
03:32:01:WU00:FS00:0xa7:ERROR:Fatal error:
03:32:01:WU00:FS00:0xa7:ERROR:An atom moved too far between two domain decomposition steps
03:32:01:WU00:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated
03:32:01:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
03:32:01:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
03:32:06:WU00:FS00:0xa7:ERROR:
03:32:06:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
03:32:06:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
03:32:06:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 4390
03:32:06:WU00:FS00:0xa7:ERROR:Fatal error:
03:32:06:WU00:FS00:0xa7:ERROR:An atom moved too far between two domain decomposition steps
03:32:06:WU00:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated
03:32:06:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
03:32:06:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
03:32:11:WU00:FS00:0xa7:WARNING:Unexpected exit() call
03:32:14:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
03:32:14:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741784 = 0xc0000028)
03:32:14:WU00:FS00:Starting
03:32:14:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
03:32:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\KLC\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11016 -checkpoint 15 -np 3
03:32:15:WU00:FS00:Started FahCore on PID 18136
03:32:15:WU00:FS00:Core PID:17556
03:32:15:WU00:FS00:FahCore 0xa7 started
03:32:15:WU00:FS00:0xa7:*********************** Log Started 2020-05-15T03:32:15Z ***********************
03:32:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:32:15:WU00:FS00:0xa7: Type: 0xa7
03:32:15:WU00:FS00:0xa7: Core: Gromacs
03:32:15:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 18136 -checkpoint 15 -np
03:32:15:WU00:FS00:0xa7: 3
03:32:15:WU00:FS00:0xa7:************************************ CBang *************************************
03:32:15:WU00:FS00:0xa7: Date: Oct 26 2019
03:32:15:WU00:FS00:0xa7: Time: 01:38:25
03:32:15:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:32:15:WU00:FS00:0xa7: Branch: master
03:32:15:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:32:15:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:32:15:WU00:FS00:0xa7: Platform: win32 10
03:32:15:WU00:FS00:0xa7: Bits: 64
03:32:15:WU00:FS00:0xa7: Mode: Release
03:32:15:WU00:FS00:0xa7:************************************ System ************************************
03:32:15:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz
03:32:15:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:32:15:WU00:FS00:0xa7: CPUs: 8
03:32:15:WU00:FS00:0xa7: Memory: 15.85GiB
03:32:15:WU00:FS00:0xa7:Free Memory: 9.99GiB
03:32:15:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:32:15:WU00:FS00:0xa7: OS Version: 6.2
03:32:15:WU00:FS00:0xa7:Has Battery: true
03:32:15:WU00:FS00:0xa7: On Battery: false
03:32:15:WU00:FS00:0xa7: UTC Offset: -6
03:32:15:WU00:FS00:0xa7: PID: 17556
03:32:15:WU00:FS00:0xa7: CWD: C:\KLC\FAHClient\work
03:32:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:32:15:WU00:FS00:0xa7: Version: 0.0.18
03:32:15:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:32:15:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:32:15:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:32:15:WU00:FS00:0xa7: Time: 01:52:30
03:32:15:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:32:15:WU00:FS00:0xa7:************************************ Build *************************************
03:32:15:WU00:FS00:0xa7: SIMD: avx_256
03:32:15:WU00:FS00:0xa7:********************************************************************************
03:32:15:WU00:FS00:0xa7:Project: 14534 (Run 586, Clone 1, Gen 50)
03:32:15:WU00:FS00:0xa7:Unit: 0x0000003ecedfaa925ea34b231c7ab426
03:32:15:WU00:FS00:0xa7:Digital signatures verified
03:32:15:WU00:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpi state.cpt -cpt 15 -nt 3
03:32:15:WU00:FS00:0xa7:ERROR:Guru Meditation #223e96ca9f4efd90.8e68897f1c7d193c (32113.33293) '00/01/md.log'
03:32:15:WU00:FS00:0xa7:WARNING:Unexpected exit() call
03:32:15:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
03:32:15:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
03:32:15:WU00:FS00:0xa7:Saving result file frame50.trr
03:32:15:WU00:FS00:0xa7:Saving result file frame50.xtc
03:32:15:WU00:FS00:0xa7:Saving result file md.log
03:32:18:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
03:32:18:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
03:33:15:WU00:FS00:Starting
03:33:15:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
03:33:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\KLC\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11016 -checkpoint 5 -np 3
03:33:15:WU00:FS00:Started FahCore on PID 4608
03:33:15:WU00:FS00:Core PID:18084
03:33:15:WU00:FS00:FahCore 0xa7 started
03:33:15:WU00:FS00:0xa7:*********************** Log Started 2020-05-15T03:33:15Z ***********************
03:33:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:33:15:WU00:FS00:0xa7: Type: 0xa7
03:33:15:WU00:FS00:0xa7: Core: Gromacs
03:33:15:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 4608 -checkpoint 5 -np 3
03:33:15:WU00:FS00:0xa7:************************************ CBang *************************************
03:33:15:WU00:FS00:0xa7: Date: Oct 26 2019
03:33:15:WU00:FS00:0xa7: Time: 01:38:25
03:33:15:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:33:15:WU00:FS00:0xa7: Branch: master
03:33:15:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:33:15:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:33:15:WU00:FS00:0xa7: Platform: win32 10
03:33:15:WU00:FS00:0xa7: Bits: 64
03:33:15:WU00:FS00:0xa7: Mode: Release
03:33:15:WU00:FS00:0xa7:************************************ System ************************************
03:33:15:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz
03:33:15:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:33:15:WU00:FS00:0xa7: CPUs: 8
03:33:15:WU00:FS00:0xa7: Memory: 15.85GiB
03:33:15:WU00:FS00:0xa7:Free Memory: 10.29GiB
03:33:15:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:33:15:WU00:FS00:0xa7: OS Version: 6.2
03:33:15:WU00:FS00:0xa7:Has Battery: true
03:33:15:WU00:FS00:0xa7: On Battery: false
03:33:15:WU00:FS00:0xa7: UTC Offset: -6
03:33:15:WU00:FS00:0xa7: PID: 18084
03:33:15:WU00:FS00:0xa7: CWD: C:\KLC\FAHClient\work
03:33:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:33:15:WU00:FS00:0xa7: Version: 0.0.18
03:33:15:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:33:15:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:33:15:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:33:15:WU00:FS00:0xa7: Time: 01:52:30
03:33:15:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:33:15:WU00:FS00:0xa7:************************************ Build *************************************
03:33:15:WU00:FS00:0xa7: SIMD: avx_256
03:33:15:WU00:FS00:0xa7:********************************************************************************
03:33:15:WU00:FS00:0xa7:Project: 14534 (Run 586, Clone 1, Gen 50)
03:33:15:WU00:FS00:0xa7:Unit: 0x0000003ecedfaa925ea34b231c7ab426
03:33:15:WU00:FS00:0xa7:Digital signatures verified
03:33:15:WU00:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpi state.cpt -cpt 5 -nt 3
03:33:15:WU00:FS00:0xa7:ERROR:Guru Meditation #223e96ca9f4efd90.8e68897f1c7d193c (32113.33293) '00/01/md.log'
03:33:15:WU00:FS00:0xa7:WARNING:Unexpected exit() call
03:33:15:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
03:33:15:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
03:33:15:WU00:FS00:0xa7:Saving result file frame50.trr
03:33:15:WU00:FS00:0xa7:Saving result file frame50.xtc
03:33:15:WU00:FS00:0xa7:Saving result file md.log
03:33:16:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
03:33:16:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
03:33:21:Saving configuration to config.xml
03:33:21:<config>
03:33:21: <!-- Folding Core -->
03:33:21: <checkpoint v='5'/>
03:33:21:
03:33:21: <!-- Folding Slot Configuration -->
03:33:21: <cause v='COVID_19'/>
03:33:21:
03:33:21: <!-- Network -->
03:33:21: <proxy v=':8080'/>
03:33:21:
03:33:21: <!-- Slot Control -->
03:33:21: <power v='FULL'/>
03:33:21:
03:33:21: <!-- User Information -->
03:33:21: <passkey v='*****'/>
03:33:21: <team v='243108'/>
03:33:21: <user v='KeenLogic'/>
03:33:21:
03:33:21: <!-- Folding Slots -->
03:33:21: <slot id='0' type='CPU'/>
03:33:21: <slot id='1' type='GPU'/>
03:33:21:</config>
03:34:15:WU00:FS00:Starting
03:34:15:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
03:34:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\KLC\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 706 -lifeline 11016 -checkpoint 5 -np 3
03:34:15:WU00:FS00:Started FahCore on PID 16380
03:34:15:WU00:FS00:Core PID:2644
03:34:15:WU00:FS00:FahCore 0xa7 started
03:34:15:WU00:FS00:0xa7:*********************** Log Started 2020-05-15T03:34:15Z ***********************
03:34:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:34:15:WU00:FS00:0xa7: Type: 0xa7
03:34:15:WU00:FS00:0xa7: Core: Gromacs
03:34:15:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 706 -lifeline 16380 -checkpoint 5 -np 3
03:34:15:WU00:FS00:0xa7:************************************ CBang *************************************
03:34:15:WU00:FS00:0xa7: Date: Oct 26 2019
03:34:15:WU00:FS00:0xa7: Time: 01:38:25
03:34:15:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:34:15:WU00:FS00:0xa7: Branch: master
03:34:15:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:34:15:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:34:15:WU00:FS00:0xa7: Platform: win32 10
03:34:15:WU00:FS00:0xa7: Bits: 64
03:34:15:WU00:FS00:0xa7: Mode: Release
03:34:15:WU00:FS00:0xa7:************************************ System ************************************
03:34:15:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-8705G CPU @ 3.10GHz
03:34:15:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:34:15:WU00:FS00:0xa7: CPUs: 8
03:34:15:WU00:FS00:0xa7: Memory: 15.85GiB
03:34:15:WU00:FS00:0xa7:Free Memory: 10.30GiB
03:34:15:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:34:15:WU00:FS00:0xa7: OS Version: 6.2
03:34:15:WU00:FS00:0xa7:Has Battery: true
03:34:15:WU00:FS00:0xa7: On Battery: false
03:34:15:WU00:FS00:0xa7: UTC Offset: -6
03:34:15:WU00:FS00:0xa7: PID: 2644
03:34:15:WU00:FS00:0xa7: CWD: C:\KLC\FAHClient\work
03:34:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:34:16:WU00:FS00:0xa7: Version: 0.0.18
03:34:16:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:34:16:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:34:16:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:34:16:WU00:FS00:0xa7: Date: Oct 26 2019
03:34:16:WU00:FS00:0xa7: Time: 01:52:30
03:34:16:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:34:16:WU00:FS00:0xa7: Branch: master
03:34:16:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:34:16:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:34:16:WU00:FS00:0xa7: Platform: win32 10
03:34:16:WU00:FS00:0xa7: Bits: 64
03:34:16:WU00:FS00:0xa7: Mode: Release
03:34:16:WU00:FS00:0xa7:************************************ Build *************************************
03:34:16:WU00:FS00:0xa7: SIMD: avx_256
03:34:16:WU00:FS00:0xa7:********************************************************************************
03:34:16:WU00:FS00:0xa7:Project: 14534 (Run 586, Clone 1, Gen 50)
03:34:16:WU00:FS00:0xa7:Unit: 0x0000003ecedfaa925ea34b231c7ab426
03:34:16:WU00:FS00:0xa7:Digital signatures verified
03:34:16:WU00:FS00:0xa7:Calling: mdrun -s frame50.tpr -o frame50.trr -x frame50.xtc -cpi state.cpt -cpt 5 -nt 3
03:34:16:WU00:FS00:0xa7:ERROR:Guru Meditation #223e96ca9f4efd90.8e68897f1c7d193c (32113.33293) '00/01/md.log'
03:34:16:WU00:FS00:0xa7:WARNING:Unexpected exit() call
03:34:16:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
03:34:16:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
03:34:16:WU00:FS00:0xa7:Saving result file frame50.trr
03:34:16:WU00:FS00:0xa7:Saving result file frame50.xtc
03:34:16:WU00:FS00:0xa7:Saving result file md.log
03:34:17:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
03:34:17:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
The BSOD might be heat-related. As a general rule, the performance of a laptop is limited by the hardware's ability to dissipate the heat.
I suggest you try folding on either the CPU or the GPU by itself. and see if that eliminates the crashes. You're not doing any good until you can eliminate the BSODs.
@bruce, I had a similar thought last night so I paused the CPU unit and let the GPU unit run. It has worked flawlessly. It finished 1 WU and is almost completed on another. How do tell the software to only do work on the GPU? Should I just delete the CPU unit?
Welcome to the F@H Forum KeenLogic,
To gracefully remove the CPU Slot, fist check if any WU was assigned to it. If yes, then in Advanced Control (FAHControl), you can right click the slot and select Finish. Once the WU is submitted, you can remove the CPU Slot by this:
Advanced Control (AKA FAHControl) -> Configure -> Slots tab -> CPU -> Remove -> Save
